root/radiance/src/px/xshowtrace.c
Revision: 2.10
Committed: Sun Mar 28 20:33:14 2004 UTC (21 years, 6 months ago) by schorsch
Changes since 2.9: +37 -16 lines
2 static const char RCSid[] = "$Id: xshowtrace.c,v 2.9 2003/11/10 12:28:56 schorsch Exp $";
5 * Display an image and watch the rays get traced.
6 *
7 * 9/21/90 Greg Ward
8 */
9
10 #include <X11/Xlib.h>
11
12 #include "standard.h"
13 #include "paths.h"
14 #include "view.h"
15
16 #define MAXDEPTH 32 /* ridiculous ray tree depth */
17
18 #ifdef SMLFLT
19 #define sscanvec(s,v) (sscanf(s,"%f %f %f",v,v+1,v+2)==3)
20 #else
21 #define sscanvec(s,v) (sscanf(s,"%lf %lf %lf",v,v+1,v+2)==3)
22 #endif
23
24 char rtcom[] = "rtrace -h- -otp -fa -x 1";
25 char xicom[] = "ximage -c 256";
26
27 VIEW ourview = STDVIEW; /* view for picture */
28 RESOLU ourres; /* picture resolution */
29
30 char *progname; /* program name */
31
32 char *picture; /* picture name */
33
34 FILE *pin; /* input stream */
35
36 Display *theDisplay = NULL; /* connection to server */
37
38 struct node { /* ray tree node */
39 int ipt[2];
40 struct node *sister;
41 struct node *daughter;
42 };
43
44 #define newnode() (struct node *)calloc(1, sizeof(struct node))
45
46 int slow = 0; /* slow trace? */
47
48 void mainloop(void);
49 static void freetree(struct node *tp);
50 static void tracerays(struct node *tp);
51 static int strtoipt(int ipt[2], char *str);
52 static void setvec(int ipt[2]);
53 static void vector(int ip1[2], int ip2[2]);
54
55
56 int
57 main( /* takes both the octree and the image */
58 int argc,
59 char *argv[]
60 )
61 {
62 int i;
63 char combuf[PATH_MAX];
64
65 progname = argv[0];
66 for (i = 1; i < argc-2; i++)
67 if (!strcmp(argv[i], "-s"))
68 slow++;
69 else
70 break;
71 if (i > argc-2) {
72 fprintf(stderr, "Usage: %s [-s] [rtrace args] octree picture\n",
73 progname);
74 exit(1);
75 }
76 picture = argv[argc-1];
77 /* get the viewing parameters */
78 if (viewfile(picture, &ourview, &ourres) <= 0 ||
79 setview(&ourview) != NULL) {
80 fprintf(stderr, "%s: cannot get view from \"%s\"\n",
81 progname, picture);
82 exit(1);
83 }
84 /* open the display */
85 if ((theDisplay = XOpenDisplay(NULL)) == NULL) {
86 fprintf(stderr,
87 "%s: cannot open display; DISPLAY variable set?\n",
88 progname);
89 exit(1);
90 }
91 /* build input command */
92 sprintf(combuf, "%s \"%s\" | %s", xicom, picture, rtcom);
93 for ( ; i < argc-1; i++) {
94 strcat(combuf, " ");
95 strcat(combuf, argv[i]);
96 }
97 /* start the damn thing */
98 if ((pin = popen(combuf, "r")) == NULL)
99 exit(1);
100 /* loop on input */
101 mainloop();
102 /* close pipe and exit */
103 pclose(pin);
104 exit(0);
105 }
106
107
108 void
109 mainloop(void) /* get and process input */
110 {
111 static struct node *sis[MAXDEPTH];
112 register struct node *newp;
113 char buf[128];
114 int level;
115 register int i;
116
117 level = 0;
118 while (fgets(buf, sizeof(buf), pin) != NULL) {
119 if ((newp = newnode()) == NULL) {
120 fprintf(stderr, "%s: memory error\n", progname);
121 return;
122 }
123 for (i = 0; buf[i] == '\t'; i++)
124 ;
125 if (strtoipt(newp->ipt, buf+i) < 0) {
126 fprintf(stderr, "%s: bad read\n", progname);
127 return;
128 }
129 newp->sister = sis[i];
130 sis[i] = newp;
131 if (i < level) {
132 newp->daughter = sis[level];
133 sis[level] = NULL;
134 }
135 level = i;
136 if (i == 0) {
137 setvec(sis[0]->ipt);
138 tracerays(sis[0]);
139 freetree(sis[0]);
140 sis[0] = NULL;
141 if (!slow)
142 XFlush(theDisplay);
143 }
144 }
145 }
146
147
148 static void
149 freetree( /* free a trace tree */
150 struct node *tp
151 )
152 {
153 register struct node *kid, *k2;
154
155 for (kid = tp->daughter; kid != NULL; kid = k2) {
156 k2 = kid->sister;
157 freetree(kid);
158 }
159 free((void *)tp);
160 }
161
162
163 static void
164 tracerays( /* trace a ray tree */
165 struct node *tp
166 )
167 {
168 register struct node *kid;
169
170 for (kid = tp->daughter; kid != NULL; kid = kid->sister) {
171 vector(tp->ipt, kid->ipt);
172 tracerays(kid);
173 }
174 }
175
176
177 static int
178 strtoipt( /* convert string x y z to image point */
179 int ipt[2],
180 char *str
181 )
182 {
183 FVECT im_pt, pt;
184
185 if (!sscanvec(str, pt))
186 return(-1);
187 if (DOT(pt,pt) <= FTINY) /* origin is really infinity */
188 ipt[0] = ipt[1] = -1; /* null vector */
189 else {
190 viewloc(im_pt, &ourview, pt);
191 loc2pix(ipt, &ourres, im_pt[0], im_pt[1]);
192 }
193 return(0);
194 }
195
196
197 #define rwind RootWindow(theDisplay,ourScreen)
198 #define ourScreen DefaultScreen(theDisplay)
199
200 GC vecGC = 0;
201 Window gwind = 0;
202 int xoff, yoff;
203
204
205 static void
206 setvec( /* set up vector drawing for pick */
207 int ipt[2]
208 )
209 {
210 extern Window xfindwind();
211 XWindowAttributes wa;
212 XColor xc;
213 XGCValues gcv;
214 int rx, ry, wx, wy;
215 Window rw, cw;
216 unsigned int pm;
217 /* compute pointer location */
218 if (gwind == 0) {
219 register char *wn;
220 for (wn = picture; *wn; wn++);
221 while (wn > picture && wn[-1] != '/') wn--;
222 if ((gwind = xfindwind(theDisplay, rwind, wn, 4)) == 0) {
223 fprintf(stderr, "%s: cannot find display window!\n",
224 progname);
225 exit(1);
226 }
227 }
228 XQueryPointer(theDisplay, gwind, &rw, &cw, &rx, &ry, &wx, &wy, &pm);
229 xoff = wx - ipt[0];
230 yoff = wy - ipt[1];
231 /* set graphics context */
232 if (vecGC == 0) {
233 XGetWindowAttributes(theDisplay, gwind, &wa);
234 xc.red = 65535; xc.green = 0; xc.blue = 0;
235 xc.flags = DoRed|DoGreen|DoBlue;
236 if (XAllocColor(theDisplay, wa.colormap, &xc)) {
237 gcv.foreground = xc.pixel;
238 vecGC = XCreateGC(theDisplay,gwind,GCForeground,&gcv);
239 } else {
240 gcv.function = GXinvert;
241 vecGC = XCreateGC(theDisplay,gwind,GCFunction,&gcv);
242 }
243 }
244 }
245
246
247 static void
248 vector( /* draw a vector */
249 int ip1[2],
250 int ip2[2]
251 )
252 {
253 if (ip2[0] == -1 && ip2[1] == -1)
254 return; /* null vector */
255 XDrawLine(theDisplay, gwind, vecGC,
256 ip1[0]+xoff, ip1[1]+yoff,
257 ip2[0]+xoff, ip2[1]+yoff);
258 if (slow) {
259 XFlush(theDisplay);
260 sleep(1);
261 }
262 }
