| 1 |
/* RCSid $Id: ambient.h,v 2.26 2022/03/07 17:52:14 greg Exp $ */ |
| 2 |
| 3 |
* Common definitions for interreflection routines. |
| 4 |
| 5 |
* Include after ray.h |
| 6 |
| 7 |
| 8 |
#ifndef _RAD_AMBIENT_H_ |
| 9 |
#define _RAD_AMBIENT_H_ |
| 10 |
#ifdef __cplusplus |
| 11 |
extern "C" { |
| 12 |
#endif |
| 13 |
| 14 |
| 15 |
* Normal and u-vector directions encoded using dircode.c |
| 16 |
| 17 |
typedef struct ambrec { |
| 18 |
struct ambrec *next; /* next in list */ |
| 19 |
float pos[3]; /* position in space */ |
| 20 |
int32 ndir; /* encoded surface normal */ |
| 21 |
int32 udir; /* u-vector direction */ |
| 22 |
short lvl; /* recursion level of parent ray */ |
| 23 |
float weight; /* weight of parent ray */ |
| 24 |
float rad[2]; /* anisotropic radii (rad[0] <= rad[1]) */ |
| 25 |
float gpos[2]; /* (u,v) gradient wrt. position */ |
| 26 |
float gdir[2]; /* (u,v) gradient wrt. direction */ |
| 27 |
uint32 corral; /* potential light leak direction flags */ |
| 28 |
SCOLOR val; /* computed indirect irradiance (last!) */ |
| 29 |
} AMBVAL; /* ambient value */ |
| 30 |
| 31 |
typedef struct ambtree { |
| 32 |
AMBVAL *alist; /* ambient value list */ |
| 33 |
struct ambtree *kid; /* 8 child nodes */ |
| 34 |
} AMBTREE; /* ambient octree */ |
| 35 |
| 36 |
extern double maxarad; /* maximum ambient radius */ |
| 37 |
extern double minarad; /* minimum ambient radius */ |
| 38 |
| 39 |
#ifndef AVGREFL |
| 40 |
#define AVGREFL 0.5 /* assumed average reflectance */ |
| 41 |
#endif |
| 42 |
| 43 |
#define AMBVALSIZ (64+AMB_CNDX[3]) /* number of bytes in portable AMBVAL */ |
| 44 |
#define AMBMAGIC 561 /* magic number for ambient value file */ |
| 45 |
#define AMBFMT "Radiance_ambval" /* format id string */ |
| 46 |
| 47 |
/* defined in ambient.c */ |
| 48 |
extern void setambres(int ar); |
| 49 |
extern void setambacc(double newa); |
| 50 |
extern void setambient(void); |
| 51 |
extern void multambient(SCOLOR aval, RAY *r, FVECT nrm); |
| 52 |
extern void ambdone(void); |
| 53 |
extern void ambnotify(OBJECT obj); |
| 54 |
extern int ambsync(void); |
| 55 |
/* defined in ambcomp.c */ |
| 56 |
extern int doambient(SCOLOR acol, RAY *r, double wt, |
| 57 |
FVECT uv[2], float rad[2], |
| 58 |
float gpos[2], float gdir[2], uint32 *crlp); |
| 59 |
/* defined in ambio.c */ |
| 60 |
extern int *AMB_CNDX; /* open ambient file RGBE indices */ |
| 61 |
extern float *AMB_WLPART; /* open ambient file spectral range */ |
| 62 |
extern int amb_headline(char *hl, void *p); |
| 63 |
extern void putambmagic(FILE *fp); |
| 64 |
extern int hasambmagic(FILE *fp); |
| 65 |
extern int writambval(AMBVAL *av, FILE *fp); |
| 66 |
extern int readambval(AMBVAL *av, FILE *fp); |
| 67 |
extern int ambvalOK(AMBVAL *av); |
| 68 |
| 69 |
| 70 |
| 71 |
#endif |
| 72 |
#endif /* _RAD_AMBIENT_H_ */ |
| 73 |
