#ifndef lint static const char RCSid[] = "$Id: RdataShareFile.cpp,v 2.4 2025/10/27 18:38:32 greg Exp $"; #endif /* * RdataShareFile.cpp * * Shared data using a regular file * * Created by Greg Ward on 10/14/2024 */ #include "rtio.h" #include "rterror.h" #include "RdataShare.h" #include #include #include const char RDSnoname[] = ""; RdataShare::~RdataShare() { freeqstr(chName); } // Struct needed for tracking allocated buffers struct RDSbuffer { RDSbuffer * next; // next in list char * buf; // allocated buffer size_t len; // buffer length off_t pos; // offset in file RDSbuffer(size_t nb, RDSbuffer *nxt = NULL); ~RDSbuffer() { delete next; if (len > 0) free(buf); } /// Find buffer matching pointer RDSbuffer * Find(void *p) { RDSbuffer * bp = this; while (p != (void *)bp->buf && (bp = bp->next) != NULL) ; return bp; } }; // Allocate an i/o buffer RDSbuffer::RDSbuffer(size_t nb, RDSbuffer *nxt) { next = nxt; buf = NULL; pos = -1; if ((len = nb) > 0) { buf = (char *)malloc(nb); if (!buf) { sprintf(errmsg, "cannot allocate %lu-byte buffer", (unsigned long)nb); error(SYSTEM, errmsg); len = 0; return; } } } // Create memory-mapped file object RdataShareFile::RdataShareFile(const char *name, int flags, size_t siz) { fd = -1; blist = NULL; if (!name || !*name) { error(CONSISTENCY, "missing file name in RdataShareFile()"); return; } if (!(flags & (RDSread|RDSwrite))) { error(CONSISTENCY, "RdataShareFile() flags must include RDSread or RDSwrite"); return; } if ((flags & (RDSextend|RDSwrite)) == RDSextend) { error(CONSISTENCY, "bad RDSextend in RdataShareFile()"); return; } int oflags = O_CLOEXEC; switch (flags & (RDSread|RDSwrite)) { case RDSread|RDSwrite: oflags |= O_RDWR|O_CREAT; break; case RDSwrite: oflags |= O_WRONLY|O_CREAT; break; case RDSread: oflags |= O_RDONLY; break; } if (flags & RDSexcl) oflags |= O_EXCL; else if (flags & RDSextend && !siz) oflags |= O_TRUNC; fd = open(name, oflags, 0666); if (fd < 0) { sprintf(errmsg, "cannot open '%s'", name); error(SYSTEM, errmsg); return; } if (!(flags & RDSextend)) { struct stat sbuf; if (flags & RDSexcl) siz = 0; else if (fstat(fd, &sbuf) >= 0) siz = sbuf.st_size; else { sprintf(errmsg, "cannot stat '%s'", name); error(SYSTEM, errmsg); close(fd); fd = -1; return; } } else if (siz && ftruncate(fd, siz) < 0) { sprintf(errmsg, "cannot resize '%s'", name); error(SYSTEM, errmsg); close(fd); fd = -1; return; } osiz = siz; chName = savqstr(name); mode = flags; } RdataShareFile::~RdataShareFile() { if (fd >= 0) close(fd); delete blist; } // Attempt to extend or shrink object (adjust if 0) size_t RdataShareFile::Resize(size_t new_siz) { if (fd < 0) return 0; if (new_siz > 0) { if (new_siz == osiz) return osiz; if (!(mode & RDSwrite)) { error(CONSISTENCY, "cannot resize read-only file"); return 0; } } else { // sync to current file length struct stat sbuf; if (fstat(fd, &sbuf) < 0) { sprintf(errmsg, "cannot stat '%s'", chName); error(SYSTEM, errmsg); return 0; } return osiz = sbuf.st_size; } // else attempt to resize file if (ftruncate(fd, new_siz) < 0) { sprintf(errmsg, "cannot resize '%s'", chName); return 0; } return osiz = new_siz; } // Get data buffer void * RdataShareFile::GetMemory(size_t offs, size_t len, int fl) { if (fd < 0) return NULL; if (fl & RDSextend && !Resize()) // sync to file length, first? return NULL; if (fl & mode & RDSread && offs + len > osiz) { if (fl & RDSextend) { // resize if requested if (!Resize(offs + len)) return NULL; } else { sprintf(errmsg, "requested block of %lu bytes past EOF in '%s'", (unsigned long)len, chName); error(CONSISTENCY, errmsg); return NULL; } } // XXX should check for buffer overlap? blist = new RDSbuffer(len, blist); blist->pos = offs; if (fl & mode & RDSread && // reading from file? pread(fd, blist->buf, len, offs) != len) { sprintf(errmsg, "read error on '%s'", chName); error(SYSTEM, errmsg); } return blist->buf; } // Return data buffer bool RdataShareFile::ReleaseMemory(void *dp, int fl) { if (!blist) return false; RDSbuffer * bp = blist->Find(dp); if (!bp) { sprintf(errmsg, "return of unallocated block for '%s'", chName); error(CONSISTENCY, errmsg); return false; } if ((fl & (RDSwrite|RDSextend)) == RDSwrite && bp->pos + bp->len > osiz) { sprintf(errmsg, "write request past EOF in '%s'", chName); error(CONSISTENCY, errmsg); return NULL; } if (fl & mode & RDSwrite) { // writing to file? if (pwrite(fd, bp->buf, bp->len, bp->pos) != bp->len) { sprintf(errmsg, "write error on '%s'", chName); error(SYSTEM, errmsg); return false; } if (bp->pos + bp->len > osiz) osiz = bp->pos + bp->len; } RDSbuffer rbuf(0, blist); // remove from buffer list RDSbuffer * bp2 = &rbuf; while (bp2->next != bp) bp2 = bp2->next; bp2->next = bp->next; bp->next = NULL; delete bp; // frees buffer memory blist = rbuf.next; return true; }
