root/radiance/src/rt/RcontribSimulManager.h
Revision: 2.12
Committed: Fri Oct 17 17:43:53 2025 UTC (4 days, 15 hours ago) by greg
Changes since 2.11: +1 -6 lines
refactor(rxcontrib): Privatized things that didn't need to be extern
1 /* RCSid $Id: RcontribSimulManager.h,v 2.11 2025/08/18 17:55:03 greg Exp $ */
2 /*
3 * RcontribSimulManager.h
4 *
5 * Rcontrib simulation manager class declaration
6 *
7 * Created by Greg Ward on 10/11/2024.
8 */
9
10 #ifndef RcontribSimulManager_h
11 #define RcontribSimulManager_h
12
13 #include "RtraceSimulManager.h"
14 #include "RdataShare.h"
15 #include "lookup.h"
16 #include "rtprocess.h"
17
18 /*
19 * As with other single-object classes, many global variable affect
20 * behavior. Besides rendering parameters, there are spectral parameters
21 * and output dimensions taken from the environment.
22 *
23 * NOTE: "record" and "row" are used interchangeably throughout.
24 */
25
26 extern char RCCONTEXT[]; // global rcontrib context
27
28 class RcontribSimulManager; // need forward decl
29
30 /// Shared data object for record output (includes header; may be write-only)
31 class RcontribOutput {
32 RcontribOutput * next; // next in sorted list
33 char * ofname; // output file name
34 uint32 rowCountPos; // row count position in header
35 void * rowp; // current row memory
36 bool NewHeader(const RcontribSimulManager *rcp);
37 int CheckHeader(const RcontribSimulManager *rcp);
38 public:
39 RdataShare * rData; // data sharing object
40 size_t rowBytes; // byte count per row
41 const char * omod; // single modifier (or NULL)
42 int32 obin; // single output bin (or -1)
43 uint32 begData; // start of data (type-aligned)
44 int32 curRow; // current output row
45 uint32 nRows; // total number of rows
46 RcontribOutput(const char *fnm = NULL) {
47 next = NULL;
48 omod = NULL;
49 obin = -1;
50 rData = NULL;
51 ofname = savqstr(fnm);
52 rowBytes = 0;
53 nRows = 0;
54 rowp = NULL; curRow = -1;
55 }
56 ~RcontribOutput() {
57 DoneRow();
58 delete rData;
59 delete next;
60 freeqstr(ofname);
61 }
62 /// Return output channel name
63 const char * GetName() const {
64 if (rData) return rData->GetName();
65 return ofname;
66 }
67 /// Update output row count
68 bool SetRowsDone(int r) {
69 if (!rData | (0 > r) | (r > nRows)) return false;
70 char * rbuf = (char *)rData->GetMemory(rowCountPos, 17, 0);
71 sprintf(rbuf, "%-16d", r);
72 rbuf[16] = '\n'; // replaces nul byte
73 return rData->ReleaseMemory(rbuf, RDSwrite);
74 }
75 /// Get buffer for indicated row (contents may be random)
76 void * GetRow(int r) {
77 if (!rData | (r < 0)) return NULL;
78 if (r != curRow) {
79 DoneRow();
80 if (r < nRows)
81 rowp = rData->GetMemory(begData + r*rowBytes,
82 rowBytes, 0);
83 if (rowp) curRow = r;
84 }
85 return rowp;
86 }
87 /// Current row with byte offset
88 void * InsertionP(int coffset) const {
89 if (!rowp | (coffset < 0) | (coffset >= rowBytes))
90 return NULL;
91 return (char *)rowp + coffset;
92 }
93 /// Release current row, writing contents
94 void DoneRow() {
95 if (rowp) rData->ReleaseMemory(rowp, RDSwrite);
96 rowp = NULL; curRow = -1;
97 }
98 /// Get next in list
99 const RcontribOutput * Next() const {
100 return next;
101 }
102 RcontribOutput * Next() {
103 return next;
104 }
105 /// RcontribSimulManager gets full access
106 friend class RcontribSimulManager;
107 };
108
109 typedef double DCOLORV; // color accumulator type
110
111 /// Free an RcontribMod
112 extern lut_free_t FreeRcMod;
113
114 /*
115 * General RcontribSimulManager class operation:
116 *
117 * 1) Call LoadOctree(), then alter the header as desired
118 * 2) Set number of spectral samples (NCSAMP) and call SetDataFormat()
119 * 3) Set xres and yres to desired dimensions (xres>0 for picture output)
120 * 4) Call AddModifier() and AddModFile() to indicate tracked modifiers
121 * 5) Set outOp and cdsF according to desired output/recovery
122 * 6) Set desired computation flags via SetFlag()
123 * 7) Call PrepOutput() to open output channels
124 * 8) Call SetThreadCount() to fork children if desired
125 * 9) Set accum to the number of ray samples per record
126 * 10) Call ComputeRecord() with accum ray samples
127 * 11) Continue until GetRowMax() records have been sent
128 * 12) Call Cleanup()
129 *
130 * The order of some of these calls may be changed. Technically, the octree
131 * may be loaded anytime before PrepOutput() is called. Also, SetThreadCount()
132 * may be called anytime *after* PrepOutput(), and may be interleaved with
133 * calls to ComputeRecord(). The accum setting may be changed at any time.
134 * Finally, it is possible to restart the output using ResetRow(), and
135 * a zero argument will rewind to the beginning, whence all records
136 * may be recalculated. The previous output rows are not zeroed or deleted,
137 * but are overwritten as the calculation proceeds from the new starting point.
138 * However, the output file(s) will indicate in the NROWS= line in the header
139 * that only the newly calculated rows are present. If you wish to start over
140 * with a different set of modifiers or outputs, call ClearModifiers() instead,
141 * which keeps the current octree in memory. This call also returns to single
142 * process mode if any children were running.
143 *
144 * It is not possible to write to standard output, but the output
145 * model is quite flexible thanks to the RdataShare polymorphic class.
146 * The current default output class creates a shared, memory-mapped file,
147 * which is the most efficient object on most systems.
148 *
149 * ASCII output is not supported, so full data recovery is.
150 */
151
152 /// Output channel opening options: new/exclusive, overwrite if exists, or recover data
153 enum RCOutputOp {RCOnew=0, RCOforce, RCOrecover};
154
155 /// Converts above to RdataShare open flags (may be adjusted by calling program)
156 extern int RSDOflags[];
157
158 /// Call-back function type to create named data channel (freed using "delete" operator)
159 typedef RdataShare * RcreateDataShareF(const char *name, RCOutputOp op, size_t siz);
160
161 /// Our default data share function
162 extern RcreateDataShareF defDataShare;
163
164 /// Modifiable ray-tracing flags for rcontrib
165 #define RCcontrib (RTmask+1) // compute contributions? (r.t. coefficients)
166 #define RCmask (RTlimDist|RTimmIrrad|RCcontrib)
167
168 /// rcontrib-like simulation manager (at most one such object)
169 class RcontribSimulManager : protected RtraceSimulManager {
170 protected:
171 static RayReportCall RctCall; // our callback for traced rays
172 ABitMap rowsDone; // bit mask of completed rows
173 uint32 rInPos; // which row (record) is next on input?
174 uby8 nChan; // NCSAMP setting for this calculation
175 char dtyp; // data type ('f', 'd', or 'c')
176 uint16 dsiz; // N-component element size in bytes
177 RcontribOutput * outList; // ordered list of output channels
178 LUTAB modLUT; // modifier lookup table
179 SUBPROC * kid; // array of child processes
180 int32 * kidRow; // row assigned to each child
181 int nkids; // child process count (-1 in child)
182 bool UpdateRowsDone(int r);
183 int GetChild(bool forceWait = false);
184 bool StartKids(int n2go);
185 int StopKids(int n2end = 0);
186 void RunChild();
187 public:
188 RCOutputOp outOp; // output operation
189 RcreateDataShareF * cdsF; // data share creator
190 int xres, yres; // output (picture) size
191 uint32 accum; // # rays to accumulate per record
192 RcontribSimulManager(const char *octn = NULL)
193 : RtraceSimulManager(NULL, NULL, octn) {
194 rInPos = 0;
195 nChan = 0;
196 dtyp = 'f';
197 dsiz = 0;
198 outList = NULL;
199 memset(&modLUT, 0, sizeof(modLUT));
200 modLUT.hashf = lu_shash;
201 modLUT.keycmp = strcmp;
202 modLUT.freek = efree;
203 modLUT.freed = FreeRcMod;
204 kid = NULL; kidRow = NULL; nkids = 0;
205 outOp = RCOnew;
206 cdsF = &defDataShare;
207 xres = yres = 0;
208 accum = 1;
209 if (octname) {
210 SetTraceCall(&RctCall, this);
211 rtFlags |= RTtraceSources;
212 UpdateMode();
213 }
214 }
215 ~RcontribSimulManager() {
216 if (nkids >= 0) ClearModifiers();
217 }
218 /// Check modifiable ray-tracing computation flag(s)
219 bool HasFlag(int fl) const {
220 return ((rtFlags & RCmask & fl) != 0);
221 }
222 /// Set/reset modifiable ray-tracing computation flag(s)
223 bool SetFlag(int fl, bool val = true) {
224 if (!(fl &= RCmask)) return false;
225 if (val) rtFlags |= fl;
226 else rtFlags &= ~fl;
227 return true;
228 }
229 /// Load octree and prepare renderer
230 bool LoadOctree(const char *octn) {
231 if (octname) Cleanup(false);
232 if (!RtraceSimulManager::LoadOctree(octn))
233 return false;
234 SetTraceCall(&RctCall, this);
235 rtFlags |= RTtraceSources;
236 return UpdateMode();
237 }
238 /// Prepare header from previous input (or clear)
239 bool NewHeader(const char *inspec=NULL) {
240 return RtraceSimulManager::NewHeader(inspec);
241 }
242 /// Add a string to header (adds newline if none)
243 bool AddHeader(const char *str) {
244 return RtraceSimulManager::AddHeader(str);
245 }
246 /// Append program line to header
247 bool AddHeader(int ac, char *av[]) {
248 return RtraceSimulManager::AddHeader(ac, av);
249 }
250 /// Get current header length in bytes
251 int GetHeadLen() const {
252 return RtraceSimulManager::GetHeadLen();
253 }
254 /// Get header lines if any
255 const char * GetHeadStr() const {
256 return RtraceSimulManager::GetHeadStr();
257 }
258 /// Look for specific header keyword, return value
259 const char * GetHeadStr(const char *key, bool inOK = false) const {
260 return RtraceSimulManager::GetHeadStr(key, inOK);
261 }
262 /// Set output format ('f', 'd', or 'c'), call before mods
263 bool SetDataFormat(int ty);
264 /// Get current format (and element size in bytes)
265 int GetFormat(int *siz = NULL) const {
266 if (siz) *siz = dsiz;
267 return dtyp;
268 }
269 /// Add a modifier and arguments, create output(s)
270 bool AddModifier(const char *modn, const char *outspec,
271 const char *prms = NULL,
272 const char *binval = NULL, int bincnt = 1);
273 /// Add a file of modifiers with associated arguments
274 bool AddModFile(const char *modfn, const char *outspec,
275 const char *prms = NULL,
276 const char *binval = NULL, int bincnt = 1);
277 /// Get named rcontrib output (or list)
278 const RcontribOutput * GetOutput(const char *nm = NULL) const {
279 if (!nm) return outList;
280 const RcontribOutput * op = outList;
281 while (op && strcmp(op->GetName(), nm))
282 op = op->next;
283 return op;
284 }
285 /// Open output channels and return # completed rows
286 int PrepOutput();
287 /// Are we ready to compute some records?
288 bool Ready() const {
289 return (rowsDone.Length() > 0) & (accum > 0);
290 }
291 /// Set number of computation threads (0 => #cores)
292 int SetThreadCount(int nt = 0);
293 /// Check thread count (1 means no multi-processing)
294 int NThreads() const {
295 return nkids + !nkids;
296 }
297 /// What is maximum row?
298 int GetRowMax() const {
299 if (!outList) return yres * (xres + !xres);
300 return outList->nRows;
301 }
302 /// Get current row count (# rows sent for computation)
303 int GetRowCount() const {
304 return rInPos;
305 }
306 /// Get # rows completed
307 int GetRowFinished() const {
308 if (!nkids) return rInPos;
309 uint32 nDone = rowsDone.Find(0, false);
310 if (nDone == ABMend)
311 return rowsDone.Length();
312 return nDone;
313 }
314 /// Add a ray/bundle to compute next record (n=accum)
315 int ComputeRecord(const FVECT orig_direc[]);
316 /// Finish pending rays if multi-processing
317 bool FlushQueue() {
318 if (nkids <= 0) return true;
319 while (GetChild(true) >= 0)
320 ;
321 return true;
322 }
323 /// Rewind calculation (previous results unchanged)
324 bool ResetRow(int r);
325 /// Clear the modifiers and close all outputs
326 void ClearModifiers() {
327 if (rowsDone.Length()) {
328 SetThreadCount(1);
329 rowsDone.NewBitMap(0);
330 rInPos = 0;
331 }
332 lu_done(&modLUT);
333 delete outList; outList = NULL;
334 nChan = 0;
335 }
336 /// Close octree, free data, return status
337 int Cleanup(bool everything = false) {
338 ClearModifiers();
339 cow_doneshare();
340 if (everything) {
341 dtyp = 'f';
342 outOp = RCOnew;
343 cdsF = &defDataShare;
344 xres = yres = 0;
345 accum = 1;
346 rtFlags &= ~RCmask;
347 }
348 return RtraceSimulManager::Cleanup(everything);
349 }
350 };
351
352 extern const char * formstr(int f); // string from format
353
354 #endif /* RcontribSimulManager_h */
