| 1 |
greg |
2.1 |
#ifndef lint
| 2 |
greg |
2.6 |
static const char RCSid[] = "$Id: RdataShareMap.cpp,v 2.5 2025/10/27 18:38:32 greg Exp $";
| 3 |
greg |
2.1 |
#endif
| 4 |
| 5 |
* RdataShareMap.cpp
| 6 |
| 7 |
* Shared data using memory-mapped file
| 8 |
| 9 |
* Created by Greg Ward on 10/14/2024
| 10 |
| 11 |
| 12 |
#include "rtio.h"
| 13 |
#include "rterror.h"
| 14 |
#include "RdataShare.h"
| 15 |
#include <unistd.h>
| 16 |
#include <sys/stat.h>
| 17 |
#include <sys/mman.h>
| 18 |
| 19 |
// Create memory-mapped file object
| 20 |
RdataShareMap::RdataShareMap(const char *name, int flags, size_t siz)
| 21 |
| 22 |
mmorg = NULL;
| 23 |
bufCount = 0;
| 24 |
| 25 |
if (!(flags & (RDSread|RDSwrite))) {
| 26 |
error(CONSISTENCY, "RdataShareMap() flags must include RDSread or RDSwrite");
| 27 |
return;
| 28 |
| 29 |
if (name && !*name) name = NULL;
| 30 |
if (!name && !siz | ((flags & (RDSextend|RDSread|RDSwrite)) !=
| 31 |
(RDSextend|RDSread|RDSwrite))) {
| 32 |
error(CONSISTENCY, "anonymous memory map must be read/write");
| 33 |
return;
| 34 |
| 35 |
if ((flags & (RDSextend|RDSwrite)) == RDSextend) {
| 36 |
error(CONSISTENCY, "bad RDSextend in RdataShareMap()");
| 37 |
return;
| 38 |
| 39 |
greg |
2.2 |
int oflags, mmprot;
| 40 |
greg |
2.1 |
switch (flags & (RDSread|RDSwrite)) {
| 41 |
case RDSread|RDSwrite:
| 42 |
greg |
2.2 |
mmprot = PROT_READ|PROT_WRITE;
| 43 |
oflags = O_RDWR|O_CREAT;
| 44 |
break;
| 45 |
case RDSwrite:
| 46 |
mmprot = PROT_WRITE;
| 47 |
oflags = O_RDWR|O_CREAT; // XXX system limitation
| 48 |
greg |
2.1 |
break;
| 49 |
case RDSread:
| 50 |
greg |
2.2 |
mmprot = PROT_READ;
| 51 |
oflags = O_RDONLY;
| 52 |
greg |
2.1 |
break;
| 53 |
| 54 |
int fd = -1;
| 55 |
if (name) { // opening a shared file
| 56 |
greg |
2.2 |
if (flags & RDSexcl) oflags |= O_EXCL;
| 57 |
greg |
2.1 |
else if (flags & RDSextend && !siz) oflags |= O_TRUNC;
| 58 |
fd = open(name, oflags, 0666);
| 59 |
if (fd < 0) {
| 60 |
sprintf(errmsg, "cannot open '%s'", name);
| 61 |
error(SYSTEM, errmsg);
| 62 |
return;
| 63 |
| 64 |
if (!(flags & RDSextend)) {
| 65 |
struct stat sbuf;
| 66 |
| 67 |
siz = 0;
| 68 |
else if (fstat(fd, &sbuf) >= 0)
| 69 |
siz = sbuf.st_size;
| 70 |
else {
| 71 |
greg |
2.4 |
sprintf(errmsg, "cannot stat '%s'", name);
| 72 |
greg |
2.1 |
| 73 |
close(fd);
| 74 |
return;
| 75 |
| 76 |
} else if (siz && ftruncate(fd, siz) < 0) {
| 77 |
sprintf(errmsg, "cannot resize '%s'", name);
| 78 |
| 79 |
close(fd);
| 80 |
return;
| 81 |
| 82 |
| 83 |
greg |
2.3 |
if (siz) mmorg = (void *)mmap(NULL, siz, mmprot,
| 84 |
greg |
2.1 |
MAP_SHARED|(name ? MAP_FILE : MAP_ANON), fd, 0);
| 85 |
close(fd);
| 86 |
if (mmorg == MAP_FAILED) {
| 87 |
if (name)
| 88 |
sprintf(errmsg, "cannot map '%s' to memory", name);
| 89 |
else
| 90 |
sprintf(errmsg, "cannot map anonymous map of %ld KBytes",
| 91 |
long(siz/1024));
| 92 |
| 93 |
mmorg = NULL;
| 94 |
return;
| 95 |
| 96 |
osiz = siz;
| 97 |
if (name) chName = savqstr(name);
| 98 |
mode = flags;
| 99 |
| 100 |
| 101 |
RdataShareMap::~RdataShareMap()
| 102 |
| 103 |
if (mmorg) munmap(mmorg, osiz);
| 104 |
| 105 |
| 106 |
// Attempt to extend or shrink object (adjust if 0)
| 107 |
size_t
| 108 |
RdataShareMap::Resize(size_t new_siz)
| 109 |
| 110 |
if (new_siz > 0) {
| 111 |
if (new_siz == osiz)
| 112 |
return osiz;
| 113 |
if (!(mode & RDSwrite)) {
| 114 |
error(CONSISTENCY, "cannot resize read-only map");
| 115 |
return 0;
| 116 |
| 117 |
| 118 |
if (bufCount > 0) {
| 119 |
error(INTERNAL, "cannot resize while memory is checked out");
| 120 |
return 0;
| 121 |
| 122 |
if (!chName) {
| 123 |
if (!new_siz) // XXX should issue warning?
| 124 |
return osiz;
| 125 |
if (new_siz > osiz) {
| 126 |
error(INTERNAL, "cannot grow anonymous map");
| 127 |
return 0;
| 128 |
| 129 |
return osiz = new_siz; // just pretend we shrank
| 130 |
| 131 |
if (!new_siz) { // sync to current file length?
| 132 |
struct stat sbuf;
| 133 |
if (stat(chName, &sbuf) < 0) {
| 134 |
sprintf(errmsg, "cannot stat '%s'", chName);
| 135 |
| 136 |
return 0;
| 137 |
| 138 |
if (sbuf.st_size <= osiz)
| 139 |
return osiz = sbuf.st_size;
| 140 |
| 141 |
new_siz = sbuf.st_size;
| 142 |
| 143 |
if (new_siz > osiz) { // need to extend & remap
| 144 |
greg |
2.6 |
int fd = open(chName, O_RDWR);
| 145 |
greg |
2.1 |
if (fd < 0) {
| 146 |
sprintf(errmsg, "cannot reopen '%s'", chName);
| 147 |
| 148 |
return 0;
| 149 |
| 150 |
if (ftruncate(fd, new_siz) < 0) {
| 151 |
sprintf(errmsg, "cannot grow '%s'", chName);
| 152 |
| 153 |
close(fd);
| 154 |
return 0;
| 155 |
| 156 |
greg |
2.3 |
| 157 |
greg |
2.1 |
mmorg = mmap(NULL, new_siz,
| 158 |
mode&RDSread ? PROT_READ|PROT_WRITE : PROT_WRITE,
| 159 |
MAP_SHARED|MAP_FILE, fd, 0);
| 160 |
close(fd);
| 161 |
| 162 |
sprintf(errmsg, "mmap() failed on '%s'", chName);
| 163 |
| 164 |
mmorg = NULL;
| 165 |
return osiz = 0;
| 166 |
| 167 |
} else if (truncate(chName, new_siz) < 0) {
| 168 |
greg |
2.5 |
sprintf(errmsg, "cannot resize '%s'", chName);
| 169 |
greg |
2.1 |
return 0;
| 170 |
| 171 |
| 172 |
| 173 |
| 174 |
// Get data buffer
| 175 |
void *
| 176 |
RdataShareMap::GetMemory(size_t offs, size_t len, int fl)
| 177 |
| 178 |
if (chName && fl & RDSextend) { // resize/extend?
| 179 |
if (offs + len > osiz ? !Resize(offs + len) : !Resize())
| 180 |
return NULL;
| 181 |
| 182 |
if (offs + len > osiz) {
| 183 |
if (chName)
| 184 |
sprintf(errmsg, "requested block of %lu bytes outside map '%s'",
| 185 |
(unsigned long)len, chName);
| 186 |
else
| 187 |
sprintf(errmsg, "requested block of %lu bytes outside %lu byte map",
| 188 |
(unsigned long)len, (unsigned long)osiz);
| 189 |
error(CONSISTENCY, errmsg);
| 190 |
return NULL;
| 191 |
| 192 |
++bufCount;
| 193 |
return (char *)mmorg + offs;
| 194 |
| 195 |
| 196 |
// Return data buffer
| 197 |
bool
| 198 |
RdataShareMap::ReleaseMemory(void *dp, int fl)
| 199 |
| 200 |
if ((dp < mmorg) | ((char *)dp >= (char *)mmorg + osiz)) {
| 201 |
if (chName)
| 202 |
sprintf(errmsg, "returned block outside map '%s'", chName);
| 203 |
else
| 204 |
sprintf(errmsg, "returned block outside %lu byte map",
| 205 |
| 206 |
| 207 |
return false;
| 208 |
| 209 |
bufCount -= (bufCount > 0);
| 210 |
return true;
| 211 |
