root/radiance/src/rt/RdataShareMap.cpp
Revision: 2.4
Committed: Thu Mar 20 17:59:10 2025 UTC (6 months, 2 weeks ago) by greg
CVS Tags: rad6R0, HEAD
fix: Variable was being used in error message before being set
2 static const char RCSid[] = "$Id: RdataShareMap.cpp,v 2.3 2024/10/31 23:55:04 greg Exp $";
5 * RdataShareMap.cpp
6 *
7 * Shared data using memory-mapped file
8 *
9 * Created by Greg Ward on 10/14/2024
10 */
11
12 #include "rtio.h"
13 #include "rterror.h"
14 #include "RdataShare.h"
15 #include <unistd.h>
16 #include <sys/stat.h>
17 #include <sys/mman.h>
18
19 // Create memory-mapped file object
20 RdataShareMap::RdataShareMap(const char *name, int flags, size_t siz)
21 {
22 mmorg = NULL;
23 bufCount = 0;
24
25 if (!(flags & (RDSread|RDSwrite))) {
26 error(CONSISTENCY, "RdataShareMap() flags must include RDSread or RDSwrite");
27 return;
28 }
29 if (name && !*name) name = NULL;
30 if (!name && !siz | ((flags & (RDSextend|RDSread|RDSwrite)) !=
31 (RDSextend|RDSread|RDSwrite))) {
32 error(CONSISTENCY, "anonymous memory map must be read/write");
33 return;
34 }
35 if ((flags & (RDSextend|RDSwrite)) == RDSextend) {
36 error(CONSISTENCY, "bad RDSextend in RdataShareMap()");
37 return;
38 }
39 int oflags, mmprot;
40 switch (flags & (RDSread|RDSwrite)) {
41 case RDSread|RDSwrite:
42 mmprot = PROT_READ|PROT_WRITE;
43 oflags = O_RDWR|O_CREAT;
44 break;
45 case RDSwrite:
46 mmprot = PROT_WRITE;
47 oflags = O_RDWR|O_CREAT; // XXX system limitation
48 break;
49 case RDSread:
50 mmprot = PROT_READ;
51 oflags = O_RDONLY;
52 break;
53 }
54 int fd = -1;
55 if (name) { // opening a shared file
56 if (flags & RDSexcl) oflags |= O_EXCL;
57 else if (flags & RDSextend && !siz) oflags |= O_TRUNC;
58 fd = open(name, oflags, 0666);
59 if (fd < 0) {
60 sprintf(errmsg, "cannot open '%s'", name);
61 error(SYSTEM, errmsg);
62 return;
63 }
64 if (!(flags & RDSextend)) {
65 struct stat sbuf;
66 if (flags & RDSexcl)
67 siz = 0;
68 else if (fstat(fd, &sbuf) >= 0)
69 siz = sbuf.st_size;
70 else {
71 sprintf(errmsg, "cannot stat '%s'", name);
72 error(SYSTEM, errmsg);
73 close(fd);
74 return;
75 }
76 } else if (siz && ftruncate(fd, siz) < 0) {
77 sprintf(errmsg, "cannot resize '%s'", name);
78 error(SYSTEM, errmsg);
79 close(fd);
80 return;
81 }
82 }
83 if (siz) mmorg = (void *)mmap(NULL, siz, mmprot,
84 MAP_SHARED|(name ? MAP_FILE : MAP_ANON), fd, 0);
85 close(fd);
86 if (mmorg == MAP_FAILED) {
87 if (name)
88 sprintf(errmsg, "cannot map '%s' to memory", name);
89 else
90 sprintf(errmsg, "cannot map anonymous map of %ld KBytes",
91 long(siz/1024));
92 error(SYSTEM, errmsg);
93 mmorg = NULL;
94 return;
95 }
96 osiz = siz;
97 if (name) chName = savqstr(name);
98 mode = flags;
99 }
100
101 RdataShareMap::~RdataShareMap()
102 {
103 if (mmorg) munmap(mmorg, osiz);
104 }
105
106 // Attempt to extend or shrink object (adjust if 0)
107 size_t
108 RdataShareMap::Resize(size_t new_siz)
109 {
110 if (new_siz > 0) {
111 if (new_siz == osiz)
112 return osiz;
113 if (!(mode & RDSwrite)) {
114 error(CONSISTENCY, "cannot resize read-only map");
115 return 0;
116 }
117 }
118 if (bufCount > 0) {
119 error(INTERNAL, "cannot resize while memory is checked out");
120 return 0;
121 }
122 if (!chName) {
123 if (!new_siz) // XXX should issue warning?
124 return osiz;
125 if (new_siz > osiz) {
126 error(INTERNAL, "cannot grow anonymous map");
127 return 0;
128 }
129 return osiz = new_siz; // just pretend we shrank
130 }
131 if (!new_siz) { // sync to current file length?
132 struct stat sbuf;
133 if (stat(chName, &sbuf) < 0) {
134 sprintf(errmsg, "cannot stat '%s'", chName);
135 error(SYSTEM, errmsg);
136 return 0;
137 }
138 if (sbuf.st_size <= osiz)
139 return osiz = sbuf.st_size;
140
141 new_siz = sbuf.st_size;
142 }
143 if (new_siz > osiz) { // need to extend & remap
144 int fd = open(chName, mode&RDSread ? O_RDWR : O_WRONLY);
145 if (fd < 0) {
146 sprintf(errmsg, "cannot reopen '%s'", chName);
147 error(SYSTEM, errmsg);
148 return 0;
149 }
150 if (ftruncate(fd, new_siz) < 0) {
151 sprintf(errmsg, "cannot grow '%s'", chName);
152 error(SYSTEM, errmsg);
153 close(fd);
154 return 0;
155 }
156 if (mmorg) munmap(mmorg, osiz);
157 mmorg = mmap(NULL, new_siz,
158 mode&RDSread ? PROT_READ|PROT_WRITE : PROT_WRITE,
159 MAP_SHARED|MAP_FILE, fd, 0);
160 close(fd);
161 if (mmorg == MAP_FAILED) {
162 sprintf(errmsg, "mmap() failed on '%s'", chName);
163 error(SYSTEM, errmsg);
164 mmorg = NULL;
165 return osiz = 0;
166 }
167 } else if (truncate(chName, new_siz) < 0) {
168 sprintf(errmsg, "cannot truncate '%s'", chName);
169 return 0;
170 }
171 return osiz = new_siz;
172 }
173
174 // Get data buffer
175 void *
176 RdataShareMap::GetMemory(size_t offs, size_t len, int fl)
177 {
178 if (chName && fl & RDSextend) { // resize/extend?
179 if (offs + len > osiz ? !Resize(offs + len) : !Resize())
180 return NULL;
181 }
182 if (offs + len > osiz) {
183 if (chName)
184 sprintf(errmsg, "requested block of %lu bytes outside map '%s'",
185 (unsigned long)len, chName);
186 else
187 sprintf(errmsg, "requested block of %lu bytes outside %lu byte map",
188 (unsigned long)len, (unsigned long)osiz);
189 error(CONSISTENCY, errmsg);
190 return NULL;
191 }
192 ++bufCount;
193 return (char *)mmorg + offs;
194 }
195
196 // Return data buffer
197 bool
198 RdataShareMap::ReleaseMemory(void *dp, int fl)
199 {
200 if ((dp < mmorg) | ((char *)dp >= (char *)mmorg + osiz)) {
201 if (chName)
202 sprintf(errmsg, "returned block outside map '%s'", chName);
203 else
204 sprintf(errmsg, "returned block outside %lu byte map",
205 (unsigned long)osiz);
206 error(CONSISTENCY, errmsg);
207 return false;
208 }
209 bufCount -= (bufCount > 0);
210 return true;
211 }
