root/radiance/src/px/ra_ps.c
Revision: 2.28
Committed: Sun Mar 28 20:33:14 2004 UTC (21 years, 7 months ago) by schorsch
CVS Tags: rad5R0, rad5R1, rad4R2, rad3R7P2, rad3R7P1, rad4R1, rad4R0, rad3R6, rad3R6P1, rad3R8, rad3R9, rad4R2P1, rad4R2P2
Changes since 2.27: +71 -46 lines
2 static const char RCSid[] = "$Id: ra_ps.c,v 2.27 2004/01/02 12:47:01 schorsch Exp $";
5 * Radiance picture to PostScript file translator -- one way!
6 */
7
8 #include <stdio.h>
9 #include <string.h>
10 #include <math.h>
11 #include <ctype.h>
12
13 #include "platform.h"
14 #include "color.h"
15 #include "resolu.h"
16
17 #define UPPER(c) ((c)&~0x20) /* ASCII trick */
18
19 #define CODE6GAM 1.47 /* gamma for 6-bit codes */
20 #define DEFGGAM 1.0 /* greyscale device gamma */
21 #define DEFCGAM 1.8 /* color device gamma */
22
23 #define GRY -1 /* artificial index for grey */
24
25 #define DEFMARG 0.5 /* default margin (inches) */
26 #define DEFWIDTH 8.5 /* default page width */
27 #define DEFHEIGHT 11 /* default page height */
28 #define HMARGIN (hmarg*72) /* horizontal margin */
29 #define VMARGIN (vmarg*72) /* vertical margin */
30 #define PWIDTH (width*72-2*HMARGIN) /* width of device */
31 #define PHEIGHT (height*72-2*VMARGIN) /* height of device */
32
33 #define RUNCHR '*' /* character to start rle */
34 #define MINRUN 4 /* minimum run-length */
35 #define RSTRT '!' /* character for MINRUN */
36 #define MAXRUN (MINRUN+'~'-RSTRT) /* maximum run-length */
37
38 char code[] = /* 6-bit code lookup table */
39 "0123456789abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ@+";
40
41 int wrongformat = 0; /* input in wrong format? */
42 double pixaspect = 1.0; /* pixel aspect ratio */
43
44 double devgam = 0.; /* device gamma response */
45 double hmarg = DEFMARG,
46 vmarg = DEFMARG; /* horizontal and vertical margins */
47 double width = DEFWIDTH,
48 height = DEFHEIGHT; /* default paper width and height */
49 double dpi = 0; /* print density (0 if unknown) */
50 int docolor = 1; /* produce color image? */
51 int bradj = 0; /* brightness adjustment */
52 int ncopies = 1; /* number of copies */
53
54 char *progname;
55 int xmax, ymax; /* input image dimensions */
56
57 typedef void putprimf_t(COLR *scn, int pri);
58
59 static gethfunc headline;
60 static putprimf_t Aputprim, Bputprim, Cputprim;
61
62 static double unit2inch(register char *s);
63 static int matchid(char *name, char *id);
64 static void parsepaper(char *ps);
65 static void quiterr(char *err);
66 static void PSheader(int ac, char **av);
67 static void PStrailer(void);
68 static void PSprocdef(char *nam);
69 static void ra2ps(void);
70 static void putrle(int cnt, int cod);
71
72
73 putprimf_t *putprim = Aputprim; /* function for writing scanline */
74
75
76 static int
77 headline( /* check header line */
78 char *s,
79 void *p
80 )
81 {
82 char fmt[32];
83
84 if (isformat(s)) {
85 formatval(fmt, s);
86 wrongformat = strcmp(fmt, COLRFMT);
87 } else if (isaspect(s))
88 pixaspect *= aspectval(s);
89 return(0);
90 }
91
92 int
93 main(int argc, char *argv[])
94 {
95 int i;
96 double d;
97
98 progname = argv[0];
99
100 for (i = 1; i < argc; i++)
101 if (argv[i][0] == '-')
102 switch (argv[i][1]) {
103 case 'b': /* produce b&w PostScript */
104 docolor = 0;
105 break;
106 case 'c': /* produce color PostScript */
107 docolor = 1;
108 break;
109 case 'A': /* standard ASCII encoding */
110 putprim = Aputprim;
111 break;
112 case 'B': /* standard binary encoding */
113 putprim = Bputprim;
114 break;
115 case 'C': /* compressed ASCII encoding */
116 putprim = Cputprim;
117 break;
118 case 'd': /* print density */
119 dpi = atof(argv[++i]);
120 break;
121 case 'g': /* device gamma adjustment */
122 devgam = atof(argv[++i]);
123 break;
124 case 'p': /* paper size */
125 parsepaper(argv[++i]);
126 break;
127 case 'm': /* margin */
128 d = atof(argv[i+1]);
129 d *= unit2inch(argv[i+1]);
130 switch (argv[i][2]) {
131 case '\0':
132 hmarg = vmarg = d;
133 break;
134 case 'h':
135 hmarg = d;
136 break;
137 case 'v':
138 vmarg = d;
139 break;
140 default:
141 goto userr;
142 }
143 i++;
144 break;
145 case 'e': /* exposure adjustment */
146 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
147 goto userr;
148 bradj = atoi(argv[++i]);
149 break;
150 case 'n': /* number of copies */
151 ncopies = atoi(argv[++i]);
152 break;
153 default:
154 goto userr;
155 }
156 else
157 break;
158
159 if (i < argc-2)
160 goto userr;
161 if (i <= argc-1 && freopen(argv[i], "r", stdin) == NULL) {
162 fprintf(stderr, "%s: can't open input \"%s\"\n",
163 progname, argv[i]);
164 exit(1);
165 }
166 if (i == argc-2 && freopen(argv[i+1], "w", stdout) == NULL) {
167 fprintf(stderr, "%s: can't open output \"%s\"\n",
168 progname, argv[i+1]);
169 exit(1);
170 }
171 SET_FILE_BINARY(stdin);
172 /* get our header */
173 getheader(stdin, headline, NULL);
174 if (wrongformat || fgetresolu(&xmax, &ymax, stdin) < 0)
175 quiterr("bad picture format");
176 /* gamma compression */
177 if (devgam <= 0.05)
178 devgam = docolor ? DEFCGAM : DEFGGAM;
179 if (putprim == Cputprim)
180 setcolrgam(CODE6GAM);
181 else if (devgam != 1.)
182 setcolrgam(devgam);
183 /* write header */
184 PSheader(argc, argv);
185 /* convert file */
186 ra2ps();
187 /* write trailer */
188 PStrailer();
189 exit(0);
190 userr:
191 fprintf(stderr,
192 "Usage: %s [-b|c][-A|B|C][-e +/-stops][-p paper][-m[h|v] margin][-d dpi][-g gamma] [input [output]]\n",
193 progname);
194 exit(1);
195 }
196
197
198 static double
199 unit2inch( /* determine unit */
200 register char *s
201 )
202 {
203 static struct unit {char n; float f;} u[] = {
204 {'i', 1.},
205 {'m', 1./25.4},
206 {'c', 1./2.54},
207 {'\0',0} };
208 register struct unit *up;
209
210 while (*s && !isalpha(*s))
211 s++;
212 for (up = u; up->n; up++)
213 if (up->n == *s)
214 return(up->f);
215 return(1.);
216 }
217
218
219 static int
220 matchid( /* see if name matches id (case insensitive) */
221 char *name,
222 register char *id
223 )
224 {
225 register char *s = name;
226
227 while (*s) {
228 if (isalpha(*s)) {
229 if (!isalpha(*id) || UPPER(*s) != UPPER(*id))
230 return(0);
231 } else if (*s != *id)
232 return(0);
233 s++; id++;
234 }
235 return(!*id || s-name >= 3); /* substrings >= 3 chars OK */
236 }
237
238
239 static void
240 parsepaper( /* determine paper size from name */
241 char *ps
242 )
243 {
244 static struct psize {char n[12]; float w,h;} p[] = {
245 {"envelope", 4.12, 9.5},
246 {"executive", 7.25, 10.5},
247 {"letter", 8.5, 11.},
248 {"lettersmall", 7.68, 10.16},
249 {"legal", 8.5, 14.},
250 {"monarch", 3.87, 7.5},
251 {"statement", 5.5, 8.5},
252 {"tabloid", 11., 17.},
253 {"A3", 11.69, 16.54},
254 {"A4", 8.27, 11.69},
255 {"A4small", 7.47, 10.85},
256 {"A5", 6.00, 8.27},
257 {"A6", 4.13, 6.00},
258 {"B4", 10.12, 14.33},
259 {"B5", 7.17, 10.12},
260 {"C5", 6.38, 9.01},
261 {"C6", 4.49, 6.38},
262 {"DL", 4.33, 8.66},
263 {"hagaki", 3.94, 5.83},
264 {"",0.0,0.0} };
265 register struct psize *pp;
266 register char *s = ps;
267 double d;
268
269 if (isdigit(*s)) { /* check for WWxHH specification */
270 width = atof(s);
271 while (*s && !isalpha(*s))
272 s++;
273 d = unit2inch(s);
274 height = atof(++s);
275 width *= d;
276 height *= d;
277 if ((width >= 1.) & (height >= 1.))
278 return;
279 } else /* check for match to standard size */
280 for (pp = p; pp->n[0]; pp++)
281 if (matchid(s, pp->n)) {
282 width = pp->w;
283 height = pp->h;
284 return;
285 }
286 fprintf(stderr, "%s: unknown paper size \"%s\" -- known sizes:\n",
287 progname, ps);
288 fprintf(stderr, "_Name________Width_Height_(inches)\n");
289 for (pp = p; pp->n[0]; pp++)
290 fprintf(stderr, "%-11s %5.2f %5.2f\n", pp->n, pp->w, pp->h);
291 fprintf(stderr, "Or use WWxHH size specification\n");
292 exit(1);
293 }
294
295
296 static void
297 quiterr( /* print message and exit */
298 char *err
299 )
300 {
301 if (err != NULL) {
302 fprintf(stderr, "%s: %s\n", progname, err);
303 exit(1);
304 }
305 exit(0);
306 }
307
308
309 static void
310 PSheader( /* print PostScript header */
311 int ac,
312 char **av
313 )
314 {
315 char *rstr;
316 int landscape, rotate, n;
317 double pwidth, pheight;
318 double iwidth, iheight;
319 /* EPS comments */
320 puts("%!PS-Adobe-2.0 EPSF-2.0");
321 printf("%%%%Title: "); printargs(ac, av, stdout);
322 printf("%%%%Creator: %s\n", progname);
323 printf("%%%%Pages: %d\n", ncopies);
324 if ( (landscape = xmax > pixaspect*ymax) )
325 puts("%%Orientation: Landscape");
326 else
327 puts("%%Orientation: Portrait");
328 if ( (rotate = (PWIDTH > PHEIGHT) ^ landscape) ) {
329 pwidth = PHEIGHT;
330 pheight = PWIDTH;
331 } else {
332 pwidth = PWIDTH;
333 pheight = PHEIGHT;
334 }
335 if (dpi > 100 && (pixaspect >= 0.99) & (pixaspect <= 1.01))
336 if (pheight/pwidth > ymax/xmax) {
337 n = pwidth*dpi/xmax; /* floor */
338 iwidth = n > 0 ? (double)(n*xmax)/dpi : pwidth;
339 iheight = iwidth*ymax/xmax;
340 } else {
341 n = pheight*dpi/ymax; /* floor */
342 iheight = n > 0 ? (double)(n*ymax)/dpi : pheight;
343 iwidth = iheight*xmax/ymax;
344 }
345 else
346 if (pheight/pwidth > pixaspect*ymax/xmax) {
347 iwidth = pwidth;
348 iheight = iwidth*pixaspect*ymax/xmax;
349 } else {
350 iheight = pheight;
351 iwidth = iheight*xmax/(pixaspect*ymax);
352 }
353 if (rotate)
354 printf("%%%%BoundingBox: %.0f %.0f %.0f %.0f\n",
355 HMARGIN+(pheight-iheight)*.5,
356 VMARGIN+(pwidth-iwidth)*.5,
357 HMARGIN+(pheight-iheight)*.5+iheight,
358 VMARGIN+(pwidth-iwidth)*.5+iwidth);
359 else
360 printf("%%%%BoundingBox: %.0f %.0f %.0f %.0f\n",
361 HMARGIN+(pwidth-iwidth)*.5,
362 VMARGIN+(pheight-iheight)*.5,
363 HMARGIN+(pwidth-iwidth)*.5+iwidth,
364 VMARGIN+(pheight-iheight)*.5+iheight);
365 puts("%%EndComments");
366 puts("gsave save");
367 puts("17 dict begin");
368 /* define image reader */
369 if (docolor) {
370 printf("/redline %d string def\n", xmax);
371 printf("/grnline %d string def\n", xmax);
372 printf("/bluline %d string def\n", xmax);
373 } else
374 printf("/gryline %d string def\n", xmax);
375 /* use compressed encoding? */
376 if (putprim == Cputprim)
377 PSprocdef("read6bitRLE");
378 /* set up transformation matrix */
379 printf("%f %f translate\n", HMARGIN, VMARGIN);
380 if (rotate) {
381 printf("%f 0 translate\n", PWIDTH);
382 puts("90 rotate");
383 }
384 printf("%f %f translate\n", (pwidth-iwidth)*.5, (pheight-iheight)*.5);
385 printf("%f %f scale\n", iwidth, iheight);
386 puts("%%EndProlog");
387 /* start image procedure */
388 printf("%d %d 8 [%d 0 0 %d 0 %d]\n", xmax, ymax, xmax, -ymax, ymax);
389 if (putprim == Cputprim) {
390 if (docolor) {
391 puts("{redline read6bitRLE}");
392 puts("{grnline read6bitRLE}");
393 puts("{bluline read6bitRLE}");
394 puts("true 3 colorimage");
395 } else
396 puts("{gryline read6bitRLE} image");
397 } else {
398 rstr = putprim==Aputprim ? "readhexstring" : "readstring";
399 if (docolor) {
400 printf("{currentfile redline %s pop}\n", rstr);
401 printf("{currentfile grnline %s pop}\n", rstr);
402 printf("{currentfile bluline %s pop}\n", rstr);
403 puts("true 3 colorimage");
404 } else
405 printf("{currentfile gryline %s pop} image\n", rstr);
406 }
407 }
408
409
410 static void
411 PStrailer(void) /* print PostScript trailer */
412 {
413 puts("%%Trailer");
414 if (ncopies > 1)
415 printf("/#copies %d def\n", ncopies);
416 puts("showpage");
417 puts("end");
418 puts("restore grestore");
419 puts("%%EOF");
420 }
421
422
423 static void
424 PSprocdef( /* define PS procedure to read image */
425 char *nam
426 )
427 {
428 short itab[128];
429 register int i;
430 /* assign code values */
431 for (i = 0; i < 128; i++) /* clear */
432 itab[i] = -1;
433 for (i = 1; i < 63; i++) /* assign greys */
434 itab[(int)code[i]] = 256.0*pow((i+.5)/64.0, CODE6GAM/devgam);
435 itab[(int)code[0]] = 0; /* black is black */
436 itab[(int)code[63]] = 255; /* and white is white */
437 printf("/codetab [");
438 for (i = 0; i < 128; i++) {
439 if (!(i & 0xf))
440 putchar('\n');
441 printf(" %3d", itab[i]);
442 }
443 printf("\n] def\n");
444 printf("/nrept 0 def\n");
445 printf("/readbyte { currentfile read not {stop} if } bind def\n");
446 printf("/decode { codetab exch get } bind def\n");
447 printf("/%s {\t%% scanbuffer\n", nam);
448 printf("\t/scanline exch def\n");
449 printf("\t{ 0 1 %d { scanline exch\n", xmax-1);
450 printf("\t\tnrept 0 le\n");
451 printf("\t\t\t{ { readbyte dup %d eq\n", RUNCHR);
452 printf("\t\t\t\t\t{ pop /nrept readbyte %d sub def\n", RSTRT-MINRUN+1);
453 printf("\t\t\t\t\t\t/reptv readbyte decode def\n");
454 printf("\t\t\t\t\t\treptv exit }\n");
455 printf("\t\t\t\t\t{ decode dup 0 lt {pop} {exit} ifelse }\n");
456 printf("\t\t\t\tifelse } loop }\n");
457 printf("\t\t\t{ /nrept nrept 1 sub def reptv }\n");
458 printf("\t\tifelse put\n");
459 printf("\t\t} for\n");
460 printf("\t} stopped {pop pop 0 string} {scanline} ifelse\n");
461 printf("} bind def\n");
462 }
463
464
465 static void
466 ra2ps(void) /* convert Radiance scanlines to 6-bit */
467 {
468 register COLR *scanin;
469 int y;
470 /* allocate scanline */
471 scanin = (COLR *)malloc(xmax*sizeof(COLR));
472 if (scanin == NULL)
473 quiterr("out of memory in ra2ps");
474 /* convert image */
475 for (y = ymax-1; y >= 0; y--) {
476 if (freadcolrs(scanin, xmax, stdin) < 0)
477 quiterr("error reading Radiance picture");
478 if (putprim == Cputprim || devgam != 1.) {
479 if (bradj) /* adjust exposure */
480 shiftcolrs(scanin, xmax, bradj);
481 colrs_gambs(scanin, xmax); /* gamma compression */
482 } else
483 normcolrs(scanin, xmax, bradj);
484 if (docolor) {
485 (*putprim)(scanin, RED);
486 (*putprim)(scanin, GRN);
487 (*putprim)(scanin, BLU);
488 } else
489 (*putprim)(scanin, GRY);
490 if (ferror(stdout))
491 quiterr("error writing PostScript file");
492 }
493 putchar('\n');
494 /* free scanline */
495 free((void *)scanin);
496 }
497
498
499 static void
500 Aputprim( /* put out hex ASCII primary from scanline */
501 COLR *scn,
502 int pri
503 )
504 {
505 static char hexdigit[] = "0123456789ABCDEF";
506 static int col = 0;
507 register int x, c;
508
509 for (x = 0; x < xmax; x++) {
510 if (pri == GRY)
511 c = normbright(scn[x]);
512 else
513 c = scn[x][pri];
514 if (c > 255) c = 255;
515 putchar(hexdigit[c>>4]);
516 putchar(hexdigit[c&0xf]);
517 if ((col += 2) >= 72) {
518 putchar('\n');
519 col = 0;
520 }
521 }
522 }
523
524
525 static void
526 Bputprim( /* put out binary primary from scanline */
527 COLR *scn,
528 int pri
529 )
530 {
531 register int x, c;
532
533 for (x = 0; x < xmax; x++) {
534 if (pri == GRY)
535 c = normbright(scn[x]);
536 else
537 c = scn[x][pri];
538 if (c > 255) c = 255;
539 putchar(c);
540 }
541 }
542
543
544 static void
545 Cputprim( /* put out compressed primary from scanline */
546 COLR *scn,
547 int pri
548 )
549 {
550 register int c;
551 register int x;
552 int lastc, cnt;
553
554 lastc = -1; cnt = 0;
555 for (x = 0; x < xmax; x++) {
556 if (pri == GRY)
557 c = normbright(scn[x]) + 2;
558 else
559 c = scn[x][pri] + 2;
560 if (c > 255) c = 255;
561 c = code[c>>2];
562 if (c == lastc && cnt < MAXRUN)
563 cnt++;
564 else {
565 putrle(cnt, lastc);
566 lastc = c;
567 cnt = 1;
568 }
569 }
570 putrle(cnt, lastc);
571 }
572
573
574 static void
575 putrle( /* put out cnt of cod */
576 register int cnt,
577 register int cod
578 )
579 {
580 static int col = 0;
581
582 if (cnt >= MINRUN) {
583 col += 3;
584 putchar(RUNCHR);
585 putchar(RSTRT-MINRUN+cnt);
586 putchar(cod);
587 } else {
588 col += cnt;
589 while (cnt-- > 0)
590 putchar(cod);
591 }
592 if (col >= 72) {
593 putchar('\n');
594 col = 0;
595 }
596 }
