| 1 |
#ifndef lint |
| 2 |
static const char RCSid[] = "$Id: RcontribSimulManager.cpp,v 2.11 2025/01/02 16:16:49 greg Exp $"; |
| 3 |
#endif |
| 4 |
| 5 |
* RcontribSimulManager.cpp |
| 6 |
| 7 |
* Rcontrib simulation manager implementation |
| 8 |
| 9 |
* Created by Greg Ward on 10/17/2024. |
| 10 |
| 11 |
| 12 |
#include <unistd.h> |
| 13 |
#include <ctype.h> |
| 14 |
#include "platform.h" |
| 15 |
#include "selcall.h" |
| 16 |
#include "RcontribSimulManager.h" |
| 17 |
#include "func.h" |
| 18 |
#include "resolu.h" |
| 19 |
#include "source.h" |
| 20 |
| 21 |
char RCCONTEXT[] = "RC."; |
| 22 |
| 23 |
extern const char HDRSTR[]; |
| 24 |
extern const char BIGEND[]; |
| 25 |
extern const char FMTSTR[]; |
| 26 |
| 27 |
// new/exclusive, overwrite if exists, or recover data |
| 28 |
int RSDOflags[] = {RDSwrite|RDSexcl|RDSextend, RDSwrite|RDSextend, |
| 29 |
RDSread|RDSwrite}; |
| 30 |
| 31 |
static const char ROWZEROSTR[] = "NROWS=0000000000000000\n"; |
| 32 |
#define LNROWSTR 6 |
| 33 |
| 34 |
// Modifier channel for recording contributions (no constructor/destructor) |
| 35 |
struct RcontribMod { |
| 36 |
RcontribOutput * opl; // pointer to first output channel |
| 37 |
char * params; // parameters string |
| 38 |
EPNODE * binv; // bin expression (NULL if 1 bin) |
| 39 |
int nbins; // bin count this modifier |
| 40 |
int coffset; // column offset in bytes |
| 41 |
DCOLORV cbin[1]; // bin accumulator (extends struct) |
| 42 |
/// Access specific (spectral) color bin |
| 43 |
DCOLORV * operator[](int n) { |
| 44 |
if ((n < 0) | (n >= nbins)) return NULL; |
| 45 |
return cbin + n*NCSAMP; |
| 46 |
| 47 |
| 48 |
| 49 |
// Struct used to assign record calculation to child |
| 50 |
struct RowAssignment { |
| 51 |
uint32 row; // row to do |
| 52 |
uint32 ac; // accumulation count |
| 53 |
| 54 |
| 55 |
// Get format identifier |
| 56 |
const char * |
| 57 |
formstr(int f) |
| 58 |
| 59 |
switch (f) { |
| 60 |
case 'a': return("ascii"); |
| 61 |
case 'f': return("float"); |
| 62 |
case 'd': return("double"); |
| 63 |
case 'c': return(NCSAMP==3 ? COLRFMT : SPECFMT); |
| 64 |
| 65 |
return("unknown"); |
| 66 |
| 67 |
| 68 |
// Our default data share function |
| 69 |
RdataShare * |
| 70 |
defDataShare(const char *name, RCOutputOp op, size_t siz) |
| 71 |
| 72 |
return new RdataShareMap(name, RSDOflags[op], siz); |
| 73 |
| 74 |
| 75 |
// Allocate rcontrib accumulator |
| 76 |
RcontribMod * |
| 77 |
NewRcMod(const char *prms, const char *binexpr, int ncbins) |
| 78 |
| 79 |
if (!prms) prms = ""; |
| 80 |
if ((ncbins > 1) & !binexpr) { |
| 81 |
error(USER, "missing bin expression"); |
| 82 |
return NULL; |
| 83 |
| 84 |
if (ncbins < 1) ncbins = 1; |
| 85 |
| 86 |
RcontribMod * mp = (RcontribMod *)ecalloc(1, sizeof(RcontribMod) + |
| 87 |
sizeof(DCOLORV)*(NCSAMP*ncbins-1) + |
| 88 |
strlen(prms)+1); |
| 89 |
| 90 |
if (binexpr) { // get/check bin expression |
| 91 |
mp->binv = eparse(const_cast<char *>(binexpr)); |
| 92 |
if (mp->binv->type == NUM) { // constant expression (0)? |
| 93 |
if ((int)evalue(mp->binv) != 0) { |
| 94 |
sprintf(errmsg, "illegal non-zero constant for bin (%s)", |
| 95 |
binexpr); |
| 96 |
error(USER, errmsg); |
| 97 |
| 98 |
if (ncbins > 1) { |
| 99 |
sprintf(errmsg, "bad bin count (%d should be 1)", ncbins); |
| 100 |
| 101 |
| 102 |
epfree(mp->binv, true); |
| 103 |
mp->binv = NULL; |
| 104 |
prms = ""; |
| 105 |
ncbins = 1; |
| 106 |
| 107 |
| 108 |
mp->params = strcpy((char *)(mp->cbin + ncbins*NCSAMP), prms); |
| 109 |
mp->nbins = ncbins; |
| 110 |
return mp; |
| 111 |
| 112 |
| 113 |
// Free an RcontribMod |
| 114 |
void |
| 115 |
FreeRcMod(void *p) |
| 116 |
| 117 |
if (!p) return; |
| 118 |
EPNODE * bep = (*(RcontribMod *)p).binv; |
| 119 |
if (bep) epfree(bep, true); |
| 120 |
efree(p); |
| 121 |
| 122 |
| 123 |
// Set output format ('f', 'd', or 'c') |
| 124 |
bool |
| 125 |
RcontribSimulManager::SetDataFormat(int ty) |
| 126 |
| 127 |
if (outList) { |
| 128 |
error(INTERNAL, "cannot call SetDataFormat() after AddModifier()"); |
| 129 |
return false; |
| 130 |
| 131 |
switch (ty) { |
| 132 |
case 'f': |
| 133 |
dsiz = sizeof(float)*NCSAMP; |
| 134 |
break; |
| 135 |
case 'd': |
| 136 |
dsiz = sizeof(double)*NCSAMP; |
| 137 |
break; |
| 138 |
case 'c': |
| 139 |
dsiz = LSCOLR; |
| 140 |
break; |
| 141 |
default: |
| 142 |
sprintf(errmsg, "unsupported output format '%c'", ty); |
| 143 |
error(INTERNAL, errmsg); |
| 144 |
return false; |
| 145 |
| 146 |
dtyp = ty; |
| 147 |
return true; |
| 148 |
| 149 |
| 150 |
// static call-back for rcontrib ray-tracing |
| 151 |
int |
| 152 |
RcontribSimulManager::RctCall(RAY *r, void *cd) |
| 153 |
| 154 |
if (!r->ro || r->ro->omod == OVOID) // hit nothing? |
| 155 |
return 0; |
| 156 |
// shadow ray not on source? |
| 157 |
if (r->rsrc >= 0 && source[r->rsrc].so != r->ro) |
| 158 |
return 0; |
| 159 |
| 160 |
const char * mname = objptr(r->ro->omod)->oname; |
| 161 |
RcontribSimulManager * rcp = (RcontribSimulManager *)cd; |
| 162 |
RcontribMod * mp = (RcontribMod *)lu_find(&rcp->modLUT,mname)->data; |
| 163 |
if (!mp) |
| 164 |
return 0; // not in our modifier list |
| 165 |
| 166 |
int bi = 0; // get bin index |
| 167 |
if (mp->binv) { |
| 168 |
worldfunc(RCCONTEXT, r); |
| 169 |
set_eparams(mp->params); |
| 170 |
double bval = evalue(mp->binv); |
| 171 |
if (bval <= -.5) |
| 172 |
return 0; // silently ignore negative bin index |
| 173 |
bi = int(bval + .5); |
| 174 |
| 175 |
DCOLORV * dvp = (*mp)[bi]; |
| 176 |
if (!dvp) { |
| 177 |
sprintf(errmsg, "bad bin number for '%s' (%d ignored)", mname, bi); |
| 178 |
error(WARNING, errmsg); |
| 179 |
return 0; |
| 180 |
| 181 |
SCOLOR contr; |
| 182 |
raycontrib(contr, r, PRIMARY); // compute coefficient |
| 183 |
if (rcp->HasFlag(RCcontrib)) |
| 184 |
smultscolor(contr, r->rcol); // -> value contribution |
| 185 |
| 186 |
for (int i = 0; i < NCSAMP; i++) |
| 187 |
*dvp++ += contr[i]; // accumulate color/spectrum |
| 188 |
return 1; |
| 189 |
| 190 |
| 191 |
// check for given format type in string, return last char position |
| 192 |
static int |
| 193 |
hasFormat(const char *tst, const char *match) |
| 194 |
| 195 |
static const char allPoss[] = "%diouxXfFeEgGaAcsb"; |
| 196 |
const char * s = tst; |
| 197 |
while (*s) { |
| 198 |
if (*s++ != '%') |
| 199 |
continue; |
| 200 |
while (!strchr(allPoss, *s)) |
| 201 |
s++; |
| 202 |
if (strchr(match, *s)) |
| 203 |
break; |
| 204 |
s++; |
| 205 |
| 206 |
return (*s != '\0')*(s - tst); |
| 207 |
| 208 |
| 209 |
// Add a modifier and arguments, opening output file(s) |
| 210 |
bool |
| 211 |
RcontribSimulManager::AddModifier(const char *modn, const char *outspec, |
| 212 |
const char *prms, const char *binval, int bincnt) |
| 213 |
| 214 |
if (!modn | !outspec || !*modn | !*outspec) { |
| 215 |
error(WARNING, "ignoring bad call to AddModifier()"); |
| 216 |
return false; |
| 217 |
| 218 |
if (*outspec == '!') { |
| 219 |
error(USER, "command output not supported by RcontribSimulManager"); |
| 220 |
return false; |
| 221 |
| 222 |
if (!nChan) { // initial call? |
| 223 |
if ((xres < 0) | (yres <= 0)) { |
| 224 |
error(USER, "xres, yres must be set before first modifier"); |
| 225 |
return false; |
| 226 |
| 227 |
if (!SetDataFormat(dtyp)) |
| 228 |
return false; |
| 229 |
nChan = NCSAMP; |
| 230 |
} else if (nChan != NCSAMP) { |
| 231 |
error(USER, "# spectral channels must be fixed in AddModifier()"); |
| 232 |
return false; |
| 233 |
| 234 |
if (Ready()) { |
| 235 |
error(INTERNAL, "call to AddModifier() after PrepOutput()"); |
| 236 |
return false; |
| 237 |
| 238 |
LUENT * lp = lu_find(&modLUT, modn); |
| 239 |
if (lp->data) { |
| 240 |
sprintf(errmsg, "duplicate modifier '%s'", modn); |
| 241 |
| 242 |
return false; |
| 243 |
| 244 |
if (!lp->key) // create new entry |
| 245 |
lp->key = strcpy((char *)emalloc(strlen(modn)+1), modn); |
| 246 |
| 247 |
RcontribMod * mp = NewRcMod(prms, binval, bincnt); |
| 248 |
if (!mp) return false; |
| 249 |
lp->data = (char *)mp; |
| 250 |
const int modndx = hasFormat(outspec, "sb"); |
| 251 |
const int binndx = hasFormat(outspec, "diouxX"); |
| 252 |
int bin0 = 0; |
| 253 |
char fnbuf[512]; |
| 254 |
if (!modndx || (binndx > 0) & (modndx > binndx)) |
| 255 |
sprintf(fnbuf, outspec, bin0, modn); |
| 256 |
else |
| 257 |
sprintf(fnbuf, outspec, modn, bin0); |
| 258 |
RcontribOutput * olast = NULL; |
| 259 |
RcontribOutput * op; |
| 260 |
for (op = outList; op; op = (olast=op)->next) { |
| 261 |
if (strcmp(op->GetName(), fnbuf)) |
| 262 |
continue; |
| 263 |
if (modndx) { // this ain't right |
| 264 |
sprintf(errmsg, "output name collision for '%s'", fnbuf); |
| 265 |
| 266 |
return false; |
| 267 |
| 268 |
if ((binndx > 0) & (xres > 0)) { |
| 269 |
sprintf(fnbuf, outspec, ++bin0); |
| 270 |
continue; // each bin goes to another image |
| 271 |
| 272 |
mp->coffset = op->rowBytes; // else add to what's there |
| 273 |
break; |
| 274 |
| 275 |
if (!op) { // create new output channel? |
| 276 |
op = new RcontribOutput(fnbuf); |
| 277 |
if (olast) olast->next = op; |
| 278 |
else outList = op; |
| 279 |
| 280 |
mp->opl = op; // first (maybe only) output channel |
| 281 |
if (modndx) // remember modifier if part of name |
| 282 |
op->omod = lp->key; |
| 283 |
if (binndx) { // append output image/bin list |
| 284 |
op->rowBytes += dsiz; |
| 285 |
op->obin = bin0; |
| 286 |
for (bincnt = 1; bincnt < mp->nbins; bincnt++) { |
| 287 |
| 288 |
sprintf(fnbuf, outspec, bin0+bincnt, modn); |
| 289 |
else |
| 290 |
sprintf(fnbuf, outspec, modn, bin0+bincnt); |
| 291 |
if (!op->next) { |
| 292 |
olast = op; |
| 293 |
olast->next = op = new RcontribOutput(fnbuf); |
| 294 |
if (modndx) op->omod = lp->key; |
| 295 |
op->obin = bin0+bincnt; |
| 296 |
} else { |
| 297 |
op = op->next; |
| 298 |
CHECK(op->obin != bin0+bincnt, CONSISTENCY, |
| 299 |
"bin number mismatch in AddModifier()"); |
| 300 |
| 301 |
CHECK(op->rowBytes != mp->coffset, CONSISTENCY, |
| 302 |
"row offset mismatch in AddModifier()"); |
| 303 |
| 304 |
| 305 |
} else // else send all results to this channel |
| 306 |
op->rowBytes += mp->nbins*dsiz; |
| 307 |
return true; |
| 308 |
| 309 |
| 310 |
// Add a file of modifiers with associated arguments |
| 311 |
bool |
| 312 |
RcontribSimulManager::AddModFile(const char *modfn, const char *outspec, |
| 313 |
const char *prms, |
| 314 |
| 315 |
| 316 |
char * path = getpath(const_cast<char *>(modfn), |
| 317 |
getrlibpath(), R_OK); |
| 318 |
FILE * fp; |
| 319 |
if (!path || !(fp = fopen(path, "r"))) { |
| 320 |
sprintf(errmsg, "cannot %s modifier file '%s'", |
| 321 |
path ? "open" : "find", modfn); |
| 322 |
error(SYSTEM, errmsg); |
| 323 |
return false; |
| 324 |
| 325 |
char mod[MAXSTR]; |
| 326 |
while (fgetword(mod, sizeof(mod), fp)) |
| 327 |
if (!AddModifier(mod, outspec, prms, binval, bincnt)) { |
| 328 |
fclose(fp); |
| 329 |
return false; |
| 330 |
| 331 |
fclose(fp); |
| 332 |
return true; |
| 333 |
| 334 |
| 335 |
// call-back to check if modifier has been loaded |
| 336 |
static int |
| 337 |
checkModExists(const LUENT *lp, void *p) |
| 338 |
| 339 |
OBJECT mod = modifier(lp->key); |
| 340 |
| 341 |
if ((mod != OVOID) & (mod < nsceneobjs)) |
| 342 |
return 1; |
| 343 |
| 344 |
sprintf(errmsg, "tracked modifier '%s' not found in main scene", lp->key); |
| 345 |
| 346 |
return 0; |
| 347 |
| 348 |
| 349 |
// Prepare output channels and return # completed rows |
| 350 |
int |
| 351 |
RcontribSimulManager::PrepOutput() |
| 352 |
| 353 |
if (!outList || !RtraceSimulManager::Ready()) { |
| 354 |
error(INTERNAL, "PrepOutput() called before octree & modifiers set"); |
| 355 |
return -1; |
| 356 |
| 357 |
if (!cdsF) { |
| 358 |
error(INTERNAL, "missing RdataShare constructor call (cdsF)"); |
| 359 |
return -1; |
| 360 |
| 361 |
if (lu_doall(&modLUT, checkModExists, NULL) < 0) |
| 362 |
return -1; |
| 363 |
| 364 |
outList->nRows = yres * (xres + !xres); // all outputs have same #rows |
| 365 |
int remWarnings = 20; |
| 366 |
for (RcontribOutput *op = outList; op; op = op->next) { |
| 367 |
if (op->rData) { |
| 368 |
error(INTERNAL, "output channel already open in PrepOutput()"); |
| 369 |
return -1; |
| 370 |
| 371 |
op->nRows = outList->nRows; |
| 372 |
op->rData = (*cdsF)(op->ofname, outOp, |
| 373 |
GetHeadLen()+1024 + op->nRows*op->rowBytes); |
| 374 |
freeqstr(op->ofname); op->ofname = NULL; |
| 375 |
if (outOp == RCOrecover) { |
| 376 |
int rd = op->CheckHeader(this); |
| 377 |
if (rd < 0) |
| 378 |
return -1; |
| 379 |
if (rd >= op->nRows) { |
| 380 |
if (remWarnings >= 0) { |
| 381 |
sprintf(errmsg, "recovered output '%s' is complete", |
| 382 |
op->GetName()); |
| 383 |
error(WARNING, --remWarnings ? errmsg : "etc..."); |
| 384 |
| 385 |
rd = op->nRows; |
| 386 |
| 387 |
if (!rInPos | (rInPos > rd)) rInPos = rd; |
| 388 |
} else if (!op->NewHeader(this)) |
| 389 |
return -1; |
| 390 |
// make sure there's room |
| 391 |
if (op->rData->GetSize() < op->begData + op->nRows*op->rowBytes && |
| 392 |
!op->rData->Resize(op->begData + op->nRows*op->rowBytes)) |
| 393 |
return -1; // calls error() for us |
| 394 |
| 395 |
rowsDone.NewBitMap(outList->nRows); // create row completion map |
| 396 |
rowsDone.ClearBits(0, rInPos, true); |
| 397 |
return rInPos; |
| 398 |
| 399 |
| 400 |
// Create header in open write-only channel |
| 401 |
bool |
| 402 |
RcontribOutput::NewHeader(const RcontribSimulManager *rcp) |
| 403 |
| 404 |
int headlim = rcp->GetHeadLen() + 1024; |
| 405 |
char * hdr = (char *)rData->GetMemory(0, headlim, 0); |
| 406 |
int esiz; |
| 407 |
const int etyp = rcp->GetFormat(&esiz); |
| 408 |
| 409 |
strcpy(hdr, HDRSTR); |
| 410 |
strcat(hdr, "RADIANCE\n"); |
| 411 |
begData = strlen(hdr); |
| 412 |
strcpy(hdr+begData, rcp->GetHeadStr()); |
| 413 |
begData += rcp->GetHeadLen(); |
| 414 |
if (omod) { |
| 415 |
sprintf(hdr+begData, "MODIFIER=%s\n", omod); |
| 416 |
begData += strlen(hdr+begData); |
| 417 |
| 418 |
if (obin >= 0) { |
| 419 |
sprintf(hdr+begData, "BIN=%d\n", obin); |
| 420 |
| 421 |
| 422 |
strcpy(hdr+begData, ROWZEROSTR); |
| 423 |
rowCountPos = begData+LNROWSTR; |
| 424 |
begData += sizeof(ROWZEROSTR)-1; |
| 425 |
if (!rcp->xres | (rowBytes > esiz)) { |
| 426 |
sprintf(hdr+begData, "NCOLS=%d\n", int(rowBytes/esiz)); |
| 427 |
| 428 |
| 429 |
sprintf(hdr+begData, "%s%d\n", NCOMPSTR, NCSAMP); |
| 430 |
| 431 |
if (NCSAMP > 3) { |
| 432 |
sprintf(hdr+begData, "%s %f %f %f %f\n", WLSPLTSTR, |
| 433 |
WLPART[0], WLPART[1], WLPART[2], WLPART[3]); |
| 434 |
| 435 |
| 436 |
if (etyp != 'c') { |
| 437 |
sprintf(hdr+begData, "%s%d\n", BIGEND, nativebigendian()); |
| 438 |
| 439 |
| 440 |
int align = 0; |
| 441 |
switch (etyp) { |
| 442 |
case 'f': |
| 443 |
align = sizeof(float); |
| 444 |
break; |
| 445 |
case 'd': |
| 446 |
align = sizeof(double); |
| 447 |
break; |
| 448 |
case 'c': |
| 449 |
break; |
| 450 |
default: |
| 451 |
error(INTERNAL, "unsupported data type in NewHeader()"); |
| 452 |
return false; |
| 453 |
| 454 |
strcpy(hdr+begData, FMTSTR); // write format string |
| 455 |
| 456 |
strcpy(hdr+begData, formstr(etyp)); |
| 457 |
| 458 |
if (align) // align data at end of header |
| 459 |
while ((begData+2) % align) |
| 460 |
hdr[begData++] = ' '; |
| 461 |
hdr[begData++] = '\n'; // EOL for data format |
| 462 |
hdr[begData++] = '\n'; // end of nominal header |
| 463 |
if ((rcp->xres > 0) & (rowBytes == esiz)) { // tack on resolution string? |
| 464 |
sprintf(hdr+begData, PIXSTDFMT, rcp->yres, rcp->xres); |
| 465 |
| 466 |
| 467 |
return rData->ReleaseMemory(hdr, RDSwrite); |
| 468 |
| 469 |
| 470 |
// find string argument in header for named variable |
| 471 |
static const char * |
| 472 |
findArgs(const char *hdr, const char *vnm, int len) |
| 473 |
| 474 |
const char * npos = strnstr(hdr, vnm, len); |
| 475 |
| 476 |
if (!npos) return NULL; |
| 477 |
| 478 |
npos += strlen(vnm); // find start of (first) argument |
| 479 |
len -= npos - hdr; |
| 480 |
while (len-- > 0 && (*npos == '=') | isspace(*npos)) |
| 481 |
if (*npos++ == '\n') |
| 482 |
return NULL; |
| 483 |
| 484 |
return (len >= 0) ? npos : NULL; |
| 485 |
| 486 |
| 487 |
// Load and check header in read/write channel |
| 488 |
int |
| 489 |
RcontribOutput::CheckHeader(const RcontribSimulManager *rcp) |
| 490 |
| 491 |
int esiz; |
| 492 |
| 493 |
const int maxlen = rcp->GetHeadLen() + 1024; |
| 494 |
char * hdr = (char *)rData->GetMemory(0, maxlen, RDSread); |
| 495 |
const char * cp; |
| 496 |
// find end of header |
| 497 |
if (!hdr || !(cp = strnstr(hdr, "\n\n", maxlen))) { |
| 498 |
sprintf(errmsg, "cannot find end of header in '%s'", GetName()); |
| 499 |
| 500 |
return -1; |
| 501 |
| 502 |
begData = cp - hdr + 1; // increment again at end |
| 503 |
// check # components |
| 504 |
if (((cp = findArgs(hdr, NCOMPSTR, begData)) ? atoi(cp) : 3) != NCSAMP) { |
| 505 |
sprintf(errmsg, "expected %s%d in '%s'", NCOMPSTR, NCSAMP, GetName()); |
| 506 |
| 507 |
return -1; |
| 508 |
| 509 |
// check format |
| 510 |
if (!(cp = findArgs(hdr, FMTSTR, begData)) || |
| 511 |
strncmp(cp, formstr(etyp), strlen(formstr(etyp)))) { |
| 512 |
sprintf(errmsg, "expected %s%s in '%s'", FMTSTR, formstr(etyp), GetName()); |
| 513 |
| 514 |
return -1; |
| 515 |
| 516 |
// check #columns |
| 517 |
if (((cp = findArgs(hdr, "NCOLS=", begData)) && atoi(cp)*esiz != rowBytes) || |
| 518 |
| 519 |
sprintf(errmsg, "expected NCOLS=%d in '%s'", |
| 520 |
int(rowBytes/esiz), GetName()); |
| 521 |
| 522 |
return -1; |
| 523 |
| 524 |
// find row count |
| 525 |
if (!(cp = findArgs(hdr, "NROWS=", begData))) { |
| 526 |
sprintf(errmsg, "missing NROWS in '%s'", GetName()); |
| 527 |
| 528 |
return -1; |
| 529 |
| 530 |
rowCountPos = cp - hdr; |
| 531 |
int rlast = atoi(cp); |
| 532 |
begData++; // advance past closing EOL |
| 533 |
if ((rcp->xres > 0) & (rowBytes == esiz)) { // check/skip resolution string? |
| 534 |
char rbuf[64]; |
| 535 |
sprintf(rbuf, PIXSTDFMT, rcp->yres, rcp->xres); |
| 536 |
int rlen = strlen(rbuf); |
| 537 |
if (strncmp(rbuf, hdr+begData, rlen)) { |
| 538 |
sprintf(errmsg, "bad resolution string in '%s'", GetName()); |
| 539 |
| 540 |
return -1; |
| 541 |
| 542 |
begData += rlen; |
| 543 |
| 544 |
// XXX assume the rest is OK: endianness, wavelength splits, modifier, bin |
| 545 |
return rData->ReleaseMemory(hdr, 0) ? rlast : -1; |
| 546 |
| 547 |
| 548 |
// Rewind calculation (previous results unchanged) |
| 549 |
bool |
| 550 |
RcontribSimulManager::ResetRow(int r) |
| 551 |
| 552 |
if (!rowsDone.Length() | (0 > r) | (r >= rInPos)) { |
| 553 |
error(WARNING, "ignoring bad call to ResetRow()"); |
| 554 |
return (r == rInPos); |
| 555 |
| 556 |
FlushQueue(); // finish current and reset |
| 557 |
for (RcontribOutput *op = outList; op; op = op->next) |
| 558 |
if (!op->SetRowsDone(r)) |
| 559 |
return false; |
| 560 |
| 561 |
rowsDone.ClearBits(r, rInPos-r, false); |
| 562 |
rInPos = r; |
| 563 |
return true; |
| 564 |
| 565 |
| 566 |
// call-back for averaging each modifier's contributions to assigned channel(s) |
| 567 |
static int |
| 568 |
putModContrib(const LUENT *lp, void *p) |
| 569 |
| 570 |
RcontribMod * mp = (RcontribMod *)lp->data; |
| 571 |
const RcontribSimulManager * rcp = (const RcontribSimulManager *)p; |
| 572 |
const double sca = 1./rcp->accum; |
| 573 |
const DCOLORV * dvp = mp->cbin; |
| 574 |
RcontribOutput * op = mp->opl; |
| 575 |
int i, n; |
| 576 |
| 577 |
switch (rcp->GetFormat()) { // conversion based on output type |
| 578 |
case 'd': { |
| 579 |
double * dvo = (double *)op->InsertionP(mp->coffset); |
| 580 |
for (n = mp->nbins; n--; ) { |
| 581 |
for (i = 0; i < NCSAMP; i++) |
| 582 |
*dvo++ = *dvp++ * sca; |
| 583 |
if ((op->obin >= 0) & (n > 0)) |
| 584 |
dvo = (double *)(op = op->Next())->InsertionP(mp->coffset); |
| 585 |
| 586 |
} break; |
| 587 |
case 'f': { |
| 588 |
float * fvo = (float *)op->InsertionP(mp->coffset); |
| 589 |
| 590 |
| 591 |
*fvo++ = float(*dvp++ * sca); |
| 592 |
| 593 |
fvo = (float *)(op = op->Next())->InsertionP(mp->coffset); |
| 594 |
| 595 |
} break; |
| 596 |
case 'c': { |
| 597 |
COLRV * cvo = (COLRV *)op->InsertionP(mp->coffset); |
| 598 |
| 599 |
SCOLOR scol; |
| 600 |
| 601 |
scol[i] = COLORV(*dvp++ * sca); |
| 602 |
scolor_scolr(cvo, scol); |
| 603 |
cvo += LSCOLR; |
| 604 |
| 605 |
cvo = (COLRV *)(op = op->Next())->InsertionP(mp->coffset); |
| 606 |
| 607 |
} break; |
| 608 |
default: |
| 609 |
error(CONSISTENCY, "unsupported output type in sendModContrib()"); |
| 610 |
return -1; |
| 611 |
| 612 |
// clear for next tally |
| 613 |
memset(mp->cbin, 0, sizeof(DCOLORV)*NCSAMP*mp->nbins); |
| 614 |
return 1; |
| 615 |
| 616 |
| 617 |
// Add a ray/bundle to compute next record |
| 618 |
int |
| 619 |
RcontribSimulManager::ComputeRecord(const FVECT orig_direc[]) |
| 620 |
| 621 |
if (!Ready()) |
| 622 |
return 0; |
| 623 |
if (rInPos >= outList->nRows) { |
| 624 |
error(WARNING, "ComputeRecord() called after last record"); |
| 625 |
return 0; |
| 626 |
| 627 |
if (nkids > 0) { // in parent process? |
| 628 |
int k = GetChild(); // updates output rows |
| 629 |
if (k < 0) return -1; // can't really happen |
| 630 |
RowAssignment rass; |
| 631 |
rass.row = kidRow[k] = rInPos++; |
| 632 |
rass.ac = accum; |
| 633 |
if (write(kid[k].w, &rass, sizeof(rass)) != sizeof(rass) || |
| 634 |
writebuf(kid[k].w, orig_direc, sizeof(FVECT)*2*accum) |
| 635 |
!= sizeof(FVECT)*2*accum) { |
| 636 |
error(SYSTEM, "cannot write to child; dead process?"); |
| 637 |
return -1; |
| 638 |
| 639 |
return accum; // tracing/output happens in child |
| 640 |
| 641 |
if (NCSAMP != nChan) { |
| 642 |
error(INTERNAL, "number of color channels must remain fixed"); |
| 643 |
return -1; |
| 644 |
| 645 |
// actual work is done here... |
| 646 |
if (EnqueueBundle(orig_direc, accum) < 0) |
| 647 |
return -1; |
| 648 |
| 649 |
RcontribOutput * op; // prepare output buffers |
| 650 |
for (op = outList; op; op = op->next) |
| 651 |
if (!op->GetRow(rInPos)) |
| 652 |
return -1; |
| 653 |
// convert averages & clear |
| 654 |
if (lu_doall(&modLUT, putModContrib, this) < 0) |
| 655 |
return -1; |
| 656 |
// write buffers |
| 657 |
| 658 |
op->DoneRow(); |
| 659 |
| 660 |
if (!nkids) // update row if solo process |
| 661 |
UpdateRowsDone(rInPos++); // XXX increment here is critical |
| 662 |
| 663 |
return accum; |
| 664 |
| 665 |
| 666 |
// Get next available child, returning index or -1 if forceWait & idling |
| 667 |
int |
| 668 |
RcontribSimulManager::GetChild(bool forceWait) |
| 669 |
| 670 |
if (nkids <= 0) |
| 671 |
return -1; |
| 672 |
// take inventory |
| 673 |
int pn, n = 0; |
| 674 |
fd_set writeset, errset; |
| 675 |
FD_ZERO(&writeset); FD_ZERO(&errset); |
| 676 |
for (pn = nkids; pn--; ) { |
| 677 |
if (kidRow[pn] < 0) { // child already ready? |
| 678 |
if (forceWait) continue; |
| 679 |
return pn; // good enough |
| 680 |
| 681 |
FD_SET(kid[pn].w, &writeset); // will check on this one |
| 682 |
FD_SET(kid[pn].w, &errset); |
| 683 |
if (kid[pn].w >= n) |
| 684 |
n = kid[pn].w + 1; |
| 685 |
| 686 |
if (!n) // every child is idle? |
| 687 |
return -1; |
| 688 |
// wait on "busy" child(ren) |
| 689 |
while ((n = select(n, NULL, &writeset, &errset, NULL)) <= 0) |
| 690 |
if (errno != EINTR) { |
| 691 |
error(SYSTEM, "select call failed in GetChild()"); |
| 692 |
return -1; |
| 693 |
| 694 |
pn = -1; // get flags set by select |
| 695 |
for (n = nkids; n--; ) |
| 696 |
if (kidRow[n] >= 0 && |
| 697 |
FD_ISSET(kid[n].w, &writeset) | |
| 698 |
FD_ISSET(kid[n].w, &errset)) { |
| 699 |
// update output row counts |
| 700 |
if (!FD_ISSET(kid[n].w, &errset)) |
| 701 |
UpdateRowsDone(kidRow[n]); |
| 702 |
kidRow[n] = -1; // flag it available |
| 703 |
pn = n; |
| 704 |
| 705 |
return pn; |
| 706 |
| 707 |
| 708 |
// Update row completion bitmap and update outputs (does not change rInPos) |
| 709 |
bool |
| 710 |
RcontribSimulManager::UpdateRowsDone(int r) |
| 711 |
| 712 |
if (!rowsDone.TestAndSet(r)) { |
| 713 |
error(WARNING, "redundant call to UpdateRowsDone()"); |
| 714 |
return false; |
| 715 |
| 716 |
int nDone = GetRowFinished(); |
| 717 |
if (nDone <= r) |
| 718 |
return true; // nothing to update, yet |
| 719 |
| 720 |
if (!op->SetRowsDone(nDone)) |
| 721 |
return false; |
| 722 |
return true; // up-to-date |
| 723 |
| 724 |
| 725 |
// Run rcontrib child process (never returns) |
| 726 |
void |
| 727 |
RcontribSimulManager::RunChild() |
| 728 |
| 729 |
FVECT * vecList = NULL; |
| 730 |
| 731 |
ssize_t nr; |
| 732 |
| 733 |
accum = 0; |
| 734 |
errno = 0; |
| 735 |
while ((nr = read(0, &rass, sizeof(rass))) == sizeof(rass)) { |
| 736 |
if (!rass.ac) { |
| 737 |
error(CONSISTENCY, "bad accumulator count in child"); |
| 738 |
exit(1); |
| 739 |
| 740 |
if (rass.ac > accum) |
| 741 |
vecList = (FVECT *)erealloc(vecList, |
| 742 |
sizeof(FVECT)*2*rass.ac); |
| 743 |
accum = rass.ac; |
| 744 |
rInPos = rass.row; |
| 745 |
| 746 |
if (readbuf(0, vecList, sizeof(FVECT)*2*accum) != |
| 747 |
| 748 |
break; |
| 749 |
| 750 |
if (ComputeRecord(vecList) <= 0) |
| 751 |
exit(1); |
| 752 |
| 753 |
if (nr) { |
| 754 |
error(SYSTEM, "read error in child process"); |
| 755 |
exit(1); |
| 756 |
| 757 |
exit(0); |
| 758 |
| 759 |
| 760 |
// Add child processes as indicated |
| 761 |
bool |
| 762 |
RcontribSimulManager::StartKids(int n2go) |
| 763 |
| 764 |
if ((n2go <= 0) | (nkids + n2go <= 1)) |
| 765 |
return false; |
| 766 |
| 767 |
if (!nkids) |
| 768 |
cow_memshare(); // preload objects |
| 769 |
| 770 |
n2go += nkids; // => desired brood size |
| 771 |
kid = (SUBPROC *)erealloc(kid, sizeof(SUBPROC)*n2go); |
| 772 |
kidRow = (int32 *)erealloc(kidRow, sizeof(int32)*n2go); |
| 773 |
| 774 |
fflush(stdout); // shouldn't use, anyway |
| 775 |
while (nkids < n2go) { |
| 776 |
kid[nkids] = sp_inactive; |
| 777 |
kid[nkids].w = dup(1); |
| 778 |
kid[nkids].flags |= PF_FILT_OUT; |
| 779 |
int rv = open_process(&kid[nkids], NULL); |
| 780 |
if (!rv) { // in child process? |
| 781 |
while (nkids-- > 0) |
| 782 |
close(kid[nkids].w); |
| 783 |
free(kid); free(kidRow); |
| 784 |
kid = NULL; kidRow = NULL; |
| 785 |
RunChild(); // should never return |
| 786 |
_exit(1); |
| 787 |
| 788 |
if (rv < 0) { |
| 789 |
error(SYSTEM, "cannot fork worker process"); |
| 790 |
return false; |
| 791 |
| 792 |
kidRow[nkids++] = -1; // newborn is ready |
| 793 |
| 794 |
return true; |
| 795 |
| 796 |
| 797 |
// Reap the indicated number of children (all if 0) |
| 798 |
int |
| 799 |
RcontribSimulManager::StopKids(int n2end) |
| 800 |
| 801 |
if (nkids <= 0) |
| 802 |
return 0; |
| 803 |
FlushQueue(); |
| 804 |
int status = 0; |
| 805 |
if (!n2end | (n2end >= nkids)) { // end all subprocesses? |
| 806 |
status = close_processes(kid, nkids); |
| 807 |
| 808 |
| 809 |
nkids = 0; |
| 810 |
} else { // else shrink family |
| 811 |
int st; |
| 812 |
while (n2end-- > 0) |
| 813 |
if ((st = close_process(&kid[--nkids])) > 0) |
| 814 |
status = st; |
| 815 |
// could call realloc(), but it hardly matters |
| 816 |
| 817 |
if (status) { |
| 818 |
sprintf(errmsg, "non-zero (%d) status from child", status); |
| 819 |
| 820 |
| 821 |
return status; |
| 822 |
| 823 |
| 824 |
// Set number of computation threads (0 => #cores) |
| 825 |
int |
| 826 |
RcontribSimulManager::SetThreadCount(int nt) |
| 827 |
| 828 |
if (!Ready()) { |
| 829 |
error(INTERNAL, "must call PrepOutput() before SetThreadCount()"); |
| 830 |
return 0; |
| 831 |
| 832 |
if (nt < 0) |
| 833 |
return NThreads(); |
| 834 |
if (!nt) nt = GetNCores(); |
| 835 |
int status = 0; |
| 836 |
if (nt == 1) |
| 837 |
status = StopKids(); |
| 838 |
else if (nt < nkids) |
| 839 |
status = StopKids(nkids-nt); |
| 840 |
else if (nt > nkids) |
| 841 |
StartKids(nt-nkids); |
| 842 |
if (status) { |
| 843 |
| 844 |
| 845 |
| 846 |
| 847 |
