| 1 |
/* RCSid $Id: driver.h,v 2.8 2003/08/20 10:00:09 schorsch Exp $ */ |
| 2 |
| 3 |
* driver.h - header file for interactive device drivers. |
| 4 |
| 5 |
#ifndef _RAD_DRIVER_H_ |
| 6 |
#define _RAD_DRIVER_H_ |
| 7 |
| 8 |
#include "color.h" |
| 9 |
| 10 |
#ifdef __cplusplus |
| 11 |
extern "C" { |
| 12 |
#endif |
| 13 |
| 14 |
typedef struct driver *dr_initf_t(char *dname, char *id); |
| 15 |
typedef int dr_getchf_t(void); |
| 16 |
typedef void dr_newcolrf_t(int ndx, int r, int g, int b); |
| 17 |
| 18 |
typedef void dr_closef_t(void); |
| 19 |
typedef void dr_clearf_t(int, int); |
| 20 |
typedef void dr_paintrf_t(COLOR col, int xmin, int ymin, int xmax, int ymax); |
| 21 |
typedef int dr_getcurf_t(int*,int*); |
| 22 |
typedef void dr_comoutf_t(char*); |
| 23 |
typedef void dr_cominf_t(char*,char*); |
| 24 |
typedef void dr_flushf_t(void); |
| 25 |
| 26 |
struct driver { /* driver functions */ |
| 27 |
dr_closef_t *close; /* close device */ |
| 28 |
dr_clearf_t *clear; /* clear device */ |
| 29 |
dr_paintrf_t *paintr; /* paint rectangle */ |
| 30 |
dr_getcurf_t *getcur; /* get cursor position */ |
| 31 |
dr_comoutf_t *comout; /* command line output */ |
| 32 |
dr_cominf_t *comin; /* command line input */ |
| 33 |
dr_flushf_t *flush; /* flush output */ |
| 34 |
double pixaspect; /* pixel aspect ratio */ |
| 35 |
int xsiz, ysiz; /* device size */ |
| 36 |
int inpready; /* input ready on device */ |
| 37 |
| 38 |
/* magic numbers for verification */ |
| 39 |
#define COM_SENDM 0x6f37 |
| 40 |
#define COM_RECVM 0x51da |
| 41 |
/* stream commands */ |
| 42 |
#define COM_CLEAR 0 |
| 43 |
#define COM_PAINTR 1 |
| 44 |
#define COM_GETCUR 2 |
| 45 |
#define COM_COMOUT 3 |
| 46 |
#define COM_COMIN 4 |
| 47 |
#define COM_FLUSH 5 |
| 48 |
#define NREQUESTS 6 /* number of valid requests */ |
| 49 |
| 50 |
extern struct device { /* interactive device */ |
| 51 |
char *name; /* device name */ |
| 52 |
char *descrip; /* description */ |
| 53 |
dr_initf_t *init; /* initialize device */ |
| 54 |
} devtable[]; /* supported devices */ |
| 55 |
| 56 |
extern char dev_default[]; /* default device name */ |
| 57 |
| 58 |
#define MB1 ('\n') /* mouse button 1 */ |
| 59 |
#define MB2 ('\r') /* mouse button 2 */ |
| 60 |
#define MB3 (' ') /* mouse button 3 */ |
| 61 |
#define ABORT ('C'-'@') /* abort key */ |
| 62 |
| 63 |
| 64 |
* How to write an interactive display driver for rview. |
| 65 |
| 66 |
| 67 |
* static struct driver dname_driver; |
| 68 |
| 69 |
* extern dr_initf_t dname_init; |
| 70 |
| 71 |
* extern struct driver * |
| 72 |
* dname_init( |
| 73 |
* char *name, |
| 74 |
* char *id |
| 75 |
| 76 |
| 77 |
* Initialize device and return pointer to driver |
| 78 |
* dname_driver. Return NULL if an error occurred. |
| 79 |
* The name string identifies the driver, |
| 80 |
* and the id string identifies the client. |
| 81 |
* A device can be open by at most one client. |
| 82 |
* Be verbose in error reports; call eputs(). |
| 83 |
* If device has its own error output, set erract. |
| 84 |
* This function then needs to be inserted into the |
| 85 |
* device table in devtable.c. |
| 86 |
| 87 |
| 88 |
| 89 |
* static dr_closef_t dname_close; |
| 90 |
| 91 |
* dname_driver.close = dname_close; |
| 92 |
| 93 |
* static void |
| 94 |
* dname_close(void) |
| 95 |
| 96 |
* Close the device. Reset error vectors. |
| 97 |
| 98 |
| 99 |
| 100 |
* static dr_clearf_t dname_clear; |
| 101 |
| 102 |
* dname_driver.clear = dname_clear; |
| 103 |
| 104 |
* static void |
| 105 |
* dname_clear( |
| 106 |
* int xres, |
| 107 |
* int yres; |
| 108 |
| 109 |
| 110 |
* Clear the device for xres by yres output. This call will |
| 111 |
* be made prior to any output. |
| 112 |
| 113 |
| 114 |
| 115 |
* static dr_paintrf_t dname_paintr; |
| 116 |
| 117 |
* dname_driver.paintr = dname_paintr; |
| 118 |
| 119 |
* static void |
| 120 |
* dname_paintr( |
| 121 |
* COLOR col, |
| 122 |
* int xmin, |
| 123 |
* int ymin, |
| 124 |
* int xmax, |
| 125 |
* int ymax |
| 126 |
| 127 |
| 128 |
* Paint a half-open rectangle from (xmin,ymin) to (xmax,ymax) |
| 129 |
* with the color col. |
| 130 |
| 131 |
| 132 |
| 133 |
* static dr_getcurf_t dname_getcur; |
| 134 |
| 135 |
* dname_driver.getcur = dname_getcur; |
| 136 |
| 137 |
* static int |
| 138 |
* dname_getcur( |
| 139 |
* int *xp, |
| 140 |
* int *yp |
| 141 |
| 142 |
| 143 |
* Get the cursor position entered by the user via mouse, |
| 144 |
* joystick, etc. Return the key hit by the user (usually |
| 145 |
* MB1 or MB2). Return ABORT to cancel. |
| 146 |
* Can be NULL for devices without this capability. |
| 147 |
| 148 |
| 149 |
| 150 |
* static dr_comoutf_t dname_comout; |
| 151 |
| 152 |
* dname_driver.comout = dname_comout; |
| 153 |
| 154 |
* static void |
| 155 |
* dname_comout( |
| 156 |
* char *out |
| 157 |
| 158 |
| 159 |
* Print the string out on the device command line. If the |
| 160 |
* string ends with '\n', the message is considered complete, |
| 161 |
* and the next call can erase it. |
| 162 |
| 163 |
| 164 |
| 165 |
* static dr_cominf_t dname_comin; |
| 166 |
| 167 |
* dname_driver.comin = dname_comin; |
| 168 |
| 169 |
* static void |
| 170 |
* dname_comin( |
| 171 |
* char *in, |
| 172 |
* char *prompt |
| 173 |
| 174 |
| 175 |
* Print a prompt then read an edited input command line |
| 176 |
* assuming the in buffer is big enough. Unless prompt is NULL, |
| 177 |
* the driver may substitute its own rview command. This is |
| 178 |
* the most reliable way to repaint areas of the screen. |
| 179 |
* If the user enters an unrecognized control character, |
| 180 |
* terminate input and return the string with only that character. |
| 181 |
* The input string should not contain a newline. The routines in |
| 182 |
* editline.c may be useful. Comin must work in consort with comout. |
| 183 |
| 184 |
| 185 |
| 186 |
* static dr_flushf_t dname_flush; |
| 187 |
| 188 |
* dname_driver.flush = dname_flush; |
| 189 |
| 190 |
* static void |
| 191 |
* dname_flush(void) |
| 192 |
| 193 |
* Flush output to the display. This is guaranteed to be called |
| 194 |
* frequently enough to keep the display up to date. |
| 195 |
* This is an ideal time to check for device input. |
| 196 |
* This function can be NULL for devices that don't need it. |
| 197 |
| 198 |
| 199 |
| 200 |
* dname_driver.xsiz |
| 201 |
* dname_driver.ysiz |
| 202 |
| 203 |
* The maximum allowable x and y dimensions. If any |
| 204 |
* size is allowable, these should be set to MAXRES. |
| 205 |
| 206 |
| 207 |
* dname_driver.inpready |
| 208 |
| 209 |
* This variable should be made positive asynchronously |
| 210 |
* when characters are ready on the input. (Often easiest |
| 211 |
* to check for input during calls to paintr.) |
| 212 |
| 213 |
| 214 |
/* defined in editline.c */ |
| 215 |
extern void editline(char *buf, dr_getchf_t *c_get, dr_comoutf_t *s_put); |
| 216 |
extern void tocombuf(char *b, struct driver *d); |
| 217 |
extern int fromcombuf(char *b, struct driver *d); |
| 218 |
| 219 |
/* defined in devcomm.c */ |
| 220 |
extern dr_initf_t slave_init; /* XXX should probably be in a seperate file */ |
| 221 |
extern struct driver *comm_init(char *dname, char *id); |
| 222 |
| 223 |
/* defined in colortab.c */ |
| 224 |
extern int new_ctab(int ncolors); |
| 225 |
extern int get_pixel(COLOR col, dr_newcolrf_t *newcolr); |
| 226 |
extern void make_gmap(double gam); |
| 227 |
extern void set_cmap(BYTE *rmap, BYTE *gmap, BYTE *bmap); |
| 228 |
extern void map_color(BYTE rgb[3], COLOR col); |
| 229 |
| 230 |
| 231 |
| 232 |
| 233 |
#endif |
| 234 |
#endif /* _RAD_DRIVER_H_ */ |
| 235 |
