| 1 |
greg |
2.1 |
#ifndef lint |
| 2 |
greg |
2.61 |
static const char RCSid[] = "$Id: aniso.c,v 2.60 2015/05/26 13:21:07 greg Exp $"; |
| 3 |
greg |
2.1 |
#endif |
| 4 |
| 5 |
* Shading functions for anisotropic materials. |
| 6 |
| 7 |
| 8 |
greg |
2.35 |
#include "copyright.h" |
| 9 |
greg |
2.34 |
| 10 |
greg |
2.1 |
#include "ray.h" |
| 11 |
greg |
2.40 |
#include "ambient.h" |
| 12 |
greg |
2.1 |
#include "otypes.h" |
| 13 |
schorsch |
2.41 |
#include "rtotypes.h" |
| 14 |
#include "source.h" |
| 15 |
greg |
2.1 |
#include "func.h" |
| 16 |
#include "random.h" |
| 17 |
greg |
2.61 |
#include "pmapmat.h" |
| 18 |
greg |
2.1 |
| 19 |
greg |
2.32 |
#ifndef MAXITER |
| 20 |
#define MAXITER 10 /* maximum # specular ray attempts */ |
| 21 |
#endif |
| 22 |
| 23 |
greg |
2.1 |
| 24 |
greg |
2.22 |
* This routine implements the anisotropic Gaussian |
| 25 |
greg |
2.54 |
* model described by Ward in Siggraph `92 article, updated with |
| 26 |
* normalization and sampling adjustments due to Geisler-Moroder and Duer. |
| 27 |
greg |
2.1 |
* We orient the surface towards the incoming ray, so a single |
| 28 |
* surface can be used to represent an infinitely thin object. |
| 29 |
| 30 |
* Arguments for MAT_PLASTIC2 and MAT_METAL2 are: |
| 31 |
* 4+ ux uy uz funcfile [transform...] |
| 32 |
* 0 |
| 33 |
greg |
2.54 |
* 6 red grn blu specular-frac. u-rough v-rough |
| 34 |
greg |
2.1 |
| 35 |
* Real arguments for MAT_TRANS2 are: |
| 36 |
* 8 red grn blu rspec u-rough v-rough trans tspec |
| 37 |
| 38 |
| 39 |
/* specularity flags */ |
| 40 |
#define SP_REFL 01 /* has reflected specular component */ |
| 41 |
#define SP_TRAN 02 /* has transmitted specular */ |
| 42 |
greg |
2.10 |
#define SP_FLAT 04 /* reflecting surface is flat */ |
| 43 |
#define SP_RBLT 010 /* reflection below sample threshold */ |
| 44 |
#define SP_TBLT 020 /* transmission below threshold */ |
| 45 |
greg |
2.1 |
| 46 |
typedef struct { |
| 47 |
greg |
2.2 |
OBJREC *mp; /* material pointer */ |
| 48 |
greg |
2.1 |
RAY *rp; /* ray pointer */ |
| 49 |
short specfl; /* specularity flags, defined above */ |
| 50 |
COLOR mcolor; /* color of this material */ |
| 51 |
COLOR scolor; /* color of specular component */ |
| 52 |
greg |
2.6 |
FVECT vrefl; /* vector in reflected direction */ |
| 53 |
greg |
2.1 |
FVECT prdir; /* vector in transmitted direction */ |
| 54 |
FVECT u, v; /* u and v vectors orienting anisotropy */ |
| 55 |
greg |
2.18 |
double u_alpha; /* u roughness */ |
| 56 |
double v_alpha; /* v roughness */ |
| 57 |
greg |
2.1 |
double rdiff, rspec; /* reflected specular, diffuse */ |
| 58 |
double trans; /* transmissivity */ |
| 59 |
double tdiff, tspec; /* transmitted specular, diffuse */ |
| 60 |
FVECT pnorm; /* perturbed surface normal */ |
| 61 |
double pdot; /* perturbed dot product */ |
| 62 |
} ANISODAT; /* anisotropic material data */ |
| 63 |
| 64 |
greg |
2.55 |
static void getacoords(ANISODAT *np); |
| 65 |
static void agaussamp(ANISODAT *np); |
| 66 |
greg |
2.34 |
| 67 |
greg |
2.1 |
| 68 |
greg |
2.34 |
static void |
| 69 |
schorsch |
2.41 |
diraniso( /* compute source contribution */ |
| 70 |
COLOR cval, /* returned coefficient */ |
| 71 |
greg |
2.54 |
void *nnp, /* material data */ |
| 72 |
schorsch |
2.41 |
FVECT ldir, /* light source direction */ |
| 73 |
double omega /* light source size */ |
| 74 |
| 75 |
greg |
2.1 |
| 76 |
greg |
2.54 |
ANISODAT *np = nnp; |
| 77 |
greg |
2.1 |
double ldot; |
| 78 |
greg |
2.16 |
double dtmp, dtmp1, dtmp2; |
| 79 |
greg |
2.1 |
FVECT h; |
| 80 |
double au2, av2; |
| 81 |
COLOR ctmp; |
| 82 |
| 83 |
setcolor(cval, 0.0, 0.0, 0.0); |
| 84 |
| 85 |
ldot = DOT(np->pnorm, ldir); |
| 86 |
| 87 |
if (ldot < 0.0 ? np->trans <= FTINY : np->trans >= 1.0-FTINY) |
| 88 |
return; /* wrong side */ |
| 89 |
| 90 |
greg |
2.54 |
if ((ldot > FTINY) & (np->rdiff > FTINY)) { |
| 91 |
greg |
2.1 |
| 92 |
* Compute and add diffuse reflected component to returned |
| 93 |
* color. The diffuse reflected component will always be |
| 94 |
* modified by the color of the material. |
| 95 |
| 96 |
copycolor(ctmp, np->mcolor); |
| 97 |
greg |
2.42 |
dtmp = ldot * omega * np->rdiff * (1.0/PI); |
| 98 |
greg |
2.1 |
scalecolor(ctmp, dtmp); |
| 99 |
addcolor(cval, ctmp); |
| 100 |
| 101 |
greg |
2.58 |
| 102 |
if ((ldot < -FTINY) & (np->tdiff > FTINY)) { |
| 103 |
| 104 |
* Compute diffuse transmission. |
| 105 |
| 106 |
| 107 |
dtmp = -ldot * omega * np->tdiff * (1.0/PI); |
| 108 |
| 109 |
| 110 |
| 111 |
| 112 |
greg |
2.61 |
if (ambRayInPmap(np->rp)) |
| 113 |
return; /* specular accounted for in photon map */ |
| 114 |
| 115 |
greg |
2.57 |
if (ldot > FTINY && np->specfl&SP_REFL) { |
| 116 |
greg |
2.1 |
| 117 |
* Compute specular reflection coefficient using |
| 118 |
greg |
2.46 |
* anisotropic Gaussian distribution model. |
| 119 |
greg |
2.1 |
| 120 |
greg |
2.2 |
/* add source width if flat */ |
| 121 |
if (np->specfl & SP_FLAT) |
| 122 |
greg |
2.42 |
au2 = av2 = omega * (0.25/PI); |
| 123 |
greg |
2.2 |
else |
| 124 |
au2 = av2 = 0.0; |
| 125 |
greg |
2.18 |
au2 += np->u_alpha*np->u_alpha; |
| 126 |
av2 += np->v_alpha*np->v_alpha; |
| 127 |
greg |
2.1 |
/* half vector */ |
| 128 |
greg |
2.54 |
VSUB(h, ldir, np->rp->rdir); |
| 129 |
greg |
2.1 |
/* ellipse */ |
| 130 |
greg |
2.16 |
dtmp1 = DOT(np->u, h); |
| 131 |
dtmp1 *= dtmp1 / au2; |
| 132 |
greg |
2.1 |
dtmp2 = DOT(np->v, h); |
| 133 |
dtmp2 *= dtmp2 / av2; |
| 134 |
greg |
2.46 |
/* new W-G-M-D model */ |
| 135 |
greg |
2.23 |
dtmp = DOT(np->pnorm, h); |
| 136 |
greg |
2.46 |
dtmp *= dtmp; |
| 137 |
dtmp1 = (dtmp1 + dtmp2) / dtmp; |
| 138 |
dtmp = exp(-dtmp1) * DOT(h,h) / |
| 139 |
(PI * dtmp*dtmp * sqrt(au2*av2)); |
| 140 |
greg |
2.1 |
/* worth using? */ |
| 141 |
if (dtmp > FTINY) { |
| 142 |
copycolor(ctmp, np->scolor); |
| 143 |
greg |
2.46 |
dtmp *= ldot * omega; |
| 144 |
greg |
2.1 |
| 145 |
| 146 |
| 147 |
| 148 |
greg |
2.58 |
| 149 |
greg |
2.57 |
if (ldot < -FTINY && np->specfl&SP_TRAN) { |
| 150 |
greg |
2.1 |
| 151 |
* Compute specular transmission. Specular transmission |
| 152 |
* is always modified by material color. |
| 153 |
| 154 |
/* roughness + source */ |
| 155 |
greg |
2.42 |
au2 = av2 = omega * (1.0/PI); |
| 156 |
greg |
2.18 |
| 157 |
| 158 |
greg |
2.16 |
/* "half vector" */ |
| 159 |
greg |
2.54 |
VSUB(h, ldir, np->prdir); |
| 160 |
greg |
2.19 |
dtmp = DOT(h,h); |
| 161 |
greg |
2.16 |
if (dtmp > FTINY*FTINY) { |
| 162 |
greg |
2.19 |
dtmp1 = DOT(h,np->pnorm); |
| 163 |
dtmp = 1.0 - dtmp1*dtmp1/dtmp; |
| 164 |
| 165 |
dtmp1 = DOT(h,np->u); |
| 166 |
greg |
2.23 |
| 167 |
greg |
2.19 |
dtmp2 = DOT(h,np->v); |
| 168 |
greg |
2.23 |
| 169 |
greg |
2.19 |
dtmp = (dtmp1 + dtmp2) / dtmp; |
| 170 |
| 171 |
greg |
2.16 |
} else |
| 172 |
dtmp = 0.0; |
| 173 |
greg |
2.46 |
/* Gaussian */ |
| 174 |
greg |
2.44 |
dtmp = exp(-dtmp) * (1.0/PI) * sqrt(-ldot/(np->pdot*au2*av2)); |
| 175 |
greg |
2.1 |
| 176 |
| 177 |
| 178 |
greg |
2.16 |
dtmp *= np->tspec * omega; |
| 179 |
greg |
2.1 |
| 180 |
| 181 |
| 182 |
| 183 |
| 184 |
| 185 |
| 186 |
greg |
2.54 |
int |
| 187 |
schorsch |
2.41 |
m_aniso( /* shade ray that hit something anisotropic */ |
| 188 |
greg |
2.54 |
OBJREC *m, |
| 189 |
RAY *r |
| 190 |
schorsch |
2.41 |
| 191 |
greg |
2.1 |
| 192 |
ANISODAT nd; |
| 193 |
COLOR ctmp; |
| 194 |
greg |
2.54 |
int i; |
| 195 |
greg |
2.1 |
/* easy shadow test */ |
| 196 |
greg |
2.10 |
if (r->crtype & SHADOW) |
| 197 |
greg |
2.27 |
return(1); |
| 198 |
greg |
2.1 |
| 199 |
if (m->oargs.nfargs != (m->otype == MAT_TRANS2 ? 8 : 6)) |
| 200 |
objerror(m, USER, "bad number of real arguments"); |
| 201 |
greg |
2.36 |
/* check for back side */ |
| 202 |
if (r->rod < 0.0) { |
| 203 |
greg |
2.56 |
if (!backvis) { |
| 204 |
greg |
2.36 |
raytrans(r); |
| 205 |
return(1); |
| 206 |
| 207 |
raytexture(r, m->omod); |
| 208 |
flipsurface(r); /* reorient if backvis */ |
| 209 |
} else |
| 210 |
| 211 |
/* get material color */ |
| 212 |
greg |
2.2 |
nd.mp = m; |
| 213 |
greg |
2.1 |
nd.rp = r; |
| 214 |
setcolor(nd.mcolor, m->oargs.farg[0], |
| 215 |
m->oargs.farg[1], |
| 216 |
m->oargs.farg[2]); |
| 217 |
/* get roughness */ |
| 218 |
nd.specfl = 0; |
| 219 |
greg |
2.18 |
nd.u_alpha = m->oargs.farg[4]; |
| 220 |
nd.v_alpha = m->oargs.farg[5]; |
| 221 |
greg |
2.54 |
if ((nd.u_alpha <= FTINY) | (nd.v_alpha <= FTINY)) |
| 222 |
greg |
2.10 |
objerror(m, USER, "roughness too small"); |
| 223 |
greg |
2.36 |
| 224 |
greg |
2.1 |
nd.pdot = raynormal(nd.pnorm, r); /* perturb normal */ |
| 225 |
if (nd.pdot < .001) |
| 226 |
nd.pdot = .001; /* non-zero for diraniso() */ |
| 227 |
multcolor(nd.mcolor, r->pcol); /* modify material color */ |
| 228 |
/* get specular component */ |
| 229 |
if ((nd.rspec = m->oargs.farg[3]) > FTINY) { |
| 230 |
nd.specfl |= SP_REFL; |
| 231 |
/* compute specular color */ |
| 232 |
if (m->otype == MAT_METAL2) |
| 233 |
copycolor(nd.scolor, nd.mcolor); |
| 234 |
else |
| 235 |
setcolor(nd.scolor, 1.0, 1.0, 1.0); |
| 236 |
scalecolor(nd.scolor, nd.rspec); |
| 237 |
greg |
2.4 |
/* check threshold */ |
| 238 |
greg |
2.25 |
if (specthresh >= nd.rspec-FTINY) |
| 239 |
greg |
2.4 |
nd.specfl |= SP_RBLT; |
| 240 |
greg |
2.6 |
/* compute refl. direction */ |
| 241 |
greg |
2.47 |
VSUM(nd.vrefl, r->rdir, nd.pnorm, 2.0*nd.pdot); |
| 242 |
greg |
2.6 |
if (DOT(nd.vrefl, r->ron) <= FTINY) /* penetration? */ |
| 243 |
greg |
2.47 |
VSUM(nd.vrefl, r->rdir, r->ron, 2.0*r->rod); |
| 244 |
greg |
2.1 |
| 245 |
/* compute transmission */ |
| 246 |
greg |
2.16 |
if (m->otype == MAT_TRANS2) { |
| 247 |
greg |
2.1 |
nd.trans = m->oargs.farg[6]*(1.0 - nd.rspec); |
| 248 |
nd.tspec = nd.trans * m->oargs.farg[7]; |
| 249 |
nd.tdiff = nd.trans - nd.tspec; |
| 250 |
if (nd.tspec > FTINY) { |
| 251 |
nd.specfl |= SP_TRAN; |
| 252 |
greg |
2.4 |
| 253 |
greg |
2.25 |
if (specthresh >= nd.tspec-FTINY) |
| 254 |
greg |
2.4 |
nd.specfl |= SP_TBLT; |
| 255 |
greg |
2.10 |
if (DOT(r->pert,r->pert) <= FTINY*FTINY) { |
| 256 |
greg |
2.1 |
VCOPY(nd.prdir, r->rdir); |
| 257 |
} else { |
| 258 |
for (i = 0; i < 3; i++) /* perturb */ |
| 259 |
greg |
2.17 |
nd.prdir[i] = r->rdir[i] - r->pert[i]; |
| 260 |
greg |
2.6 |
if (DOT(nd.prdir, r->ron) < -FTINY) |
| 261 |
normalize(nd.prdir); /* OK */ |
| 262 |
else |
| 263 |
| 264 |
greg |
2.1 |
| 265 |
| 266 |
} else |
| 267 |
nd.tdiff = nd.tspec = nd.trans = 0.0; |
| 268 |
| 269 |
/* diffuse reflection */ |
| 270 |
nd.rdiff = 1.0 - nd.trans - nd.rspec; |
| 271 |
| 272 |
greg |
2.39 |
if (r->ro != NULL && isflat(r->ro->otype)) |
| 273 |
greg |
2.4 |
nd.specfl |= SP_FLAT; |
| 274 |
| 275 |
greg |
2.55 |
getacoords(&nd); /* set up coordinates */ |
| 276 |
greg |
2.1 |
| 277 |
greg |
2.60 |
if (nd.specfl & (SP_REFL|SP_TRAN)) |
| 278 |
greg |
2.55 |
agaussamp(&nd); |
| 279 |
greg |
2.1 |
| 280 |
if (nd.rdiff > FTINY) { /* ambient from this side */ |
| 281 |
greg |
2.43 |
copycolor(ctmp, nd.mcolor); /* modified by material color */ |
| 282 |
greg |
2.52 |
scalecolor(ctmp, nd.rdiff); |
| 283 |
if (nd.specfl & SP_RBLT) /* add in specular as well? */ |
| 284 |
addcolor(ctmp, nd.scolor); |
| 285 |
greg |
2.43 |
multambient(ctmp, r, nd.pnorm); |
| 286 |
greg |
2.1 |
addcolor(r->rcol, ctmp); /* add to returned color */ |
| 287 |
| 288 |
greg |
2.58 |
| 289 |
greg |
2.1 |
if (nd.tdiff > FTINY) { /* ambient from other side */ |
| 290 |
greg |
2.31 |
FVECT bnorm; |
| 291 |
| 292 |
greg |
2.1 |
flipsurface(r); |
| 293 |
greg |
2.31 |
bnorm[0] = -nd.pnorm[0]; |
| 294 |
bnorm[1] = -nd.pnorm[1]; |
| 295 |
bnorm[2] = -nd.pnorm[2]; |
| 296 |
greg |
2.43 |
copycolor(ctmp, nd.mcolor); /* modified by color */ |
| 297 |
greg |
2.4 |
if (nd.specfl & SP_TBLT) |
| 298 |
scalecolor(ctmp, nd.trans); |
| 299 |
else |
| 300 |
scalecolor(ctmp, nd.tdiff); |
| 301 |
greg |
2.43 |
multambient(ctmp, r, bnorm); |
| 302 |
greg |
2.1 |
addcolor(r->rcol, ctmp); |
| 303 |
flipsurface(r); |
| 304 |
| 305 |
/* add direct component */ |
| 306 |
direct(r, diraniso, &nd); |
| 307 |
greg |
2.27 |
| 308 |
return(1); |
| 309 |
greg |
2.1 |
| 310 |
| 311 |
greg |
2.34 |
static void |
| 312 |
schorsch |
2.41 |
getacoords( /* set up coordinate system */ |
| 313 |
greg |
2.54 |
ANISODAT *np |
| 314 |
schorsch |
2.41 |
| 315 |
greg |
2.1 |
| 316 |
greg |
2.54 |
MFUNC *mf; |
| 317 |
int i; |
| 318 |
greg |
2.1 |
| 319 |
mf = getfunc(np->mp, 3, 0x7, 1); |
| 320 |
greg |
2.55 |
setfunc(np->mp, np->rp); |
| 321 |
greg |
2.1 |
errno = 0; |
| 322 |
for (i = 0; i < 3; i++) |
| 323 |
np->u[i] = evalue(mf->ep[i]); |
| 324 |
greg |
2.57 |
if ((errno == EDOM) | (errno == ERANGE)) |
| 325 |
np->u[0] = np->u[1] = np->u[2] = 0.0; |
| 326 |
greg |
2.53 |
if (mf->fxp != &unitxf) |
| 327 |
multv3(np->u, np->u, mf->fxp->xfm); |
| 328 |
greg |
2.1 |
fcross(np->v, np->pnorm, np->u); |
| 329 |
if (normalize(np->v) == 0.0) { |
| 330 |
greg |
2.57 |
if (fabs(np->u_alpha - np->v_alpha) > 0.001) |
| 331 |
objerror(np->mp, WARNING, "illegal orientation vector"); |
| 332 |
greg |
2.59 |
getperpendicular(np->u, np->pnorm, 1); /* punting */ |
| 333 |
greg |
2.57 |
| 334 |
np->u_alpha = np->v_alpha = sqrt( 0.5 * |
| 335 |
(np->u_alpha*np->u_alpha + np->v_alpha*np->v_alpha) ); |
| 336 |
} else |
| 337 |
fcross(np->u, np->v, np->pnorm); |
| 338 |
greg |
2.1 |
| 339 |
| 340 |
| 341 |
greg |
2.34 |
static void |
| 342 |
greg |
2.46 |
agaussamp( /* sample anisotropic Gaussian specular */ |
| 343 |
greg |
2.54 |
ANISODAT *np |
| 344 |
schorsch |
2.41 |
| 345 |
greg |
2.1 |
| 346 |
RAY sr; |
| 347 |
FVECT h; |
| 348 |
double rv[2]; |
| 349 |
double d, sinp, cosp; |
| 350 |
greg |
2.47 |
COLOR scol; |
| 351 |
greg |
2.50 |
int maxiter, ntrials, nstarget, nstaken; |
| 352 |
greg |
2.54 |
int i; |
| 353 |
greg |
2.1 |
/* compute reflection */ |
| 354 |
greg |
2.4 |
if ((np->specfl & (SP_REFL|SP_RBLT)) == SP_REFL && |
| 355 |
greg |
2.55 |
rayorigin(&sr, SPECULAR, np->rp, np->scolor) == 0) { |
| 356 |
greg |
2.50 |
nstarget = 1; |
| 357 |
greg |
2.47 |
if (specjitter > 1.5) { /* multiple samples? */ |
| 358 |
greg |
2.55 |
nstarget = specjitter*np->rp->rweight + .5; |
| 359 |
greg |
2.50 |
if (sr.rweight <= minweight*nstarget) |
| 360 |
nstarget = sr.rweight/minweight; |
| 361 |
if (nstarget > 1) { |
| 362 |
d = 1./nstarget; |
| 363 |
scalecolor(sr.rcoef, d); |
| 364 |
greg |
2.48 |
sr.rweight *= d; |
| 365 |
greg |
2.47 |
} else |
| 366 |
greg |
2.50 |
nstarget = 1; |
| 367 |
greg |
2.47 |
| 368 |
greg |
2.50 |
setcolor(scol, 0., 0., 0.); |
| 369 |
greg |
2.51 |
dimlist[ndims++] = (int)(size_t)np->mp; |
| 370 |
greg |
2.50 |
maxiter = MAXITER*nstarget; |
| 371 |
for (nstaken = ntrials = 0; nstaken < nstarget && |
| 372 |
ntrials < maxiter; ntrials++) { |
| 373 |
if (ntrials) |
| 374 |
greg |
2.32 |
d = frandom(); |
| 375 |
else |
| 376 |
d = urand(ilhash(dimlist,ndims)+samplendx); |
| 377 |
multisamp(rv, 2, d); |
| 378 |
d = 2.0*PI * rv[0]; |
| 379 |
gwlarson |
2.33 |
cosp = tcos(d) * np->u_alpha; |
| 380 |
sinp = tsin(d) * np->v_alpha; |
| 381 |
greg |
2.47 |
d = 1./sqrt(cosp*cosp + sinp*sinp); |
| 382 |
cosp *= d; |
| 383 |
sinp *= d; |
| 384 |
if ((0. <= specjitter) & (specjitter < 1.)) |
| 385 |
rv[1] = 1.0 - specjitter*rv[1]; |
| 386 |
greg |
2.32 |
if (rv[1] <= FTINY) |
| 387 |
d = 1.0; |
| 388 |
else |
| 389 |
d = sqrt(-log(rv[1]) / |
| 390 |
(cosp*cosp/(np->u_alpha*np->u_alpha) + |
| 391 |
sinp*sinp/(np->v_alpha*np->v_alpha))); |
| 392 |
| 393 |
h[i] = np->pnorm[i] + |
| 394 |
d*(cosp*np->u[i] + sinp*np->v[i]); |
| 395 |
greg |
2.55 |
d = -2.0 * DOT(h, np->rp->rdir) / (1.0 + d*d); |
| 396 |
VSUM(sr.rdir, np->rp->rdir, h, d); |
| 397 |
greg |
2.50 |
/* sample rejection test */ |
| 398 |
greg |
2.55 |
if ((d = DOT(sr.rdir, np->rp->ron)) <= FTINY) |
| 399 |
greg |
2.47 |
continue; |
| 400 |
checknorm(sr.rdir); |
| 401 |
greg |
2.50 |
if (nstarget > 1) { /* W-G-M-D adjustment */ |
| 402 |
if (nstaken) rayclear(&sr); |
| 403 |
rayvalue(&sr); |
| 404 |
greg |
2.55 |
d = 2./(1. + np->rp->rod/d); |
| 405 |
greg |
2.50 |
scalecolor(sr.rcol, d); |
| 406 |
addcolor(scol, sr.rcol); |
| 407 |
} else { |
| 408 |
rayvalue(&sr); |
| 409 |
multcolor(sr.rcol, sr.rcoef); |
| 410 |
greg |
2.55 |
addcolor(np->rp->rcol, sr.rcol); |
| 411 |
greg |
2.32 |
| 412 |
greg |
2.50 |
++nstaken; |
| 413 |
| 414 |
if (nstarget > 1) { /* final W-G-M-D weighting */ |
| 415 |
multcolor(scol, sr.rcoef); |
| 416 |
d = (double)nstarget/ntrials; |
| 417 |
scalecolor(scol, d); |
| 418 |
greg |
2.55 |
addcolor(np->rp->rcol, scol); |
| 419 |
greg |
2.32 |
| 420 |
greg |
2.1 |
ndims--; |
| 421 |
| 422 |
| 423 |
greg |
2.43 |
copycolor(sr.rcoef, np->mcolor); /* modify by material color */ |
| 424 |
scalecolor(sr.rcoef, np->tspec); |
| 425 |
greg |
2.7 |
if ((np->specfl & (SP_TRAN|SP_TBLT)) == SP_TRAN && |
| 426 |
greg |
2.55 |
rayorigin(&sr, SPECULAR, np->rp, sr.rcoef) == 0) { |
| 427 |
greg |
2.50 |
nstarget = 1; |
| 428 |
greg |
2.47 |
| 429 |
greg |
2.55 |
| 430 |
greg |
2.50 |
| 431 |
| 432 |
| 433 |
d = 1./nstarget; |
| 434 |
greg |
2.48 |
| 435 |
sr.rweight *= d; |
| 436 |
greg |
2.47 |
} else |
| 437 |
greg |
2.50 |
nstarget = 1; |
| 438 |
greg |
2.47 |
| 439 |
greg |
2.51 |
| 440 |
greg |
2.50 |
| 441 |
| 442 |
| 443 |
if (ntrials) |
| 444 |
greg |
2.32 |
d = frandom(); |
| 445 |
else |
| 446 |
d = urand(ilhash(dimlist,ndims)+1823+samplendx); |
| 447 |
| 448 |
| 449 |
gwlarson |
2.33 |
| 450 |
| 451 |
greg |
2.47 |
| 452 |
cosp *= d; |
| 453 |
sinp *= d; |
| 454 |
| 455 |
| 456 |
greg |
2.32 |
| 457 |
d = 1.0; |
| 458 |
else |
| 459 |
| 460 |
| 461 |
gwlarson |
2.33 |
| 462 |
greg |
2.32 |
| 463 |
sr.rdir[i] = np->prdir[i] + |
| 464 |
| 465 |
greg |
2.55 |
if (DOT(sr.rdir, np->rp->ron) >= -FTINY) |
| 466 |
greg |
2.47 |
continue; |
| 467 |
normalize(sr.rdir); /* OK, normalize */ |
| 468 |
greg |
2.50 |
if (nstaken) /* multi-sampling */ |
| 469 |
greg |
2.47 |
rayclear(&sr); |
| 470 |
rayvalue(&sr); |
| 471 |
| 472 |
greg |
2.55 |
| 473 |
greg |
2.50 |
++nstaken; |
| 474 |
greg |
2.32 |
| 475 |
greg |
2.7 |
ndims--; |
| 476 |
| 477 |
greg |
2.1 |
