root/radiance/src/qtrvu/viewdialog.ui
Revision: 1.2
Committed: Mon Aug 6 17:51:45 2012 UTC (13 years, 1 month ago) by greg
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R0, rad5R1, rad4R2, rad6R0, rad4R2P1, rad4R2P2, HEAD
Changes since 1.1: +7 -0 lines
Zack's patch to add stereographic view type
# User Rev Content
1 greg 1.1 <?xml version="1.0" encoding="UTF-8"?>
2     <ui version="4.0">
3     <class>viewDialog</class>
4     <widget class="QDialog" name="viewDialog">
5     <property name="geometry">
6     <rect>
7     <x>0</x>
8     <y>0</y>
9     <width>576</width>
10     <height>456</height>
11     </rect>
12     </property>
13     <property name="windowTitle">
14     <string>View</string>
15     </property>
16     <layout class="QVBoxLayout" name="verticalLayout_2">
17     <item>
18     <widget class="QWidget" name="topWidget" native="true">
19     <layout class="QHBoxLayout" name="horizontalLayout">
20     <item>
21     <widget class="QFrame" name="typeFrame">
22     <property name="frameShape">
23     <enum>QFrame::StyledPanel</enum>
24     </property>
25     <property name="frameShadow">
26     <enum>QFrame::Raised</enum>
27     </property>
28     <layout class="QVBoxLayout" name="verticalLayout">
29     <item>
30     <widget class="QLabel" name="label">
31     <property name="text">
32     <string>Type</string>
33     </property>
34     </widget>
35     </item>
36     <item>
37     <widget class="QRadioButton" name="angular">
38     <property name="text">
39     <string>Angular</string>
40     </property>
41     </widget>
42     </item>
43     <item>
44     <widget class="QRadioButton" name="cylindrical">
45     <property name="text">
46     <string>Cylindrical</string>
47     </property>
48     </widget>
49     </item>
50     <item>
51     <widget class="QRadioButton" name="hemispherical">
52     <property name="text">
53     <string>Hemispherical</string>
54     </property>
55     </widget>
56     </item>
57     <item>
58 greg 1.2 <widget class="QRadioButton" name="planispheric">
59     <property name="text">
60     <string>Planispheric</string>
61     </property>
62     </widget>
63     </item>
64     <item>
65 greg 1.1 <widget class="QRadioButton" name="parallel">
66     <property name="text">
67     <string>Parallel</string>
68     </property>
69     </widget>
70     </item>
71     <item>
72     <widget class="QRadioButton" name="perspective">
73     <property name="text">
74     <string>Perspective</string>
75     </property>
76     <property name="checked">
77     <bool>true</bool>
78     </property>
79     </widget>
80     </item>
81     </layout>
82     </widget>
83     </item>
84     <item>
85     <widget class="QFrame" name="viewFrame">
86     <property name="frameShape">
87     <enum>QFrame::StyledPanel</enum>
88     </property>
89     <property name="frameShadow">
90     <enum>QFrame::Raised</enum>
91     </property>
92     <layout class="QGridLayout" name="gridLayout">
93     <item row="0" column="0" colspan="2">
94     <widget class="QLabel" name="label_5">
95     <property name="text">
96     <string>Viewpoint</string>
97     </property>
98     </widget>
99     </item>
100     <item row="1" column="0">
101     <widget class="QLabel" name="label_2">
102     <property name="text">
103     <string>X:</string>
104     </property>
105     </widget>
106     </item>
107     <item row="1" column="1">
108     <widget class="QLineEdit" name="viewX">
109     <property name="sizePolicy">
110     <sizepolicy hsizetype="Maximum" vsizetype="Fixed">
111     <horstretch>0</horstretch>
112     <verstretch>0</verstretch>
113     </sizepolicy>
114     </property>
115     <property name="maximumSize">
116     <size>
117     <width>60</width>
118     <height>16777215</height>
119     </size>
120     </property>
121     </widget>
122     </item>
123     <item row="2" column="0">
124     <widget class="QLabel" name="label_3">
125     <property name="text">
126     <string>Y:</string>
127     </property>
128     </widget>
129     </item>
130     <item row="2" column="1">
131     <widget class="QLineEdit" name="viewY">
132     <property name="sizePolicy">
133     <sizepolicy hsizetype="Maximum" vsizetype="Fixed">
134     <horstretch>0</horstretch>
135     <verstretch>0</verstretch>
136     </sizepolicy>
137     </property>
138     <property name="maximumSize">
139     <size>
140     <width>60</width>
141     <height>16777215</height>
142     </size>
143     </property>
144     </widget>
145     </item>
146     <item row="3" column="0">
147     <widget class="QLabel" name="label_4">
148     <property name="text">
149     <string>Z:</string>
150     </property>
151     </widget>
152     </item>
153     <item row="3" column="1">
154     <widget class="QLineEdit" name="viewZ">
155     <property name="sizePolicy">
156     <sizepolicy hsizetype="Maximum" vsizetype="Fixed">
157     <horstretch>0</horstretch>
158     <verstretch>0</verstretch>
159     </sizepolicy>
160     </property>
161     <property name="maximumSize">
162     <size>
163     <width>60</width>
164     <height>16777215</height>
165     </size>
166     </property>
167     </widget>
168     </item>
169     </layout>
170     </widget>
171     </item>
172     <item>
173     <widget class="QFrame" name="directionFrame">
174     <property name="frameShape">
175     <enum>QFrame::StyledPanel</enum>
176     </property>
177     <property name="frameShadow">
178     <enum>QFrame::Raised</enum>
179     </property>
180     <layout class="QGridLayout" name="gridLayout_2">
181     <item row="0" column="0" colspan="2">
182     <widget class="QLabel" name="label_12">
183     <property name="text">
184     <string>Direction</string>
185     </property>
186     </widget>
187     </item>
188     <item row="1" column="0">
189     <widget class="QLabel" name="label_6">
190     <property name="text">
191     <string>X:</string>
192     </property>
193     </widget>
194     </item>
195     <item row="1" column="1">
196     <widget class="QLineEdit" name="dirX">
197     <property name="sizePolicy">
198     <sizepolicy hsizetype="Maximum" vsizetype="Fixed">
199     <horstretch>0</horstretch>
200     <verstretch>0</verstretch>
201     </sizepolicy>
202     </property>
203     <property name="maximumSize">
204     <size>
205     <width>60</width>
206     <height>16777215</height>
207     </size>
208     </property>
209     </widget>
210     </item>
211     <item row="2" column="0">
212     <widget class="QLabel" name="label_7">
213     <property name="text">
214     <string>Y:</string>
215     </property>
216     </widget>
217     </item>
218     <item row="2" column="1">
219     <widget class="QLineEdit" name="dirY">
220     <property name="sizePolicy">
221     <sizepolicy hsizetype="Maximum" vsizetype="Fixed">
222     <horstretch>0</horstretch>
223     <verstretch>0</verstretch>
224     </sizepolicy>
225     </property>
226     <property name="maximumSize">
227     <size>
228     <width>60</width>
229     <height>16777215</height>
230     </size>
231     </property>
232     </widget>
233     </item>
234     <item row="3" column="0">
235     <widget class="QLabel" name="label_8">
236     <property name="text">
237     <string>Z:</string>
238     </property>
239     </widget>
240     </item>
241     <item row="3" column="1">
242     <widget class="QLineEdit" name="dirZ">
243     <property name="sizePolicy">
244     <sizepolicy hsizetype="Maximum" vsizetype="Fixed">
245     <horstretch>0</horstretch>
246     <verstretch>0</verstretch>
247     </sizepolicy>
248     </property>
249     <property name="maximumSize">
250     <size>
251     <width>60</width>
252     <height>16777215</height>
253     </size>
254     </property>
255     </widget>
256     </item>
257     </layout>
258     </widget>
259     </item>
260     <item>
261     <widget class="QFrame" name="upFrame">
262     <property name="frameShape">
263     <enum>QFrame::StyledPanel</enum>
264     </property>
265     <property name="frameShadow">
266     <enum>QFrame::Raised</enum>
267     </property>
268     <layout class="QGridLayout" name="gridLayout_3">
269     <item row="0" column="0" colspan="2">
270     <widget class="QLabel" name="label_13">
271     <property name="text">
272     <string>Up</string>
273     </property>
274     </widget>
275     </item>
276     <item row="1" column="0">
277     <widget class="QLabel" name="label_9">
278     <property name="text">
279     <string>X:</string>
280     </property>
281     </widget>
282     </item>
283     <item row="1" column="1">
284     <widget class="QLineEdit" name="upX">
285     <property name="sizePolicy">
286     <sizepolicy hsizetype="Maximum" vsizetype="Fixed">
287     <horstretch>0</horstretch>
288     <verstretch>0</verstretch>
289     </sizepolicy>
290     </property>
291     <property name="maximumSize">
292     <size>
293     <width>60</width>
294     <height>16777215</height>
295     </size>
296     </property>
297     </widget>
298     </item>
299     <item row="2" column="0">
300     <widget class="QLabel" name="label_10">
301     <property name="text">
302     <string>Y:</string>
303     </property>
304     </widget>
305     </item>
306     <item row="2" column="1">
307     <widget class="QLineEdit" name="upY">
308     <property name="sizePolicy">
309     <sizepolicy hsizetype="Maximum" vsizetype="Fixed">
310     <horstretch>0</horstretch>
311     <verstretch>0</verstretch>
312     </sizepolicy>
313     </property>
314     <property name="maximumSize">
315     <size>
316     <width>60</width>
317     <height>16777215</height>
318     </size>
319     </property>
320     </widget>
321     </item>
322     <item row="3" column="0">
323     <widget class="QLabel" name="label_11">
324     <property name="text">
325     <string>Z:</string>
326     </property>
327     </widget>
328     </item>
329     <item row="3" column="1">
330     <widget class="QLineEdit" name="upZ">
331     <property name="sizePolicy">
332     <sizepolicy hsizetype="Maximum" vsizetype="Fixed">
333     <horstretch>0</horstretch>
334     <verstretch>0</verstretch>
335     </sizepolicy>
336     </property>
337     <property name="maximumSize">
338     <size>
339     <width>60</width>
340     <height>16777215</height>
341     </size>
342     </property>
343     </widget>
344     </item>
345     </layout>
346     </widget>
347     </item>
348     </layout>
349     </widget>
350     </item>
351     <item>
352     <widget class="QWidget" name="bottomWidget" native="true">
353     <layout class="QHBoxLayout" name="horizontalLayout_2">
354     <item>
355     <widget class="QFrame" name="sizeFrame">
356     <property name="frameShape">
357     <enum>QFrame::StyledPanel</enum>
358     </property>
359     <property name="frameShadow">
360     <enum>QFrame::Raised</enum>
361     </property>
362     <layout class="QGridLayout" name="gridLayout_4">
363     <item row="0" column="0">
364     <widget class="QLabel" name="label_16">
365     <property name="text">
366     <string>Size</string>
367     </property>
368     </widget>
369     </item>
370     <item row="1" column="0">
371     <widget class="QLabel" name="label_14">
372     <property name="text">
373     <string>Horiz:</string>
374     </property>
375     </widget>
376     </item>
377     <item row="1" column="1">
378     <widget class="QLineEdit" name="sizeHoriz">
379     <property name="maximumSize">
380     <size>
381     <width>60</width>
382     <height>16777215</height>
383     </size>
384     </property>
385     </widget>
386     </item>
387     <item row="2" column="0">
388     <widget class="QLabel" name="label_15">
389     <property name="text">
390     <string>Vert:</string>
391     </property>
392     </widget>
393     </item>
394     <item row="2" column="1">
395     <widget class="QLineEdit" name="sizeVert">
396     <property name="maximumSize">
397     <size>
398     <width>60</width>
399     <height>16777215</height>
400     </size>
401     </property>
402     </widget>
403     </item>
404     </layout>
405     </widget>
406     </item>
407     <item>
408     <widget class="QFrame" name="frame_2">
409     <property name="frameShape">
410     <enum>QFrame::StyledPanel</enum>
411     </property>
412     <property name="frameShadow">
413     <enum>QFrame::Raised</enum>
414     </property>
415     <layout class="QGridLayout" name="gridLayout_5">
416     <item row="0" column="0" colspan="2">
417     <widget class="QLabel" name="label_19">
418     <property name="text">
419     <string>Clipping plane</string>
420     </property>
421     </widget>
422     </item>
423     <item row="1" column="0">
424     <widget class="QLabel" name="label_17">
425     <property name="text">
426     <string>Fore:</string>
427     </property>
428     </widget>
429     </item>
430     <item row="1" column="1">
431     <widget class="QLineEdit" name="fore">
432     <property name="maximumSize">
433     <size>
434     <width>60</width>
435     <height>16777215</height>
436     </size>
437     </property>
438     </widget>
439     </item>
440     <item row="2" column="0">
441     <widget class="QLabel" name="label_18">
442     <property name="text">
443     <string>Aft:</string>
444     </property>
445     </widget>
446     </item>
447     <item row="2" column="1">
448     <widget class="QLineEdit" name="aft">
449     <property name="maximumSize">
450     <size>
451     <width>60</width>
452     <height>16777215</height>
453     </size>
454     </property>
455     </widget>
456     </item>
457     </layout>
458     </widget>
459     </item>
460     <item>
461     <widget class="QFrame" name="frame_3">
462     <property name="frameShape">
463     <enum>QFrame::StyledPanel</enum>
464     </property>
465     <property name="frameShadow">
466     <enum>QFrame::Raised</enum>
467     </property>
468     <layout class="QGridLayout" name="gridLayout_6">
469     <item row="0" column="0">
470     <widget class="QLabel" name="label_22">
471     <property name="text">
472     <string>Offset</string>
473     </property>
474     </widget>
475     </item>
476     <item row="1" column="0">
477     <widget class="QLabel" name="label_20">
478     <property name="text">
479     <string>Horiz:</string>
480     </property>
481     </widget>
482     </item>
483     <item row="1" column="1">
484     <widget class="QLineEdit" name="offsetHoriz">
485     <property name="maximumSize">
486     <size>
487     <width>60</width>
488     <height>16777215</height>
489     </size>
490     </property>
491     </widget>
492     </item>
493     <item row="2" column="0">
494     <widget class="QLabel" name="label_21">
495     <property name="text">
496     <string>Vert:</string>
497     </property>
498     </widget>
499     </item>
500     <item row="2" column="1">
501     <widget class="QLineEdit" name="offsetVert">
502     <property name="maximumSize">
503     <size>
504     <width>60</width>
505     <height>16777215</height>
506     </size>
507     </property>
508     </widget>
509     </item>
510     </layout>
511     </widget>
512     </item>
513     </layout>
514     </widget>
515     </item>
516     <item>
517     <widget class="QDialogButtonBox" name="buttonBox">
518     <property name="orientation">
519     <enum>Qt::Horizontal</enum>
520     </property>
521     <property name="standardButtons">
522     <set>QDialogButtonBox::Cancel|QDialogButtonBox::Ok</set>
523     </property>
524     </widget>
525     </item>
526     </layout>
527     </widget>
528     <resources/>
529     <connections>
530     <connection>
531     <sender>buttonBox</sender>
532     <signal>accepted()</signal>
533     <receiver>viewDialog</receiver>
534     <slot>accept()</slot>
535     <hints>
536     <hint type="sourcelabel">
537     <x>248</x>
538     <y>254</y>
539     </hint>
540     <hint type="destinationlabel">
541     <x>157</x>
542     <y>274</y>
543     </hint>
544     </hints>
545     </connection>
546     <connection>
547     <sender>buttonBox</sender>
548     <signal>rejected()</signal>
549     <receiver>viewDialog</receiver>
550     <slot>reject()</slot>
551     <hints>
552     <hint type="sourcelabel">
553     <x>316</x>
554     <y>260</y>
555     </hint>
556     <hint type="destinationlabel">
557     <x>286</x>
558     <y>274</y>
559     </hint>
560     </hints>
561     </connection>
562     </connections>
563     </ui>
