1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: RcontribSimulManager.cpp,v 2.12 2025/10/16 18:36:23 greg Exp $"; |
3 |
#endif |
4 |
5 |
* RcontribSimulManager.cpp |
6 |
7 |
* Rcontrib simulation manager implementation |
8 |
9 |
* Created by Greg Ward on 10/17/2024. |
10 |
11 |
12 |
#include <unistd.h> |
13 |
#include <ctype.h> |
14 |
#include "platform.h" |
15 |
#include "selcall.h" |
16 |
#include "RcontribSimulManager.h" |
17 |
#include "func.h" |
18 |
#include "resolu.h" |
19 |
#include "source.h" |
20 |
21 |
char RCCONTEXT[] = "RC."; |
22 |
23 |
extern const char HDRSTR[]; |
24 |
extern const char BIGEND[]; |
25 |
extern const char FMTSTR[]; |
26 |
27 |
// new/exclusive, overwrite if exists, or recover data |
28 |
int RSDOflags[] = {RDSwrite|RDSexcl|RDSextend, RDSwrite|RDSextend, |
29 |
RDSread|RDSwrite}; |
30 |
31 |
static const char ROWZEROSTR[] = "NROWS=0000000000000000\n"; |
32 |
#define LNROWSTR 6 |
33 |
34 |
// Modifier channel for recording contributions (no constructor/destructor) |
35 |
struct RcontribMod { |
36 |
RcontribOutput * opl; // pointer to first output channel |
37 |
char * params; // parameters string |
38 |
EPNODE * binv; // bin expression (NULL if 1 bin) |
39 |
int nbins; // bin count this modifier |
40 |
int coffset; // column offset in bytes |
41 |
DCOLORV cbin[1]; // bin accumulator (extends struct) |
42 |
/// Access specific (spectral) color bin |
43 |
DCOLORV * operator[](int n) { |
44 |
if ((n < 0) | (n >= nbins)) return NULL; |
45 |
return cbin + n*NCSAMP; |
46 |
47 |
48 |
49 |
// Struct used to assign record calculation to child |
50 |
struct RowAssignment { |
51 |
uint32 row; // row to do |
52 |
uint32 ac; // accumulation count |
53 |
54 |
55 |
// Get format identifier |
56 |
const char * |
57 |
formstr(int f) |
58 |
59 |
switch (f) { |
60 |
case 'a': return("ascii"); |
61 |
case 'f': return("float"); |
62 |
case 'd': return("double"); |
63 |
case 'c': return(NCSAMP==3 ? COLRFMT : SPECFMT); |
64 |
65 |
return("unknown"); |
66 |
67 |
68 |
// Our default data share function |
69 |
RdataShare * |
70 |
defDataShare(const char *name, RCOutputOp op, size_t siz) |
71 |
72 |
return new RdataShareMap(name, RSDOflags[op], siz); |
73 |
74 |
75 |
// Allocate rcontrib accumulator |
76 |
RcontribMod * |
77 |
NewRcMod(const char *prms, const char *binexpr, int ncbins) |
78 |
79 |
if (!prms) prms = ""; |
80 |
if ((ncbins > 1) & !binexpr) { |
81 |
error(USER, "missing bin expression"); |
82 |
return NULL; |
83 |
84 |
if (ncbins < 1) ncbins = 1; |
85 |
86 |
RcontribMod * mp = (RcontribMod *)ecalloc(1, sizeof(RcontribMod) + |
87 |
sizeof(DCOLORV)*(NCSAMP*ncbins-1) + |
88 |
strlen(prms)+1); |
89 |
90 |
if (binexpr) { // get/check bin expression |
91 |
mp->binv = eparse(const_cast<char *>(binexpr)); |
92 |
if (mp->binv->type == NUM) { // constant expression (0)? |
93 |
if ((int)evalue(mp->binv) != 0) { |
94 |
sprintf(errmsg, "illegal non-zero constant for bin (%s)", |
95 |
binexpr); |
96 |
error(USER, errmsg); |
97 |
98 |
if (ncbins > 1) { |
99 |
sprintf(errmsg, "bad bin count (%d should be 1)", ncbins); |
100 |
101 |
102 |
epfree(mp->binv, true); |
103 |
mp->binv = NULL; |
104 |
prms = ""; |
105 |
ncbins = 1; |
106 |
107 |
108 |
mp->params = strcpy((char *)(mp->cbin + ncbins*NCSAMP), prms); |
109 |
mp->nbins = ncbins; |
110 |
return mp; |
111 |
112 |
113 |
// Free an RcontribMod |
114 |
void |
115 |
FreeRcMod(void *p) |
116 |
117 |
if (!p) return; |
118 |
EPNODE * bep = (*(RcontribMod *)p).binv; |
119 |
if (bep) epfree(bep, true); |
120 |
efree(p); |
121 |
122 |
123 |
// Set output format ('f', 'd', or 'c') |
124 |
bool |
125 |
RcontribSimulManager::SetDataFormat(int ty) |
126 |
127 |
if (outList) { |
128 |
error(INTERNAL, "cannot call SetDataFormat() after AddModifier()"); |
129 |
return false; |
130 |
131 |
switch (ty) { |
132 |
case 'f': |
133 |
dsiz = sizeof(float)*NCSAMP; |
134 |
break; |
135 |
case 'd': |
136 |
dsiz = sizeof(double)*NCSAMP; |
137 |
break; |
138 |
case 'c': |
139 |
dsiz = LSCOLR; |
140 |
break; |
141 |
default: |
142 |
sprintf(errmsg, "unsupported output format '%c'", ty); |
143 |
error(INTERNAL, errmsg); |
144 |
return false; |
145 |
146 |
dtyp = ty; |
147 |
return true; |
148 |
149 |
150 |
// static call-back for rcontrib ray-tracing |
151 |
int |
152 |
RcontribSimulManager::RctCall(RAY *r, void *cd) |
153 |
154 |
if (!r->ro || r->ro->omod == OVOID) // hit nothing? |
155 |
return 0; |
156 |
// shadow ray not on source? |
157 |
if (r->rsrc >= 0 && source[r->rsrc].so != r->ro) |
158 |
return 0; |
159 |
160 |
const char * mname = objptr(r->ro->omod)->oname; |
161 |
RcontribSimulManager * rcp = (RcontribSimulManager *)cd; |
162 |
RcontribMod * mp = (RcontribMod *)lu_find(&rcp->modLUT,mname)->data; |
163 |
if (!mp) |
164 |
return 0; // not in our modifier list |
165 |
166 |
int bi = 0; // get bin index |
167 |
if (mp->binv) { |
168 |
worldfunc(RCCONTEXT, r); |
169 |
set_eparams(mp->params); |
170 |
double bval = evalue(mp->binv); |
171 |
if (bval <= -.5) |
172 |
return 0; // silently ignore negative bin index |
173 |
bi = int(bval + .5); |
174 |
175 |
DCOLORV * dvp = (*mp)[bi]; |
176 |
if (!dvp) { |
177 |
sprintf(errmsg, "bad bin number for '%s' (%d ignored)", mname, bi); |
178 |
error(WARNING, errmsg); |
179 |
return 0; |
180 |
181 |
SCOLOR contr; |
182 |
raycontrib(contr, r, PRIMARY); // compute coefficient |
183 |
if (rcp->HasFlag(RCcontrib)) |
184 |
smultscolor(contr, r->rcol); // -> value contribution |
185 |
186 |
for (int i = 0; i < NCSAMP; i++) |
187 |
*dvp++ += contr[i]; // accumulate color/spectrum |
188 |
return 1; |
189 |
190 |
191 |
// check for given format type in string, return last char position |
192 |
static int |
193 |
hasFormat(const char *tst, const char *match) |
194 |
195 |
static const char allPoss[] = "%diouxXfFeEgGaAcsb"; |
196 |
const char * s = tst; |
197 |
while (*s) { |
198 |
if (*s++ != '%') |
199 |
continue; |
200 |
while (!strchr(allPoss, *s)) |
201 |
s++; |
202 |
if (strchr(match, *s)) |
203 |
break; |
204 |
s++; |
205 |
206 |
return (*s != '\0')*(s - tst); |
207 |
208 |
209 |
// Add a modifier and arguments, opening output file(s) |
210 |
bool |
211 |
RcontribSimulManager::AddModifier(const char *modn, const char *outspec, |
212 |
const char *prms, const char *binval, int bincnt) |
213 |
214 |
if (!modn | !outspec || !*modn | !*outspec) { |
215 |
error(WARNING, "ignoring bad call to AddModifier()"); |
216 |
return false; |
217 |
218 |
if (*outspec == '!') { |
219 |
error(USER, "command output not supported by RcontribSimulManager"); |
220 |
return false; |
221 |
222 |
if (!nChan) { // initial call? |
223 |
if ((xres < 0) | (yres <= 0)) { |
224 |
error(USER, "xres, yres must be set before first modifier"); |
225 |
return false; |
226 |
227 |
if (!SetDataFormat(dtyp)) |
228 |
return false; |
229 |
nChan = NCSAMP; |
230 |
} else if (nChan != NCSAMP) { |
231 |
error(USER, "# spectral channels must be fixed in AddModifier()"); |
232 |
return false; |
233 |
234 |
if (Ready()) { |
235 |
error(INTERNAL, "call to AddModifier() after PrepOutput()"); |
236 |
return false; |
237 |
238 |
LUENT * lp = lu_find(&modLUT, modn); |
239 |
if (lp->data) { |
240 |
sprintf(errmsg, "duplicate modifier '%s'", modn); |
241 |
242 |
return false; |
243 |
244 |
if (!lp->key) // create new entry |
245 |
lp->key = strcpy((char *)emalloc(strlen(modn)+1), modn); |
246 |
247 |
RcontribMod * mp = NewRcMod(prms, binval, bincnt); |
248 |
if (!mp) return false; |
249 |
lp->data = (char *)mp; |
250 |
const int modndx = hasFormat(outspec, "sb"); |
251 |
const int binndx = hasFormat(outspec, "diouxX"); |
252 |
int bin0 = 0; |
253 |
char fnbuf[512]; |
254 |
if (!modndx || (binndx > 0) & (modndx > binndx)) |
255 |
sprintf(fnbuf, outspec, bin0, modn); |
256 |
else |
257 |
sprintf(fnbuf, outspec, modn, bin0); |
258 |
RcontribOutput * olast = NULL; |
259 |
RcontribOutput * op; |
260 |
for (op = outList; op; op = (olast=op)->next) { |
261 |
if (strcmp(op->GetName(), fnbuf)) |
262 |
continue; |
263 |
if (modndx) { // this ain't right |
264 |
sprintf(errmsg, "output name collision for '%s'", fnbuf); |
265 |
266 |
return false; |
267 |
268 |
if ((binndx > 0) & (xres > 0)) { |
269 |
sprintf(fnbuf, outspec, ++bin0); |
270 |
continue; // each bin goes to another image |
271 |
272 |
mp->coffset = op->rowBytes; // else add to what's there |
273 |
break; |
274 |
275 |
if (!op) { // create new output channel? |
276 |
op = new RcontribOutput(fnbuf); |
277 |
if (olast) olast->next = op; |
278 |
else outList = op; |
279 |
280 |
mp->opl = op; // first (maybe only) output channel |
281 |
if (modndx) // remember modifier if part of name |
282 |
op->omod = lp->key; |
283 |
if (binndx) { // append output image/bin list |
284 |
op->rowBytes += dsiz; |
285 |
op->obin = bin0; |
286 |
for (bincnt = 1; bincnt < mp->nbins; bincnt++) { |
287 |
288 |
sprintf(fnbuf, outspec, bin0+bincnt, modn); |
289 |
else |
290 |
sprintf(fnbuf, outspec, modn, bin0+bincnt); |
291 |
if (!op->next) { |
292 |
olast = op; |
293 |
olast->next = op = new RcontribOutput(fnbuf); |
294 |
if (modndx) op->omod = lp->key; |
295 |
op->obin = bin0+bincnt; |
296 |
} else { |
297 |
op = op->next; |
298 |
CHECK(op->obin != bin0+bincnt, CONSISTENCY, |
299 |
"bin number mismatch in AddModifier()"); |
300 |
301 |
CHECK(op->rowBytes != mp->coffset, CONSISTENCY, |
302 |
"row offset mismatch in AddModifier()"); |
303 |
304 |
305 |
} else // else send all results to this channel |
306 |
op->rowBytes += mp->nbins*dsiz; |
307 |
return true; |
308 |
309 |
310 |
// Add a file of modifiers with associated arguments |
311 |
bool |
312 |
RcontribSimulManager::AddModFile(const char *modfn, const char *outspec, |
313 |
const char *prms, |
314 |
315 |
316 |
char * path = getpath(const_cast<char *>(modfn), |
317 |
getrlibpath(), R_OK); |
318 |
FILE * fp; |
319 |
if (!path || !(fp = fopen(path, "r"))) { |
320 |
sprintf(errmsg, "cannot %s modifier file '%s'", |
321 |
path ? "open" : "find", modfn); |
322 |
error(SYSTEM, errmsg); |
323 |
return false; |
324 |
325 |
char mod[MAXSTR]; |
326 |
while (fgetword(mod, sizeof(mod), fp)) |
327 |
if (!AddModifier(mod, outspec, prms, binval, bincnt)) { |
328 |
fclose(fp); |
329 |
return false; |
330 |
331 |
fclose(fp); |
332 |
return true; |
333 |
334 |
335 |
// call-back to check if modifier has been loaded |
336 |
static int |
337 |
checkModExists(const LUENT *lp, void *p) |
338 |
339 |
OBJECT mod = modifier(lp->key); |
340 |
341 |
if ((mod != OVOID) & (mod < nsceneobjs)) |
342 |
return 1; |
343 |
344 |
sprintf(errmsg, "tracked modifier '%s' not found in main scene", lp->key); |
345 |
346 |
return 0; |
347 |
348 |
349 |
// Prepare output channels and return # completed rows |
350 |
int |
351 |
RcontribSimulManager::PrepOutput() |
352 |
353 |
if (!outList || !RtraceSimulManager::Ready()) { |
354 |
error(INTERNAL, "PrepOutput() called before octree & modifiers set"); |
355 |
return -1; |
356 |
357 |
if (!cdsF) { |
358 |
error(INTERNAL, "missing RdataShare constructor call (cdsF)"); |
359 |
return -1; |
360 |
361 |
if (lu_doall(&modLUT, checkModExists, NULL) < 0) |
362 |
return -1; |
363 |
364 |
outList->nRows = yres * (xres + !xres); // all outputs have same #rows |
365 |
int remWarnings = 20; |
366 |
for (RcontribOutput *op = outList; op; op = op->next) { |
367 |
if (op->rData) { |
368 |
error(INTERNAL, "output channel already open in PrepOutput()"); |
369 |
return -1; |
370 |
371 |
op->nRows = outList->nRows; |
372 |
op->rData = (*cdsF)(op->ofname, outOp, |
373 |
GetHeadLen()+1024 + op->nRows*op->rowBytes); |
374 |
freeqstr(op->ofname); op->ofname = NULL; |
375 |
if (outOp == RCOrecover) { |
376 |
int rd = op->CheckHeader(this); |
377 |
if (rd < 0) |
378 |
return -1; |
379 |
if (rd >= op->nRows) { |
380 |
if (remWarnings >= 0) { |
381 |
sprintf(errmsg, "recovered output '%s' is complete", |
382 |
op->GetName()); |
383 |
error(WARNING, --remWarnings ? errmsg : "etc..."); |
384 |
385 |
rd = op->nRows; |
386 |
387 |
if (!rInPos | (rInPos > rd)) rInPos = rd; |
388 |
} else if (!op->NewHeader(this)) |
389 |
return -1; |
390 |
// make sure there's room |
391 |
if (op->rData->GetSize() < op->begData + op->nRows*op->rowBytes && |
392 |
!op->rData->Resize(op->begData + op->nRows*op->rowBytes)) |
393 |
return -1; // calls error() for us |
394 |
395 |
rowsDone.NewBitMap(outList->nRows); // create row completion map |
396 |
rowsDone.ClearBits(0, rInPos, true); |
397 |
return rInPos; |
398 |
399 |
400 |
// Create header in open write-only channel |
401 |
bool |
402 |
RcontribOutput::NewHeader(const RcontribSimulManager *rcp) |
403 |
404 |
int headlim = rcp->GetHeadLen() + 1024; |
405 |
char * hdr = (char *)rData->GetMemory(0, headlim, 0); |
406 |
int esiz; |
407 |
const int etyp = rcp->GetFormat(&esiz); |
408 |
409 |
strcpy(hdr, HDRSTR); |
410 |
strcat(hdr, "RADIANCE\n"); |
411 |
begData = strlen(hdr); |
412 |
strcpy(hdr+begData, rcp->GetHeadStr()); |
413 |
begData += rcp->GetHeadLen(); |
414 |
if (omod) { |
415 |
sprintf(hdr+begData, "MODIFIER=%s\n", omod); |
416 |
begData += strlen(hdr+begData); |
417 |
418 |
if (obin >= 0) { |
419 |
sprintf(hdr+begData, "BIN=%d\n", obin); |
420 |
421 |
422 |
strcpy(hdr+begData, ROWZEROSTR); |
423 |
rowCountPos = begData+LNROWSTR; |
424 |
begData += sizeof(ROWZEROSTR)-1; |
425 |
if (!rcp->xres | (rowBytes > esiz)) { |
426 |
sprintf(hdr+begData, "NCOLS=%d\n", int(rowBytes/esiz)); |
427 |
428 |
429 |
sprintf(hdr+begData, "%s%d\n", NCOMPSTR, NCSAMP); |
430 |
431 |
if (NCSAMP > 3) { |
432 |
sprintf(hdr+begData, "%s %f %f %f %f\n", WLSPLTSTR, |
433 |
WLPART[0], WLPART[1], WLPART[2], WLPART[3]); |
434 |
435 |
436 |
if (etyp != 'c') { |
437 |
sprintf(hdr+begData, "%s%d\n", BIGEND, nativebigendian()); |
438 |
439 |
440 |
int align = 0; |
441 |
switch (etyp) { |
442 |
case 'f': |
443 |
align = sizeof(float); |
444 |
break; |
445 |
case 'd': |
446 |
align = sizeof(double); |
447 |
break; |
448 |
case 'c': |
449 |
break; |
450 |
default: |
451 |
error(INTERNAL, "unsupported data type in NewHeader()"); |
452 |
return false; |
453 |
454 |
strcpy(hdr+begData, FMTSTR); // write format string |
455 |
456 |
strcpy(hdr+begData, formstr(etyp)); |
457 |
458 |
if (align) // align data at end of header |
459 |
while ((begData+2) % align) |
460 |
hdr[begData++] = ' '; |
461 |
hdr[begData++] = '\n'; // EOL for data format |
462 |
hdr[begData++] = '\n'; // end of nominal header |
463 |
if ((rcp->xres > 0) & (rowBytes == esiz)) { // tack on resolution string? |
464 |
sprintf(hdr+begData, PIXSTDFMT, rcp->yres, rcp->xres); |
465 |
466 |
467 |
return rData->ReleaseMemory(hdr, RDSwrite); |
468 |
469 |
470 |
// find string argument in header for named variable |
471 |
static const char * |
472 |
findArgs(const char *hdr, const char *vnm, int len) |
473 |
474 |
const char * npos = strnstr(hdr, vnm, len); |
475 |
476 |
if (!npos) return NULL; |
477 |
478 |
npos += strlen(vnm); // find start of (first) argument |
479 |
len -= npos - hdr; |
480 |
while (len-- > 0 && (*npos == '=') | isspace(*npos)) |
481 |
if (*npos++ == '\n') |
482 |
return NULL; |
483 |
484 |
return (len >= 0) ? npos : NULL; |
485 |
486 |
487 |
// Load and check header in read/write channel |
488 |
int |
489 |
RcontribOutput::CheckHeader(const RcontribSimulManager *rcp) |
490 |
491 |
int esiz; |
492 |
493 |
const int maxlen = rcp->GetHeadLen() + 1024; |
494 |
char * hdr = (char *)rData->GetMemory(0, maxlen, RDSread); |
495 |
const char * cp; |
496 |
// find end of header |
497 |
if (!hdr || !(cp = strnstr(hdr, "\n\n", maxlen))) { |
498 |
sprintf(errmsg, "cannot find end of header in '%s'", GetName()); |
499 |
500 |
return -1; |
501 |
502 |
begData = cp - hdr + 1; // increment again at end |
503 |
// check # components |
504 |
if (((cp = findArgs(hdr, NCOMPSTR, begData)) ? atoi(cp) : 3) != NCSAMP) { |
505 |
sprintf(errmsg, "expected %s%d in '%s'", NCOMPSTR, NCSAMP, GetName()); |
506 |
507 |
return -1; |
508 |
509 |
// check format |
510 |
if (!(cp = findArgs(hdr, FMTSTR, begData)) || |
511 |
strncmp(cp, formstr(etyp), strlen(formstr(etyp)))) { |
512 |
sprintf(errmsg, "expected %s%s in '%s'", FMTSTR, formstr(etyp), GetName()); |
513 |
514 |
return -1; |
515 |
516 |
// check #columns |
517 |
if (((cp = findArgs(hdr, "NCOLS=", begData)) && atoi(cp)*esiz != rowBytes) || |
518 |
519 |
sprintf(errmsg, "expected NCOLS=%d in '%s'", |
520 |
int(rowBytes/esiz), GetName()); |
521 |
522 |
return -1; |
523 |
524 |
// find row count |
525 |
if (!(cp = findArgs(hdr, "NROWS=", begData))) { |
526 |
sprintf(errmsg, "missing NROWS in '%s'", GetName()); |
527 |
528 |
return -1; |
529 |
530 |
rowCountPos = cp - hdr; |
531 |
int rlast = atoi(cp); |
532 |
begData++; // advance past closing EOL |
533 |
if ((rcp->xres > 0) & (rowBytes == esiz)) { // check/skip resolution string? |
534 |
char rbuf[64]; |
535 |
sprintf(rbuf, PIXSTDFMT, rcp->yres, rcp->xres); |
536 |
int rlen = strlen(rbuf); |
537 |
if (strncmp(rbuf, hdr+begData, rlen)) { |
538 |
sprintf(errmsg, "bad resolution string in '%s'", GetName()); |
539 |
540 |
return -1; |
541 |
542 |
begData += rlen; |
543 |
544 |
// XXX assume the rest is OK: endianness, wavelength splits, modifier, bin |
545 |
return rData->ReleaseMemory(hdr, 0) ? rlast : -1; |
546 |
547 |
548 |
// Rewind calculation (previous results unchanged) |
549 |
bool |
550 |
RcontribSimulManager::ResetRow(int r) |
551 |
552 |
if (!rowsDone.Length() | (0 > r) | (r >= rInPos)) { |
553 |
error(WARNING, "ignoring bad call to ResetRow()"); |
554 |
return (r == rInPos); |
555 |
556 |
FlushQueue(); // finish current and reset |
557 |
for (RcontribOutput *op = outList; op; op = op->next) |
558 |
if (!op->SetRowsDone(r)) |
559 |
return false; |
560 |
561 |
rowsDone.ClearBits(r, rInPos-r, false); |
562 |
rInPos = r; |
563 |
return true; |
564 |
565 |
566 |
// call-back for averaging each modifier's contributions to assigned channel(s) |
567 |
static int |
568 |
putModContrib(const LUENT *lp, void *p) |
569 |
570 |
RcontribMod * mp = (RcontribMod *)lp->data; |
571 |
const RcontribSimulManager * rcp = (const RcontribSimulManager *)p; |
572 |
const double sca = 1./rcp->accum; |
573 |
const DCOLORV * dvp = mp->cbin; |
574 |
RcontribOutput * op = mp->opl; |
575 |
int i, n; |
576 |
577 |
switch (rcp->GetFormat()) { // conversion based on output type |
578 |
case 'd': { |
579 |
double * dvo = (double *)op->InsertionP(mp->coffset); |
580 |
for (n = mp->nbins; n--; ) { |
581 |
for (i = 0; i < NCSAMP; i++) |
582 |
*dvo++ = *dvp++ * sca; |
583 |
if ((op->obin >= 0) & (n > 0)) |
584 |
dvo = (double *)(op = op->Next())->InsertionP(mp->coffset); |
585 |
586 |
} break; |
587 |
case 'f': { |
588 |
float * fvo = (float *)op->InsertionP(mp->coffset); |
589 |
590 |
591 |
*fvo++ = float(*dvp++ * sca); |
592 |
593 |
fvo = (float *)(op = op->Next())->InsertionP(mp->coffset); |
594 |
595 |
} break; |
596 |
case 'c': { |
597 |
COLRV * cvo = (COLRV *)op->InsertionP(mp->coffset); |
598 |
599 |
SCOLOR scol; |
600 |
601 |
scol[i] = COLORV(*dvp++ * sca); |
602 |
scolor_scolr(cvo, scol); |
603 |
cvo += LSCOLR; |
604 |
605 |
cvo = (COLRV *)(op = op->Next())->InsertionP(mp->coffset); |
606 |
607 |
} break; |
608 |
default: |
609 |
error(CONSISTENCY, "unsupported output type in putModContrib()"); |
610 |
return -1; |
611 |
612 |
// clear for next tally |
613 |
memset(mp->cbin, 0, sizeof(DCOLORV)*NCSAMP*mp->nbins); |
614 |
return 1; |
615 |
616 |
617 |
// Add a ray/bundle to compute next record |
618 |
int |
619 |
RcontribSimulManager::ComputeRecord(const FVECT orig_direc[]) |
620 |
621 |
if (!Ready()) |
622 |
return 0; |
623 |
if (rInPos >= outList->nRows) { |
624 |
error(WARNING, "ComputeRecord() called after last record"); |
625 |
return 0; |
626 |
627 |
if (nkids > 0) { // in parent process? |
628 |
int k = GetChild(); // updates output rows |
629 |
if (k < 0) return -1; // can't really happen |
630 |
RowAssignment rass; |
631 |
rass.row = kidRow[k] = rInPos++; |
632 |
rass.ac = accum; |
633 |
if (write(kid[k].w, &rass, sizeof(rass)) != sizeof(rass) || |
634 |
writebuf(kid[k].w, orig_direc, sizeof(FVECT)*2*accum) |
635 |
!= sizeof(FVECT)*2*accum) { |
636 |
error(SYSTEM, "cannot write to child; dead process?"); |
637 |
return -1; |
638 |
639 |
return accum; // tracing/output happens in child |
640 |
641 |
if (NCSAMP != nChan) { |
642 |
error(INTERNAL, "number of color channels must remain fixed"); |
643 |
return -1; |
644 |
645 |
// actual work is done here... |
646 |
if (EnqueueBundle(orig_direc, accum) < 0) |
647 |
return -1; |
648 |
649 |
RcontribOutput * op; // prepare output buffers |
650 |
for (op = outList; op; op = op->next) |
651 |
if (!op->GetRow(rInPos)) |
652 |
return -1; |
653 |
// convert averages & clear |
654 |
if (lu_doall(&modLUT, putModContrib, this) < 0) |
655 |
return -1; |
656 |
// write buffers |
657 |
658 |
op->DoneRow(); |
659 |
660 |
if (!nkids) // update row if solo process |
661 |
UpdateRowsDone(rInPos++); // XXX increment here is critical |
662 |
663 |
return accum; |
664 |
665 |
666 |
// Get next available child, returning index or -1 if forceWait & idling |
667 |
int |
668 |
RcontribSimulManager::GetChild(bool forceWait) |
669 |
670 |
if (nkids <= 0) |
671 |
return -1; |
672 |
// take inventory |
673 |
int pn, n = 0; |
674 |
fd_set writeset, errset; |
675 |
FD_ZERO(&writeset); FD_ZERO(&errset); |
676 |
for (pn = nkids; pn--; ) { |
677 |
if (kidRow[pn] < 0) { // child already ready? |
678 |
if (forceWait) continue; |
679 |
return pn; // good enough |
680 |
681 |
FD_SET(kid[pn].w, &writeset); // will check on this one |
682 |
FD_SET(kid[pn].w, &errset); |
683 |
if (kid[pn].w >= n) |
684 |
n = kid[pn].w + 1; |
685 |
686 |
if (!n) // every child is idle? |
687 |
return -1; |
688 |
// wait on "busy" child(ren) |
689 |
while ((n = select(n, NULL, &writeset, &errset, NULL)) <= 0) |
690 |
if (errno != EINTR) { |
691 |
error(SYSTEM, "select call failed in GetChild()"); |
692 |
return -1; |
693 |
694 |
pn = -1; // get flags set by select |
695 |
for (n = nkids; n--; ) |
696 |
if (kidRow[n] >= 0 && |
697 |
FD_ISSET(kid[n].w, &writeset) | |
698 |
FD_ISSET(kid[n].w, &errset)) { |
699 |
// update output row counts |
700 |
if (!FD_ISSET(kid[n].w, &errset)) |
701 |
UpdateRowsDone(kidRow[n]); |
702 |
kidRow[n] = -1; // flag it available |
703 |
pn = n; |
704 |
705 |
return pn; |
706 |
707 |
708 |
// Update row completion bitmap and update outputs (does not change rInPos) |
709 |
bool |
710 |
RcontribSimulManager::UpdateRowsDone(int r) |
711 |
712 |
if (!rowsDone.TestAndSet(r)) { |
713 |
error(WARNING, "redundant call to UpdateRowsDone()"); |
714 |
return false; |
715 |
716 |
int nDone = GetRowFinished(); |
717 |
if (nDone <= r) |
718 |
return true; // nothing to update, yet |
719 |
720 |
if (!op->SetRowsDone(nDone)) |
721 |
return false; |
722 |
return true; // up-to-date |
723 |
724 |
725 |
// Run rcontrib child process (never returns) |
726 |
void |
727 |
RcontribSimulManager::RunChild() |
728 |
729 |
FVECT * vecList = NULL; |
730 |
731 |
ssize_t nr; |
732 |
733 |
accum = 0; |
734 |
errno = 0; |
735 |
while ((nr = read(0, &rass, sizeof(rass))) == sizeof(rass)) { |
736 |
if (!rass.ac) { |
737 |
error(CONSISTENCY, "bad accumulator count in child"); |
738 |
exit(1); |
739 |
740 |
if (rass.ac > accum) { |
741 |
efree(vecList); |
742 |
vecList = (FVECT *)emalloc(sizeof(FVECT)*2*rass.ac); |
743 |
744 |
accum = rass.ac; |
745 |
rInPos = rass.row; |
746 |
747 |
if (readbuf(0, vecList, sizeof(FVECT)*2*accum) != |
748 |
749 |
break; |
750 |
751 |
if (ComputeRecord(vecList) <= 0) |
752 |
exit(1); |
753 |
754 |
if (nr) { |
755 |
error(SYSTEM, "read error in child process"); |
756 |
exit(1); |
757 |
758 |
exit(0); |
759 |
760 |
761 |
// Add child processes as indicated |
762 |
bool |
763 |
RcontribSimulManager::StartKids(int n2go) |
764 |
765 |
if ((n2go <= 0) | (nkids + n2go <= 1)) |
766 |
return false; |
767 |
768 |
if (!nkids) |
769 |
cow_memshare(); // preload objects |
770 |
771 |
n2go += nkids; // => desired brood size |
772 |
kid = (SUBPROC *)erealloc(kid, sizeof(SUBPROC)*n2go); |
773 |
kidRow = (int32 *)erealloc(kidRow, sizeof(int32)*n2go); |
774 |
775 |
fflush(stdout); // shouldn't use, anyway |
776 |
while (nkids < n2go) { |
777 |
kid[nkids] = sp_inactive; |
778 |
kid[nkids].w = dup(1); |
779 |
kid[nkids].flags |= PF_FILT_OUT; |
780 |
int rv = open_process(&kid[nkids], NULL); |
781 |
if (!rv) { // in child process? |
782 |
while (nkids-- > 0) |
783 |
close(kid[nkids].w); |
784 |
free(kid); free(kidRow); |
785 |
kid = NULL; kidRow = NULL; |
786 |
RunChild(); // should never return |
787 |
_exit(1); |
788 |
789 |
if (rv < 0) { |
790 |
error(SYSTEM, "cannot fork worker process"); |
791 |
return false; |
792 |
793 |
kidRow[nkids++] = -1; // newborn is ready |
794 |
795 |
return true; |
796 |
797 |
798 |
// Reap the indicated number of children (all if 0) |
799 |
int |
800 |
RcontribSimulManager::StopKids(int n2end) |
801 |
802 |
if (nkids <= 0) |
803 |
return 0; |
804 |
FlushQueue(); |
805 |
int status = 0; |
806 |
if (!n2end | (n2end >= nkids)) { // end all subprocesses? |
807 |
status = close_processes(kid, nkids); |
808 |
809 |
810 |
nkids = 0; |
811 |
} else { // else shrink family |
812 |
int st; |
813 |
while (n2end-- > 0) |
814 |
if ((st = close_process(&kid[--nkids])) > 0) |
815 |
status = st; |
816 |
// could call realloc(), but it hardly matters |
817 |
818 |
if (status) { |
819 |
sprintf(errmsg, "non-zero (%d) status from child", status); |
820 |
821 |
822 |
return status; |
823 |
824 |
825 |
// Set number of computation threads (0 => #cores) |
826 |
int |
827 |
RcontribSimulManager::SetThreadCount(int nt) |
828 |
829 |
if (!Ready()) { |
830 |
error(INTERNAL, "must call PrepOutput() before SetThreadCount()"); |
831 |
return 0; |
832 |
833 |
if (nt < 0) |
834 |
return NThreads(); |
835 |
if (!nt) nt = GetNCores(); |
836 |
int status = 0; |
837 |
if (nt == 1) |
838 |
status = StopKids(); |
839 |
else if (nt < nkids) |
840 |
status = StopKids(nkids-nt); |
841 |
else if (nt > nkids) |
842 |
StartKids(nt-nkids); |
843 |
if (status) { |
844 |
845 |
846 |
847 |
848 |
