| 1 |
greg |
1.1 |
#ifndef lint
| 2 |
greg |
2.26 |
static const char RCSid[] = "$Id: ra_rgbe.c,v 2.25 2025/04/22 14:51:29 greg Exp $";
| 3 |
greg |
1.1 |
#endif
| 4 |
| 5 |
* program to convert from RADIANCE RLE to flat format
| 6 |
| 7 |
| 8 |
greg |
2.4 |
#include <math.h>
| 9 |
schorsch |
2.12 |
| 10 |
#include "platform.h"
| 11 |
greg |
2.19 |
#include "rtio.h"
| 12 |
greg |
2.4 |
#include "color.h"
| 13 |
#include "resolu.h"
| 14 |
| 15 |
greg |
2.19 |
#define dumpheader(fp) putbinary(headlines, 1, headlen, fp)
| 16 |
gregl |
2.8 |
| 17 |
greg |
1.1 |
int bradj = 0; /* brightness adjustment */
| 18 |
int doflat = 1; /* produce flat file */
| 19 |
gregl |
2.8 |
int force = 0; /* force file overwrite? */
| 20 |
int findframe = 0; /* find a specific frame? */
| 21 |
int frameno = 0; /* current frame number */
| 22 |
int fmterr = 0; /* got input format error */
| 23 |
greg |
2.22 |
char *headlines = NULL; /* current header info. */
| 24 |
int headlen1 = 0; /* length of initial frame header */
| 25 |
int headlen = 0; /* current header length */
| 26 |
char fmt[MAXFMTLEN]; /* input format */
| 27 |
gregl |
2.8 |
| 28 |
greg |
1.1 |
char *progname;
| 29 |
| 30 |
schorsch |
2.16 |
static gethfunc addhline;
| 31 |
schorsch |
2.17 |
static int transfer(char *ospec);
| 32 |
static int loadheader(FILE *fp);
| 33 |
schorsch |
2.16 |
| 34 |
greg |
1.1 |
| 35 |
schorsch |
2.17 |
int
| 36 |
main(int argc, char *argv[])
| 37 |
greg |
1.1 |
| 38 |
gregl |
2.8 |
char *ospec;
| 39 |
greg |
1.1 |
int i;
| 40 |
gregl |
2.7 |
| 41 |
greg |
1.1 |
progname = argv[0];
| 42 |
| 43 |
for (i = 1; i < argc; i++)
| 44 |
if (argv[i][0] == '-')
| 45 |
switch (argv[i][1]) {
| 46 |
case 'r':
| 47 |
doflat = !doflat;
| 48 |
break;
| 49 |
case 'e':
| 50 |
if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
| 51 |
goto userr;
| 52 |
bradj = atoi(argv[++i]);
| 53 |
break;
| 54 |
gregl |
2.8 |
case 'n':
| 55 |
findframe = atoi(argv[++i]);
| 56 |
break;
| 57 |
case 'f':
| 58 |
force++;
| 59 |
break;
| 60 |
case '\0':
| 61 |
goto gotfile;
| 62 |
greg |
1.1 |
default:
| 63 |
goto userr;
| 64 |
| 65 |
else
| 66 |
break;
| 67 |
gregl |
2.8 |
gotfile:
| 68 |
greg |
1.1 |
if (i < argc-2)
| 69 |
goto userr;
| 70 |
gregl |
2.8 |
if (i <= argc-1 && strcmp(argv[i], "-") &&
| 71 |
freopen(argv[i], "r", stdin) == NULL) {
| 72 |
greg |
1.1 |
fprintf(stderr, "%s: can't open input \"%s\"\n",
| 73 |
progname, argv[i]);
| 74 |
exit(1);
| 75 |
| 76 |
schorsch |
2.12 |
SET_FILE_BINARY(stdin);
| 77 |
gregl |
2.8 |
ospec = i==argc-2 ? argv[i+1] : (char *)NULL;
| 78 |
while (transfer(ospec))
| 79 |
| 80 |
greg |
1.1 |
exit(0);
| 81 |
userr:
| 82 |
gregl |
2.8 |
fprintf(stderr,
| 83 |
"Usage: %s [-r][-e +/-stops][-f][-n frame] [input [outspec]]\n",
| 84 |
greg |
1.1 |
progname);
| 85 |
exit(1);
| 86 |
| 87 |
| 88 |
| 89 |
schorsch |
2.17 |
static int
| 90 |
transfer( /* transfer a Radiance picture */
| 91 |
char *ospec
| 92 |
| 93 |
greg |
1.1 |
| 94 |
schorsch |
2.15 |
char oname[PATH_MAX];
| 95 |
gregl |
2.8 |
FILE *fp;
| 96 |
greg |
1.2 |
int order;
| 97 |
greg |
2.3 |
int xmax, ymax;
| 98 |
greg |
1.1 |
COLR *scanin;
| 99 |
int y;
| 100 |
gregl |
2.8 |
/* get header info. */
| 101 |
if (!(y = loadheader(stdin)))
| 102 |
return(0);
| 103 |
if (y < 0 || (order = fgetresolu(&xmax, &ymax, stdin)) < 0) {
| 104 |
fprintf(stderr, "%s: bad input format\n", progname);
| 105 |
exit(1);
| 106 |
| 107 |
/* did we pass the target frame? */
| 108 |
if (findframe && findframe < frameno)
| 109 |
return(0);
| 110 |
/* allocate scanline */
| 111 |
greg |
2.23 |
scanin = (COLR *)malloc(xmax*sizeof(COLR));
| 112 |
gregl |
2.8 |
if (scanin == NULL) {
| 113 |
perror(progname);
| 114 |
exit(1);
| 115 |
| 116 |
/* skip frame? */
| 117 |
if (findframe > frameno) {
| 118 |
greg |
2.23 |
if (NCSAMP > 3) {
| 119 |
if (fseek(stdin, ymax*xmax*LSCOLR, SEEK_CUR) < 0) {
| 120 |
perror(progname);
| 121 |
exit(1);
| 122 |
| 123 |
} else
| 124 |
for (y = ymax; y--; )
| 125 |
gregl |
2.8 |
if (freadcolrs(scanin, xmax, stdin) < 0) {
| 126 |
fprintf(stderr,
| 127 |
"%s: error reading input picture\n",
| 128 |
progname);
| 129 |
exit(1);
| 130 |
| 131 |
greg |
2.23 |
free(scanin);
| 132 |
gregl |
2.8 |
return(1);
| 133 |
| 134 |
/* open output file/command */
| 135 |
if (ospec == NULL) {
| 136 |
strcpy(oname, "<stdout>");
| 137 |
fp = stdout;
| 138 |
} else {
| 139 |
sprintf(oname, ospec, frameno);
| 140 |
if (oname[0] == '!') {
| 141 |
if ((fp = popen(oname+1, "w")) == NULL) {
| 142 |
fprintf(stderr, "%s: cannot start \"%s\"\n",
| 143 |
progname, oname);
| 144 |
exit(1);
| 145 |
| 146 |
} else {
| 147 |
if (!force && access(oname, 0) >= 0) {
| 148 |
fprintf(stderr,
| 149 |
"%s: output file \"%s\" exists\n",
| 150 |
progname, oname);
| 151 |
exit(1);
| 152 |
| 153 |
if ((fp = fopen(oname, "w")) == NULL) {
| 154 |
fprintf(stderr, "%s: ", progname);
| 155 |
perror(oname);
| 156 |
exit(1);
| 157 |
| 158 |
| 159 |
| 160 |
schorsch |
2.12 |
SET_FILE_BINARY(fp);
| 161 |
greg |
2.22 |
newheader("RADIANCE", fp); /* put out header */
| 162 |
dumpheader(fp);
| 163 |
gregl |
2.8 |
fputs(progname, fp);
| 164 |
greg |
1.1 |
if (bradj)
| 165 |
gregl |
2.8 |
fprintf(fp, " -e %+d", bradj);
| 166 |
gregl |
2.7 |
if (!doflat)
| 167 |
gregl |
2.8 |
fputs(" -r", fp);
| 168 |
fputc('\n', fp);
| 169 |
greg |
2.2 |
if (bradj)
| 170 |
gregl |
2.8 |
fputexpos(pow(2.0, (double)bradj), fp);
| 171 |
greg |
2.22 |
if (frameno)
| 172 |
fprintf(fp, "FRAME=%d\n", frameno);
| 173 |
if (fmt[0])
| 174 |
fputformat(fmt, fp);
| 175 |
gregl |
2.8 |
fputc('\n', fp);
| 176 |
fputresolu(order, xmax, ymax, fp);
| 177 |
/* transfer picture */
| 178 |
gregl |
2.7 |
for (y = ymax; y--; ) {
| 179 |
greg |
2.23 |
if (fread2colrs(scanin, xmax, stdin, NCSAMP, WLPART) < 0) {
| 180 |
gregl |
2.8 |
fprintf(stderr, "%s: error reading input picture\n",
| 181 |
progname);
| 182 |
exit(1);
| 183 |
| 184 |
greg |
1.1 |
if (bradj)
| 185 |
shiftcolrs(scanin, xmax, bradj);
| 186 |
greg |
2.22 |
if (doflat ? (putbinary(scanin, sizeof(COLR), xmax, fp) != xmax) :
| 187 |
(fwritecolrs(scanin, xmax, fp) < 0))
| 188 |
goto writerr;
| 189 |
greg |
1.1 |
| 190 |
greg |
2.23 |
free(scanin); /* clean up */
| 191 |
if (fflush(fp) == EOF)
| 192 |
greg |
2.22 |
goto writerr;
| 193 |
greg |
2.24 |
| 194 |
greg |
2.25 |
if (pclose(fp) != 0)
| 195 |
fprintf(stderr, "%s: warning - bad status from \"%s\"\n",
| 196 |
greg |
2.24 |
progname, oname);
| 197 |
} else if (ospec != NULL)
| 198 |
gregl |
2.8 |
fclose(fp);
| 199 |
return(1);
| 200 |
greg |
2.22 |
writerr:
| 201 |
fprintf(stderr, "%s: error writing output to \"%s\"\n",
| 202 |
progname, oname);
| 203 |
exit(1);
| 204 |
gregl |
2.8 |
| 205 |
| 206 |
| 207 |
schorsch |
2.16 |
static int
| 208 |
addhline( /* add a line to our info. header */
| 209 |
char *s,
| 210 |
void *p
| 211 |
| 212 |
gregl |
2.8 |
| 213 |
int n;
| 214 |
| 215 |
greg |
2.22 |
if (isheadid(s))
| 216 |
return(0);
| 217 |
if (!strncmp(s, "FRAME=", 6)) {
| 218 |
frameno = atoi(s+6);
| 219 |
return(0);
| 220 |
| 221 |
if (formatval(fmt, s)) {
| 222 |
greg |
2.23 |
if (!strcmp(fmt, SPECFMT))
| 223 |
strcpy(fmt, COLRFMT);
| 224 |
else
| 225 |
fmterr += !globmatch(PICFMT, fmt);
| 226 |
return(0);
| 227 |
| 228 |
if (isncomp(s)) {
| 229 |
NCSAMP = ncompval(s);
| 230 |
return(NCSAMP - 3);
| 231 |
| 232 |
if (iswlsplit(s)) {
| 233 |
wlsplitval(WLPART, s);
| 234 |
greg |
2.22 |
return(0);
| 235 |
| 236 |
gregl |
2.8 |
n = strlen(s);
| 237 |
if (headlen)
| 238 |
greg |
2.11 |
headlines = (char *)realloc((void *)headlines, headlen+n+1);
| 239 |
gregl |
2.8 |
else
| 240 |
headlines = (char *)malloc(n+1);
| 241 |
if (headlines == NULL) {
| 242 |
perror(progname);
| 243 |
exit(1);
| 244 |
| 245 |
strcpy(headlines+headlen, s);
| 246 |
headlen += n;
| 247 |
gwlarson |
2.9 |
return(0);
| 248 |
gregl |
2.8 |
| 249 |
| 250 |
| 251 |
schorsch |
2.17 |
static int
| 252 |
loadheader( /* load an info. header into memory */
| 253 |
FILE *fp
| 254 |
| 255 |
gregl |
2.8 |
| 256 |
fmterr = 0; frameno = 0;
| 257 |
greg |
2.22 |
/* revert to initial header length */
| 258 |
if (!headlen1) headlen1 = headlen;
| 259 |
else headlen = headlen1;
| 260 |
| 261 |
gregl |
2.8 |
if (getheader(fp, addhline, NULL) < 0)
| 262 |
return(0);
| 263 |
if (fmterr)
| 264 |
return(-1);
| 265 |
return(1);
| 266 |
greg |
1.1 |
