root/radiance/src/px/ra_skel.c
Fri Mar 10 19:40:13 2006 UTC (19 years, 7 months ago) by schorsch
CVS Tags: rad3R8, rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3, rad5R4
Diff to previous 2.12
Thu Jun 5 19:29:34 2003 UTC (22 years, 4 months ago) by schorsch
Changes since 2.11: +5 -8 lines
Sat Feb 22 02:07:28 2003 UTC (22 years, 7 months ago) by greg
Changes since 2.10: +4 -8 lines
Tue Apr 5 14:10:52 1994 UTC (31 years, 6 months ago) by greg
fixed a comment
Sun Feb 27 10:17:18 1994 UTC (31 years, 7 months ago) by greg
Thu Nov 18 09:55:24 1993 UTC (31 years, 11 months ago) by greg
minor compiler warning fixes
Wed Oct 27 09:37:35 1993 UTC (31 years, 11 months ago) by greg
Changes since 2.6: +6 -4 lines
fixed missing loop
Mon Jul 12 12:41:16 1993 UTC (32 years, 3 months ago) by greg
renamed gamma to avoid math library conflict
Fri Jun 4 14:47:53 1993 UTC (32 years, 4 months ago) by greg
added math.h for atof() usage
Thu Dec 17 15:50:13 1992 UTC (32 years, 10 months ago) by greg
fixed munged comment
Mon Sep 21 12:15:17 1992 UTC (33 years, 1 month ago) by greg
Changes since 2.2: +10 -2 lines
Changes for PC port
Thu Dec 19 14:52:19 1991 UTC (33 years, 10 months ago) by greg
Tue Nov 12 15:16:41 1991 UTC (33 years, 11 months ago) by greg
