| 1 |
#ifndef lint |
| 2 |
static const char       RCSid[] = "$Id$"; |
| 3 |
#endif |
| 4 |
| 5 |
 *  Program to convert between RADIANCE and TIFF files. |
| 6 |
 *  Added LogLuv encodings 7/97 (GWL). |
| 7 |
 *  Added white-balance adjustment 10/01 (GW). |
| 8 |
| 9 |
| 10 |
#include  <stdio.h> |
| 11 |
#include  <math.h> |
| 12 |
#include  <time.h> |
| 13 |
#include  "tiffio.h" |
| 14 |
#include  "color.h" |
| 15 |
#include  "resolu.h" |
| 16 |
| 17 |
#define  GAMCOR         2.2             /* default gamma */ |
| 18 |
| 19 |
                                /* conversion flags */ |
| 20 |
#define C_CXFM          0x1             /* needs color transformation */ |
| 21 |
#define C_GAMUT         0x2             /* needs gamut mapping */ |
| 22 |
#define C_GAMMA         0x4             /* needs gamma correction */ |
| 23 |
#define C_GRY           0x8             /* TIFF is greyscale */ |
| 24 |
#define C_XYZE          0x10            /* Radiance is XYZE */ |
| 25 |
#define C_RFLT          0x20            /* Radiance data is float */ |
| 26 |
#define C_TFLT          0x40            /* TIFF data is float */ |
| 27 |
#define C_TWRD          0x80            /* TIFF data is 16-bit */ |
| 28 |
#define C_PRIM          0x100           /* has assigned primaries */ |
| 29 |
| 30 |
struct { |
| 31 |
        uint16  flags;          /* conversion flags (defined above) */ |
| 32 |
        uint16  comp;           /* TIFF compression type */ |
| 33 |
        uint16  phot;           /* TIFF photometric type */ |
| 34 |
        uint16  pconf;          /* TIFF planar configuration */ |
| 35 |
        float   gamcor;         /* gamma correction value */ |
| 36 |
        short   bradj;          /* Radiance exposure adjustment (stops) */ |
| 37 |
        uint16  orient;         /* visual orientation (TIFF spec.) */ |
| 38 |
        double  stonits;        /* input conversion to nits */ |
| 39 |
        float   pixrat;         /* pixel aspect ratio */ |
| 40 |
        FILE    *rfp;           /* Radiance stream pointer */ |
| 41 |
        TIFF    *tif;           /* TIFF pointer */ |
| 42 |
        uint32  xmax, ymax;     /* image dimensions */ |
| 43 |
        COLORMAT        cmat;   /* color transformation matrix */ |
| 44 |
        RGBPRIMS        prims;  /* RGB primaries */ |
| 45 |
        union { |
| 46 |
                COLR    *colrs;         /* 4-byte ???E pointer */ |
| 47 |
                COLOR   *colors;        /* float array pointer */ |
| 48 |
                char    *p;             /* generic pointer */ |
| 49 |
        } r;                    /* Radiance scanline */ |
| 50 |
        union { |
| 51 |
                uint8   *bp;            /* byte pointer */ |
| 52 |
                uint16  *wp;            /* word pointer */ |
| 53 |
                float   *fp;            /* float pointer */ |
| 54 |
| 55 |
        } t;                    /* TIFF scanline */ |
| 56 |
        int     (*tf)();        /* translation procedure */ |
| 57 |
}       cvts = {        /* conversion structure */ |
| 58 |
        0, COMPRESSION_NONE, PHOTOMETRIC_RGB, |
| 59 |
        PLANARCONFIG_CONTIG, GAMCOR, 0, 1, 1., 1., |
| 60 |
| 61 |
| 62 |
#define CHK(f)          (cvts.flags & (f)) |
| 63 |
#define SET(f)          (cvts.flags |= (f)) |
| 64 |
#define CLR(f)          (cvts.flags &= ~(f)) |
| 65 |
#define TGL(f)          (cvts.flags ^= (f)) |
| 66 |
| 67 |
int     Luv2Color(), L2Color(), RGB2Colr(), Gry2Colr(); |
| 68 |
int     Color2Luv(), Color2L(), Colr2RGB(), Colr2Gry(); |
| 69 |
int     RRGGBB2Color(), GGry2Color(); |
| 70 |
| 71 |
short   ortab[8] = {            /* orientation conversion table */ |
| 72 |
        YMAJOR|YDECR, |
| 73 |
        YMAJOR|YDECR|XDECR, |
| 74 |
        YMAJOR|XDECR, |
| 75 |
        YMAJOR, |
| 76 |
        YDECR, |
| 77 |
        XDECR|YDECR, |
| 78 |
        XDECR, |
| 79 |
        0 |
| 80 |
| 81 |
| 82 |
#define pixorder()      ortab[cvts.orient-1] |
| 83 |
| 84 |
char  *progname; |
| 85 |
| 86 |
| 87 |
main(argc, argv) |
| 88 |
int  argc; |
| 89 |
char  *argv[]; |
| 90 |
| 91 |
        int  reverse = 0; |
| 92 |
        int  i; |
| 93 |
| 94 |
        progname = argv[0]; |
| 95 |
| 96 |
        for (i = 1; i < argc; i++) |
| 97 |
                if (argv[i][0] == '-') |
| 98 |
                        switch (argv[i][1]) { |
| 99 |
                        case 'g':               /* gamma correction */ |
| 100 |
                                cvts.gamcor = atof(argv[++i]); |
| 101 |
                                break; |
| 102 |
                        case 'x':               /* XYZE Radiance output */ |
| 103 |
                                TGL(C_XYZE); |
| 104 |
                                break; |
| 105 |
                        case 'z':               /* LZW compressed output */ |
| 106 |
                                cvts.comp = COMPRESSION_LZW; |
| 107 |
                                break; |
| 108 |
                        case 'L':               /* LogLuv 32-bit output */ |
| 109 |
                                cvts.comp = COMPRESSION_SGILOG; |
| 110 |
                                cvts.phot = PHOTOMETRIC_LOGLUV; |
| 111 |
                                break; |
| 112 |
                        case 'l':               /* LogLuv 24-bit output */ |
| 113 |
                                cvts.comp = COMPRESSION_SGILOG24; |
| 114 |
| 115 |
                                break; |
| 116 |
                        case 'b':               /* greyscale output? */ |
| 117 |
                                TGL(C_GRY); |
| 118 |
                                break; |
| 119 |
                        case 'e':               /* exposure adjustment */ |
| 120 |
                                if (argv[i+1][0] != '+' && argv[i+1][0] != '-') |
| 121 |
                                        goto userr; |
| 122 |
                                cvts.bradj = atoi(argv[++i]); |
| 123 |
                                break; |
| 124 |
                        case 'r':               /* reverse conversion? */ |
| 125 |
                                reverse = !reverse; |
| 126 |
                                break; |
| 127 |
                        case '\0': |
| 128 |
                                goto doneopts; |
| 129 |
                        default: |
| 130 |
                                goto userr; |
| 131 |
| 132 |
                else |
| 133 |
                        break; |
| 134 |
doneopts: |
| 135 |
        if (reverse) { |
| 136 |
| 137 |
                if (i != argc-2 && i != argc-1) |
| 138 |
                        goto userr; |
| 139 |
| 140 |
                tiff2ra(i, argv); |
| 141 |
| 142 |
        } else { |
| 143 |
| 144 |
                if (i != argc-2) |
| 145 |
                        goto userr; |
| 146 |
| 147 |
                if (CHK(C_GRY))         /* consistency corrections */ |
| 148 |
                        if (cvts.phot == PHOTOMETRIC_RGB) |
| 149 |
                                cvts.phot = PHOTOMETRIC_MINISBLACK; |
| 150 |
                        else { |
| 151 |
                                cvts.phot = PHOTOMETRIC_LOGL; |
| 152 |
| 153 |
| 154 |
| 155 |
                ra2tiff(i, argv); |
| 156 |
| 157 |
| 158 |
        exit(0); |
| 159 |
userr: |
| 160 |
        fprintf(stderr, |
| 161 |
        "Usage: %s [-z|-L|-l][-b][-e +/-stops][-g gamma] {in.pic|-} out.tif\n", |
| 162 |
                        progname); |
| 163 |
        fprintf(stderr, |
| 164 |
        "   Or: %s -r [-x][-e +/-stops][-g gamma] in.tif [out.pic|-]\n", |
| 165 |
                        progname); |
| 166 |
        exit(1); |
| 167 |
| 168 |
| 169 |
| 170 |
quiterr(err)            /* print message and exit */ |
| 171 |
char  *err; |
| 172 |
| 173 |
        if (err != NULL) { |
| 174 |
                fprintf(stderr, "%s: %s\n", progname, err); |
| 175 |
                exit(1); |
| 176 |
| 177 |
        exit(0); |
| 178 |
| 179 |
| 180 |
| 181 |
allocbufs()                     /* allocate scanline buffers */ |
| 182 |
| 183 |
        int     rsiz, tsiz; |
| 184 |
| 185 |
        rsiz = CHK(C_RFLT) ? sizeof(COLOR) : sizeof(COLR); |
| 186 |
        tsiz = (CHK(C_TFLT) ? sizeof(float) :  |
| 187 |
                        CHK(C_TWRD) ? sizeof(uint16) : sizeof(uint8)) * |
| 188 |
                        (CHK(C_GRY) ? 1 : 3); |
| 189 |
        cvts.r.p = (char *)malloc(rsiz*cvts.xmax); |
| 190 |
        cvts.t.p = (char *)malloc(tsiz*cvts.xmax); |
| 191 |
        if (cvts.r.p == NULL | cvts.t.p == NULL) |
| 192 |
                quiterr("no memory to allocate scanline buffers"); |
| 193 |
| 194 |
| 195 |
| 196 |
initfromtif()           /* initialize conversion from TIFF input */ |
| 197 |
| 198 |
        uint16  hi; |
| 199 |
        float   *fa, f1, f2; |
| 200 |
| 201 |
        CLR(C_GRY|C_GAMMA|C_PRIM|C_RFLT|C_TFLT|C_CXFM); |
| 202 |
| 203 |
        TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_PLANARCONFIG, &cvts.pconf); |
| 204 |
| 205 |
        if (TIFFGetField(cvts.tif, TIFFTAG_PRIMARYCHROMATICITIES, &fa)) { |
| 206 |
                cvts.prims[RED][CIEX] = fa[0]; |
| 207 |
                cvts.prims[RED][CIEY] = fa[1]; |
| 208 |
                cvts.prims[GRN][CIEX] = fa[2]; |
| 209 |
                cvts.prims[GRN][CIEY] = fa[3]; |
| 210 |
                cvts.prims[BLU][CIEX] = fa[4]; |
| 211 |
                cvts.prims[BLU][CIEY] = fa[5]; |
| 212 |
                cvts.prims[WHT][CIEX] = 1./3.; |
| 213 |
                cvts.prims[WHT][CIEY] = 1./3.; |
| 214 |
                if (TIFFGetField(cvts.tif, TIFFTAG_WHITEPOINT, &fa)) { |
| 215 |
                        cvts.prims[WHT][CIEX] = fa[0]; |
| 216 |
                        cvts.prims[WHT][CIEY] = fa[1]; |
| 217 |
| 218 |
                SET(C_PRIM); |
| 219 |
| 220 |
| 221 |
        if (!TIFFGetField(cvts.tif, TIFFTAG_COMPRESSION, &cvts.comp)) |
| 222 |
                cvts.comp = COMPRESSION_NONE; |
| 223 |
| 224 |
        if (TIFFGetField(cvts.tif, TIFFTAG_XRESOLUTION, &f1) && |
| 225 |
                        TIFFGetField(cvts.tif, TIFFTAG_YRESOLUTION, &f2)) |
| 226 |
                cvts.pixrat = f1/f2; |
| 227 |
| 228 |
        TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_ORIENTATION, &cvts.orient); |
| 229 |
| 230 |
        if (!TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_PHOTOMETRIC, &cvts.phot)) |
| 231 |
                quiterr("TIFF has unspecified photometric type"); |
| 232 |
| 233 |
        switch (cvts.phot) { |
| 234 |
        case PHOTOMETRIC_LOGLUV: |
| 235 |
                SET(C_RFLT|C_TFLT); |
| 236 |
                if (!CHK(C_XYZE)) { |
| 237 |
                        cpcolormat(cvts.cmat, xyz2rgbmat); |
| 238 |
                        SET(C_CXFM|C_GAMUT); |
| 239 |
                } else if (cvts.comp == COMPRESSION_SGILOG) |
| 240 |
                        SET(C_GAMUT); |
| 241 |
                if (cvts.pconf != PLANARCONFIG_CONTIG) |
| 242 |
                        quiterr("cannot handle separate Luv planes"); |
| 243 |
                TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT, |
| 244 |
                                SGILOGDATAFMT_FLOAT); |
| 245 |
                cvts.tf = Luv2Color; |
| 246 |
                break; |
| 247 |
        case PHOTOMETRIC_LOGL: |
| 248 |
                SET(C_GRY|C_RFLT|C_TFLT|C_GAMUT); |
| 249 |
                cvts.pconf = PLANARCONFIG_CONTIG; |
| 250 |
| 251 |
| 252 |
                cvts.tf = L2Color; |
| 253 |
                break; |
| 254 |
        case PHOTOMETRIC_YCBCR: |
| 255 |
                if (cvts.comp == COMPRESSION_JPEG && |
| 256 |
                                cvts.pconf == PLANARCONFIG_CONTIG) { |
| 257 |
                        TIFFSetField(cvts.tif, TIFFTAG_JPEGCOLORMODE, |
| 258 |
                                        JPEGCOLORMODE_RGB); |
| 259 |
                        cvts.phot = PHOTOMETRIC_RGB; |
| 260 |
                } else |
| 261 |
                        quiterr("unsupported photometric type"); |
| 262 |
                /* fall through */ |
| 263 |
        case PHOTOMETRIC_RGB: |
| 264 |
                SET(C_GAMMA); |
| 265 |
                setcolrgam(cvts.gamcor); |
| 266 |
                if (CHK(C_XYZE)) { |
| 267 |
                        comprgb2xyzWBmat(cvts.cmat, |
| 268 |
                                        CHK(C_PRIM) ? cvts.prims : stdprims); |
| 269 |
                        SET(C_CXFM); |
| 270 |
| 271 |
                if (!TIFFGetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, &hi) || |
| 272 |
                                hi != 3) |
| 273 |
                        quiterr("unsupported samples per pixel for RGB"); |
| 274 |
                if (!TIFFGetField(cvts.tif, TIFFTAG_BITSPERSAMPLE, &hi) || |
| 275 |
                                hi != 8 & hi != 16) |
| 276 |
                        quiterr("unsupported bits per sample for RGB"); |
| 277 |
                if (hi == 8) |
| 278 |
                        cvts.tf = RGB2Colr; |
| 279 |
                else { |
| 280 |
                        cvts.tf = RRGGBB2Color; |
| 281 |
                        SET(C_RFLT|C_TWRD); |
| 282 |
| 283 |
                break; |
| 284 |
        case PHOTOMETRIC_MINISBLACK: |
| 285 |
                SET(C_GRY|C_GAMMA); |
| 286 |
| 287 |
| 288 |
| 289 |
                                hi != 1) |
| 290 |
                        quiterr("unsupported samples per pixel for greyscale"); |
| 291 |
| 292 |
| 293 |
                        quiterr("unsupported bits per sample for greyscale"); |
| 294 |
                if (hi == 8) |
| 295 |
                        cvts.tf = Gry2Colr; |
| 296 |
                else { |
| 297 |
                        cvts.tf = GGry2Color; |
| 298 |
| 299 |
| 300 |
                break; |
| 301 |
        default: |
| 302 |
| 303 |
                break; |
| 304 |
| 305 |
| 306 |
        if (!TIFFGetField(cvts.tif, TIFFTAG_IMAGEWIDTH, &cvts.xmax) || |
| 307 |
                !TIFFGetField(cvts.tif, TIFFTAG_IMAGELENGTH, &cvts.ymax)) |
| 308 |
                quiterr("unknown input image resolution"); |
| 309 |
| 310 |
        if (!TIFFGetField(cvts.tif, TIFFTAG_STONITS, &cvts.stonits)) |
| 311 |
                cvts.stonits = 1.; |
| 312 |
                                        /* add to Radiance header */ |
| 313 |
        if (cvts.pixrat < .99 || cvts.pixrat > 1.01) |
| 314 |
                fputaspect(cvts.pixrat, cvts.rfp); |
| 315 |
| 316 |
                fputexpos(pow(2.,(double)cvts.bradj)/cvts.stonits, cvts.rfp); |
| 317 |
                fputformat(CIEFMT, cvts.rfp); |
| 318 |
        } else { |
| 319 |
                if (CHK(C_PRIM)) |
| 320 |
                        fputprims(cvts.prims, cvts.rfp); |
| 321 |
                fputexpos(WHTEFFICACY*pow(2.,(double)cvts.bradj)/cvts.stonits, |
| 322 |
                                cvts.rfp); |
| 323 |
                fputformat(COLRFMT, cvts.rfp); |
| 324 |
| 325 |
| 326 |
        allocbufs();                    /* allocate scanline buffers */ |
| 327 |
| 328 |
| 329 |
| 330 |
tiff2ra(ac, av)         /* convert TIFF image to Radiance picture */ |
| 331 |
int  ac; |
| 332 |
char  *av[]; |
| 333 |
| 334 |
        int32   y; |
| 335 |
                                        /* open TIFF input */ |
| 336 |
        if ((cvts.tif = TIFFOpen(av[ac], "r")) == NULL) |
| 337 |
                quiterr("cannot open TIFF input"); |
| 338 |
                                        /* open Radiance output */ |
| 339 |
        if (av[ac+1] == NULL || !strcmp(av[ac+1], "-")) |
| 340 |
                cvts.rfp = stdout; |
| 341 |
        else if ((cvts.rfp = fopen(av[ac+1], "w")) == NULL) |
| 342 |
                quiterr("cannot open Radiance output picture"); |
| 343 |
                                        /* start output header */ |
| 344 |
        newheader("RADIANCE", cvts.rfp); |
| 345 |
        printargs(ac, av, cvts.rfp); |
| 346 |
| 347 |
        initfromtif();                  /* initialize conversion */ |
| 348 |
| 349 |
        fputc('\n', cvts.rfp);          /* finish Radiance header */ |
| 350 |
        fputresolu(pixorder(), (int)cvts.xmax, (int)cvts.ymax, cvts.rfp); |
| 351 |
| 352 |
        for (y = 0; y < cvts.ymax; y++)         /* convert image */ |
| 353 |
                (*cvts.tf)(y); |
| 354 |
                                                /* clean up */ |
| 355 |
        fclose(cvts.rfp); |
| 356 |
        TIFFClose(cvts.tif); |
| 357 |
| 358 |
| 359 |
| 360 |
int |
| 361 |
headline(s)                     /* process Radiance input header line */ |
| 362 |
char    *s; |
| 363 |
| 364 |
        char    fmt[32]; |
| 365 |
| 366 |
        if (formatval(fmt, s)) { |
| 367 |
                if (!strcmp(fmt, COLRFMT)) |
| 368 |
                        CLR(C_XYZE); |
| 369 |
                else if (!strcmp(fmt, CIEFMT)) |
| 370 |
                        SET(C_XYZE); |
| 371 |
                else |
| 372 |
                        quiterr("unrecognized input picture format"); |
| 373 |
                return(1); |
| 374 |
| 375 |
        if (isexpos(s)) { |
| 376 |
                cvts.stonits /= exposval(s); |
| 377 |
                return(1); |
| 378 |
| 379 |
        if (isaspect(s)) { |
| 380 |
                cvts.pixrat *= aspectval(s); |
| 381 |
                return(1); |
| 382 |
| 383 |
        if (isprims(s)) { |
| 384 |
                primsval(cvts.prims, s); |
| 385 |
                SET(C_PRIM); |
| 386 |
                return(1); |
| 387 |
| 388 |
        return(0); |
| 389 |
| 390 |
| 391 |
| 392 |
initfromrad()                   /* initialize input from a Radiance picture */ |
| 393 |
| 394 |
        int     i1, i2, po; |
| 395 |
                                                /* read Radiance header */ |
| 396 |
        CLR(C_RFLT|C_TFLT|C_XYZE|C_PRIM|C_GAMMA|C_CXFM); |
| 397 |
| 398 |
        cvts.pixrat = 1.; |
| 399 |
| 400 |
        getheader(cvts.rfp, headline, NULL); |
| 401 |
        if ((po = fgetresolu(&i1, &i2, cvts.rfp)) < 0) |
| 402 |
                quiterr("bad Radiance picture"); |
| 403 |
        cvts.xmax = i1; cvts.ymax = i2; |
| 404 |
        for (i1 = 0; i1 < 8; i1++)              /* interpret orientation */ |
| 405 |
                if (ortab[i1] == po) { |
| 406 |
                        cvts.orient = i1 + 1; |
| 407 |
                        break; |
| 408 |
| 409 |
        if (i1 >= 8) |
| 410 |
                quiterr("internal error 1 in initfromrad"); |
| 411 |
        if (!(po & YMAJOR)) |
| 412 |
                cvts.pixrat = 1./cvts.pixrat; |
| 413 |
        if (!CHK(C_XYZE)) |
| 414 |
                cvts.stonits *= WHTEFFICACY; |
| 415 |
                                                /* set up conversion */ |
| 416 |
        TIFFSetField(cvts.tif, TIFFTAG_COMPRESSION, cvts.comp); |
| 417 |
        TIFFSetField(cvts.tif, TIFFTAG_PHOTOMETRIC, cvts.phot); |
| 418 |
| 419 |
| 420 |
| 421 |
| 422 |
                CLR(C_GRY); |
| 423 |
| 424 |
| 425 |
| 426 |
                        SET(C_CXFM); |
| 427 |
| 428 |
                if (cvts.comp != COMPRESSION_SGILOG && |
| 429 |
                                cvts.comp != COMPRESSION_SGILOG24) |
| 430 |
                        quiterr("internal error 2 in initfromrad"); |
| 431 |
| 432 |
| 433 |
                cvts.tf = Color2Luv; |
| 434 |
                break; |
| 435 |
| 436 |
                SET(C_GRY|C_RFLT|C_TFLT); |
| 437 |
                if (cvts.comp != COMPRESSION_SGILOG)     |
| 438 |
                        quiterr("internal error 3 in initfromrad"); |
| 439 |
| 440 |
| 441 |
                cvts.tf = Color2L; |
| 442 |
                break; |
| 443 |
| 444 |
                SET(C_GAMMA|C_GAMUT); |
| 445 |
                CLR(C_GRY); |
| 446 |
| 447 |
| 448 |
                        compxyz2rgbWBmat(cvts.cmat, |
| 449 |
| 450 |
                        SET(C_CXFM); |
| 451 |
| 452 |
                if (CHK(C_PRIM)) { |
| 453 |
                        TIFFSetField(cvts.tif, TIFFTAG_PRIMARYCHROMATICITIES, |
| 454 |
                                        (float *)cvts.prims); |
| 455 |
                        TIFFSetField(cvts.tif, TIFFTAG_WHITEPOINT, |
| 456 |
                                        (float *)cvts.prims[WHT]); |
| 457 |
| 458 |
                cvts.tf = Colr2RGB; |
| 459 |
                break; |
| 460 |
| 461 |
                SET(C_GRY|C_GAMMA|C_GAMUT); |
| 462 |
| 463 |
                cvts.tf = Colr2Gry; |
| 464 |
                break; |
| 465 |
        default: |
| 466 |
                quiterr("internal error 4 in initfromrad"); |
| 467 |
                break; |
| 468 |
| 469 |
                                                /* set other TIFF fields */ |
| 470 |
        TIFFSetField(cvts.tif, TIFFTAG_IMAGEWIDTH, cvts.xmax); |
| 471 |
        TIFFSetField(cvts.tif, TIFFTAG_IMAGELENGTH, cvts.ymax); |
| 472 |
        TIFFSetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, CHK(C_GRY) ? 1 : 3); |
| 473 |
        TIFFSetField(cvts.tif, TIFFTAG_BITSPERSAMPLE, CHK(C_TFLT) ? 32 : 8); |
| 474 |
        TIFFSetField(cvts.tif, TIFFTAG_XRESOLUTION, 72.); |
| 475 |
        TIFFSetField(cvts.tif, TIFFTAG_YRESOLUTION, 72./cvts.pixrat); |
| 476 |
        TIFFSetField(cvts.tif, TIFFTAG_ORIENTATION, cvts.orient); |
| 477 |
        TIFFSetField(cvts.tif, TIFFTAG_RESOLUTIONUNIT, 2); |
| 478 |
        TIFFSetField(cvts.tif, TIFFTAG_PLANARCONFIG, cvts.pconf); |
| 479 |
        TIFFSetField(cvts.tif, TIFFTAG_STONITS, |
| 480 |
                        cvts.stonits/pow(2.,(double)cvts.bradj)); |
| 481 |
        if (cvts.comp == COMPRESSION_NONE) |
| 482 |
                i1 = TIFFScanlineSize(cvts.tif); |
| 483 |
        else |
| 484 |
                i1 = 3*cvts.xmax;       /* conservative guess */ |
| 485 |
        i2 = 8192/i1;                           /* compute good strip size */ |
| 486 |
        if (i2 < 1) i2 = 1; |
| 487 |
        TIFFSetField(cvts.tif, TIFFTAG_ROWSPERSTRIP, (uint32)i2); |
| 488 |
| 489 |
| 490 |
| 491 |
| 492 |
| 493 |
ra2tiff(ac, av)         /* convert Radiance picture to TIFF image */ |
| 494 |
int  ac; |
| 495 |
char  *av[]; |
| 496 |
| 497 |
        uint32  y; |
| 498 |
                                                /* open Radiance file */ |
| 499 |
        if (!strcmp(av[ac], "-")) |
| 500 |
                cvts.rfp = stdin; |
| 501 |
        else if ((cvts.rfp = fopen(av[ac], "r")) == NULL) |
| 502 |
                quiterr("cannot open Radiance input picture"); |
| 503 |
                                                /* open TIFF file */ |
| 504 |
        if ((cvts.tif = TIFFOpen(av[ac+1], "w")) == NULL) |
| 505 |
                quiterr("cannot open TIFF output"); |
| 506 |
| 507 |
        initfromrad();                          /* initialize conversion */ |
| 508 |
| 509 |
| 510 |
                (*cvts.tf)(y); |
| 511 |
                                                /* clean up */ |
| 512 |
| 513 |
        fclose(cvts.rfp); |
| 514 |
| 515 |
| 516 |
| 517 |
int |
| 518 |
Luv2Color(y)                    /* read/convert/write Luv->COLOR scanline */ |
| 519 |
uint32  y; |
| 520 |
| 521 |
        register int    x; |
| 522 |
| 523 |
        if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_RFLT|C_TFLT)) |
| 524 |
                quiterr("internal error 1 in Luv2Color"); |
| 525 |
| 526 |
        if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0) |
| 527 |
                quiterr("error reading TIFF input"); |
| 528 |
| 529 |
        for (x = cvts.xmax; x--; ) { |
| 530 |
                colval(cvts.r.colors[x],CIEX) = cvts.t.fp[3*x]; |
| 531 |
                colval(cvts.r.colors[x],CIEY) = cvts.t.fp[3*x + 1]; |
| 532 |
                colval(cvts.r.colors[x],CIEZ) = cvts.t.fp[3*x + 2]; |
| 533 |
                if (CHK(C_CXFM)) |
| 534 |
                        colortrans(cvts.r.colors[x], cvts.cmat, |
| 535 |
                                        cvts.r.colors[x]); |
| 536 |
                if (CHK(C_GAMUT)) |
| 537 |
                        clipgamut(cvts.r.colors[x], cvts.t.fp[3*x + 1], |
| 538 |
                                        CGAMUT_LOWER, cblack, cwhite); |
| 539 |
| 540 |
        if (cvts.bradj) { |
| 541 |
                double  m = pow(2.,(double)cvts.bradj); |
| 542 |
                for (x = cvts.xmax; x--; ) |
| 543 |
                        scalecolor(cvts.r.colors[x], m); |
| 544 |
| 545 |
| 546 |
        if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0) |
| 547 |
                quiterr("error writing Radiance picture"); |
| 548 |
| 549 |
| 550 |
| 551 |
int |
| 552 |
RRGGBB2Color(y)                 /* read/convert/write RGB16->COLOR scanline */ |
| 553 |
uint32  y; |
| 554 |
| 555 |
        int     dogamma = cvts.gamcor < 0.99 | cvts.gamcor > 1.01; |
| 556 |
        register double d; |
| 557 |
        register int    x; |
| 558 |
| 559 |
        if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_TWRD|C_RFLT)) |
| 560 |
                quiterr("internal error 1 in RRGGBB2Color"); |
| 561 |
| 562 |
| 563 |
| 564 |
| 565 |
| 566 |
                d = (cvts.t.wp[3*x] + 0.5)*(1./(1L<<16)); |
| 567 |
                if (dogamma) d = pow(d, cvts.gamcor); |
| 568 |
                colval(cvts.r.colors[x],RED) = d; |
| 569 |
                d = (cvts.t.wp[3*x + 1] + 0.5)*(1./(1L<<16)); |
| 570 |
| 571 |
                colval(cvts.r.colors[x],GRN) = d; |
| 572 |
                d = (cvts.t.wp[3*x + 2] + 0.5)*(1./(1L<<16)); |
| 573 |
| 574 |
                colval(cvts.r.colors[x],BLU) = d; |
| 575 |
                if (CHK(C_CXFM)) |
| 576 |
| 577 |
| 578 |
                if (CHK(C_GAMUT)) |
| 579 |
| 580 |
| 581 |
| 582 |
        if (cvts.bradj) { |
| 583 |
                d = pow(2.,(double)cvts.bradj); |
| 584 |
| 585 |
                        scalecolor(cvts.r.colors[x], d); |
| 586 |
| 587 |
| 588 |
| 589 |
| 590 |
| 591 |
| 592 |
| 593 |
int |
| 594 |
L2Color(y)                      /* read/convert/write L16->COLOR scanline */ |
| 595 |
uint32  y; |
| 596 |
| 597 |
        register int    x; |
| 598 |
| 599 |
        if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_RFLT|C_TFLT|C_GRY)) |
| 600 |
                quiterr("internal error 1 in L2Color"); |
| 601 |
| 602 |
| 603 |
| 604 |
| 605 |
| 606 |
                colval(cvts.r.colors[x],RED) = |
| 607 |
                colval(cvts.r.colors[x],GRN) = |
| 608 |
                colval(cvts.r.colors[x],BLU) = |
| 609 |
                                cvts.t.fp[x] > 0. ? cvts.t.fp[x] : 0.; |
| 610 |
| 611 |
| 612 |
| 613 |
| 614 |
| 615 |
| 616 |
int |
| 617 |
RGB2Colr(y)                     /* read/convert/write RGB->COLR scanline */ |
| 618 |
uint32  y; |
| 619 |
| 620 |
        COLOR   ctmp; |
| 621 |
        register int    x; |
| 622 |
| 623 |
        if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY)) |
| 624 |
                quiterr("internal error 1 in RGB2Colr"); |
| 625 |
| 626 |
        if (cvts.pconf == PLANARCONFIG_CONTIG) { |
| 627 |
| 628 |
                        goto readerr; |
| 629 |
| 630 |
                        cvts.r.colrs[x][RED] = cvts.t.bp[3*x]; |
| 631 |
                        cvts.r.colrs[x][GRN] = cvts.t.bp[3*x + 1]; |
| 632 |
                        cvts.r.colrs[x][BLU] = cvts.t.bp[3*x + 2]; |
| 633 |
| 634 |
        } else { |
| 635 |
| 636 |
                        goto readerr; |
| 637 |
                if (TIFFReadScanline(cvts.tif, |
| 638 |
                                (tdata_t)(cvts.t.bp + cvts.xmax), y, 1) < 0) |
| 639 |
                        goto readerr; |
| 640 |
| 641 |
                                (tdata_t)(cvts.t.bp + 2*cvts.xmax), y, 2) < 0) |
| 642 |
                        goto readerr; |
| 643 |
| 644 |
                        cvts.r.colrs[x][RED] = cvts.t.bp[x]; |
| 645 |
                        cvts.r.colrs[x][GRN] = cvts.t.bp[cvts.xmax + x]; |
| 646 |
                        cvts.r.colrs[x][BLU] = cvts.t.bp[2*cvts.xmax + x]; |
| 647 |
| 648 |
| 649 |
| 650 |
        gambs_colrs(cvts.r.colrs, cvts.xmax); |
| 651 |
        if (CHK(C_CXFM)) |
| 652 |
| 653 |
                        colr_color(ctmp, cvts.r.colrs[x]); |
| 654 |
                        colortrans(ctmp, cvts.cmat, ctmp); |
| 655 |
                        if (CHK(C_GAMUT))       /* !CHK(C_XYZE) */ |
| 656 |
                                clipgamut(ctmp, bright(ctmp), CGAMUT_LOWER, |
| 657 |
                                                cblack, cwhite); |
| 658 |
                        setcolr(cvts.r.colrs[x], colval(ctmp,RED), |
| 659 |
                                        colval(ctmp,GRN), colval(ctmp,BLU)); |
| 660 |
| 661 |
        if (cvts.bradj) |
| 662 |
                shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj); |
| 663 |
| 664 |
        if (fwritecolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0) |
| 665 |
| 666 |
        return; |
| 667 |
readerr: |
| 668 |
| 669 |
| 670 |
| 671 |
| 672 |
int |
| 673 |
Gry2Colr(y)                     /* read/convert/write G8->COLR scanline */ |
| 674 |
uint32  y; |
| 675 |
| 676 |
        register int    x; |
| 677 |
| 678 |
        if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != C_GRY) |
| 679 |
                quiterr("internal error 1 in Gry2Colr"); |
| 680 |
| 681 |
| 682 |
| 683 |
| 684 |
| 685 |
                cvts.r.colrs[x][RED] = |
| 686 |
                cvts.r.colrs[x][GRN] = |
| 687 |
                cvts.r.colrs[x][BLU] = cvts.t.bp[x]; |
| 688 |
| 689 |
| 690 |
        if (cvts.bradj) |
| 691 |
| 692 |
| 693 |
| 694 |
| 695 |
| 696 |
| 697 |
| 698 |
int |
| 699 |
GGry2Color(y)                   /* read/convert/write G16->COLOR scanline */ |
| 700 |
uint32  y; |
| 701 |
| 702 |
| 703 |
        double  m; |
| 704 |
| 705 |
        register int    x; |
| 706 |
| 707 |
        if (CHK(C_TFLT|C_TWRD|C_GRY|C_RFLT) != (C_GRY|C_RFLT|C_TWRD)) |
| 708 |
                quiterr("internal error 1 in GGry2Color"); |
| 709 |
| 710 |
| 711 |
| 712 |
| 713 |
        if (cvts.bradj) |
| 714 |
                m = pow(2., (double)cvts.bradj); |
| 715 |
| 716 |
                d = (cvts.t.wp[x] + 0.5)*(1./(1L<<16)); |
| 717 |
| 718 |
                if (cvts.bradj) d *= m; |
| 719 |
| 720 |
| 721 |
| 722 |
| 723 |
| 724 |
| 725 |
| 726 |
| 727 |
| 728 |
int |
| 729 |
Color2L(y)                      /* read/convert/write COLOR->L16 scanline */ |
| 730 |
uint32  y; |
| 731 |
| 732 |
| 733 |
        register int    x; |
| 734 |
| 735 |
        if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY) != (C_RFLT|C_TFLT|C_GRY)) |
| 736 |
                quiterr("internal error 1 in Color2L"); |
| 737 |
| 738 |
        if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0) |
| 739 |
                quiterr("error reading Radiance picture"); |
| 740 |
| 741 |
| 742 |
                cvts.t.fp[x] = m*( CHK(C_XYZE) ? colval(cvts.r.colors[x],CIEY) |
| 743 |
                                                : bright(cvts.r.colors[x]) ); |
| 744 |
| 745 |
        if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0) |
| 746 |
                quiterr("error writing TIFF output"); |
| 747 |
| 748 |
| 749 |
| 750 |
int |
| 751 |
Color2Luv(y)                    /* read/convert/write COLOR->Luv scanline */ |
| 752 |
uint32  y; |
| 753 |
| 754 |
        register int    x; |
| 755 |
| 756 |
| 757 |
                quiterr("internal error 1 in Color2Luv"); |
| 758 |
| 759 |
| 760 |
| 761 |
| 762 |
        if (CHK(C_CXFM)) |
| 763 |
| 764 |
| 765 |
| 766 |
        if (cvts.bradj) { |
| 767 |
| 768 |
| 769 |
| 770 |
| 771 |
| 772 |
| 773 |
                cvts.t.fp[3*x] = colval(cvts.r.colors[x],CIEX); |
| 774 |
                cvts.t.fp[3*x+1] = colval(cvts.r.colors[x],CIEY); |
| 775 |
                cvts.t.fp[3*x+2] = colval(cvts.r.colors[x],CIEZ); |
| 776 |
| 777 |
| 778 |
| 779 |
| 780 |
| 781 |
| 782 |
| 783 |
int |
| 784 |
Colr2Gry(y)                     /* read/convert/write COLR->RGB scanline */ |
| 785 |
uint32  y; |
| 786 |
| 787 |
        register int    x; |
| 788 |
| 789 |
| 790 |
                quiterr("internal error 1 in Colr2Gry"); |
| 791 |
| 792 |
        if (freadcolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0) |
| 793 |
| 794 |
| 795 |
        if (cvts.bradj) |
| 796 |
| 797 |
| 798 |
                colval(cvts.r.colrs[x],CIEY) = normbright(cvts.r.colrs[x]); |
| 799 |
        colrs_gambs(cvts.r.colrs, cvts.xmax); |
| 800 |
| 801 |
| 802 |
                cvts.t.bp[x] = colval(cvts.r.colrs[x],CIEY); |
| 803 |
| 804 |
| 805 |
| 806 |
| 807 |
| 808 |
| 809 |
int |
| 810 |
Colr2RGB(y)                     /* read/convert/write COLR->RGB scanline */ |
| 811 |
uint32  y; |
| 812 |
| 813 |
        COLOR   ctmp; |
| 814 |
        register int    x; |
| 815 |
| 816 |
        if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY)) |
| 817 |
                quiterr("internal error 1 in Colr2RGB"); |
| 818 |
| 819 |
| 820 |
| 821 |
| 822 |
        if (cvts.bradj) |
| 823 |
| 824 |
        if (CHK(C_CXFM)) |
| 825 |
| 826 |
| 827 |
| 828 |
                        if (CHK(C_GAMUT)) |
| 829 |
                                clipgamut(ctmp, bright(ctmp), CGAMUT, |
| 830 |
                                                cblack, cwhite); |
| 831 |
| 832 |
| 833 |
| 834 |
| 835 |
| 836 |
| 837 |
                cvts.t.bp[3*x] = cvts.r.colrs[x][RED]; |
| 838 |
                cvts.t.bp[3*x+1] = cvts.r.colrs[x][GRN]; |
| 839 |
                cvts.t.bp[3*x+2] = cvts.r.colrs[x][BLU]; |
| 840 |
| 841 |
| 842 |
| 843 |
| 844 |
