| 1 |
greg |
2.1 |
#ifndef lint |
| 2 |
schorsch |
2.12 |
static const char RCSid[] = "$Id: ra_skel.c,v 2.11 2003/02/22 02:07:28 greg Exp $"; |
| 3 |
greg |
2.1 |
#endif |
| 4 |
greg |
2.4 |
| 5 |
* Skeletal 24-bit image conversion program. Replace "skel" |
| 6 |
greg |
2.1 |
* in this file with a more appropriate image type identifier. |
| 7 |
| 8 |
greg |
2.10 |
* The Rmakefile entry should look something like this: |
| 9 |
greg |
2.1 |
* ra_skel: ra_skel.o |
| 10 |
* cc $(CFLAGS) -o ra_skel ra_skel.o -lrt -lm |
| 11 |
* ra_skel.o: ../common/color.h ../common/resolu.h |
| 12 |
| 13 |
* If you like to do things the hard way, you can link directly |
| 14 |
* to the object files "color.o colrops.o resolu.o header.o" in |
| 15 |
* the common subdirectory instead of using the -lrt library. |
| 16 |
| 17 |
| 18 |
#include <stdio.h> |
| 19 |
greg |
2.5 |
#include <math.h> |
| 20 |
greg |
2.11 |
#include <time.h> |
| 21 |
schorsch |
2.12 |
| 22 |
#include "platform.h" |
| 23 |
greg |
2.1 |
#include "color.h" |
| 24 |
#include "resolu.h" |
| 25 |
| 26 |
greg |
2.6 |
double gamcor = 2.2; /* gamma correction */ |
| 27 |
greg |
2.1 |
| 28 |
int bradj = 0; /* brightness adjustment */ |
| 29 |
| 30 |
char *progname; |
| 31 |
| 32 |
int xmax, ymax; |
| 33 |
| 34 |
| 35 |
main(argc, argv) |
| 36 |
int argc; |
| 37 |
char *argv[]; |
| 38 |
| 39 |
int reverse = 0; |
| 40 |
int i; |
| 41 |
| 42 |
progname = argv[0]; |
| 43 |
| 44 |
for (i = 1; i < argc; i++) |
| 45 |
if (argv[i][0] == '-') |
| 46 |
switch (argv[i][1]) { |
| 47 |
case 'g': /* gamma correction */ |
| 48 |
greg |
2.6 |
gamcor = atof(argv[++i]); |
| 49 |
greg |
2.1 |
break; |
| 50 |
case 'e': /* exposure adjustment */ |
| 51 |
if (argv[i+1][0] != '+' && argv[i+1][0] != '-') |
| 52 |
goto userr; |
| 53 |
bradj = atoi(argv[++i]); |
| 54 |
break; |
| 55 |
case 'r': /* reverse conversion */ |
| 56 |
reverse = 1; |
| 57 |
break; |
| 58 |
default: |
| 59 |
goto userr; |
| 60 |
| 61 |
else |
| 62 |
break; |
| 63 |
| 64 |
if (i < argc-2) |
| 65 |
goto userr; |
| 66 |
if (i <= argc-1 && freopen(argv[i], "r", stdin) == NULL) { |
| 67 |
fprintf(stderr, "%s: can't open input \"%s\"\n", |
| 68 |
progname, argv[i]); |
| 69 |
exit(1); |
| 70 |
| 71 |
if (i == argc-2 && freopen(argv[i+1], "w", stdout) == NULL) { |
| 72 |
greg |
2.8 |
fprintf(stderr, "%s: can't open output \"%s\"\n", |
| 73 |
greg |
2.1 |
progname, argv[i+1]); |
| 74 |
exit(1); |
| 75 |
| 76 |
schorsch |
2.12 |
SET_FILE_BINARY(stdin); |
| 77 |
SET_FILE_BINARY(stdout); |
| 78 |
greg |
2.6 |
setcolrgam(gamcor); /* set up gamma correction */ |
| 79 |
greg |
2.1 |
if (reverse) { |
| 80 |
/* get their image resolution */ |
| 81 |
read_skel_head(&xmax, &ymax); |
| 82 |
/* put our header */ |
| 83 |
greg |
2.9 |
newheader("RADIANCE", stdout); |
| 84 |
greg |
2.1 |
printargs(i, argv, stdout); |
| 85 |
fputformat(COLRFMT, stdout); |
| 86 |
putchar('\n'); |
| 87 |
fprtresolu(xmax, ymax, stdout); |
| 88 |
/* convert file */ |
| 89 |
skel2ra(); |
| 90 |
} else { |
| 91 |
/* get our header */ |
| 92 |
if (checkheader(stdin, COLRFMT, NULL) < 0 || |
| 93 |
fgetresolu(&xmax, &ymax, stdin) < 0) |
| 94 |
quiterr("bad picture format"); |
| 95 |
/* write their header */ |
| 96 |
write_skel_head(xmax, ymax); |
| 97 |
| 98 |
ra2skel(); |
| 99 |
| 100 |
exit(0); |
| 101 |
userr: |
| 102 |
fprintf(stderr, |
| 103 |
"Usage: %s [-r][-g gamma][-e +/-stops] [input [output]]\n", |
| 104 |
progname); |
| 105 |
exit(1); |
| 106 |
| 107 |
| 108 |
| 109 |
quiterr(err) /* print message and exit */ |
| 110 |
char *err; |
| 111 |
| 112 |
if (err != NULL) { |
| 113 |
fprintf(stderr, "%s: %s\n", progname, err); |
| 114 |
exit(1); |
| 115 |
| 116 |
exit(0); |
| 117 |
| 118 |
| 119 |
| 120 |
skel2ra() /* convert 24-bit scanlines to Radiance picture */ |
| 121 |
| 122 |
COLR *scanout; |
| 123 |
register int x; |
| 124 |
int y; |
| 125 |
/* allocate scanline */ |
| 126 |
scanout = (COLR *)malloc(xmax*sizeof(COLR)); |
| 127 |
if (scanout == NULL) |
| 128 |
quiterr("out of memory in skel2ra"); |
| 129 |
/* convert image */ |
| 130 |
for (y = ymax-1; y >= 0; y--) { |
| 131 |
greg |
2.7 |
for (x = 0; x < xmax; x++) { |
| 132 |
scanout[x][RED] = getc(stdin); |
| 133 |
scanout[x][GRN] = getc(stdin); |
| 134 |
scanout[x][BLU] = getc(stdin); |
| 135 |
| 136 |
if (feof(stdin) | ferror(stdin)) |
| 137 |
greg |
2.1 |
quiterr("error reading skel image"); |
| 138 |
/* undo gamma */ |
| 139 |
gambs_colrs(scanout, xmax); |
| 140 |
if (bradj) /* adjust exposure */ |
| 141 |
shiftcolrs(scanout, xmax, bradj); |
| 142 |
if (fwritecolrs(scanout, xmax, stdout) < 0) |
| 143 |
quiterr("error writing Radiance picture"); |
| 144 |
| 145 |
/* free scanline */ |
| 146 |
greg |
2.11 |
free((void *)scanout); |
| 147 |
greg |
2.1 |
| 148 |
| 149 |
| 150 |
ra2skel() /* convert Radiance scanlines to 24-bit */ |
| 151 |
| 152 |
COLR *scanin; |
| 153 |
register int x; |
| 154 |
int y; |
| 155 |
| 156 |
scanin = (COLR *)malloc(xmax*sizeof(COLR)); |
| 157 |
if (scanin == NULL) |
| 158 |
quiterr("out of memory in ra2skel"); |
| 159 |
| 160 |
| 161 |
if (freadcolrs(scanin, xmax, stdin) < 0) |
| 162 |
quiterr("error reading Radiance picture"); |
| 163 |
| 164 |
shiftcolrs(scanin, xmax, bradj); |
| 165 |
colrs_gambs(scanin, xmax); /* gamma correction */ |
| 166 |
| 167 |
putc(scanin[x][RED], stdout); |
| 168 |
putc(scanin[x][GRN], stdout); |
| 169 |
putc(scanin[x][BLU], stdout); |
| 170 |
| 171 |
if (ferror(stdout)) |
| 172 |
quiterr("error writing skel file"); |
| 173 |
| 174 |
| 175 |
greg |
2.11 |
free((void *)scanin); |
| 176 |
greg |
2.1 |
