root/radiance/src/rt/README
Revision: 2.5
Committed: Mon Aug 8 16:47:04 1994 UTC (31 years, 5 months ago) by greg
brought up to date
1 RENDERING PROGRAMS
2 SCCSid "$SunId$ LBL"
3
4 This directory contains the RADIANCE renderers "rpict", "rtrace" and "rview".
5
6 ambient.h common definitions for interreflection routines
7 data.h header file for routines which interpolate data
8 driver.h header file for interactive device drivers
9 func.h header file for modifiers using function files
10 nwsdev.h header file for NeWS driver
11 otspecial.h special type flags for objects used in rendering
12 ray.h header file for routines using rays
13 rpaint.h header file for image painting (rview)
14 source.h header file for ray tracing sources
15 x11icon.h icon for rview under X11
16 x11twind.h header for X11 text window routines
17 xtwind.h header for X10 text window routines
18 Version.c program version
19 aed.c driver for AED 512 terminal
20 ambcomp.c routines to compute "ambient" values using Monte Carlo
21 ambient.c routines dealing with ambient (inter-reflected) component
22 ambio.c ambient value input and output routines
23 aniso.c material functions for plastic2, metal2 and trans2
24 caldefn.c store variable definitions
25 calexpr.c compute data values using expression parser
26 colortab.c allocate and control dynamic color table
27 data.c routines dealing with interpolated data
28 devcomm.c communication routines for separate drivers
29 devmain.c main for independent drivers
30 devtable.c device table for rview
31 dielectric.c shading function for transparent materials
32 editline.c routine for editing raw input for rview
33 fprism.c routines for prismatic glazing calculations
34 freeobjmem.c routines for freeing unneeded object structures
35 func.c interface to calcomp functions
36 glass.c simpler shading function for thin glass surfaces
37 initotypes.c initialize ofun[] list for renderers
38 lookamb.c program to examine ambient components
39 m_brdf.c shading for materials with arbitrary BRDF's
40 m_clip.c routine for clipped (cut) objects
41 m_direct.c routines for prism material types
42 m_mirror.c routines for mirror material supporting virtual light sources
43 malloc.c memory allocation routines
44 mx_data.c routine for stored mixtures
45 mx_func.c routine for mixture functions
46 noise3.c noise functions for random textures
47 normal.c shading function for normal materials
48 nwsdev.c NeWS driver, by Isaac Kwo
49 nwsdev.cps NeWS driver source
50 o_cone.c routine to determine ray intersection with cones
51 o_face.c compute ray intersection with faces
52 o_instance.c routines for computing ray intersections with octrees
53 p_data.c routine for stored patterns
54 p_func.c routine for procedural patterns
55 persist.c routines for persistent (& parallel) execution
56 preload.c routines for preloading (initializing) data structures
57 rayinit.cal initialization function file
58 raytrace.c routines for tracing and shading rays
59 readfargs.c allocate, read and free object arguments
60 rmain.c main for ray tracing programs
61 rpict.c routines and variables for picture generation
62 rtrace.c program and variables for individual ray tracing
63 rv2.c command routines used in tracing a view
64 rv3.c miscellaneous routines for rview
65 rview.c routines and variables for interactive view generation
66 source.c routines dealing with illumination sources
67 sphere.c compute ray intersection with spheres
68 srcsamp.c source sampling routines
69 srcsupp.c support routines for source objects and materials
70 suncom.c program to read and edit raw tty input
71 sundev.c standalone driver for Sunwindows
72 t_data.c routine for stored textures
73 t_func.c routine for procedural textures
74 text.c functions for text patterns and mixtures
75 tty.c i/o for terminal drivers
76 virtuals.c routines for simulating virtual light sources
77 x10.c driver for X-windows version 10R4
78 x11.c driver for X-windows version 11R3
79 x11twind.c routines for X11 text windows
80 xtwind.c routines for X text windows
81 zeroes.c compute roots for various equations
