root/radiance/src/px/ra_rgbe.c
Revision: 2.8
Committed: Fri Jan 23 11:38:39 1998 UTC (27 years, 9 months ago) by gregl
Changes since 2.7: +157 -51 lines
made program read multiple frames in a single file
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * program to convert from RADIANCE RLE to flat format
9 */
10
11 #include <stdio.h>
12 #include <math.h>
13 #include "color.h"
14 #include "resolu.h"
15
16 #ifdef MSDOS
17 #include <fcntl.h>
18 #endif
19
20 extern char *malloc(), *realloc(), *tempbuffer();
21 extern int addhline();
22
23 #define dumpheader(fp) fwrite(headlines, 1, headlen, fp)
24
25 int bradj = 0; /* brightness adjustment */
26
27 int doflat = 1; /* produce flat file */
28
29 int force = 0; /* force file overwrite? */
30
31 int findframe = 0; /* find a specific frame? */
32
33 int frameno = 0; /* current frame number */
34 int fmterr = 0; /* got input format error */
35 char *headlines; /* current header info. */
36 int headlen; /* current header length */
37
38 char *progname;
39
40
41 main(argc, argv)
42 int argc;
43 char *argv[];
44 {
45 char *ospec;
46 int i;
47
48 progname = argv[0];
49
50 for (i = 1; i < argc; i++)
51 if (argv[i][0] == '-')
52 switch (argv[i][1]) {
53 case 'r':
54 doflat = !doflat;
55 break;
56 case 'e':
57 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
58 goto userr;
59 bradj = atoi(argv[++i]);
60 break;
61 case 'n':
62 findframe = atoi(argv[++i]);
63 break;
64 case 'f':
65 force++;
66 break;
67 case '\0':
68 goto gotfile;
69 default:
70 goto userr;
71 }
72 else
73 break;
74 gotfile:
75 if (i < argc-2)
76 goto userr;
77 if (i <= argc-1 && strcmp(argv[i], "-") &&
78 freopen(argv[i], "r", stdin) == NULL) {
79 fprintf(stderr, "%s: can't open input \"%s\"\n",
80 progname, argv[i]);
81 exit(1);
82 }
83 #ifdef MSDOS
84 setmode(fileno(stdin), O_BINARY);
85 #endif
86 ospec = i==argc-2 ? argv[i+1] : (char *)NULL;
87 while (transfer(ospec))
88 ;
89 exit(0);
90 userr:
91 fprintf(stderr,
92 "Usage: %s [-r][-e +/-stops][-f][-n frame] [input [outspec]]\n",
93 progname);
94 exit(1);
95 }
96
97
98 transfer(ospec) /* transfer a Radiance picture */
99 char *ospec;
100 {
101 char oname[128];
102 FILE *fp;
103 int order;
104 int xmax, ymax;
105 COLR *scanin;
106 int y;
107 /* get header info. */
108 if (!(y = loadheader(stdin)))
109 return(0);
110 if (y < 0 || (order = fgetresolu(&xmax, &ymax, stdin)) < 0) {
111 fprintf(stderr, "%s: bad input format\n", progname);
112 exit(1);
113 }
114 /* did we pass the target frame? */
115 if (findframe && findframe < frameno)
116 return(0);
117 /* allocate scanline */
118 scanin = (COLR *)tempbuffer(xmax*sizeof(COLR));
119 if (scanin == NULL) {
120 perror(progname);
121 exit(1);
122 }
123 /* skip frame? */
124 if (findframe > frameno) {
125 for (y = ymax; y--; )
126 if (freadcolrs(scanin, xmax, stdin) < 0) {
127 fprintf(stderr,
128 "%s: error reading input picture\n",
129 progname);
130 exit(1);
131 }
132 return(1);
133 }
134 /* open output file/command */
135 if (ospec == NULL) {
136 strcpy(oname, "<stdout>");
137 fp = stdout;
138 } else {
139 sprintf(oname, ospec, frameno);
140 if (oname[0] == '!') {
141 if ((fp = popen(oname+1, "w")) == NULL) {
142 fprintf(stderr, "%s: cannot start \"%s\"\n",
143 progname, oname);
144 exit(1);
145 }
146 } else {
147 if (!force && access(oname, 0) >= 0) {
148 fprintf(stderr,
149 "%s: output file \"%s\" exists\n",
150 progname, oname);
151 exit(1);
152 }
153 if ((fp = fopen(oname, "w")) == NULL) {
154 fprintf(stderr, "%s: ", progname);
155 perror(oname);
156 exit(1);
157 }
158 }
159 }
160 #ifdef MSDOS
161 setmode(fileno(fp), O_BINARY);
162 #endif
163 dumpheader(fp); /* put out header */
164 fputs(progname, fp);
165 if (bradj)
166 fprintf(fp, " -e %+d", bradj);
167 if (!doflat)
168 fputs(" -r", fp);
169 fputc('\n', fp);
170 if (bradj)
171 fputexpos(pow(2.0, (double)bradj), fp);
172 fputc('\n', fp);
173 fputresolu(order, xmax, ymax, fp);
174 /* transfer picture */
175 for (y = ymax; y--; ) {
176 if (freadcolrs(scanin, xmax, stdin) < 0) {
177 fprintf(stderr, "%s: error reading input picture\n",
178 progname);
179 exit(1);
180 }
181 if (bradj)
182 shiftcolrs(scanin, xmax, bradj);
183 if (doflat)
184 fwrite((char *)scanin, sizeof(COLR), xmax, fp);
185 else
186 fwritecolrs(scanin, xmax, fp);
187 if (ferror(fp)) {
188 fprintf(stderr, "%s: error writing output to \"%s\"\n",
189 progname, oname);
190 exit(1);
191 }
192 }
193 /* clean up */
194 if (oname[0] == '!')
195 pclose(fp);
196 else if (ospec != NULL)
197 fclose(fp);
198 return(1);
199 }
200
201
202 addhline(s) /* add a line to our info. header */
203 char *s;
204 {
205 char fmt[32];
206 int n;
207
208 if (formatval(fmt, s))
209 fmterr += !globmatch(PICFMT, fmt);
210 else if (!strncmp(s, "FRAME=", 6))
211 frameno = atoi(s+6);
212 n = strlen(s);
213 if (headlen)
214 headlines = (char *)realloc(headlines, headlen+n+1);
215 else
216 headlines = (char *)malloc(n+1);
217 if (headlines == NULL) {
218 perror(progname);
219 exit(1);
220 }
221 strcpy(headlines+headlen, s);
222 headlen += n;
223 }
224
225
226 loadheader(fp) /* load an info. header into memory */
227 FILE *fp;
228 {
229 fmterr = 0; frameno = 0;
230 if (headlen) { /* free old header */
231 free(headlines);
232 headlen = 0;
233 }
234 if (getheader(fp, addhline, NULL) < 0)
235 return(0);
236 if (fmterr)
237 return(-1);
238 return(1);
239 }
