root/radiance/src/rt/ashikhmin.c
Fri Jun 20 18:05:30 2025 UTC (4 months, 3 weeks ago) by greg
CVS Tags: HEAD, rad6R0
refactor: Changed macros to function type for clarity
Fri Jun 20 16:48:39 2025 UTC (4 months, 3 weeks ago) by greg
fix: Last change would have caused array underrun
Fri Jun 20 16:34:23 2025 UTC (4 months, 3 weeks ago) by greg
fix: Avoid array bounds errors in dimlist[] in deep ray trees
Fri May 23 17:09:26 2025 UTC (5 months, 2 weeks ago) by greg
perf: Removed unnecessary randomization in call to getperpendicular()
Fri Apr 5 01:10:26 2024 UTC (19 months, 1 week ago) by greg
fix: Improved tracking of reflected vs. transmitted rays for antimatter
Wed Nov 15 18:02:52 2023 UTC (23 months, 3 weeks ago) by greg
Changes since 2.6: +29 -29 lines
Wed Sep 2 18:59:01 2015 UTC (10 years, 2 months ago) by greg
CVS Tags: rad5R0, rad5R1, rad5R2, rad5R3, rad5R4
Changes since 2.5: +3 -2 lines
Had to reinstate ambRayInPmap() macro to avoid over-counting bug
Thu May 21 05:54:54 2015 UTC (10 years, 5 months ago) by greg
Thu Dec 4 05:26:28 2014 UTC (10 years, 11 months ago) by greg
Changes since 2.3: +13 -15 lines
Wed Aug 7 05:10:09 2013 UTC (12 years, 3 months ago) by greg
Changes since 2.2: +1 -2 lines
Sun Jul 29 21:56:16 2012 UTC (13 years, 3 months ago) by greg
Changes since 2.1: +20 -26 lines
Bug fixes in Ashikhmin-Shirley and code cleanup
Sun Jul 29 19:01:39 2012 UTC (13 years, 3 months ago) by greg
