root/radiance/src/rt/devmain.c
Revision: 2.6
Committed: Thu Feb 9 21:54:11 2023 UTC (2 years, 8 months ago) by greg
CVS Tags: rad5R4, rad6R0, HEAD
Changes since 2.5: +23 -26 lines
fix: compile error fixes related to redeclaration of eputs() and wputs()
2 static const char RCSid[] = "$Id: devmain.c,v 2.5 2016/08/18 00:52:48 greg Exp $";
5 * devmain.c - main for independent drivers.
6 *
7 * Redefine your initialization routine to dinit.
8 */
9
10 #include "copyright.h"
11
12 #include "standard.h"
13
14 #include "color.h"
15
16 #include "driver.h"
17
18 struct driver *dev = NULL; /* output device */
19
20 FILE *devin, *devout; /* communications channels */
21
22 char *progname; /* driver name */
23
24 int r_clear(), r_paintr(), r_getcur(), r_comout(), r_comin(), r_flush();
25
26 int (*dev_func[NREQUESTS])() = { /* request handlers */
27 r_clear, r_paintr,
28 r_getcur, r_comout,
29 r_comin, r_flush
30 };
31
32
33 main(argc, argv) /* set up communications and main loop */
34 int argc;
35 char *argv[];
36 {
37 extern struct driver *dinit();
38 int com;
39 /* set up I/O */
40 progname = argv[0];
41 if (argc < 3) {
42 eputs("arg count\n");
43 quit(1);
44 }
45 devin = fdopen(atoi(argv[1]), "r");
46 devout = fdopen(atoi(argv[2]), "w");
47 if (devin == NULL || devout == NULL || getw(devin) != COM_SENDM) {
48 eputs("connection failure\n");
49 quit(1);
50 }
51 /* open device */
52 if ((dev = dinit(argv[0], argv[3])) == NULL)
53 quit(1);
54 putw(COM_RECVM, devout); /* verify initialization */
55 sendstate();
56 fflush(devout);
57 /* loop on requests */
58 while ((com = getc(devin)) != EOF) {
59 if (com >= NREQUESTS || dev_func[com] == NULL) {
60 eputs("invalid request\n");
61 quit(1);
62 }
63 (*dev_func[com])(); /* process request */
64 }
65 quit(0); /* all done, clean up and exit */
66 }
67
68
69 void
70 quit(code) /* close device and exit */
71 int code;
72 {
73 if (dev != NULL)
74 (*dev->close)();
75 exit(code);
76 }
77
78
79 r_clear() /* clear screen */
80 {
81 int xres, yres;
82
83 xres = getw(devin);
84 yres = getw(devin);
85 (*dev->clear)(xres, yres);
86 }
87
88
89 r_paintr() /* paint a rectangle */
90 {
91 COLOR col;
92 int xmin, ymin, xmax, ymax;
93
94 getbinary((char *)col, sizeof(COLOR), 1, devin);
95 xmin = getw(devin); ymin = getw(devin);
96 xmax = getw(devin); ymax = getw(devin);
97 (*dev->paintr)(col, xmin, ymin, xmax, ymax);
98 }
99
100
101 r_flush() /* flush output */
102 {
103 if (dev->flush != NULL)
104 (*dev->flush)();
105 putc(COM_FLUSH, devout);
106 sendstate();
107 fflush(devout);
108 }
109
110
111 r_getcur() /* get and return cursor position */
112 {
113 int c;
114 int x, y;
115 /* get it if we can */
116 if (dev->getcur == NULL) {
117 c = ABORT;
118 x = y = 0;
119 } else
120 c = (*dev->getcur)(&x, &y);
121 /* reply */
122 putc(COM_GETCUR, devout);
123 putc(c, devout);
124 putw(x, devout);
125 putw(y, devout);
126 fflush(devout);
127 }
128
129
130 void
131 mygets(char *s, FILE *fp) /* get string from file (with nul) */
132 {
133 int c;
134
135 while ((c = getc(fp)) != EOF)
136 if ((*s++ = c) == '\0')
137 return;
138 *s = '\0';
139 }
140
141
142 void
143 myputs(const char *s, FILE *fp) /* put string to file (with nul) */
144 {
145 do
146 putc(*s, fp);
147 while (*s++);
148 }
149
150
151 r_comout() /* print string to command line */
152 {
153 char str[256];
154
155 mygets(str, devin);
156 (*dev->comout)(str);
157 }
158
159
160 r_comin() /* read string from command line */
161 {
162 char buf[256], *prompt;
163 /* get prompt */
164 if (getc(devin)) {
165 mygets(buf, devin);
166 prompt = buf;
167 } else
168 prompt = NULL;
169 /* get string */
170 (*dev->comin)(buf, prompt);
171 /* reply */
172 putc(COM_COMIN, devout);
173 myputs(buf, devout);
174 sendstate();
175 fflush(devout);
176 }
177
178
179 void
180 eputs(const char *s) /* put string to stderr */
181 {
182 static int midline = 0;
183
184 if (!*s)
185 return;
186 if (!midline++) {
187 fputs(progname, stderr);
188 fputs(": ", stderr);
189 }
190 fputs(s, stderr);
191 if (s[strlen(s)-1] == '\n') {
192 fflush(stderr);
193 midline = 0;
194 }
195 }
196
197
198 sendstate() /* send driver state variables */
199 {
200 putbinary(&dev->pixaspect, sizeof(dev->pixaspect), 1, devout);
201 putw(dev->xsiz, devout);
202 putw(dev->ysiz, devout);
203 putw(dev->inpready, devout);
204 }
