root/radiance/src/rt/SConscript
Tue Jan 9 00:08:57 2018 UTC (7 years, 11 months ago) by schorsch
Changes since 1.19: +26 -15 lines
Diff to previous 1.19
SCons Option to build Pmap with OOC data on unix
Mon Jan 8 13:38:37 2018 UTC (7 years, 11 months ago) by schorsch
Changes since 1.18: +8 -2 lines
Diff to previous 1.18
Fri Mar 18 22:58:46 2016 UTC (9 years, 9 months ago) by schorsch
Changes since 1.17: +14 -10 lines
Diff to previous 1.17
create a seperate grouping for the files needed by rvu display drivers
Thu Mar 10 21:43:23 2016 UTC (9 years, 9 months ago) by schorsch
Changes since 1.16: +23 -56 lines
Diff to previous 1.16
Sat Mar 5 13:24:58 2016 UTC (9 years, 9 months ago) by schorsch
Changes since 1.15: +22 -5 lines
Diff to previous 1.15
Sat Mar 5 00:29:28 2016 UTC (9 years, 9 months ago) by schorsch
Changes since 1.14: +18 -5 lines
Diff to previous 1.14
update SCons
Fri Apr 15 21:52:16 2011 UTC (14 years, 8 months ago) by greg
Diff to previous 1.13
SCONS fixes for latest build
Wed Jun 2 15:58:30 2010 UTC (15 years, 7 months ago) by greg
Diff to previous 1.12
Fixes to MINGW build
Thu May 27 19:32:13 2010 UTC (15 years, 7 months ago) by greg
Diff to previous 1.11
Tue Dec 23 15:04:01 2008 UTC (17 years ago) by schorsch
Changes since 1.10: +5 -1 lines
Diff to previous 1.10
Mon Apr 21 07:31:30 2008 UTC (17 years, 8 months ago) by schorsch
Changes since 1.9: +6 -5 lines
Diff to previous 1.9
Scons update for mingw.
Mon Sep 19 11:30:10 2005 UTC (20 years, 3 months ago) by schorsch
Diff to previous 1.8
Wed Sep 14 09:28:35 2005 UTC (20 years, 3 months ago) by schorsch
Diff to previous 1.7
Diff to previous 1.6
Thu Oct 21 15:47:13 2004 UTC (21 years, 2 months ago) by schorsch
Changes since 1.5: +10 -8 lines
Diff to previous 1.5
SCons build simplifications.
Sun Jul 4 12:08:48 2004 UTC (21 years, 6 months ago) by schorsch
Changes since 1.4: +6 -4 lines
Diff to previous 1.4
Thu Jan 1 20:54:46 2004 UTC (22 years ago) by schorsch
Diff to previous 1.3
Renamed rview to rvu.
Thu Jan 1 10:57:46 2004 UTC (22 years ago) by schorsch
Diff to previous 1.2
Integrated new source occlusion testing routines into SCons build.
Mon Oct 27 10:35:43 2003 UTC (22 years, 2 months ago) by schorsch
Changes since 1.1: +47 -40 lines
Tue Oct 21 19:27:29 2003 UTC (22 years, 2 months ago) by schorsch
