| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: devcomm.c,v 2.19 2016/08/18 00:52:48 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* devcomm.c - communication routines for separate drivers.
| 6 |
| 7 |
* External symbols declared in driver.h
| 8 |
| 9 |
| 10 |
#include "copyright.h"
| 11 |
| 12 |
#include <sys/types.h>
| 13 |
#if !defined(_WIN32) && !defined(_WIN64)
| 14 |
#include <sys/wait.h>
| 15 |
#endif
| 16 |
| 17 |
#include "paths.h"
| 18 |
#include "platform.h"
| 19 |
#include "standard.h"
| 20 |
#include "driver.h"
| 21 |
| 22 |
#ifndef DEVPATH
| 23 |
#define DEVPATH getenv("PATH") /* device search path */
| 24 |
#endif
| 25 |
| 26 |
FILE *devin, *devout;
| 27 |
int devchild;
| 28 |
| 29 |
static struct driver * final_connect(void);
| 30 |
static void mygets(char *s, FILE *fp);
| 31 |
static void myputs(const char *s, FILE *fp);
| 32 |
static void reply_error(char *routine);
| 33 |
static void getstate(void);
| 34 |
| 35 |
static dr_closef_t comm_close;
| 36 |
static dr_clearf_t comm_clear;
| 37 |
static dr_paintrf_t comm_paintr;
| 38 |
static dr_getcurf_t comm_getcur;
| 39 |
static dr_comoutf_t comm_comout;
| 40 |
static dr_cominf_t comm_comin;
| 41 |
static dr_flushf_t comm_flush;
| 42 |
| 43 |
struct driver comm_driver = {
| 44 |
comm_close, comm_clear, comm_paintr, comm_getcur,
| 45 |
comm_comout, comm_comin, comm_flush
| 46 |
| 47 |
| 48 |
| 49 |
| 50 |
final_connect(void) /* verify and initialize connection */
| 51 |
| 52 |
putw(COM_SENDM, devout);
| 53 |
fflush(devout);
| 54 |
if (getw(devin) != COM_RECVM)
| 55 |
return(NULL);
| 56 |
/* get driver parameters */
| 57 |
getstate();
| 58 |
/* set error vectors */
| 59 |
erract[COMMAND].pf = comm_comout;
| 60 |
/* doesn't work with raypcalls.c
| 61 |
if (erract[WARNING].pf != NULL)
| 62 |
erract[WARNING].pf = comm_comout;
| 63 |
| 64 |
return(&comm_driver);
| 65 |
| 66 |
| 67 |
| 68 |
struct driver *
| 69 |
slave_init( /* run rview in slave mode */
| 70 |
char *dname,
| 71 |
char *id
| 72 |
| 73 |
| 74 |
devchild = -1; /* we're the slave here */
| 75 |
devout = stdout; /* use standard input */
| 76 |
devin = stdin; /* and standard output */
| 77 |
return(final_connect()); /* verify initialization */
| 78 |
| 79 |
| 80 |
| 81 |
struct driver *
| 82 |
comm_init( /* set up and execute driver */
| 83 |
char *dname,
| 84 |
char *id
| 85 |
| 86 |
| 87 |
char *dvcname;
| 88 |
int p1[2], p2[2];
| 89 |
char pin[16], pout[16];
| 90 |
/* find driver program */
| 91 |
if ((dvcname = getpath(dname, DEVPATH, X_OK)) == NULL) {
| 92 |
eputs(dname);
| 93 |
eputs(": not found\n");
| 94 |
return(NULL);
| 95 |
| 96 |
#ifdef RHAS_FORK_EXEC
| 97 |
/* open communication pipes */
| 98 |
if (pipe(p1) == -1 || pipe(p2) == -1)
| 99 |
goto syserr;
| 100 |
if ((devchild = fork()) == 0) { /* fork driver process */
| 101 |
close(p1[1]);
| 102 |
close(p2[0]);
| 103 |
sprintf(pin, "%d", p1[0]);
| 104 |
sprintf(pout, "%d", p2[1]);
| 105 |
execl(dvcname, dname, pin, pout, id, NULL);
| 106 |
perror(dvcname);
| 107 |
_exit(127);
| 108 |
| 109 |
if (devchild == -1)
| 110 |
goto syserr;
| 111 |
close(p1[0]);
| 112 |
close(p2[1]);
| 113 |
| 114 |
* Close write stream on exec to avoid multiprocessing deadlock.
| 115 |
* No use in read stream without it, so set flag there as well.
| 116 |
| 117 |
fcntl(p1[1], F_SETFD, FD_CLOEXEC);
| 118 |
fcntl(p2[0], F_SETFD, FD_CLOEXEC);
| 119 |
if ((devout = fdopen(p1[1], "w")) == NULL)
| 120 |
goto syserr;
| 121 |
if ((devin = fdopen(p2[0], "r")) == NULL)
| 122 |
goto syserr;
| 123 |
| 124 |
syserr:
| 125 |
perror(dname);
| 126 |
return(NULL);
| 127 |
| 128 |
#else /* ! RHAS_FORK_EXEC */
| 129 |
| 130 |
eputs(dname);
| 131 |
eputs(": no fork/exec\n");
| 132 |
return(NULL);
| 133 |
| 134 |
#endif /* ! RHAS_FORK_EXEC */
| 135 |
| 136 |
| 137 |
| 138 |
static void
| 139 |
comm_close(void) /* done with driver */
| 140 |
| 141 |
int pid;
| 142 |
| 143 |
erract[COMMAND].pf = NULL; /* reset error vectors */
| 144 |
| 145 |
erract[WARNING].pf = wputs;
| 146 |
fclose(devout);
| 147 |
fclose(devin);
| 148 |
if (devchild < 0)
| 149 |
return;
| 150 |
| 151 |
while ((pid = wait(0)) != -1 && pid != devchild)
| 152 |
| 153 |
#endif
| 154 |
| 155 |
| 156 |
| 157 |
static void
| 158 |
comm_clear( /* clear screen */
| 159 |
int xres,
| 160 |
int yres
| 161 |
| 162 |
| 163 |
putc(COM_CLEAR, devout);
| 164 |
putw(xres, devout);
| 165 |
putw(yres, devout);
| 166 |
fflush(devout);
| 167 |
| 168 |
| 169 |
| 170 |
static void
| 171 |
comm_paintr( /* paint a rectangle */
| 172 |
COLOR col,
| 173 |
int xmin,
| 174 |
int ymin,
| 175 |
int xmax,
| 176 |
int ymax
| 177 |
| 178 |
| 179 |
putc(COM_PAINTR, devout);
| 180 |
putbinary(col, sizeof(COLOR), 1, devout);
| 181 |
putw(xmin, devout);
| 182 |
putw(ymin, devout);
| 183 |
putw(xmax, devout);
| 184 |
putw(ymax, devout);
| 185 |
| 186 |
| 187 |
| 188 |
static void
| 189 |
comm_flush(void) /* flush output to driver */
| 190 |
| 191 |
putc(COM_FLUSH, devout);
| 192 |
fflush(devout);
| 193 |
if (getc(devin) != COM_FLUSH)
| 194 |
reply_error("flush");
| 195 |
getstate();
| 196 |
| 197 |
| 198 |
| 199 |
static int
| 200 |
comm_getcur( /* get and return cursor position */
| 201 |
int *xp,
| 202 |
int *yp
| 203 |
| 204 |
| 205 |
int c;
| 206 |
| 207 |
putc(COM_GETCUR, devout);
| 208 |
fflush(devout);
| 209 |
if (getc(devin) != COM_GETCUR)
| 210 |
reply_error("getcur");
| 211 |
c = getc(devin);
| 212 |
*xp = getw(devin);
| 213 |
*yp = getw(devin);
| 214 |
return(c);
| 215 |
| 216 |
| 217 |
| 218 |
static void
| 219 |
comm_comout( /* print string to command line */
| 220 |
const char *str
| 221 |
| 222 |
| 223 |
putc(COM_COMOUT, devout);
| 224 |
myputs(str, devout);
| 225 |
if (str[strlen(str)-1] == '\n')
| 226 |
fflush(devout);
| 227 |
| 228 |
| 229 |
| 230 |
static void
| 231 |
comm_comin( /* read string from command line */
| 232 |
char *buf,
| 233 |
char *prompt
| 234 |
| 235 |
| 236 |
putc(COM_COMIN, devout);
| 237 |
if (prompt == NULL)
| 238 |
putc(0, devout);
| 239 |
else {
| 240 |
putc(1, devout);
| 241 |
myputs(prompt, devout);
| 242 |
| 243 |
fflush(devout);
| 244 |
if (getc(devin) != COM_COMIN)
| 245 |
reply_error("comin");
| 246 |
mygets(buf, devin);
| 247 |
getstate();
| 248 |
| 249 |
| 250 |
| 251 |
static void
| 252 |
mygets( /* get string from file (with nul) */
| 253 |
char *s,
| 254 |
FILE *fp
| 255 |
| 256 |
| 257 |
int c;
| 258 |
| 259 |
while ((c = getc(fp)) != EOF)
| 260 |
if ((*s++ = c) == '\0')
| 261 |
return;
| 262 |
*s = '\0';
| 263 |
| 264 |
| 265 |
| 266 |
static void
| 267 |
myputs( /* put string to file (with nul) */
| 268 |
const char *s,
| 269 |
FILE *fp
| 270 |
| 271 |
| 272 |
do
| 273 |
putc(*s, fp);
| 274 |
while (*s++);
| 275 |
| 276 |
| 277 |
| 278 |
static void
| 279 |
reply_error( /* what should we do here? */
| 280 |
char *routine
| 281 |
| 282 |
| 283 |
eputs(routine);
| 284 |
eputs(": driver reply error\n");
| 285 |
quit(1);
| 286 |
| 287 |
| 288 |
| 289 |
static void
| 290 |
getstate(void) /* get driver state variables */
| 291 |
| 292 |
getbinary((char *)&comm_driver.pixaspect,
| 293 |
sizeof(comm_driver.pixaspect), 1, devin);
| 294 |
comm_driver.xsiz = getw(devin);
| 295 |
comm_driver.ysiz = getw(devin);
| 296 |
comm_driver.inpready = getw(devin);
| 297 |
