root/radiance/src/rt/SConscript
Revision: 1.15
Committed: Sat Mar 5 00:29:28 2016 UTC (9 years, 10 months ago) by schorsch
Changes since 1.14: +18 -5 lines
update SCons
1 import os
2 from build_utils import vstamp
3
4 Import('env') # inherit from parent
5
6 mlib = env['RAD_MLIB']
7
8 # compose paths
9 def radbin(name): return os.path.join(env['RAD_BUILDBIN'], name)
10 def radlib(name): return os.path.join(env['RAD_BUILDLIB'], name)
11
12 # custom compile flags
13 dielectric = env.Object(source='dielectric.c',
14 CCFLAGS=env.get('CCFLAGS',[]) + ['-DDISPERSE'])
15
16 duphead = env.Object(source="duphead.c")
17 persist = env.Object(source="persist.c")
18 ambio = env.Object(source="ambio.c")
19 rayfifo = env.Object(source="rayfifo.c")
20 raypwin = env.Object(source="raypwin.c")
21 raycalls = env.Object(source="raycalls.c")
22
23
24 # source and object dependencies
25 RAY = Split('''ambcomp.c ambient.c freeobjmem.c initotypes.c preload.c
26 raytrace.c renderopts.c''') + [ambio]
27 PMAP = Split('''pmap.c pmapsrc.c pmapmat.c pmaprand.c pmapio.c pmapdata.c
28 pmapbias.c pmapparm.c pmapcontrib.c pmapamb.c pmapray.c pmapopt.c
29 pmapdiag.c pmaptype.c''')
30
31 SURF = Split('''srcsamp.c srcsupp.c srcobstr.c source.c virtuals.c sphere.c
32 o_face.c o_cone.c o_instance.c o_mesh.c''')
33
34 MAT = Split('''aniso.c normal.c m_clip.c glass.c m_brdf.c m_mirror.c
35 m_direct.c m_mist.c fprism.c m_alias.c m_bsdf.c ashikhmin.c '''
36 ) + [dielectric]
37
38 MOD = Split('p_func.c t_func.c p_data.c t_data.c text.c mx_func.c mx_data.c')
39
40 SUP = Split('func.c noise3.c data.c')
41
42 # build libraries
43 rsrc = RAY + PMAP + SURF + MAT + MOD + SUP
44 env.Command('Version.c', 'VERSION', vstamp.build_version_c)
45 env.Depends('Version.c', rsrc)
46 Version = env.Object(source=['Version.c'])
47 rlib = env.Library(target=radlib('rttrace'), source=rsrc + [Version])
48
49 #if os.name == 'nt': # XXX until we get around fork() and friends
50 # rcsrc = Split('raycalls.c')
51 #else: rcsrc = Split('raycalls.c raypcalls.c')
52 rcsrc = Split('raycalls.c $RAD_PCALLS')
53 rclib = env.Library(target=radlib('raycalls'), source=rcsrc)
54 Default(rclib)
55
56 fullib=['rttrace', 'rtscene', 'rtpic', 'rtfunc', 'rtproc', 'rtmath',
57 'rtargs', 'rtpath', 'rtio', 'rtcont', 'rtmem', 'rterror']
58 # build executables
59 lasrc = ['lookamb.c', ambio]
60 lookamb = env.Program(target=radbin('lookamb'), source=lasrc,
61 LIBS=['rtio', 'rtpic', 'rtmath', mlib])
62 Default(lookamb)
63 env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', lookamb)])
64
65 rcontrib = env.Program(target=radbin('rcontrib'),
66 source = Split('rcmain.c rcontrib.c rc2.c rc3.c') + [Version],
67 LIBS= ['rttrace','rtscene','rtpic','rtargs','rtfunc','rtio',
68 'rtproc','rtcont',
69 'rtmem', 'rtpath', 'rtmath','rtnet','rterror','$RAD_SOCKETLIB',mlib]),
70 Default(rcontrib)
71 env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', rcontrib)])
72
73
74 rtmain = env.Object(source=['rtmain.c'],
75 CCFLAGS=env.get('CCFLAGS',[]) + ['-DNICE=4'])
76 rtsrc = ['rtrace.c', duphead, persist, rtmain, rayfifo, raypwin, raycalls]
77 rtrace = env.Program(target=radbin('rtrace'), source=rtsrc,
78 LIBS=fullib + ['rtnet'] + mlib
79 )
80 Default(rtrace)
81 env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', rtrace)])
82
83 rpsrc = Split('rpmain.c rpict.c srcdraw.c') + [duphead, persist]
84 rpict = env.Program(target=radbin('rpict'), source=rpsrc,
85 LIBS=fullib+['rtnet','$RAD_SOCKETLIB']+mlib)
86 Default(rpict)
87 env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', rpict)])
88
89 if env.has_key('X11LIB'): # lots of special requirements for rvu
90 x11incls = [env['X11INCLUDE']] + env['CPPPATH']
91 x11 = env.Object(source='x11.c', CPPPATH=x11incls)
92 x11twind = env.Object(source='x11twind.c', CPPPATH=x11incls)
93 rvmain = env.Object(source='rvmain.c',
94 CCFLAGS=env['CCFLAGS'] + ['-DNICE=6'])
95 rv3 = env.Object(source='rv3.c',
96 CCFLAGS=env['CCFLAGS']
97 )
98
99 devsrc = Split('devtable.c devcomm.c colortab.c editline.c')
100 rvobjs = [x11, x11twind, rv3, rvmain, rlib]
101 rvsrc = Split('rview.c rv2.c') + devsrc + rvobjs
102 rvu = env.Program(target=radbin('rvu'), source=rvsrc,
103 LIBPATH=env['LIBPATH'] + [env['X11LIB']],
104 LIBS = (['rtscene', rclib, 'rttrace', 'rtnet', 'rtpic', 'rtfunc', 'rtproc', 'rtmath',
105 'rtargs', 'rtpath', 'rtio', 'rtcont', 'rtmem', 'rterror',
106 'X11'] + mlib)
107 #LIBS=fullib + ['X11', rclib] + mlib
108 )
109 Default(rvu)
110 env.Append(RAD_BININSTALL=[env.Install('$RAD_BINDIR', rvu)])
111
112 LIBFILES = Split('rayinit.cal')
113 env.Append(RAD_RLIBINSTALL=[env.Install('$RAD_RLIBDIR', LIBFILES)])
114
