| 1 | greg | 2.1 | #ifndef lint |
| 2 | schorsch | 2.7 | static const char       RCSid[] = "$Id: fprism.c,v 2.6 2003/08/04 22:37:53 greg Exp $"; |
| 3 | greg | 2.1 | #endif |
| 4 |  |  | /* Ce programme calcule les directions et les energies des rayons lumineux |
| 5 |  |  | resultant du passage d'un rayon au travers d'un vitrage prismatique |
| 6 |  |  |  |
| 7 |  |  | 1991, LESO - EPFL, R. Compagnon - F. Di Pasquale                          */ |
| 8 |  |  |  |
| 9 |  |  | #include "standard.h" |
| 10 |  |  |  |
| 11 | schorsch | 2.7 | #include "calcomp.h" |
| 12 |  |  | #include "func.h" |
| 13 |  |  |  |
| 14 | greg | 2.1 | #ifdef NOSTRUCTASSIGN |
| 15 |  |  | static double err = "No structure assignment!"; /* generate compiler error */ |
| 16 |  |  | #endif |
| 17 |  |  |  |
| 18 |  |  |  |
| 19 |  |  | static double |
| 20 | schorsch | 2.7 | Sqrt( |
| 21 |  |  | double x |
| 22 |  |  | ) |
| 23 | greg | 2.1 | { |
| 24 |  |  | if (x < 0.) |
| 25 |  |  | return(0.); |
| 26 |  |  | return(sqrt(x)); |
| 27 |  |  | } |
| 28 |  |  |  |
| 29 |  |  | /* definitions de macros utiles */ |
| 30 |  |  |  |
| 31 |  |  | #define ALPHA 0 |
| 32 |  |  | #define BETA 1 |
| 33 |  |  | #define GAMMA 2 |
| 34 |  |  | #define DELTA 3 |
| 35 |  |  | #define AUCUNE 4 |
| 36 |  |  | #define X(r) r.v[0] |
| 37 |  |  | #define Y(r) r.v[1] |
| 38 |  |  | #define Z(r) r.v[2] |
| 39 |  |  | #define XX(v) v[0] |
| 40 |  |  | #define YY(v) v[1] |
| 41 |  |  | #define ZZ(v) v[2] |
| 42 |  |  | #define alpha_beta(v_alpha,v_beta) tfm(matbt,v_alpha,v_beta) |
| 43 |  |  | #define beta_alpha(v_beta,v_alpha) tfm(matb,v_beta,v_alpha) |
| 44 |  |  | #define alpha_gamma(v_alpha,v_gamma) tfm(matct,v_alpha,v_gamma) |
| 45 |  |  | #define gamma_alpha(v_gamma,v_alpha) tfm(matc,v_gamma,v_alpha) |
| 46 |  |  | #define prob_alpha_gamma(r) (1.-prob_alpha_beta(r)) |
| 47 |  |  | #define prob_beta_gamma(r) (1.-prob_beta_alpha(r)) |
| 48 |  |  | #define prob_gamma_beta(r) (1.-prob_gamma_alpha(r)) |
| 49 |  |  | #define prob_delta_gamma(r) (1.-prob_delta_beta(r)) |
| 50 |  |  | #define prob_beta_delta(r) (prob_beta_alpha(r)) |
| 51 |  |  | #define prob_gamma_delta(r) (prob_gamma_alpha(r)) |
| 52 |  |  | #define prob_delta_beta(r) (prob_alpha_beta(r)) |
| 53 |  |  |  |
| 54 |  |  |  |
| 55 |  |  | /* Definitions des types de donnees */ |
| 56 |  |  |  |
| 57 |  |  | typedef struct { FVECT v;               /* direction */ |
| 58 |  |  | double ppar1,pper1, |
| 59 |  |  | ppar2,pper2;    /* polarisations */ |
| 60 |  |  | double e;              /* energie */ |
| 61 |  |  | double n;              /* milieu dans lequel on se propage */ |
| 62 |  |  | int orig,dest;         /* origine et destination          */ |
| 63 |  |  | } TRAYON; |
| 64 |  |  |  |
| 65 |  |  | typedef struct { double a,b,c,d;        /* longueurs caracteristiques      */ |
| 66 |  |  | double np;             /* indice de refraction            */ |
| 67 |  |  | } TPRISM; |
| 68 |  |  |  |
| 69 |  |  |  |
| 70 |  |  | /* Definitions des variables globales */ |
| 71 |  |  |  |
| 72 |  |  | static TPRISM prism;                        /* le prisme ! */ |
| 73 |  |  | static MAT4 matb = MAT4IDENT;           /* matrices de changement de bases */ |
| 74 |  |  | static MAT4 matbt = MAT4IDENT; |
| 75 |  |  | static MAT4 matc = MAT4IDENT; |
| 76 |  |  | static MAT4 matct = MAT4IDENT; |
| 77 |  |  | static double seuil;                    /* seuil pour l'arret du trace     */ |
| 78 |  |  | static double sinus,cosinus;            /* sin et cos                      */ |
| 79 |  |  | static double rapport;                  /* rapport entre les indices des |
| 80 |  |  | milieux refracteur et incident  */ |
| 81 |  |  | static int tot_ref;                     /* flag pour les surfaces |
| 82 |  |  | reflechissantes                 */ |
| 83 |  |  | static double fact_ref[4]={1.0,1.0,1.0,1.0};    /* facteurs de reflexion     */ |
| 84 |  |  | static double tolerance;                /* degre de tol. pour les amalgames */ |
| 85 |  |  | static double tolsource;                /* degre de tol. pour les sources  */ |
| 86 |  |  | static int bidon; |
| 87 |  |  | #define BADVAL  (-10) |
| 88 |  |  | static long prismclock = -1; |
| 89 |  |  | static int nosource;                    /* indique que l'on ne trace pas |
| 90 |  |  | en direction d'une source */ |
| 91 |  |  | static int sens;                        /* indique le sens de prop. du ray.*/ |
| 92 |  |  | static int nbrayons;                    /* indice des rayons sortants      */ |
| 93 |  |  | static TRAYON *ray;                     /* tableau des rayons sortants     */ |
| 94 |  |  | static TRAYON *raytemp;                 /* variable temporaire             */ |
| 95 |  |  |  |
| 96 | schorsch | 2.7 |  |
| 97 |  |  | static void prepare_matrices(void); |
| 98 |  |  | static void tfm(MAT4 mat, FVECT v_old, FVECT v_new); |
| 99 |  |  | static double prob_alpha_beta(TRAYON r); |
| 100 |  |  | static double prob_beta_alpha(TRAYON r); |
| 101 |  |  | static double prob_gamma_alpha(TRAYON r); |
| 102 |  |  | static void v_par(FVECT v, FVECT v_out); |
| 103 |  |  | static void v_per(FVECT v, FVECT v_out); |
| 104 |  |  | static TRAYON transalphabeta(TRAYON r_initial); |
| 105 |  |  | static TRAYON transbetaalpha(TRAYON r_initial); |
| 106 |  |  | static TRAYON transalphagamma(TRAYON r_initial); |
| 107 |  |  | static TRAYON transgammaalpha(TRAYON r_initial); |
| 108 |  |  | static int compare(TRAYON r1, TRAYON r2, double marge); |
| 109 |  |  | static void sortie(TRAYON r); |
| 110 |  |  | static void trigo(TRAYON r); |
| 111 |  |  | static TRAYON reflexion(TRAYON r_incident); |
| 112 |  |  | static TRAYON transmission(TRAYON r_incident); |
| 113 |  |  | static void trace_rayon(TRAYON r_incident); |
| 114 |  |  | static void inverser(TRAYON *r1, TRAYON *r2); |
| 115 |  |  | static void setprism(void); |
| 116 |  |  | static double l_get_val(char *nm); |
| 117 | greg | 2.1 |  |
| 118 |  |  |  |
| 119 |  |  | /* Definition des routines */ |
| 120 |  |  |  |
| 121 | greg | 2.3 | #define term(a,b) a/Sqrt(a*a+b*b) |
| 122 | schorsch | 2.7 | static void |
| 123 |  |  | prepare_matrices(void) |
| 124 | greg | 2.1 | { |
| 125 | schorsch | 2.7 | /* preparation des matrices de changement de bases */ |
| 126 | greg | 2.1 |  |
| 127 | schorsch | 2.7 | matb[0][0] = matbt[0][0] = matb[1][1] = matbt[1][1] = term(prism.a,prism.d); |
| 128 |  |  | matb[1][0] = matbt[0][1] = term(-prism.d,prism.a); |
| 129 |  |  | matb[0][1] = matbt[1][0] = term(prism.d,prism.a); |
| 130 |  |  | matc[0][0] = matct[0][0] = matc[1][1] = matct[1][1] = term(prism.b,prism.d); |
| 131 |  |  | matc[1][0] = matct[0][1] = term(prism.d,prism.b); |
| 132 |  |  | matc[0][1] = matct[1][0] = term(-prism.d,prism.b); |
| 133 |  |  | return; |
| 134 | greg | 2.1 | } |
| 135 |  |  | #undef term |
| 136 |  |  |  |
| 137 |  |  |  |
| 138 | schorsch | 2.7 | static void |
| 139 |  |  | tfm( |
| 140 |  |  | MAT4 mat, |
| 141 |  |  | FVECT v_old, |
| 142 |  |  | FVECT v_new |
| 143 |  |  | ) |
| 144 |  |  | { |
| 145 |  |  | /* passage d'un repere old au repere new par la matrice mat */ |
| 146 |  |  | FVECT v_temp; |
| 147 |  |  |  |
| 148 |  |  | multv3(v_temp,v_old,mat); |
| 149 |  |  | normalize(v_temp); |
| 150 |  |  | VCOPY(v_new,v_temp); |
| 151 |  |  | return; |
| 152 | greg | 2.1 | } |
| 153 |  |  |  |
| 154 |  |  | #define A prism.a |
| 155 |  |  | #define B prism.b |
| 156 |  |  | #define C prism.c |
| 157 |  |  | #define D prism.d |
| 158 |  |  |  |
| 159 |  |  |  |
| 160 |  |  | static double |
| 161 | schorsch | 2.7 | prob_alpha_beta( |
| 162 |  |  | TRAYON r |
| 163 |  |  | ) |
| 164 | greg | 2.1 | { |
| 165 | schorsch | 2.7 | /* calcul de la probabilite de passage de alpha a beta */ |
| 166 |  |  | double prob,test; |
| 167 | greg | 2.1 |  |
| 168 | schorsch | 2.7 | if ( X(r) != 0. ) |
| 169 | greg | 2.1 | { |
| 170 | schorsch | 2.7 | test = Y(r)/X(r); |
| 171 |  |  | if ( test > B/D ) prob = 1.; |
| 172 |  |  | else if ( test >= -A/D ) prob = (A+test*D)/(A+B); |
| 173 |  |  | else prob = 0.; |
| 174 | greg | 2.1 | } |
| 175 | schorsch | 2.7 | else prob = 0.; |
| 176 |  |  | return prob; |
| 177 | greg | 2.1 | } |
| 178 |  |  |  |
| 179 |  |  |  |
| 180 |  |  | static double |
| 181 | schorsch | 2.7 | prob_beta_alpha( |
| 182 |  |  | TRAYON r |
| 183 |  |  | ) |
| 184 | greg | 2.1 | { |
| 185 | schorsch | 2.7 | /* calcul de la probabilite de passage de beta a aplha */ |
| 186 |  |  | double prob,test; |
| 187 | greg | 2.1 |  |
| 188 | schorsch | 2.7 | if ( X(r) != 0. ) |
| 189 | greg | 2.1 | { |
| 190 | schorsch | 2.7 | test = Y(r)/X(r); |
| 191 |  |  | if ( test > B/D ) prob = (A+B)/(A+test*D); |
| 192 |  |  | else if ( test >= -A/D ) prob = 1.; |
| 193 |  |  | else prob = 0.; |
| 194 | greg | 2.1 | } |
| 195 | schorsch | 2.7 | else prob = 0.; |
| 196 |  |  | return prob; |
| 197 | greg | 2.1 | } |
| 198 |  |  |  |
| 199 |  |  |  |
| 200 | schorsch | 2.7 | static double |
| 201 |  |  | prob_gamma_alpha( |
| 202 |  |  | TRAYON r |
| 203 |  |  | ) |
| 204 | greg | 2.1 | { |
| 205 | schorsch | 2.7 | /* calcul de la probabilite de passage de gamma a alpha */ |
| 206 |  |  | double prob,test; |
| 207 | greg | 2.1 |  |
| 208 | schorsch | 2.7 | if ( X(r) != 0. ) |
| 209 | greg | 2.1 | { |
| 210 | schorsch | 2.7 | test = Y(r)/X(r); |
| 211 |  |  | if ( test > B/D ) prob = 0.; |
| 212 |  |  | else if ( test >= -A/D ) prob = 1.; |
| 213 |  |  | else prob = (A+B)/(B-test*D); |
| 214 | greg | 2.1 | } |
| 215 | schorsch | 2.7 | else prob = 0.; |
| 216 |  |  | return prob; |
| 217 | greg | 2.1 | } |
| 218 |  |  |  |
| 219 |  |  | #undef A |
| 220 |  |  | #undef B |
| 221 |  |  | #undef C |
| 222 |  |  | #undef D |
| 223 |  |  |  |
| 224 |  |  |  |
| 225 | schorsch | 2.7 | static void |
| 226 |  |  | v_par( |
| 227 |  |  | FVECT v, |
| 228 |  |  | FVECT v_out |
| 229 |  |  | ) |
| 230 | greg | 2.1 | /* calcule le vecteur par au plan d'incidence lie a v */ |
| 231 |  |  | { |
| 232 | schorsch | 2.7 | FVECT v_temp; |
| 233 |  |  | double det; |
| 234 | greg | 2.1 |  |
| 235 | schorsch | 2.7 | det = Sqrt( (YY(v)*YY(v)+ZZ(v)*ZZ(v))*(YY(v)*YY(v)+ZZ(v)*ZZ(v))+ |
| 236 |  |  | (XX(v)*XX(v)*YY(v)*YY(v))+(XX(v)*XX(v)*ZZ(v)*ZZ(v)) ); |
| 237 |  |  | XX(v_temp) = (YY(v)*YY(v)+ZZ(v)*ZZ(v))/det; |
| 238 |  |  | YY(v_temp) = -( XX(v)*YY(v) )/det; |
| 239 |  |  | ZZ(v_temp) = -( XX(v)*ZZ(v) )/det; |
| 240 |  |  | VCOPY(v_out,v_temp); |
| 241 |  |  | return; |
| 242 | greg | 2.1 | } |
| 243 |  |  |  |
| 244 |  |  |  |
| 245 | schorsch | 2.7 | static void |
| 246 |  |  | v_per( |
| 247 |  |  | FVECT v, |
| 248 |  |  | FVECT v_out |
| 249 |  |  | ) |
| 250 | greg | 2.1 | /* calcule le vecteur perp au plan d'incidence lie a v */ |
| 251 |  |  | { |
| 252 | schorsch | 2.7 | FVECT v_temp; |
| 253 |  |  | double det; |
| 254 | greg | 2.1 |  |
| 255 | schorsch | 2.7 | det = Sqrt( (ZZ(v)*ZZ(v)+YY(v)*YY(v)) ); |
| 256 |  |  | XX(v_temp) = 0.; |
| 257 |  |  | YY(v_temp) = -ZZ(v)/det; |
| 258 |  |  | ZZ(v_temp) = YY(v)/det; |
| 259 |  |  | VCOPY(v_out,v_temp); |
| 260 |  |  | return; |
| 261 | greg | 2.1 | } |
| 262 |  |  |  |
| 263 |  |  |  |
| 264 |  |  | static TRAYON |
| 265 | schorsch | 2.7 | transalphabeta( |
| 266 |  |  | TRAYON r_initial |
| 267 |  |  | ) |
| 268 | greg | 2.1 | /* transforme le rayon r_initial de la base associee a alpha dans |
| 269 |  |  | la base associee a beta */ |
| 270 |  |  | { |
| 271 | schorsch | 2.7 | TRAYON r_final; |
| 272 |  |  | FVECT vpar_temp1,vpar_temp2,vper_temp1,vper_temp2; |
| 273 | greg | 2.1 |  |
| 274 | schorsch | 2.7 | r_final = r_initial; |
| 275 |  |  | alpha_beta(r_initial.v,r_final.v); |
| 276 |  |  | if ((Y(r_initial) != 0. || Z(r_initial) != 0.)&&(Y(r_final) !=0. || Z(r_final)!= 0.)) |
| 277 |  |  | { |
| 278 |  |  | v_par(r_initial.v,vpar_temp1); |
| 279 |  |  | alpha_beta(vpar_temp1,vpar_temp1); |
| 280 |  |  | v_per(r_initial.v,vper_temp1); |
| 281 |  |  | alpha_beta(vper_temp1,vper_temp1); |
| 282 |  |  | v_par(r_final.v,vpar_temp2); |
| 283 |  |  | v_per(r_final.v,vper_temp2); |
| 284 |  |  | r_final.ppar1 = (r_initial.ppar1*fdot(vpar_temp1,vpar_temp2))+ |
| 285 |  |  | (r_initial.pper1*fdot(vper_temp1,vpar_temp2)); |
| 286 |  |  | r_final.pper1 = (r_initial.ppar1*fdot(vpar_temp1,vper_temp2))+ |
| 287 |  |  | (r_initial.pper1*fdot(vper_temp1,vper_temp2)); |
| 288 |  |  | r_final.ppar2 = (r_initial.ppar2*fdot(vpar_temp1,vpar_temp2))+ |
| 289 |  |  | (r_initial.pper2*fdot(vper_temp1,vpar_temp2)); |
| 290 |  |  | r_final.pper2 = (r_initial.ppar2*fdot(vpar_temp1,vper_temp2))+ |
| 291 |  |  | (r_initial.pper2*fdot(vper_temp1,vper_temp2)); |
| 292 |  |  | } |
| 293 |  |  | return r_final; |
| 294 | greg | 2.1 | } |
| 295 |  |  |  |
| 296 |  |  |  |
| 297 |  |  | static TRAYON |
| 298 | schorsch | 2.7 | transbetaalpha( |
| 299 |  |  | TRAYON r_initial |
| 300 |  |  | ) |
| 301 |  |  | { |
| 302 |  |  | /* transforme le rayon r_initial de la base associee a beta dans |
| 303 |  |  | la base associee a alpha */ |
| 304 |  |  | TRAYON r_final; |
| 305 |  |  | FVECT vpar_temp1,vpar_temp2,vper_temp1,vper_temp2; |
| 306 |  |  |  |
| 307 |  |  | r_final = r_initial; |
| 308 |  |  | beta_alpha(r_initial.v,r_final.v); |
| 309 |  |  | if ((Y(r_initial) != 0. || Z(r_initial) != 0. )&&(Y(r_final) != 0. || Z(r_final)!= 0.)) |
| 310 |  |  | { |
| 311 |  |  | v_par(r_initial.v,vpar_temp1); |
| 312 |  |  | beta_alpha(vpar_temp1,vpar_temp1); |
| 313 |  |  | v_per(r_initial.v,vper_temp1); |
| 314 |  |  | beta_alpha(vper_temp1,vper_temp1); |
| 315 |  |  | v_par(r_final.v,vpar_temp2); |
| 316 |  |  | v_per(r_final.v,vper_temp2); |
| 317 |  |  | r_final.ppar1 = (r_initial.ppar1*fdot(vpar_temp1,vpar_temp2))+ |
| 318 |  |  | (r_initial.pper1*fdot(vper_temp1,vpar_temp2)); |
| 319 |  |  | r_final.pper1 = (r_initial.ppar1*fdot(vpar_temp1,vper_temp2))+ |
| 320 |  |  | (r_initial.pper1*fdot(vper_temp1,vper_temp2)); |
| 321 |  |  | r_final.ppar2 = (r_initial.ppar2*fdot(vpar_temp1,vpar_temp2))+ |
| 322 |  |  | (r_initial.pper2*fdot(vper_temp1,vpar_temp2)); |
| 323 |  |  | r_final.pper2 = (r_initial.ppar2*fdot(vpar_temp1,vper_temp2))+ |
| 324 |  |  | (r_initial.pper2*fdot(vper_temp1,vper_temp2)); |
| 325 | greg | 2.1 |  |
| 326 | schorsch | 2.7 | } |
| 327 |  |  | return r_final; |
| 328 | greg | 2.1 | } |
| 329 |  |  |  |
| 330 |  |  |  |
| 331 |  |  | static TRAYON |
| 332 | schorsch | 2.7 | transalphagamma( |
| 333 |  |  | TRAYON r_initial |
| 334 |  |  | ) |
| 335 | greg | 2.1 | /* transforme le rayon r_initial de la base associee a alpha dans |
| 336 |  |  | la base associee a gamma */ |
| 337 |  |  | { |
| 338 | schorsch | 2.7 | TRAYON r_final; |
| 339 |  |  | FVECT vpar_temp1,vpar_temp2,vper_temp1,vper_temp2; |
| 340 | greg | 2.1 |  |
| 341 | schorsch | 2.7 | r_final = r_initial; |
| 342 |  |  | alpha_gamma(r_initial.v,r_final.v); |
| 343 |  |  | if (( Y(r_initial) != 0. || Z(r_initial) != 0. )&&(Y(r_final)!= 0. || Z(r_final) !=0.)) |
| 344 |  |  | { |
| 345 |  |  | v_par(r_initial.v,vpar_temp1); |
| 346 |  |  | alpha_gamma(vpar_temp1,vpar_temp1); |
| 347 |  |  | v_per(r_initial.v,vper_temp1); |
| 348 |  |  | alpha_gamma(vper_temp1,vper_temp1); |
| 349 |  |  | v_par(r_final.v,vpar_temp2); |
| 350 |  |  | v_per(r_final.v,vper_temp2); |
| 351 |  |  | r_final.ppar1 = (r_initial.ppar1*fdot(vpar_temp1,vpar_temp2))+ |
| 352 |  |  | (r_initial.pper1*fdot(vper_temp1,vpar_temp2)); |
| 353 |  |  | r_final.pper1 = (r_initial.ppar1*fdot(vpar_temp1,vper_temp2))+ |
| 354 |  |  | (r_initial.pper1*fdot(vper_temp1,vper_temp2)); |
| 355 |  |  | r_final.ppar2 = (r_initial.ppar2*fdot(vpar_temp1,vpar_temp2))+ |
| 356 |  |  | (r_initial.pper2*fdot(vper_temp1,vpar_temp2)); |
| 357 |  |  | r_final.pper2 = (r_initial.ppar2*fdot(vpar_temp1,vper_temp2))+ |
| 358 |  |  | (r_initial.pper2*fdot(vper_temp1,vper_temp2)); |
| 359 | greg | 2.1 |  |
| 360 | schorsch | 2.7 | } |
| 361 |  |  | return r_final; |
| 362 | greg | 2.1 | } |
| 363 |  |  |  |
| 364 |  |  |  |
| 365 |  |  | static TRAYON |
| 366 | schorsch | 2.7 | transgammaalpha( |
| 367 |  |  | TRAYON r_initial |
| 368 |  |  | ) |
| 369 | greg | 2.1 | /* transforme le rayon r_initial de la base associee a gamma dans |
| 370 |  |  | la base associee a alpha */ |
| 371 |  |  | { |
| 372 | schorsch | 2.7 | TRAYON r_final; |
| 373 |  |  | FVECT vpar_temp1,vpar_temp2,vper_temp1,vper_temp2; |
| 374 | greg | 2.1 |  |
| 375 | schorsch | 2.7 | r_final = r_initial; |
| 376 |  |  | gamma_alpha(r_initial.v,r_final.v); |
| 377 |  |  | if (( Y(r_initial) != 0. || Z(r_initial) != 0. )&&(Y(r_final) !=0. || Z(r_final) != 0.)) |
| 378 |  |  | { |
| 379 |  |  | v_par(r_initial.v,vpar_temp1); |
| 380 |  |  | gamma_alpha(vpar_temp1,vpar_temp1); |
| 381 |  |  | v_per(r_initial.v,vper_temp1); |
| 382 |  |  | gamma_alpha(vper_temp1,vper_temp1); |
| 383 |  |  | v_par(r_final.v,vpar_temp2); |
| 384 |  |  | v_per(r_final.v,vper_temp2); |
| 385 |  |  | r_final.ppar1 = (r_initial.ppar1*fdot(vpar_temp1,vpar_temp2))+ |
| 386 |  |  | (r_initial.pper1*fdot(vper_temp1,vpar_temp2)); |
| 387 |  |  | r_final.pper1 = (r_initial.ppar1*fdot(vpar_temp1,vper_temp2))+ |
| 388 |  |  | (r_initial.pper1*fdot(vper_temp1,vper_temp2)); |
| 389 |  |  | r_final.ppar2 = (r_initial.ppar2*fdot(vpar_temp1,vpar_temp2))+ |
| 390 |  |  | (r_initial.pper2*fdot(vper_temp1,vpar_temp2)); |
| 391 |  |  | r_final.pper2 = (r_initial.ppar2*fdot(vpar_temp1,vper_temp2))+ |
| 392 |  |  | (r_initial.pper2*fdot(vper_temp1,vper_temp2)); |
| 393 |  |  | } |
| 394 |  |  | return r_final; |
| 395 | greg | 2.1 | } |
| 396 |  |  |  |
| 397 |  |  |  |
| 398 |  |  |  |
| 399 | greg | 2.2 | static int |
| 400 | schorsch | 2.7 | compare( |
| 401 |  |  | TRAYON r1, |
| 402 |  |  | TRAYON r2, |
| 403 |  |  | double marge |
| 404 |  |  | ) |
| 405 | greg | 2.2 | { |
| 406 | schorsch | 2.7 | double arctg1, arctg2; |
| 407 | greg | 2.2 |  |
| 408 | schorsch | 2.7 | arctg1 = atan2(Y(r1),X(r1)); |
| 409 |  |  | arctg2 = atan2(Y(r2),X(r2)); |
| 410 |  |  | if ((arctg1 - marge <= arctg2) && (arctg1 + marge >= arctg2)) return 1; |
| 411 |  |  | else return 0; |
| 412 | greg | 2.2 | } |
| 413 |  |  |  |
| 414 |  |  |  |
| 415 |  |  |  |
| 416 |  |  |  |
| 417 | schorsch | 2.7 | static void |
| 418 |  |  | sortie( |
| 419 |  |  | TRAYON r |
| 420 |  |  | ) |
| 421 | greg | 2.1 | { |
| 422 | schorsch | 2.7 | int i = 0; |
| 423 |  |  | int egalite = 0; |
| 424 | greg | 2.1 |  |
| 425 |  |  |  |
| 426 | schorsch | 2.7 | if(r.e > seuil) |
| 427 |  |  | { |
| 428 |  |  | while (i < nbrayons && egalite == 0) |
| 429 |  |  | { |
| 430 |  |  | raytemp = &ray[i]; |
| 431 |  |  | egalite = compare(r,*raytemp,tolerance); |
| 432 |  |  | if (egalite) raytemp->e = raytemp->e + r.e; |
| 433 |  |  | else i = i + 1; |
| 434 |  |  | } |
| 435 |  |  | if (egalite == 0) |
| 436 |  |  | { |
| 437 |  |  | if (nbrayons == 0) ray = (TRAYON *)calloc(1,sizeof(TRAYON)); |
| 438 |  |  | else ray = (TRAYON *)realloc((void *)ray, (nbrayons+1)*(sizeof(TRAYON))); |
| 439 |  |  | if (ray == NULL) |
| 440 |  |  | error(SYSTEM, "out of memory in sortie\n"); |
| 441 |  |  | raytemp = &ray[nbrayons]; |
| 442 |  |  | raytemp->v[0] = X(r); |
| 443 |  |  | raytemp->v[1] = Y(r); |
| 444 |  |  | raytemp->v[2] = Z(r); |
| 445 |  |  | raytemp->e = r.e; |
| 446 |  |  | nbrayons++; |
| 447 |  |  | } |
| 448 |  |  | } |
| 449 |  |  | return; |
| 450 | greg | 2.1 | } |
| 451 |  |  |  |
| 452 |  |  |  |
| 453 | schorsch | 2.7 | static void |
| 454 |  |  | trigo( |
| 455 |  |  | TRAYON r |
| 456 |  |  | ) |
| 457 | greg | 2.1 | /* calcule les grandeurs trigonometriques relatives au rayon incident |
| 458 |  |  | et le rapport entre les indices du milieu refracteur et incident   */ |
| 459 |  |  | { |
| 460 | schorsch | 2.7 | double det; |
| 461 |  |  |  |
| 462 |  |  | det = Sqrt(X(r)*X(r)+Y(r)*Y(r)+Z(r)*Z(r)); |
| 463 |  |  | sinus = Sqrt(Y(r)*Y(r)+Z(r)*Z(r))/det; |
| 464 |  |  | cosinus = Sqrt(X(r)*X(r))/det; |
| 465 |  |  | if (r.n == 1.) rapport = prism.np * prism.np; |
| 466 |  |  | else rapport = 1./(prism.np * prism.np); |
| 467 |  |  | return; |
| 468 | greg | 2.1 | } |
| 469 |  |  |  |
| 470 |  |  |  |
| 471 |  |  | static TRAYON |
| 472 | schorsch | 2.7 | reflexion( |
| 473 |  |  | TRAYON r_incident |
| 474 |  |  | ) |
| 475 | greg | 2.1 | { |
| 476 |  |  | /* calcul du rayon reflechi par une face */ |
| 477 |  |  | TRAYON r_reflechi; |
| 478 |  |  |  |
| 479 |  |  | r_reflechi = r_incident; |
| 480 |  |  | trigo(r_incident); |
| 481 |  |  | X(r_reflechi) = -X(r_incident); |
| 482 |  |  | Y(r_reflechi) = Y(r_incident); |
| 483 |  |  | Z(r_reflechi) = Z(r_incident); |
| 484 | greg | 2.3 | if(sinus > Sqrt(rapport) || r_incident.dest == tot_ref) |
| 485 | greg | 2.1 | { |
| 486 |  |  | r_reflechi.ppar1 = r_incident.ppar1; |
| 487 |  |  | r_reflechi.pper1 = r_incident.pper1; |
| 488 |  |  | r_reflechi.ppar2 = r_incident.ppar2; |
| 489 |  |  | r_reflechi.pper2 = r_incident.pper2; |
| 490 |  |  | r_reflechi.e = r_incident.e * fact_ref[r_incident.dest]; |
| 491 |  |  | } |
| 492 |  |  | else |
| 493 |  |  | { |
| 494 | greg | 2.3 | r_reflechi.ppar1 = r_incident.ppar1*(rapport*cosinus-Sqrt(rapport- |
| 495 |  |  | (sinus*sinus)))/(rapport*cosinus+Sqrt(rapport-(sinus*sinus))); |
| 496 |  |  | r_reflechi.pper1 = r_incident.pper1*(cosinus-Sqrt |
| 497 |  |  | (rapport-(sinus*sinus)))/(cosinus+Sqrt(rapport-(sinus*sinus))); |
| 498 |  |  | r_reflechi.ppar2 = r_incident.ppar2*(rapport*cosinus-Sqrt(rapport- |
| 499 |  |  | (sinus*sinus)))/(rapport*cosinus+Sqrt(rapport-(sinus*sinus))); |
| 500 |  |  | r_reflechi.pper2 = r_incident.pper2*(cosinus-Sqrt |
| 501 |  |  | (rapport-(sinus*sinus)))/(cosinus+Sqrt(rapport-(sinus*sinus))); |
| 502 | greg | 2.1 | r_reflechi.e = r_incident.e *(((r_reflechi.ppar1*r_reflechi.ppar1+ |
| 503 |  |  | r_reflechi.pper1*r_reflechi.pper1)/(r_incident.ppar1*r_incident.ppar1+ |
| 504 |  |  | r_incident.pper1*r_incident.pper1))+((r_reflechi.ppar2*r_reflechi.ppar2 |
| 505 |  |  | +r_reflechi.pper2*r_reflechi.pper2)/(r_incident.ppar2*r_incident.ppar2 |
| 506 |  |  | +r_incident.pper2*r_incident.pper2)))/2; |
| 507 |  |  | } |
| 508 |  |  |  |
| 509 |  |  | /* a la sortie de cette routine r_transmis.orig et .dest ne sont pas definis!*/ |
| 510 |  |  | return r_reflechi; |
| 511 |  |  | } |
| 512 |  |  |  |
| 513 |  |  |  |
| 514 |  |  | static TRAYON |
| 515 | schorsch | 2.7 | transmission( |
| 516 |  |  | TRAYON r_incident |
| 517 |  |  | ) |
| 518 | greg | 2.1 | { |
| 519 |  |  | /* calcul du rayon refracte par une face */ |
| 520 |  |  | TRAYON r_transmis; |
| 521 |  |  |  |
| 522 |  |  | r_transmis = r_incident; |
| 523 |  |  | trigo(r_incident); |
| 524 | greg | 2.3 | if (sinus <= Sqrt(rapport) && r_incident.dest != tot_ref) |
| 525 | greg | 2.1 | { |
| 526 |  |  | X(r_transmis) = (X(r_incident)/(fabs(X(r_incident))))* |
| 527 | greg | 2.3 | (Sqrt(1.-(Y(r_incident)*Y(r_incident)+Z(r_incident)* |
| 528 | greg | 2.1 | Z(r_incident))/rapport)); |
| 529 | greg | 2.3 | Y(r_transmis) = Y(r_incident)/Sqrt(rapport); |
| 530 |  |  | Z(r_transmis) = Z(r_incident)/Sqrt(rapport); |
| 531 |  |  | r_transmis.ppar1 = r_incident.ppar1*2.*Sqrt(rapport)*cosinus/ |
| 532 |  |  | (Sqrt(rapport-sinus*sinus)+rapport*cosinus); |
| 533 |  |  | r_transmis.pper1 = r_incident.pper1*2.*cosinus/(cosinus+Sqrt(rapport |
| 534 | greg | 2.1 | - sinus*sinus)); |
| 535 | greg | 2.3 | r_transmis.ppar2 = r_incident.ppar2*2.*Sqrt(rapport)*cosinus/ |
| 536 |  |  | (Sqrt(rapport-sinus*sinus)+rapport*cosinus); |
| 537 |  |  | r_transmis.pper2 = r_incident.pper2*2.*cosinus/(cosinus+Sqrt(rapport |
| 538 | greg | 2.1 | - sinus*sinus)); |
| 539 | greg | 2.3 | r_transmis.e = (r_incident.e/2)*(Sqrt(rapport-sinus*sinus)/cosinus) |
| 540 | greg | 2.1 | *(((r_transmis.ppar1*r_transmis.ppar1+r_transmis.pper1* |
| 541 |  |  | r_transmis.pper1) |
| 542 |  |  | /(r_incident.ppar1*r_incident.ppar1+r_incident.pper1* |
| 543 |  |  | r_incident.pper1))+ |
| 544 |  |  | ((r_transmis.ppar2*r_transmis.ppar2+r_transmis.pper2*r_transmis.pper2) |
| 545 |  |  | /(r_incident.ppar2*r_incident.ppar2+r_incident.pper2*r_incident.pper2))); |
| 546 |  |  | if(r_incident.n == 1.) r_transmis.n = prism.np; |
| 547 |  |  | else r_transmis.n = 1.; |
| 548 |  |  | } |
| 549 |  |  | else r_transmis.e = 0.; |
| 550 |  |  |  |
| 551 |  |  | /* a la sortie de cette routine r_transmis.orig et .dest ne sont pas definis!*/ |
| 552 |  |  |  |
| 553 |  |  | return r_transmis; |
| 554 |  |  | } |
| 555 |  |  |  |
| 556 |  |  |  |
| 557 |  |  |  |
| 558 |  |  |  |
| 559 |  |  | #define ensuite(rayon,prob_passage,destination) r_suite = rayon; \ |
| 560 |  |  | r_suite.e = prob_passage(rayon)*rayon.e; \ |
| 561 |  |  | r_suite.dest = destination; \ |
| 562 |  |  | if ( r_suite.e > seuil ) trace_rayon(r_suite) |
| 563 |  |  |  |
| 564 |  |  |  |
| 565 | schorsch | 2.7 | static void |
| 566 |  |  | trace_rayon( |
| 567 |  |  | TRAYON r_incident |
| 568 |  |  | ) |
| 569 | greg | 2.1 | { |
| 570 |  |  | /* trace le rayon donne */ |
| 571 |  |  | TRAYON r_reflechi,r_transmis,r_suite; |
| 572 |  |  |  |
| 573 |  |  | switch (r_incident.dest) |
| 574 |  |  | { |
| 575 |  |  | case ALPHA: |
| 576 |  |  | if ( r_incident.orig == ALPHA ) |
| 577 |  |  | { |
| 578 |  |  | r_reflechi = reflexion(r_incident); |
| 579 |  |  | sortie(r_reflechi); |
| 580 |  |  |  |
| 581 |  |  | r_transmis = transmission(r_incident); |
| 582 |  |  | r_transmis.orig = ALPHA; |
| 583 |  |  |  |
| 584 |  |  | ensuite(r_transmis,prob_alpha_beta,BETA); |
| 585 |  |  | ensuite(r_transmis,prob_alpha_gamma,GAMMA); |
| 586 |  |  | } |
| 587 |  |  | else |
| 588 |  |  | { |
| 589 |  |  | r_reflechi = reflexion(r_incident); |
| 590 |  |  | r_reflechi.orig = ALPHA; |
| 591 |  |  | ensuite(r_reflechi,prob_alpha_beta,BETA); |
| 592 |  |  | ensuite(r_reflechi,prob_alpha_gamma,GAMMA); |
| 593 |  |  |  |
| 594 |  |  | r_transmis = transmission(r_incident); |
| 595 |  |  | sortie(r_transmis); |
| 596 |  |  | } |
| 597 |  |  | break; |
| 598 |  |  | case BETA: |
| 599 |  |  | r_reflechi = transbetaalpha(reflexion(transalphabeta(r_incident))); |
| 600 |  |  | r_reflechi.orig = BETA; |
| 601 |  |  | r_transmis = transbetaalpha(transmission(transalphabeta |
| 602 |  |  | (r_incident))); |
| 603 |  |  | r_transmis.orig = GAMMA; |
| 604 |  |  | if ( r_incident.n > 1.0 )  /* le rayon vient de l'interieur */ |
| 605 |  |  | { |
| 606 |  |  | ensuite(r_reflechi,prob_beta_alpha,ALPHA); |
| 607 |  |  | ensuite(r_reflechi,prob_beta_gamma,GAMMA); |
| 608 |  |  |  |
| 609 |  |  | ensuite(r_transmis,prob_beta_gamma,GAMMA); |
| 610 |  |  | ensuite(r_transmis,prob_beta_delta,DELTA); |
| 611 |  |  | } |
| 612 |  |  | else   /* le rayon vient de l'exterieur */ |
| 613 |  |  | { |
| 614 |  |  | ensuite(r_reflechi,prob_beta_gamma,GAMMA); |
| 615 |  |  | ensuite(r_reflechi,prob_beta_delta,DELTA); |
| 616 |  |  |  |
| 617 |  |  | ensuite(r_transmis,prob_beta_alpha,ALPHA); |
| 618 |  |  | ensuite(r_transmis,prob_beta_gamma,GAMMA); |
| 619 |  |  | } |
| 620 |  |  | break; |
| 621 |  |  | case GAMMA: |
| 622 |  |  | r_reflechi = transgammaalpha(reflexion(transalphagamma(r_incident))); |
| 623 |  |  | r_reflechi.orig = GAMMA; |
| 624 |  |  | r_transmis = transgammaalpha(transmission(transalphagamma |
| 625 |  |  | (r_incident))); |
| 626 |  |  | r_transmis.orig = GAMMA; |
| 627 |  |  | if ( r_incident.n > 1.0 )  /* le rayon vient de l'interieur */ |
| 628 |  |  | { |
| 629 |  |  | ensuite(r_reflechi,prob_gamma_alpha,ALPHA); |
| 630 |  |  | ensuite(r_reflechi,prob_gamma_beta,BETA); |
| 631 |  |  |  |
| 632 |  |  | ensuite(r_transmis,prob_gamma_beta,BETA); |
| 633 |  |  | ensuite(r_transmis,prob_gamma_delta,DELTA); |
| 634 |  |  | } |
| 635 |  |  | else   /* le rayon vient de l'exterieur */ |
| 636 |  |  | { |
| 637 |  |  | ensuite(r_reflechi,prob_gamma_beta,BETA); |
| 638 |  |  | ensuite(r_reflechi,prob_gamma_delta,DELTA); |
| 639 |  |  |  |
| 640 |  |  | ensuite(r_transmis,prob_gamma_alpha,ALPHA); |
| 641 |  |  | ensuite(r_transmis,prob_gamma_beta,BETA); |
| 642 |  |  | } |
| 643 |  |  | break; |
| 644 |  |  | case DELTA: |
| 645 |  |  | if ( r_incident.orig != DELTA ) sortie(r_incident); |
| 646 |  |  | else |
| 647 |  |  | { |
| 648 |  |  | ensuite(r_incident,prob_delta_beta,BETA); |
| 649 |  |  | ensuite(r_incident,prob_delta_gamma,GAMMA); |
| 650 |  |  | } |
| 651 |  |  | break; |
| 652 |  |  | } |
| 653 |  |  | return; |
| 654 |  |  | } |
| 655 |  |  |  |
| 656 |  |  | #undef ensuite |
| 657 |  |  |  |
| 658 | schorsch | 2.7 | static void |
| 659 |  |  | inverser( |
| 660 |  |  | TRAYON *r1, |
| 661 |  |  | TRAYON *r2 |
| 662 |  |  | ) |
| 663 | greg | 2.1 | { |
| 664 | schorsch | 2.7 | TRAYON temp; |
| 665 |  |  | temp = *r1; |
| 666 |  |  | *r1 = *r2; |
| 667 |  |  | *r2 = temp; |
| 668 | greg | 2.1 | } |
| 669 |  |  |  |
| 670 |  |  |  |
| 671 |  |  |  |
| 672 | schorsch | 2.7 | static void |
| 673 |  |  | setprism(void) |
| 674 | greg | 2.1 | { |
| 675 |  |  | double d; |
| 676 |  |  | TRAYON r_initial,rsource; |
| 677 | schorsch | 2.7 | int i,j; |
| 678 | greg | 2.1 |  |
| 679 |  |  | prismclock = eclock; |
| 680 |  |  | r_initial.ppar1 = r_initial.pper2 = 1.; |
| 681 |  |  | r_initial.pper1 = r_initial.ppar2 = 0.; |
| 682 |  |  |  |
| 683 |  |  | d = 1; prism.a = funvalue("arg", 1, &d); |
| 684 |  |  | if(prism.a < 0.) goto badopt; |
| 685 |  |  | d = 2; prism.b = funvalue("arg", 1, &d); |
| 686 |  |  | if(prism.b < 0.) goto badopt; |
| 687 |  |  | d = 3; prism.c = funvalue("arg", 1, &d); |
| 688 |  |  | if(prism.c < 0.) goto badopt; |
| 689 |  |  | d = 4; prism.d = funvalue("arg", 1, &d); |
| 690 |  |  | if(prism.d < 0.) goto badopt; |
| 691 |  |  | d = 5; prism.np = funvalue("arg", 1, &d); |
| 692 |  |  | if(prism.np < 1.) goto badopt; |
| 693 |  |  | d = 6; seuil = funvalue("arg", 1, &d); |
| 694 |  |  | if (seuil < 0. || seuil >=1) goto badopt; |
| 695 |  |  | d = 7; tot_ref = (int)(funvalue("arg", 1, &d) + .5); |
| 696 |  |  | if (tot_ref != 1 && tot_ref != 2 && tot_ref != 4) goto badopt; |
| 697 |  |  | if (tot_ref < 4 ) |
| 698 |  |  | { |
| 699 |  |  | d = 8; fact_ref[tot_ref] = funvalue("arg", 1, &d); |
| 700 |  |  | if (fact_ref[tot_ref] < 0. || fact_ref[tot_ref] > 1.) goto badopt; |
| 701 |  |  | } |
| 702 |  |  | d = 9; tolerance = funvalue("arg", 1, &d); |
| 703 |  |  | if (tolerance <= 0.) goto badopt; |
| 704 |  |  | d = 10; tolsource = funvalue("arg", 1, &d); |
| 705 |  |  | if (tolsource < 0. ) goto badopt; |
| 706 |  |  | X(r_initial) = varvalue("Dx"); |
| 707 |  |  | Y(r_initial) = varvalue("Dy"); |
| 708 |  |  | Z(r_initial) = varvalue("Dz"); |
| 709 |  |  | #ifdef DEBUG |
| 710 |  |  | fprintf(stderr,"dx=%lf dy=%lf dz=%lf\n",X(r_initial),Y(r_initial),Z(r_initial)); |
| 711 |  |  | #endif |
| 712 |  |  |  |
| 713 |  |  | /* initialisation */ |
| 714 |  |  | prepare_matrices(); |
| 715 |  |  | r_initial.e = 1.0; |
| 716 |  |  | r_initial.n = 1.0; |
| 717 |  |  |  |
| 718 |  |  | if(ray!=NULL) free(ray); |
| 719 |  |  | nbrayons = 0; |
| 720 |  |  | /* determination de l'origine et de la destination du rayon initial */ |
| 721 |  |  |  |
| 722 |  |  | if ( X(r_initial) != 0.) |
| 723 |  |  | { |
| 724 |  |  | if ( X(r_initial) > 0. ) |
| 725 |  |  | { |
| 726 |  |  | r_initial.orig = r_initial.dest = ALPHA; |
| 727 |  |  | sens = 1; |
| 728 |  |  | } |
| 729 |  |  | else if ( X(r_initial) < 0. ) |
| 730 |  |  | { |
| 731 |  |  | r_initial.orig = r_initial.dest = DELTA; |
| 732 |  |  | sens = -1; |
| 733 |  |  | } |
| 734 |  |  |  |
| 735 |  |  | normalize(r_initial.v); |
| 736 |  |  |  |
| 737 |  |  | trace_rayon(r_initial); |
| 738 |  |  |  |
| 739 |  |  | X(rsource) = varvalue("DxA"); |
| 740 |  |  | Y(rsource) = varvalue("DyA"); |
| 741 |  |  | Z(rsource) = varvalue("DzA"); |
| 742 |  |  | nosource = ( X(rsource)==0. && Y(rsource)==0. && Z(rsource)==0. ); |
| 743 |  |  | if ( !nosource ) |
| 744 |  |  | { |
| 745 |  |  | for (j=0; j<nbrayons; j++) |
| 746 |  |  | { |
| 747 |  |  | if ( !compare(ray[j],rsource,tolsource) ) ray[j].e =0.; |
| 748 |  |  | } |
| 749 |  |  | } |
| 750 |  |  | for  (j = 0; j < nbrayons; j++) |
| 751 |  |  | { |
| 752 |  |  | for (i = j+1; i < nbrayons; i++) |
| 753 |  |  | { |
| 754 |  |  | if (ray[j].e < ray[i].e) inverser(&ray[j],&ray[i]); |
| 755 |  |  | } |
| 756 |  |  | } |
| 757 |  |  |  |
| 758 |  |  | bidon = 1; |
| 759 |  |  | } |
| 760 |  |  | else bidon = 0; |
| 761 |  |  | return; |
| 762 |  |  |  |
| 763 |  |  | /* message puis sortie si erreur dans la ligne de commande */ |
| 764 |  |  | badopt: |
| 765 |  |  | bidon = BADVAL; |
| 766 |  |  | return; |
| 767 |  |  | } |
| 768 | greg | 2.2 |  |
| 769 |  |  |  |
| 770 |  |  | static double |
| 771 | schorsch | 2.7 | l_get_val( |
| 772 |  |  | char *nm |
| 773 |  |  | ) |
| 774 | greg | 2.2 | { |
| 775 |  |  | int val, dir, i, trouve, curseur; |
| 776 |  |  | int nb; |
| 777 |  |  | double valeur; |
| 778 |  |  | TRAYON *rayt, raynull; |
| 779 |  |  |  |
| 780 |  |  | if (prismclock < 0 || prismclock < eclock) setprism(); |
| 781 |  |  | if (bidon == BADVAL) { |
| 782 |  |  | errno = EDOM; |
| 783 |  |  | return(0.0); |
| 784 |  |  | } |
| 785 |  |  | val = (int)(argument(1) + .5); |
| 786 |  |  | dir = (int)(argument(2) + .5); |
| 787 |  |  | nb = (int)(argument(3) + .5); |
| 788 |  |  | X(raynull) = bidon; |
| 789 |  |  | Y(raynull) = Z(raynull) = 0.; |
| 790 |  |  | raynull.e = 0.; |
| 791 |  |  | trouve = curseur = 0; |
| 792 |  |  | if ( !nosource && nb==2 ) nb=1; /* on est en train de tracer la source |
| 793 |  |  | a partir de sa seconde source virtuelle */ |
| 794 |  |  | #ifdef DEBUG |
| 795 |  |  | fprintf(stderr, " On considere le rayon no: %d\n", nb); |
| 796 |  |  | #endif |
| 797 |  |  | for(i=0; i < nbrayons &&!trouve; i++) |
| 798 |  |  | { |
| 799 |  |  | if(ray[i].v[0] * dir * sens >= 0.) curseur ++; |
| 800 |  |  | if(curseur == nb) |
| 801 |  |  | { |
| 802 |  |  | rayt = &ray[i]; |
| 803 |  |  | trouve = 1; |
| 804 |  |  | } |
| 805 |  |  | } |
| 806 |  |  | if(!trouve) rayt = &raynull; |
| 807 |  |  | switch(val) { |
| 808 |  |  | case 0 : valeur = rayt->v[0]; |
| 809 |  |  | break; |
| 810 |  |  | case 1 : valeur = rayt->v[1]; |
| 811 |  |  | break; |
| 812 |  |  | case 2 : valeur = rayt->v[2]; |
| 813 |  |  | break; |
| 814 |  |  | case 3 : valeur = rayt->e; |
| 815 |  |  | break; |
| 816 |  |  | default : errno = EDOM; return(0.0); |
| 817 |  |  | } |
| 818 |  |  | #ifdef DEBUG |
| 819 |  |  | fprintf(stderr, "get_val( %i, %i, %i) = %lf\n",val,dir,nb,valeur); |
| 820 |  |  | #endif |
| 821 |  |  | return valeur; |
| 822 |  |  | } |
| 823 |  |  |  |
| 824 | greg | 2.1 |  |
| 825 | schorsch | 2.7 | extern void |
| 826 |  |  | setprismfuncs(void)  /* declared in func.h */ |
| 827 | greg | 2.1 | { |
| 828 |  |  | funset("fprism_val", 3, '=', l_get_val); |
| 829 |  |  | } |
