/* RCSid $Id: RcontribSimulManager.h,v 2.13 2025/10/23 16:33:39 greg Exp $ */ /* * RcontribSimulManager.h * * Rcontrib simulation manager class declaration * * Created by Greg Ward on 10/11/2024. */ #ifndef RcontribSimulManager_h #define RcontribSimulManager_h #include "RtraceSimulManager.h" #include "RdataShare.h" #include "lookup.h" #include "rtprocess.h" /* * As with other single-object classes, many global variable affect * behavior. Besides rendering parameters, there are spectral parameters * and output dimensions taken from the environment. * * NOTE: "record" and "row" are used interchangeably throughout. */ extern char RCCONTEXT[]; // global rcontrib context class RcontribSimulManager; // need forward decl /// Shared data object for record output (includes header; may be write-only) class RcontribOutput { RcontribOutput * next; // next in sorted list char * ofname; // output file name uint32 rowCountPos; // row count position in header void * rowp; // current row memory bool NewHeader(const RcontribSimulManager *rcp); int CheckHeader(const RcontribSimulManager *rcp); public: RdataShare * rData; // data sharing object size_t rowBytes; // byte count per row const char * omod; // single modifier (or NULL) int32 obin; // single output bin (or -1) uint32 begData; // start of data (type-aligned) int32 curRow; // current output row uint32 nRows; // total number of rows RcontribOutput(const char *fnm = NULL) { next = NULL; omod = NULL; obin = -1; rData = NULL; ofname = savqstr(fnm); rowBytes = 0; nRows = 0; rowp = NULL; curRow = -1; } ~RcontribOutput() { DoneRow(); delete rData; delete next; freeqstr(ofname); } /// Return output channel name const char * GetName() const { if (rData) return rData->GetName(); return ofname; } /// Update output row count bool SetRowsDone(int r) { if (!rData | (0 > r) | (r > nRows)) return false; char * rbuf = (char *)rData->GetMemory(rowCountPos, 17, 0); sprintf(rbuf, "%-16d", r); rbuf[16] = '\n'; // replaces nul byte return rData->ReleaseMemory(rbuf, RDSwrite); } /// Get buffer for indicated row (contents may be random) void * GetRow(int r) { if (!rData | (r < 0)) return NULL; if (r != curRow) { DoneRow(); if (r < nRows) rowp = rData->GetMemory(begData + r*rowBytes, rowBytes, 0); if (rowp) curRow = r; } return rowp; } /// Current row with byte offset void * InsertionP(int coffset) const { if (!rowp | (coffset < 0) | (coffset >= rowBytes)) return NULL; return (char *)rowp + coffset; } /// Release current row, writing contents void DoneRow() { if (rowp) rData->ReleaseMemory(rowp, RDSwrite); rowp = NULL; curRow = -1; } /// Get next in list const RcontribOutput * Next() const { return next; } RcontribOutput * Next() { return next; } /// RcontribSimulManager gets full access friend class RcontribSimulManager; }; typedef double DCOLORV; // color accumulator type /// Free an RcontribMod extern lut_free_t FreeRcMod; /* * General RcontribSimulManager class operation: * * 1) Call LoadOctree(), then alter the header as desired * 2) Set number of spectral samples (NCSAMP) and call SetDataFormat() * 3) Set xres and yres to desired dimensions (xres>0 for picture output) * 4) Call AddModifier() and AddModFile() to indicate tracked modifiers * 5) Set outOp and cdsF according to desired output/recovery * 6) Set desired computation flags via SetFlag() * 7) Call PrepOutput() to open output channels * 8) Call SetThreadCount() to fork children if desired * 9) Set accum to the number of ray samples per record * 10) Call ComputeRecord() with accum ray samples * 11) Continue until GetRowMax() records have been sent * 12) Call Cleanup() * * The order of some of these calls may be changed. Technically, the octree * may be loaded anytime before PrepOutput() is called. Also, SetThreadCount() * may be called anytime *after* PrepOutput(), and may be interleaved with * calls to ComputeRecord(). The accum setting may be changed at any time. * Finally, it is possible to restart the output using ResetRow(), and * a zero argument will rewind to the beginning, whence all records * may be recalculated. The previous output rows are not zeroed or deleted, * but are overwritten as the calculation proceeds from the new starting point. * However, the output file(s) will indicate in the NROWS= line in the header * that only the newly calculated rows are present. If you wish to start over * with a different set of modifiers or outputs, call ClearModifiers() instead, * which keeps the current octree in memory. This call also returns to single * process mode if any children were running. * * It is not possible to write to standard output, but the output * model is quite flexible thanks to the RdataShare polymorphic class. * The current default output class creates a shared, memory-mapped file, * which is the most efficient object on most systems. * * ASCII output is not supported, so full data recovery is. */ /// Output channel opening options: new/exclusive, overwrite if exists, or recover data enum RCOutputOp {RCOnew=0, RCOforce, RCOrecover}; /// Converts above to RdataShare open flags (may be adjusted by calling program) extern int RSDOflags[]; /// Call-back function type to create named data channel (freed using "delete" operator) typedef RdataShare * RcreateDataShareF(const char *name, RCOutputOp op, size_t siz); /// Provided data share function extern RcreateDataShareF fileDataShare, mapDataShare; #ifndef defDataShare #define defDataShare mapDataShare // default data share creator #endif /// Modifiable ray-tracing flags for rcontrib #define RCcontrib (RTmask+1) // compute contributions? (r.t. coefficients) #define RCmask (RTlimDist|RTimmIrrad|RCcontrib) /// rcontrib-like simulation manager (at most one such object) class RcontribSimulManager : protected RtraceSimulManager { protected: static RayReportCall RctCall; // our callback for traced rays ABitMap rowsDone; // bit mask of completed rows uint32 rInPos; // which row (record) is next on input? uby8 nChan; // NCSAMP setting for this calculation char dtyp; // data type ('f', 'd', or 'c') uint16 dsiz; // N-component element size in bytes RcontribOutput * outList; // ordered list of output channels LUTAB modLUT; // modifier lookup table SUBPROC * kid; // array of child processes int32 * kidRow; // row assigned to each child int nkids; // child process count (-1 in child) bool UpdateRowsDone(int r); int GetChild(bool forceWait = false); bool StartKids(int n2go); int StopKids(int n2end = 0); void RunChild(); public: RCOutputOp outOp; // output operation RcreateDataShareF * cdsF; // data share creator int xres, yres; // output (picture) size uint32 accum; // # rays to accumulate per record RcontribSimulManager(const char *octn = NULL) : RtraceSimulManager(NULL, NULL, octn) { rInPos = 0; nChan = 0; dtyp = 'f'; dsiz = 0; outList = NULL; memset(&modLUT, 0, sizeof(modLUT)); modLUT.hashf = lu_shash; modLUT.keycmp = strcmp; modLUT.freek = efree; modLUT.freed = FreeRcMod; kid = NULL; kidRow = NULL; nkids = 0; outOp = RCOnew; cdsF = &defDataShare; xres = yres = 0; accum = 1; if (octname) { SetTraceCall(&RctCall, this); rtFlags |= RTtraceSources; UpdateMode(); } } ~RcontribSimulManager() { if (nkids >= 0) ClearModifiers(); } /// Check modifiable ray-tracing computation flag(s) bool HasFlag(int fl) const { return ((rtFlags & RCmask & fl) != 0); } /// Set/reset modifiable ray-tracing computation flag(s) bool SetFlag(int fl, bool val = true) { if (!(fl &= RCmask)) return false; if (val) rtFlags |= fl; else rtFlags &= ~fl; return true; } /// Load octree and prepare renderer bool LoadOctree(const char *octn) { if (octname) Cleanup(false); if (!RtraceSimulManager::LoadOctree(octn)) return false; SetTraceCall(&RctCall, this); rtFlags |= RTtraceSources; return UpdateMode(); } /// Prepare header from previous input (or clear) bool NewHeader(const char *inspec=NULL) { return RtraceSimulManager::NewHeader(inspec); } /// Add a string to header (adds newline if none) bool AddHeader(const char *str) { return RtraceSimulManager::AddHeader(str); } /// Append program line to header bool AddHeader(int ac, char *av[]) { return RtraceSimulManager::AddHeader(ac, av); } /// Get current header length in bytes int GetHeadLen() const { return RtraceSimulManager::GetHeadLen(); } /// Get header lines if any const char * GetHeadStr() const { return RtraceSimulManager::GetHeadStr(); } /// Look for specific header keyword, return value const char * GetHeadStr(const char *key, bool inOK = false) const { return RtraceSimulManager::GetHeadStr(key, inOK); } /// Set output format ('f', 'd', or 'c'), call before mods bool SetDataFormat(int ty); /// Get current format (and element size in bytes) int GetFormat(int *siz = NULL) const { if (siz) *siz = dsiz; return dtyp; } /// Add a modifier and arguments, create output(s) bool AddModifier(const char *modn, const char *outspec, const char *prms = NULL, const char *binval = NULL, int bincnt = 1); /// Add a file of modifiers with associated arguments bool AddModFile(const char *modfn, const char *outspec, const char *prms = NULL, const char *binval = NULL, int bincnt = 1); /// Get named rcontrib output (or list) const RcontribOutput * GetOutput(const char *nm = NULL) const { if (!nm) return outList; const RcontribOutput * op = outList; while (op && strcmp(op->GetName(), nm)) op = op->next; return op; } /// Open output channels and return # completed rows int PrepOutput(); /// Are we ready to compute some records? bool Ready() const { return (rowsDone.Length() > 0) & (accum > 0); } /// Set number of computation threads (0 => #cores) int SetThreadCount(int nt = 0); /// Check thread count (1 means no multi-processing) int NThreads() const { return nkids + !nkids; } /// What is maximum row? int GetRowMax() const { if (!outList) return yres * (xres + !xres); return outList->nRows; } /// Get current row count (# rows sent for computation) int GetRowCount() const { return rInPos; } /// Get # rows completed int GetRowFinished() const { if (!nkids) return rInPos; uint32 nDone = rowsDone.Find(0, false); if (nDone == ABMend) return rowsDone.Length(); return nDone; } /// Add a ray/bundle to compute next record (n=accum) int ComputeRecord(const FVECT orig_direc[]); /// Finish pending rays if multi-processing bool FlushQueue() { if (nkids <= 0) return true; while (GetChild(true) >= 0) ; return true; } /// Rewind calculation (previous results unchanged) bool ResetRow(int r); /// Clear the modifiers and close all outputs void ClearModifiers() { if (rowsDone.Length()) { SetThreadCount(1); rowsDone.NewBitMap(0); rInPos = 0; } lu_done(&modLUT); delete outList; outList = NULL; nChan = 0; } /// Close octree, free data, return status int Cleanup(bool everything = false) { ClearModifiers(); cow_doneshare(); if (everything) { dtyp = 'f'; outOp = RCOnew; cdsF = &defDataShare; xres = yres = 0; accum = 1; rtFlags &= ~RCmask; } return RtraceSimulManager::Cleanup(everything); } }; extern const char * formstr(int f); // string from format #endif /* RcontribSimulManager_h */
