root/radiance/src/rt/RcontribSimulManager.h
Revision: 2.14
Committed: Sat Oct 25 03:30:35 2025 UTC (2 weeks ago) by greg
Changes since 2.13: +9 -8 lines
fix(rxcontrib,rxfluxmtx): Repaired logic with NCOLS= and -r + speed improvement
# User Rev Content
1 greg 2.14 /* RCSid $Id: RcontribSimulManager.h,v 2.13 2025/10/23 16:33:39 greg Exp $ */
2 greg 2.1 /*
3     * RcontribSimulManager.h
4     *
5     * Rcontrib simulation manager class declaration
6     *
7     * Created by Greg Ward on 10/11/2024.
8     */
9
10     #ifndef RcontribSimulManager_h
11     #define RcontribSimulManager_h
12
13     #include "RtraceSimulManager.h"
14     #include "RdataShare.h"
15     #include "lookup.h"
16     #include "rtprocess.h"
17
18     /*
19     * As with other single-object classes, many global variable affect
20     * behavior. Besides rendering parameters, there are spectral parameters
21     * and output dimensions taken from the environment.
22     *
23     * NOTE: "record" and "row" are used interchangeably throughout.
24     */
25
26     extern char RCCONTEXT[]; // global rcontrib context
27
28 greg 2.2 class RcontribSimulManager; // need forward decl
29 greg 2.1
30     /// Shared data object for record output (includes header; may be write-only)
31     class RcontribOutput {
32     RcontribOutput * next; // next in sorted list
33     char * ofname; // output file name
34     uint32 rowCountPos; // row count position in header
35     void * rowp; // current row memory
36     bool NewHeader(const RcontribSimulManager *rcp);
37     int CheckHeader(const RcontribSimulManager *rcp);
38     public:
39     RdataShare * rData; // data sharing object
40     size_t rowBytes; // byte count per row
41     const char * omod; // single modifier (or NULL)
42     int32 obin; // single output bin (or -1)
43     uint32 begData; // start of data (type-aligned)
44     int32 curRow; // current output row
45     uint32 nRows; // total number of rows
46     RcontribOutput(const char *fnm = NULL) {
47     next = NULL;
48     omod = NULL;
49     obin = -1;
50     rData = NULL;
51     ofname = savqstr(fnm);
52     rowBytes = 0;
53     nRows = 0;
54     rowp = NULL; curRow = -1;
55     }
56     ~RcontribOutput() {
57     DoneRow();
58     delete rData;
59     delete next;
60     freeqstr(ofname);
61     }
62     /// Return output channel name
63     const char * GetName() const {
64     if (rData) return rData->GetName();
65     return ofname;
66     }
67     /// Update output row count
68     bool SetRowsDone(int r) {
69 greg 2.11 if (!rData | (0 > r) | (r > nRows)) return false;
70 greg 2.1 char * rbuf = (char *)rData->GetMemory(rowCountPos, 17, 0);
71     sprintf(rbuf, "%-16d", r);
72     rbuf[16] = '\n'; // replaces nul byte
73     return rData->ReleaseMemory(rbuf, RDSwrite);
74     }
75     /// Get buffer for indicated row (contents may be random)
76     void * GetRow(int r) {
77     if (!rData | (r < 0)) return NULL;
78     if (r != curRow) {
79     DoneRow();
80     if (r < nRows)
81     rowp = rData->GetMemory(begData + r*rowBytes,
82     rowBytes, 0);
83     if (rowp) curRow = r;
84     }
85     return rowp;
86     }
87     /// Current row with byte offset
88     void * InsertionP(int coffset) const {
89     if (!rowp | (coffset < 0) | (coffset >= rowBytes))
90     return NULL;
91     return (char *)rowp + coffset;
92     }
93     /// Release current row, writing contents
94     void DoneRow() {
95     if (rowp) rData->ReleaseMemory(rowp, RDSwrite);
96     rowp = NULL; curRow = -1;
97     }
98     /// Get next in list
99     const RcontribOutput * Next() const {
100     return next;
101     }
102     RcontribOutput * Next() {
103     return next;
104     }
105     /// RcontribSimulManager gets full access
106     friend class RcontribSimulManager;
107     };
108
109     typedef double DCOLORV; // color accumulator type
110
111     /// Free an RcontribMod
112     extern lut_free_t FreeRcMod;
113
114     /*
115     * General RcontribSimulManager class operation:
116     *
117     * 1) Call LoadOctree(), then alter the header as desired
118     * 2) Set number of spectral samples (NCSAMP) and call SetDataFormat()
119 greg 2.6 * 3) Set xres and yres to desired dimensions (xres>0 for picture output)
120     * 4) Call AddModifier() and AddModFile() to indicate tracked modifiers
121     * 5) Set outOp and cdsF according to desired output/recovery
122     * 6) Set desired computation flags via SetFlag()
123     * 7) Call PrepOutput() to open output channels
124     * 8) Call SetThreadCount() to fork children if desired
125     * 9) Set accum to the number of ray samples per record
126     * 10) Call ComputeRecord() with accum ray samples
127     * 11) Continue until GetRowMax() records have been sent
128     * 12) Call Cleanup()
129 greg 2.1 *
130     * The order of some of these calls may be changed. Technically, the octree
131     * may be loaded anytime before PrepOutput() is called. Also, SetThreadCount()
132 greg 2.6 * may be called anytime *after* PrepOutput(), and may be interleaved with
133 greg 2.1 * calls to ComputeRecord(). The accum setting may be changed at any time.
134     * Finally, it is possible to restart the output using ResetRow(), and
135     * a zero argument will rewind to the beginning, whence all records
136     * may be recalculated. The previous output rows are not zeroed or deleted,
137     * but are overwritten as the calculation proceeds from the new starting point.
138     * However, the output file(s) will indicate in the NROWS= line in the header
139 greg 2.7 * that only the newly calculated rows are present. If you wish to start over
140     * with a different set of modifiers or outputs, call ClearModifiers() instead,
141     * which keeps the current octree in memory. This call also returns to single
142     * process mode if any children were running.
143 greg 2.1 *
144     * It is not possible to write to standard output, but the output
145     * model is quite flexible thanks to the RdataShare polymorphic class.
146     * The current default output class creates a shared, memory-mapped file,
147     * which is the most efficient object on most systems.
148     *
149     * ASCII output is not supported, so full data recovery is.
150     */
151
152     /// Output channel opening options: new/exclusive, overwrite if exists, or recover data
153 greg 2.3 enum RCOutputOp {RCOnew=0, RCOforce, RCOrecover};
154 greg 2.1
155     /// Converts above to RdataShare open flags (may be adjusted by calling program)
156     extern int RSDOflags[];
157
158     /// Call-back function type to create named data channel (freed using "delete" operator)
159     typedef RdataShare * RcreateDataShareF(const char *name, RCOutputOp op, size_t siz);
160
161 greg 2.13 /// Provided data share function
162     extern RcreateDataShareF fileDataShare, mapDataShare;
163
164     #ifndef defDataShare
165     #define defDataShare mapDataShare // default data share creator
166     #endif
167 greg 2.1
168 greg 2.2 /// Modifiable ray-tracing flags for rcontrib
169 greg 2.6 #define RCcontrib (RTmask+1) // compute contributions? (r.t. coefficients)
170     #define RCmask (RTlimDist|RTimmIrrad|RCcontrib)
171 greg 2.1
172     /// rcontrib-like simulation manager (at most one such object)
173     class RcontribSimulManager : protected RtraceSimulManager {
174     protected:
175     static RayReportCall RctCall; // our callback for traced rays
176     ABitMap rowsDone; // bit mask of completed rows
177 greg 2.14 mutable uint32 nrDone; // current contiguous #rows done
178 greg 2.1 uint32 rInPos; // which row (record) is next on input?
179     uby8 nChan; // NCSAMP setting for this calculation
180     char dtyp; // data type ('f', 'd', or 'c')
181     uint16 dsiz; // N-component element size in bytes
182     RcontribOutput * outList; // ordered list of output channels
183     LUTAB modLUT; // modifier lookup table
184     SUBPROC * kid; // array of child processes
185     int32 * kidRow; // row assigned to each child
186     int nkids; // child process count (-1 in child)
187     bool UpdateRowsDone(int r);
188     int GetChild(bool forceWait = false);
189     bool StartKids(int n2go);
190     int StopKids(int n2end = 0);
191     void RunChild();
192     public:
193     RCOutputOp outOp; // output operation
194     RcreateDataShareF * cdsF; // data share creator
195 greg 2.6 int xres, yres; // output (picture) size
196 greg 2.1 uint32 accum; // # rays to accumulate per record
197     RcontribSimulManager(const char *octn = NULL)
198     : RtraceSimulManager(NULL, NULL, octn) {
199 greg 2.14 nrDone = rInPos = 0;
200 greg 2.1 nChan = 0;
201     dtyp = 'f';
202     dsiz = 0;
203     outList = NULL;
204     memset(&modLUT, 0, sizeof(modLUT));
205     modLUT.hashf = lu_shash;
206     modLUT.keycmp = strcmp;
207     modLUT.freek = efree;
208     modLUT.freed = FreeRcMod;
209     kid = NULL; kidRow = NULL; nkids = 0;
210     outOp = RCOnew;
211     cdsF = &defDataShare;
212 greg 2.6 xres = yres = 0;
213 greg 2.1 accum = 1;
214 greg 2.10 if (octname) {
215     SetTraceCall(&RctCall, this);
216     rtFlags |= RTtraceSources;
217     UpdateMode();
218     }
219 greg 2.1 }
220     ~RcontribSimulManager() {
221 greg 2.7 if (nkids >= 0) ClearModifiers();
222 greg 2.1 }
223 greg 2.2 /// Check modifiable ray-tracing computation flag(s)
224     bool HasFlag(int fl) const {
225     return ((rtFlags & RCmask & fl) != 0);
226     }
227     /// Set/reset modifiable ray-tracing computation flag(s)
228     bool SetFlag(int fl, bool val = true) {
229     if (!(fl &= RCmask)) return false;
230     if (val) rtFlags |= fl;
231     else rtFlags &= ~fl;
232     return true;
233     }
234 greg 2.1 /// Load octree and prepare renderer
235     bool LoadOctree(const char *octn) {
236 greg 2.10 if (octname) Cleanup(false);
237     if (!RtraceSimulManager::LoadOctree(octn))
238     return false;
239     SetTraceCall(&RctCall, this);
240     rtFlags |= RTtraceSources;
241     return UpdateMode();
242 greg 2.1 }
243     /// Prepare header from previous input (or clear)
244     bool NewHeader(const char *inspec=NULL) {
245     return RtraceSimulManager::NewHeader(inspec);
246     }
247     /// Add a string to header (adds newline if none)
248     bool AddHeader(const char *str) {
249     return RtraceSimulManager::AddHeader(str);
250     }
251     /// Append program line to header
252     bool AddHeader(int ac, char *av[]) {
253     return RtraceSimulManager::AddHeader(ac, av);
254     }
255     /// Get current header length in bytes
256     int GetHeadLen() const {
257     return RtraceSimulManager::GetHeadLen();
258     }
259     /// Get header lines if any
260     const char * GetHeadStr() const {
261     return RtraceSimulManager::GetHeadStr();
262     }
263     /// Look for specific header keyword, return value
264     const char * GetHeadStr(const char *key, bool inOK = false) const {
265     return RtraceSimulManager::GetHeadStr(key, inOK);
266     }
267     /// Set output format ('f', 'd', or 'c'), call before mods
268     bool SetDataFormat(int ty);
269     /// Get current format (and element size in bytes)
270     int GetFormat(int *siz = NULL) const {
271     if (siz) *siz = dsiz;
272     return dtyp;
273     }
274     /// Add a modifier and arguments, create output(s)
275     bool AddModifier(const char *modn, const char *outspec,
276     const char *prms = NULL,
277     const char *binval = NULL, int bincnt = 1);
278     /// Add a file of modifiers with associated arguments
279     bool AddModFile(const char *modfn, const char *outspec,
280     const char *prms = NULL,
281     const char *binval = NULL, int bincnt = 1);
282 greg 2.2 /// Get named rcontrib output (or list)
283     const RcontribOutput * GetOutput(const char *nm = NULL) const {
284     if (!nm) return outList;
285     const RcontribOutput * op = outList;
286     while (op && strcmp(op->GetName(), nm))
287     op = op->next;
288     return op;
289     }
290 greg 2.1 /// Open output channels and return # completed rows
291     int PrepOutput();
292     /// Are we ready to compute some records?
293     bool Ready() const {
294 greg 2.4 return (rowsDone.Length() > 0) & (accum > 0);
295 greg 2.1 }
296     /// Set number of computation threads (0 => #cores)
297     int SetThreadCount(int nt = 0);
298     /// Check thread count (1 means no multi-processing)
299     int NThreads() const {
300     return nkids + !nkids;
301     }
302     /// What is maximum row?
303     int GetRowMax() const {
304     if (!outList) return yres * (xres + !xres);
305     return outList->nRows;
306     }
307     /// Get current row count (# rows sent for computation)
308     int GetRowCount() const {
309     return rInPos;
310     }
311     /// Get # rows completed
312     int GetRowFinished() const {
313 greg 2.14 if (!nkids) return nrDone = rInPos;
314     nrDone = rowsDone.Find(nrDone, false);
315     if (nrDone == ABMend)
316     nrDone = rowsDone.Length();
317     return nrDone;
318 greg 2.1 }
319     /// Add a ray/bundle to compute next record (n=accum)
320     int ComputeRecord(const FVECT orig_direc[]);
321     /// Finish pending rays if multi-processing
322     bool FlushQueue() {
323     if (nkids <= 0) return true;
324     while (GetChild(true) >= 0)
325     ;
326     return true;
327     }
328 greg 2.7 /// Rewind calculation (previous results unchanged)
329     bool ResetRow(int r);
330     /// Clear the modifiers and close all outputs
331     void ClearModifiers() {
332 greg 2.1 if (rowsDone.Length()) {
333     SetThreadCount(1);
334     rowsDone.NewBitMap(0);
335 greg 2.14 nrDone = rInPos = 0;
336 greg 2.1 }
337     lu_done(&modLUT);
338     delete outList; outList = NULL;
339     nChan = 0;
340 greg 2.7 }
341     /// Close octree, free data, return status
342     int Cleanup(bool everything = false) {
343     ClearModifiers();
344 greg 2.9 cow_doneshare();
345 greg 2.10 if (everything) {
346     dtyp = 'f';
347     outOp = RCOnew;
348     cdsF = &defDataShare;
349     xres = yres = 0;
350     accum = 1;
351     rtFlags &= ~RCmask;
352     }
353 greg 2.1 return RtraceSimulManager::Cleanup(everything);
354     }
355     };
356
357 greg 2.8 extern const char * formstr(int f); // string from format
358
359 greg 2.1 #endif /* RcontribSimulManager_h */
