| 1 | #ifndef lint |
| 2 | static const char RCSid[] = "$Id: aniso.c,v 2.42 2004/09/20 17:32:04 greg Exp $"; |
| 3 | #endif |
| 4 | /* |
| 5 | *  Shading functions for anisotropic materials. |
| 6 | */ |
| 7 |  |
| 8 | #include "copyright.h" |
| 9 |  |
| 10 | #include  "ray.h" |
| 11 | #include  "ambient.h" |
| 12 | #include  "otypes.h" |
| 13 | #include  "rtotypes.h" |
| 14 | #include  "source.h" |
| 15 | #include  "func.h" |
| 16 | #include  "random.h" |
| 17 |  |
| 18 | #ifndef  MAXITER |
| 19 | #define  MAXITER        10              /* maximum # specular ray attempts */ |
| 20 | #endif |
| 21 |  |
| 22 | /* |
| 23 | *      This routine implements the anisotropic Gaussian |
| 24 | *  model described by Ward in Siggraph `92 article. |
| 25 | *      We orient the surface towards the incoming ray, so a single |
| 26 | *  surface can be used to represent an infinitely thin object. |
| 27 | * |
| 28 | *  Arguments for MAT_PLASTIC2 and MAT_METAL2 are: |
| 29 | *  4+ ux       uy      uz      funcfile        [transform...] |
| 30 | *  0 |
| 31 | *  6  red      grn     blu     specular-frac.  u-facet-slope v-facet-slope |
| 32 | * |
| 33 | *  Real arguments for MAT_TRANS2 are: |
| 34 | *  8  red      grn     blu     rspec   u-rough v-rough trans   tspec |
| 35 | */ |
| 36 |  |
| 37 | /* specularity flags */ |
| 38 | #define  SP_REFL        01              /* has reflected specular component */ |
| 39 | #define  SP_TRAN        02              /* has transmitted specular */ |
| 40 | #define  SP_FLAT        04              /* reflecting surface is flat */ |
| 41 | #define  SP_RBLT        010             /* reflection below sample threshold */ |
| 42 | #define  SP_TBLT        020             /* transmission below threshold */ |
| 43 | #define  SP_BADU        040             /* bad u direction calculation */ |
| 44 |  |
| 45 | typedef struct { |
| 46 | OBJREC  *mp;            /* material pointer */ |
| 47 | RAY  *rp;               /* ray pointer */ |
| 48 | short  specfl;          /* specularity flags, defined above */ |
| 49 | COLOR  mcolor;          /* color of this material */ |
| 50 | COLOR  scolor;          /* color of specular component */ |
| 51 | FVECT  vrefl;           /* vector in reflected direction */ |
| 52 | FVECT  prdir;           /* vector in transmitted direction */ |
| 53 | FVECT  u, v;            /* u and v vectors orienting anisotropy */ |
| 54 | double  u_alpha;        /* u roughness */ |
| 55 | double  v_alpha;        /* v roughness */ |
| 56 | double  rdiff, rspec;   /* reflected specular, diffuse */ |
| 57 | double  trans;          /* transmissivity */ |
| 58 | double  tdiff, tspec;   /* transmitted specular, diffuse */ |
| 59 | FVECT  pnorm;           /* perturbed surface normal */ |
| 60 | double  pdot;           /* perturbed dot product */ |
| 61 | }  ANISODAT;            /* anisotropic material data */ |
| 62 |  |
| 63 | static srcdirf_t diraniso; |
| 64 | static void getacoords(RAY  *r, ANISODAT  *np); |
| 65 | static void agaussamp(RAY  *r, ANISODAT  *np); |
| 66 |  |
| 67 |  |
| 68 | static void |
| 69 | diraniso(               /* compute source contribution */ |
| 70 | COLOR  cval,                    /* returned coefficient */ |
| 71 | void  *nnp,             /* material data */ |
| 72 | FVECT  ldir,                    /* light source direction */ |
| 73 | double  omega                   /* light source size */ |
| 74 | ) |
| 75 | { |
| 76 | register ANISODAT *np = nnp; |
| 77 | double  ldot; |
| 78 | double  dtmp, dtmp1, dtmp2; |
| 79 | FVECT  h; |
| 80 | double  au2, av2; |
| 81 | COLOR  ctmp; |
| 82 |  |
| 83 | setcolor(cval, 0.0, 0.0, 0.0); |
| 84 |  |
| 85 | ldot = DOT(np->pnorm, ldir); |
| 86 |  |
| 87 | if (ldot < 0.0 ? np->trans <= FTINY : np->trans >= 1.0-FTINY) |
| 88 | return;         /* wrong side */ |
| 89 |  |
| 90 | if (ldot > FTINY && np->rdiff > FTINY) { |
| 91 | /* |
| 92 | *  Compute and add diffuse reflected component to returned |
| 93 | *  color.  The diffuse reflected component will always be |
| 94 | *  modified by the color of the material. |
| 95 | */ |
| 96 | copycolor(ctmp, np->mcolor); |
| 97 | dtmp = ldot * omega * np->rdiff * (1.0/PI); |
| 98 | scalecolor(ctmp, dtmp); |
| 99 | addcolor(cval, ctmp); |
| 100 | } |
| 101 | if (ldot > FTINY && (np->specfl&(SP_REFL|SP_BADU)) == SP_REFL) { |
| 102 | /* |
| 103 | *  Compute specular reflection coefficient using |
| 104 | *  anisotropic gaussian distribution model. |
| 105 | */ |
| 106 | /* add source width if flat */ |
| 107 | if (np->specfl & SP_FLAT) |
| 108 | au2 = av2 = omega * (0.25/PI); |
| 109 | else |
| 110 | au2 = av2 = 0.0; |
| 111 | au2 += np->u_alpha*np->u_alpha; |
| 112 | av2 += np->v_alpha*np->v_alpha; |
| 113 | /* half vector */ |
| 114 | h[0] = ldir[0] - np->rp->rdir[0]; |
| 115 | h[1] = ldir[1] - np->rp->rdir[1]; |
| 116 | h[2] = ldir[2] - np->rp->rdir[2]; |
| 117 | /* ellipse */ |
| 118 | dtmp1 = DOT(np->u, h); |
| 119 | dtmp1 *= dtmp1 / au2; |
| 120 | dtmp2 = DOT(np->v, h); |
| 121 | dtmp2 *= dtmp2 / av2; |
| 122 | /* gaussian */ |
| 123 | dtmp = DOT(np->pnorm, h); |
| 124 | dtmp = (dtmp1 + dtmp2) / (dtmp*dtmp); |
| 125 | dtmp = exp(-dtmp) / (4.0*PI * np->pdot * sqrt(au2*av2)); |
| 126 | /* worth using? */ |
| 127 | if (dtmp > FTINY) { |
| 128 | copycolor(ctmp, np->scolor); |
| 129 | dtmp *= omega; |
| 130 | scalecolor(ctmp, dtmp); |
| 131 | addcolor(cval, ctmp); |
| 132 | } |
| 133 | } |
| 134 | if (ldot < -FTINY && np->tdiff > FTINY) { |
| 135 | /* |
| 136 | *  Compute diffuse transmission. |
| 137 | */ |
| 138 | copycolor(ctmp, np->mcolor); |
| 139 | dtmp = -ldot * omega * np->tdiff * (1.0/PI); |
| 140 | scalecolor(ctmp, dtmp); |
| 141 | addcolor(cval, ctmp); |
| 142 | } |
| 143 | if (ldot < -FTINY && (np->specfl&(SP_TRAN|SP_BADU)) == SP_TRAN) { |
| 144 | /* |
| 145 | *  Compute specular transmission.  Specular transmission |
| 146 | *  is always modified by material color. |
| 147 | */ |
| 148 | /* roughness + source */ |
| 149 | au2 = av2 = omega * (1.0/PI); |
| 150 | au2 += np->u_alpha*np->u_alpha; |
| 151 | av2 += np->v_alpha*np->v_alpha; |
| 152 | /* "half vector" */ |
| 153 | h[0] = ldir[0] - np->prdir[0]; |
| 154 | h[1] = ldir[1] - np->prdir[1]; |
| 155 | h[2] = ldir[2] - np->prdir[2]; |
| 156 | dtmp = DOT(h,h); |
| 157 | if (dtmp > FTINY*FTINY) { |
| 158 | dtmp1 = DOT(h,np->pnorm); |
| 159 | dtmp = 1.0 - dtmp1*dtmp1/dtmp; |
| 160 | if (dtmp > FTINY*FTINY) { |
| 161 | dtmp1 = DOT(h,np->u); |
| 162 | dtmp1 *= dtmp1 / au2; |
| 163 | dtmp2 = DOT(h,np->v); |
| 164 | dtmp2 *= dtmp2 / av2; |
| 165 | dtmp = (dtmp1 + dtmp2) / dtmp; |
| 166 | } |
| 167 | } else |
| 168 | dtmp = 0.0; |
| 169 | /* gaussian */ |
| 170 | dtmp = exp(-dtmp) / (PI * np->pdot * sqrt(au2*av2)); |
| 171 | /* worth using? */ |
| 172 | if (dtmp > FTINY) { |
| 173 | copycolor(ctmp, np->mcolor); |
| 174 | dtmp *= np->tspec * omega; |
| 175 | scalecolor(ctmp, dtmp); |
| 176 | addcolor(cval, ctmp); |
| 177 | } |
| 178 | } |
| 179 | } |
| 180 |  |
| 181 |  |
| 182 | extern int |
| 183 | m_aniso(                        /* shade ray that hit something anisotropic */ |
| 184 | register OBJREC  *m, |
| 185 | register RAY  *r |
| 186 | ) |
| 187 | { |
| 188 | ANISODAT  nd; |
| 189 | COLOR  ctmp; |
| 190 | register int  i; |
| 191 | /* easy shadow test */ |
| 192 | if (r->crtype & SHADOW) |
| 193 | return(1); |
| 194 |  |
| 195 | if (m->oargs.nfargs != (m->otype == MAT_TRANS2 ? 8 : 6)) |
| 196 | objerror(m, USER, "bad number of real arguments"); |
| 197 | /* check for back side */ |
| 198 | if (r->rod < 0.0) { |
| 199 | if (!backvis && m->otype != MAT_TRANS2) { |
| 200 | raytrans(r); |
| 201 | return(1); |
| 202 | } |
| 203 | raytexture(r, m->omod); |
| 204 | flipsurface(r);                 /* reorient if backvis */ |
| 205 | } else |
| 206 | raytexture(r, m->omod); |
| 207 | /* get material color */ |
| 208 | nd.mp = m; |
| 209 | nd.rp = r; |
| 210 | setcolor(nd.mcolor, m->oargs.farg[0], |
| 211 | m->oargs.farg[1], |
| 212 | m->oargs.farg[2]); |
| 213 | /* get roughness */ |
| 214 | nd.specfl = 0; |
| 215 | nd.u_alpha = m->oargs.farg[4]; |
| 216 | nd.v_alpha = m->oargs.farg[5]; |
| 217 | if (nd.u_alpha < FTINY || nd.v_alpha <= FTINY) |
| 218 | objerror(m, USER, "roughness too small"); |
| 219 |  |
| 220 | nd.pdot = raynormal(nd.pnorm, r);       /* perturb normal */ |
| 221 | if (nd.pdot < .001) |
| 222 | nd.pdot = .001;                 /* non-zero for diraniso() */ |
| 223 | multcolor(nd.mcolor, r->pcol);          /* modify material color */ |
| 224 | /* get specular component */ |
| 225 | if ((nd.rspec = m->oargs.farg[3]) > FTINY) { |
| 226 | nd.specfl |= SP_REFL; |
| 227 | /* compute specular color */ |
| 228 | if (m->otype == MAT_METAL2) |
| 229 | copycolor(nd.scolor, nd.mcolor); |
| 230 | else |
| 231 | setcolor(nd.scolor, 1.0, 1.0, 1.0); |
| 232 | scalecolor(nd.scolor, nd.rspec); |
| 233 | /* check threshold */ |
| 234 | if (specthresh >= nd.rspec-FTINY) |
| 235 | nd.specfl |= SP_RBLT; |
| 236 | /* compute refl. direction */ |
| 237 | for (i = 0; i < 3; i++) |
| 238 | nd.vrefl[i] = r->rdir[i] + 2.0*nd.pdot*nd.pnorm[i]; |
| 239 | if (DOT(nd.vrefl, r->ron) <= FTINY)     /* penetration? */ |
| 240 | for (i = 0; i < 3; i++)         /* safety measure */ |
| 241 | nd.vrefl[i] = r->rdir[i] + 2.*r->rod*r->ron[i]; |
| 242 | } |
| 243 | /* compute transmission */ |
| 244 | if (m->otype == MAT_TRANS2) { |
| 245 | nd.trans = m->oargs.farg[6]*(1.0 - nd.rspec); |
| 246 | nd.tspec = nd.trans * m->oargs.farg[7]; |
| 247 | nd.tdiff = nd.trans - nd.tspec; |
| 248 | if (nd.tspec > FTINY) { |
| 249 | nd.specfl |= SP_TRAN; |
| 250 | /* check threshold */ |
| 251 | if (specthresh >= nd.tspec-FTINY) |
| 252 | nd.specfl |= SP_TBLT; |
| 253 | if (DOT(r->pert,r->pert) <= FTINY*FTINY) { |
| 254 | VCOPY(nd.prdir, r->rdir); |
| 255 | } else { |
| 256 | for (i = 0; i < 3; i++)         /* perturb */ |
| 257 | nd.prdir[i] = r->rdir[i] - r->pert[i]; |
| 258 | if (DOT(nd.prdir, r->ron) < -FTINY) |
| 259 | normalize(nd.prdir);    /* OK */ |
| 260 | else |
| 261 | VCOPY(nd.prdir, r->rdir); |
| 262 | } |
| 263 | } |
| 264 | } else |
| 265 | nd.tdiff = nd.tspec = nd.trans = 0.0; |
| 266 |  |
| 267 | /* diffuse reflection */ |
| 268 | nd.rdiff = 1.0 - nd.trans - nd.rspec; |
| 269 |  |
| 270 | if (r->ro != NULL && isflat(r->ro->otype)) |
| 271 | nd.specfl |= SP_FLAT; |
| 272 |  |
| 273 | getacoords(r, &nd);                     /* set up coordinates */ |
| 274 |  |
| 275 | if (nd.specfl & (SP_REFL|SP_TRAN) && !(nd.specfl & SP_BADU)) |
| 276 | agaussamp(r, &nd); |
| 277 |  |
| 278 | if (nd.rdiff > FTINY) {         /* ambient from this side */ |
| 279 | copycolor(ctmp, nd.mcolor);     /* modified by material color */ |
| 280 | if (nd.specfl & SP_RBLT) |
| 281 | scalecolor(ctmp, 1.0-nd.trans); |
| 282 | else |
| 283 | scalecolor(ctmp, nd.rdiff); |
| 284 | multambient(ctmp, r, nd.pnorm); |
| 285 | addcolor(r->rcol, ctmp);        /* add to returned color */ |
| 286 | } |
| 287 | if (nd.tdiff > FTINY) {         /* ambient from other side */ |
| 288 | FVECT  bnorm; |
| 289 |  |
| 290 | flipsurface(r); |
| 291 | bnorm[0] = -nd.pnorm[0]; |
| 292 | bnorm[1] = -nd.pnorm[1]; |
| 293 | bnorm[2] = -nd.pnorm[2]; |
| 294 | copycolor(ctmp, nd.mcolor);     /* modified by color */ |
| 295 | if (nd.specfl & SP_TBLT) |
| 296 | scalecolor(ctmp, nd.trans); |
| 297 | else |
| 298 | scalecolor(ctmp, nd.tdiff); |
| 299 | multambient(ctmp, r, bnorm); |
| 300 | addcolor(r->rcol, ctmp); |
| 301 | flipsurface(r); |
| 302 | } |
| 303 | /* add direct component */ |
| 304 | direct(r, diraniso, &nd); |
| 305 |  |
| 306 | return(1); |
| 307 | } |
| 308 |  |
| 309 |  |
| 310 | static void |
| 311 | getacoords(             /* set up coordinate system */ |
| 312 | RAY  *r, |
| 313 | register ANISODAT  *np |
| 314 | ) |
| 315 | { |
| 316 | register MFUNC  *mf; |
| 317 | register int  i; |
| 318 |  |
| 319 | mf = getfunc(np->mp, 3, 0x7, 1); |
| 320 | setfunc(np->mp, r); |
| 321 | errno = 0; |
| 322 | for (i = 0; i < 3; i++) |
| 323 | np->u[i] = evalue(mf->ep[i]); |
| 324 | if (errno == EDOM || errno == ERANGE) { |
| 325 | objerror(np->mp, WARNING, "compute error"); |
| 326 | np->specfl |= SP_BADU; |
| 327 | return; |
| 328 | } |
| 329 | if (mf->f != &unitxf) |
| 330 | multv3(np->u, np->u, mf->f->xfm); |
| 331 | fcross(np->v, np->pnorm, np->u); |
| 332 | if (normalize(np->v) == 0.0) { |
| 333 | objerror(np->mp, WARNING, "illegal orientation vector"); |
| 334 | np->specfl |= SP_BADU; |
| 335 | return; |
| 336 | } |
| 337 | fcross(np->u, np->v, np->pnorm); |
| 338 | } |
| 339 |  |
| 340 |  |
| 341 | static void |
| 342 | agaussamp(              /* sample anisotropic gaussian specular */ |
| 343 | RAY  *r, |
| 344 | register ANISODAT  *np |
| 345 | ) |
| 346 | { |
| 347 | RAY  sr; |
| 348 | FVECT  h; |
| 349 | double  rv[2]; |
| 350 | double  d, sinp, cosp; |
| 351 | int  niter; |
| 352 | register int  i; |
| 353 | /* compute reflection */ |
| 354 | if ((np->specfl & (SP_REFL|SP_RBLT)) == SP_REFL && |
| 355 | rayorigin(&sr, SPECULAR, r, np->scolor) == 0) { |
| 356 | dimlist[ndims++] = (int)np->mp; |
| 357 | for (niter = 0; niter < MAXITER; niter++) { |
| 358 | if (niter) |
| 359 | d = frandom(); |
| 360 | else |
| 361 | d = urand(ilhash(dimlist,ndims)+samplendx); |
| 362 | multisamp(rv, 2, d); |
| 363 | d = 2.0*PI * rv[0]; |
| 364 | cosp = tcos(d) * np->u_alpha; |
| 365 | sinp = tsin(d) * np->v_alpha; |
| 366 | d = sqrt(cosp*cosp + sinp*sinp); |
| 367 | cosp /= d; |
| 368 | sinp /= d; |
| 369 | rv[1] = 1.0 - specjitter*rv[1]; |
| 370 | if (rv[1] <= FTINY) |
| 371 | d = 1.0; |
| 372 | else |
| 373 | d = sqrt(-log(rv[1]) / |
| 374 | (cosp*cosp/(np->u_alpha*np->u_alpha) + |
| 375 | sinp*sinp/(np->v_alpha*np->v_alpha))); |
| 376 | for (i = 0; i < 3; i++) |
| 377 | h[i] = np->pnorm[i] + |
| 378 | d*(cosp*np->u[i] + sinp*np->v[i]); |
| 379 | d = -2.0 * DOT(h, r->rdir) / (1.0 + d*d); |
| 380 | for (i = 0; i < 3; i++) |
| 381 | sr.rdir[i] = r->rdir[i] + d*h[i]; |
| 382 | if (DOT(sr.rdir, r->ron) > FTINY) { |
| 383 | rayvalue(&sr); |
| 384 | multcolor(sr.rcol, sr.rcoef); |
| 385 | addcolor(r->rcol, sr.rcol); |
| 386 | break; |
| 387 | } |
| 388 | } |
| 389 | ndims--; |
| 390 | } |
| 391 | /* compute transmission */ |
| 392 | copycolor(sr.rcoef, np->mcolor);                /* modify by material color */ |
| 393 | scalecolor(sr.rcoef, np->tspec); |
| 394 | if ((np->specfl & (SP_TRAN|SP_TBLT)) == SP_TRAN && |
| 395 | rayorigin(&sr, SPECULAR, r, sr.rcoef) == 0) { |
| 396 | dimlist[ndims++] = (int)np->mp; |
| 397 | for (niter = 0; niter < MAXITER; niter++) { |
| 398 | if (niter) |
| 399 | d = frandom(); |
| 400 | else |
| 401 | d = urand(ilhash(dimlist,ndims)+1823+samplendx); |
| 402 | multisamp(rv, 2, d); |
| 403 | d = 2.0*PI * rv[0]; |
| 404 | cosp = tcos(d) * np->u_alpha; |
| 405 | sinp = tsin(d) * np->v_alpha; |
| 406 | d = sqrt(cosp*cosp + sinp*sinp); |
| 407 | cosp /= d; |
| 408 | sinp /= d; |
| 409 | rv[1] = 1.0 - specjitter*rv[1]; |
| 410 | if (rv[1] <= FTINY) |
| 411 | d = 1.0; |
| 412 | else |
| 413 | d = sqrt(-log(rv[1]) / |
| 414 | (cosp*cosp/(np->u_alpha*np->u_alpha) + |
| 415 | sinp*sinp/(np->v_alpha*np->v_alpha))); |
| 416 | for (i = 0; i < 3; i++) |
| 417 | sr.rdir[i] = np->prdir[i] + |
| 418 | d*(cosp*np->u[i] + sinp*np->v[i]); |
| 419 | if (DOT(sr.rdir, r->ron) < -FTINY) { |
| 420 | normalize(sr.rdir);     /* OK, normalize */ |
| 421 | rayvalue(&sr); |
| 422 | multcolor(sr.rcol, sr.rcoef); |
| 423 | addcolor(r->rcol, sr.rcol); |
| 424 | break; |
| 425 | } |
| 426 | } |
| 427 | ndims--; |
| 428 | } |
| 429 | } |
