| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: ra_t16.c,v 2.8 2004/03/28 20:33:14 schorsch Exp $";
| 3 |
#endif
| 4 |
| 5 |
* ra_t16.c - program to convert between RADIANCE and
| 6 |
* Targa 16, 24 and 32-bit images.
| 7 |
| 8 |
* 11/2/88 Adapted from ra_t8.c
| 9 |
| 10 |
| 11 |
#include <stdio.h>
| 12 |
#include <string.h>
| 13 |
#include <time.h>
| 14 |
#include <math.h>
| 15 |
| 16 |
#include "platform.h"
| 17 |
#include "rtio.h"
| 18 |
#include "rtmisc.h"
| 19 |
#include "color.h"
| 20 |
#include "resolu.h"
| 21 |
#include "random.h"
| 22 |
#include "targa.h"
| 23 |
| 24 |
#define goodpic(h) (((h)->dataType==IM_RGB || (h)->dataType==IM_CRGB) \
| 25 |
&& ((h)->dataBits==16 || (h)->dataBits==24))
| 26 |
| 27 |
#define taralloc(h) (unsigned char *)emalloc((h)->x*(h)->y*(h)->dataBits/8)
| 28 |
| 29 |
#define readtarga(h,d,f) ((h)->dataBits==16 ? \
| 30 |
readt16(h,(unsigned short*)d,f) : readt24(h,d,f))
| 31 |
| 32 |
#define writetarga(h,d,f) ((h)->dataBits==16 ? \
| 33 |
writet16(h,(unsigned short*)d,f) : writet24(h,d,f))
| 34 |
| 35 |
double gamcor = 2.2; /* gamma correction */
| 36 |
int bradj = 0; /* brightness adjustment */
| 37 |
char *progname;
| 38 |
char msg[128];
| 39 |
| 40 |
static int getint2(FILE *fp);
| 41 |
static void putint2(int i, FILE *fp);
| 42 |
static void quiterr(char *err);
| 43 |
static int getthead(struct hdStruct *hp, char *ip, FILE *fp);
| 44 |
static int putthead(struct hdStruct *hp, char *ip, FILE *fp);
| 45 |
static void tg2ra(struct hdStruct *hp);
| 46 |
static void ra2tg(struct hdStruct *hp);
| 47 |
static void writet24(struct hdStruct *h, unsigned char *d, FILE *fp);
| 48 |
static void writet16(struct hdStruct *h, unsigned short *d, FILE *fp);
| 49 |
static void readt24(struct hdStruct *h, unsigned char *data, FILE *fp);
| 50 |
static void readt16(struct hdStruct *h, unsigned short *data, FILE *fp);
| 51 |
| 52 |
| 53 |
int
| 54 |
main(int argc, char *argv[])
| 55 |
| 56 |
struct hdStruct head;
| 57 |
int reverse = 0;
| 58 |
int i;
| 59 |
SET_DEFAULT_BINARY();
| 60 |
SET_FILE_BINARY(stdin);
| 61 |
SET_FILE_BINARY(stdout);
| 62 |
progname = argv[0];
| 63 |
| 64 |
head.dataBits = 16;
| 65 |
for (i = 1; i < argc; i++)
| 66 |
if (argv[i][0] == '-')
| 67 |
switch (argv[i][1]) {
| 68 |
case 'g':
| 69 |
gamcor = atof(argv[++i]);
| 70 |
break;
| 71 |
case 'r':
| 72 |
reverse = !reverse;
| 73 |
break;
| 74 |
case '2':
| 75 |
head.dataBits = 16;
| 76 |
break;
| 77 |
case '3':
| 78 |
head.dataBits = 24;
| 79 |
break;
| 80 |
case 'e':
| 81 |
if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
| 82 |
goto userr;
| 83 |
bradj = atoi(argv[++i]);
| 84 |
break;
| 85 |
default:
| 86 |
goto userr;
| 87 |
| 88 |
else
| 89 |
break;
| 90 |
| 91 |
if (i < argc-2)
| 92 |
goto userr;
| 93 |
/* open input file */
| 94 |
if (i <= argc-1 && freopen(argv[i], "r", stdin) == NULL) {
| 95 |
sprintf(msg, "can't open input \"%s\"", argv[i]);
| 96 |
quiterr(msg);
| 97 |
| 98 |
/* open output file */
| 99 |
if (i == argc-2 && freopen(argv[i+1], "w", stdout) == NULL) {
| 100 |
sprintf(msg, "can't open output \"%s\"", argv[i+1]);
| 101 |
quiterr(msg);
| 102 |
| 103 |
/* set gamma */
| 104 |
setcolrgam(gamcor);
| 105 |
/* convert */
| 106 |
if (reverse) {
| 107 |
/* get header */
| 108 |
if (getthead(&head, NULL, stdin) < 0)
| 109 |
quiterr("bad targa file");
| 110 |
if (!goodpic(&head))
| 111 |
quiterr("incompatible format");
| 112 |
/* put header */
| 113 |
newheader("RADIANCE", stdout);
| 114 |
printargs(i, argv, stdout);
| 115 |
fputformat(COLRFMT, stdout);
| 116 |
putchar('\n');
| 117 |
fprtresolu(head.x, head.y, stdout);
| 118 |
/* convert file */
| 119 |
tg2ra(&head);
| 120 |
} else {
| 121 |
if (checkheader(stdin, COLRFMT, NULL) < 0 ||
| 122 |
fgetresolu(&head.x, &head.y, stdin) < 0)
| 123 |
quiterr("bad picture file");
| 124 |
/* assign header */
| 125 |
head.textSize = 0;
| 126 |
head.mapType = CM_NOMAP;
| 127 |
head.dataType = IM_RGB;
| 128 |
head.XOffset = 0;
| 129 |
head.YOffset = 0;
| 130 |
head.imType = 0;
| 131 |
/* write header */
| 132 |
putthead(&head, NULL, stdout);
| 133 |
/* convert file */
| 134 |
ra2tg(&head);
| 135 |
| 136 |
exit(0);
| 137 |
userr:
| 138 |
fprintf(stderr, "Usage: %s [-2|-3|-r][-g gamma][-e +/-stops] [input [output]]\n",
| 139 |
progname);
| 140 |
exit(1);
| 141 |
| 142 |
| 143 |
| 144 |
static int
| 145 |
getint2( /* get a 2-byte positive integer */
| 146 |
register FILE *fp
| 147 |
| 148 |
| 149 |
register int b1, b2;
| 150 |
| 151 |
if ((b1 = getc(fp)) == EOF || (b2 = getc(fp)) == EOF)
| 152 |
quiterr("read error");
| 153 |
| 154 |
return(b1 | b2<<8);
| 155 |
| 156 |
| 157 |
| 158 |
static void
| 159 |
putint2( /* put a 2-byte positive integer */
| 160 |
register int i,
| 161 |
register FILE *fp
| 162 |
| 163 |
| 164 |
putc(i&0xff, fp);
| 165 |
putc(i>>8&0xff, fp);
| 166 |
| 167 |
| 168 |
| 169 |
static void
| 170 |
quiterr( /* print message and exit */
| 171 |
char *err
| 172 |
| 173 |
| 174 |
fprintf(stderr, "%s: %s\n", progname, err);
| 175 |
exit(1);
| 176 |
| 177 |
| 178 |
| 179 |
void
| 180 |
eputs(
| 181 |
char *s
| 182 |
| 183 |
| 184 |
fputs(s, stderr);
| 185 |
| 186 |
| 187 |
| 188 |
void
| 189 |
quit(
| 190 |
int code
| 191 |
| 192 |
| 193 |
exit(code);
| 194 |
| 195 |
| 196 |
| 197 |
static int
| 198 |
getthead( /* read header from input */
| 199 |
| 200 |
char *ip,
| 201 |
register FILE *fp
| 202 |
| 203 |
| 204 |
int nidbytes;
| 205 |
| 206 |
if ((nidbytes = getc(fp)) == EOF)
| 207 |
return(-1);
| 208 |
hp->mapType = getc(fp);
| 209 |
hp->dataType = getc(fp);
| 210 |
hp->mapOrig = getint2(fp);
| 211 |
hp->mapLength = getint2(fp);
| 212 |
hp->CMapBits = getc(fp);
| 213 |
hp->XOffset = getint2(fp);
| 214 |
hp->YOffset = getint2(fp);
| 215 |
hp->x = getint2(fp);
| 216 |
hp->y = getint2(fp);
| 217 |
hp->dataBits = getc(fp);
| 218 |
hp->imType = getc(fp);
| 219 |
| 220 |
if (ip != NULL)
| 221 |
if (nidbytes)
| 222 |
fread((char *)ip, nidbytes, 1, fp);
| 223 |
else
| 224 |
*ip = '\0';
| 225 |
else if (nidbytes)
| 226 |
fseek(fp, (long)nidbytes, 1);
| 227 |
| 228 |
return(feof(fp) || ferror(fp) ? -1 : 0);
| 229 |
| 230 |
| 231 |
| 232 |
static int
| 233 |
putthead( /* write header to output */
| 234 |
| 235 |
char *ip,
| 236 |
register FILE *fp
| 237 |
| 238 |
| 239 |
if (ip != NULL)
| 240 |
putc(strlen(ip), fp);
| 241 |
else
| 242 |
putc(0, fp);
| 243 |
putc(hp->mapType, fp);
| 244 |
putc(hp->dataType, fp);
| 245 |
putint2(hp->mapOrig, fp);
| 246 |
putint2(hp->mapLength, fp);
| 247 |
putc(hp->CMapBits, fp);
| 248 |
putint2(hp->XOffset, fp);
| 249 |
putint2(hp->YOffset, fp);
| 250 |
putint2(hp->x, fp);
| 251 |
putint2(hp->y, fp);
| 252 |
putc(hp->dataBits, fp);
| 253 |
putc(hp->imType, fp);
| 254 |
| 255 |
if (ip != NULL)
| 256 |
fputs(ip, fp);
| 257 |
| 258 |
return(ferror(fp) ? -1 : 0);
| 259 |
| 260 |
| 261 |
| 262 |
static void
| 263 |
tg2ra( /* targa file to RADIANCE file */
| 264 |
struct hdStruct *hp
| 265 |
| 266 |
| 267 |
COLR *scanline;
| 268 |
unsigned char *tarData;
| 269 |
register int i, j;
| 270 |
/* skip color table */
| 271 |
if (hp->mapType == CM_HASMAP)
| 272 |
fseek(stdin, (long)hp->mapLength*hp->CMapBits/8, 1);
| 273 |
/* allocate targa data */
| 274 |
tarData = taralloc(hp);
| 275 |
/* get data */
| 276 |
readtarga(hp, tarData, stdin);
| 277 |
/* allocate input scanline */
| 278 |
scanline = (COLR *)emalloc(hp->x*sizeof(COLR));
| 279 |
/* convert file */
| 280 |
for (i = hp->y-1; i >= 0; i--) {
| 281 |
if (hp->dataBits == 16) {
| 282 |
register unsigned short *dp;
| 283 |
dp = (unsigned short *)tarData + i*hp->x;
| 284 |
for (j = 0; j < hp->x; j++) {
| 285 |
scanline[j][RED] = *dp>>7 & 0xf8;
| 286 |
scanline[j][GRN] = *dp>>2 & 0xf8;
| 287 |
scanline[j][BLU] = *dp<<3 & 0xf8;
| 288 |
dp++;
| 289 |
| 290 |
} else { /* hp->dataBits == 24 */
| 291 |
register unsigned char *dp;
| 292 |
dp = (unsigned char *)tarData + i*3*hp->x;
| 293 |
| 294 |
scanline[j][RED] = dp[2];
| 295 |
scanline[j][GRN] = dp[1];
| 296 |
scanline[j][BLU] = dp[0];
| 297 |
dp += 3;
| 298 |
| 299 |
| 300 |
gambs_colrs(scanline, hp->x);
| 301 |
if (bradj)
| 302 |
shiftcolrs(scanline, hp->x, bradj);
| 303 |
if (fwritecolrs(scanline, hp->x, stdout) < 0)
| 304 |
quiterr("error writing RADIANCE file");
| 305 |
| 306 |
free((void *)scanline);
| 307 |
free((void *)tarData);
| 308 |
| 309 |
| 310 |
| 311 |
static void
| 312 |
ra2tg( /* convert radiance to targa file */
| 313 |
struct hdStruct *hp
| 314 |
| 315 |
| 316 |
register int i, j;
| 317 |
| 318 |
COLR *inl;
| 319 |
/* allocate space for data */
| 320 |
inl = (COLR *)emalloc(hp->x*sizeof(COLR));
| 321 |
| 322 |
/* convert file */
| 323 |
for (j = hp->y-1; j >= 0; j--) {
| 324 |
if (freadcolrs(inl, hp->x, stdin) < 0)
| 325 |
quiterr("error reading RADIANCE file");
| 326 |
if (bradj)
| 327 |
shiftcolrs(inl, hp->x, bradj);
| 328 |
colrs_gambs(inl, hp->x);
| 329 |
| 330 |
| 331 |
register int v;
| 332 |
dp = (unsigned short *)tarData + j*hp->x;
| 333 |
for (i = 0; i < hp->x; i++) {
| 334 |
v = inl[i][RED] + (random()&7);
| 335 |
if (v > 255) v = 255;
| 336 |
*dp = (v&0xf8)<<7;
| 337 |
v = inl[i][GRN] + (random()&7);
| 338 |
| 339 |
*dp |= (v&0xf8)<<2;
| 340 |
v = inl[i][BLU] + (random()&7);
| 341 |
| 342 |
*dp++ |= v>>3;
| 343 |
| 344 |
| 345 |
| 346 |
dp = (unsigned char *)tarData + j*3*hp->x;
| 347 |
| 348 |
*dp++ = inl[i][BLU];
| 349 |
*dp++ = inl[i][GRN];
| 350 |
*dp++ = inl[i][RED];
| 351 |
| 352 |
| 353 |
| 354 |
/* write out targa data */
| 355 |
writetarga(hp, tarData, stdout);
| 356 |
| 357 |
free((void *)inl);
| 358 |
| 359 |
| 360 |
| 361 |
| 362 |
static void
| 363 |
writet24( /* write out 24-bit targa data */
| 364 |
struct hdStruct *h,
| 365 |
unsigned char *d,
| 366 |
FILE *fp
| 367 |
| 368 |
| 369 |
if (h->dataType == IM_RGB) { /* uncompressed */
| 370 |
if (fwrite((char *)d, 3*h->x, h->y, fp) != h->y)
| 371 |
quiterr("error writing targa file");
| 372 |
return;
| 373 |
| 374 |
quiterr("unsupported output type");
| 375 |
| 376 |
| 377 |
| 378 |
static void
| 379 |
writet16( /* write out 16-bit targa data */
| 380 |
struct hdStruct *h,
| 381 |
register unsigned short *d,
| 382 |
FILE *fp
| 383 |
| 384 |
| 385 |
register int cnt;
| 386 |
| 387 |
| 388 |
for (cnt = h->x*h->y; cnt-- > 0; )
| 389 |
putint2(*d++, fp);
| 390 |
if (ferror(fp))
| 391 |
| 392 |
return;
| 393 |
| 394 |
| 395 |
| 396 |
| 397 |
| 398 |
static void
| 399 |
readt24( /* read in 24-bit targa data */
| 400 |
register struct hdStruct *h,
| 401 |
| 402 |
FILE *fp
| 403 |
| 404 |
| 405 |
register int cnt, c;
| 406 |
| 407 |
int r, g, b;
| 408 |
| 409 |
| 410 |
if (fread((char *)data, 3*h->x, h->y, fp) != h->y)
| 411 |
goto readerr;
| 412 |
return;
| 413 |
| 414 |
for (dp = data; dp < data+3*h->x*h->y; ) {
| 415 |
if ((c = getc(fp)) == EOF)
| 416 |
goto readerr;
| 417 |
cnt = (c & 0x7f) + 1;
| 418 |
if (c & 0x80) { /* repeated pixel */
| 419 |
b = getc(fp); g = getc(fp);
| 420 |
if ((r = getc(fp)) == EOF)
| 421 |
goto readerr;
| 422 |
while (cnt--) {
| 423 |
*dp++ = b;
| 424 |
*dp++ = g;
| 425 |
*dp++ = r;
| 426 |
| 427 |
} else /* non-repeating pixels */
| 428 |
while (cnt--) {
| 429 |
*dp++ = getc(fp); *dp++ = getc(fp);
| 430 |
| 431 |
goto readerr;
| 432 |
*dp++ = r;
| 433 |
| 434 |
| 435 |
return;
| 436 |
readerr:
| 437 |
quiterr("error reading targa file");
| 438 |
| 439 |
| 440 |
| 441 |
static void
| 442 |
readt16( /* read in 16-bit targa data */
| 443 |
| 444 |
| 445 |
FILE *fp
| 446 |
| 447 |
| 448 |
| 449 |
| 450 |
| 451 |
| 452 |
dp = data;
| 453 |
| 454 |
*dp++ = getint2(fp);
| 455 |
return;
| 456 |
| 457 |
for (dp = data; dp < data+h->x*h->y; ) {
| 458 |
| 459 |
goto readerr;
| 460 |
| 461 |
| 462 |
c = getint2(fp);
| 463 |
while (cnt--)
| 464 |
*dp++ = c;
| 465 |
| 466 |
while (cnt--)
| 467 |
| 468 |
| 469 |
return;
| 470 |
readerr:
| 471 |
| 472 |
