root/radiance/src/px/ra_pr24.c
Revision: 2.13
Committed: Fri Nov 5 03:31:38 2004 UTC (20 years, 11 months ago) by greg
State: FILE REMOVED
2 static const char RCSid[] = "$Id: ra_pr24.c,v 2.12 2004/03/28 20:33:14 schorsch Exp $";
5 * program to convert between RADIANCE and 24-bit rasterfiles.
6 */
7
8 #include <stdio.h>
9 #include <time.h>
10 #include <math.h>
11 #include <string.h>
12
13 #include "platform.h"
14 #include "rasterfile.h"
15 #include "color.h"
16 #include "resolu.h"
17
18 double gamcor = 2.2; /* gamma correction */
19 int bradj = 0; /* brightness adjustment */
20 char *progname;
21 int xmax, ymax;
22
23 static void quiterr(char *err);
24 static void pr2ra(int rf, int pad);
25 static void ra2pr(int rf, int pad);
26
27
28 int
29 main(int argc, char *argv[])
30 {
31 struct rasterfile head;
32 int reverse = 0;
33 int i;
34 SET_DEFAULT_BINARY();
35 SET_FILE_BINARY(stdin);
36 SET_FILE_BINARY(stdout);
37 progname = argv[0];
38
39 head.ras_type = RT_STANDARD;
40 for (i = 1; i < argc; i++)
41 if (argv[i][0] == '-')
42 switch (argv[i][1]) {
43 case 'g':
44 gamcor = atof(argv[++i]);
45 break;
46 case 'e':
47 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
48 goto userr;
49 bradj = atoi(argv[++i]);
50 break;
51 case 'r':
52 if (!strcmp(argv[i], "-rgb"))
53 head.ras_type = RT_FORMAT_RGB;
54 else
55 reverse = 1;
56 break;
57 default:
58 goto userr;
59 }
60 else
61 break;
62
63 if (i < argc-2)
64 goto userr;
65 if (i <= argc-1 && freopen(argv[i], "r", stdin) == NULL) {
66 fprintf(stderr, "%s: can't open input \"%s\"\n",
67 progname, argv[i]);
68 exit(1);
69 }
70 if (i == argc-2 && freopen(argv[i+1], "w", stdout) == NULL) {
71 fprintf(stderr, "%s: can't open output \"%s\"\n",
72 progname, argv[i+1]);
73 exit(1);
74 }
75 setcolrgam(gamcor);
76 if (reverse) {
77 /* get header */
78 if (fread((char *)&head, sizeof(head), 1, stdin) != 1)
79 quiterr("missing header");
80 if (head.ras_magic != RAS_MAGIC)
81 quiterr("bad raster format");
82 xmax = head.ras_width;
83 ymax = head.ras_height;
84 if ((head.ras_type != RT_STANDARD
85 && head.ras_type != RT_FORMAT_RGB)
86 || head.ras_maptype != RMT_NONE
87 || head.ras_depth != 24)
88 quiterr("incompatible format");
89 /* put header */
90 newheader("RADIANCE", stdout);
91 printargs(i, argv, stdout);
92 fputformat(COLRFMT, stdout);
93 putchar('\n');
94 fprtresolu(xmax, ymax, stdout);
95 /* convert file */
96 pr2ra(head.ras_type, head.ras_length/ymax - xmax*3);
97 } else {
98 /* get header info. */
99 if (checkheader(stdin, COLRFMT, NULL) < 0 ||
100 fgetresolu(&xmax, &ymax, stdin) < 0)
101 quiterr("bad picture format");
102 /* write rasterfile header */
103 head.ras_magic = RAS_MAGIC;
104 head.ras_width = xmax + (xmax&1);
105 head.ras_height = ymax;
106 head.ras_depth = 24;
107 head.ras_length = head.ras_width*head.ras_height*3;
108 head.ras_maptype = RMT_NONE;
109 head.ras_maplength = 0;
110 fwrite((char *)&head, sizeof(head), 1, stdout);
111 /* convert file */
112 ra2pr(head.ras_type, head.ras_length/ymax - xmax*3);
113 }
114 exit(0);
115 userr:
116 fprintf(stderr, "Usage: %s [-r][-g gamma][-e +/-stops] [input [output]]\n",
117 progname);
118 exit(1);
119 }
120
121
122 static void
123 quiterr( /* print message and exit */
124 char *err
125 )
126 {
127 if (err != NULL) {
128 fprintf(stderr, "%s: %s\n", progname, err);
129 exit(1);
130 }
131 exit(0);
132 }
133
134
135 static void
136 pr2ra( /* convert 24-bit scanlines to Radiance picture */
137 int rf,
138 int pad
139 )
140 {
141 COLR *scanout;
142 register int x;
143 int y;
144 /* allocate scanline */
145 scanout = (COLR *)malloc(xmax*sizeof(COLR));
146 if (scanout == NULL)
147 quiterr("out of memory in pr2ra");
148 /* convert image */
149 for (y = ymax-1; y >= 0; y--) {
150 if (rf == RT_FORMAT_RGB)
151 for (x = 0; x < xmax; x++) {
152 scanout[x][RED] = getc(stdin);
153 scanout[x][GRN] = getc(stdin);
154 scanout[x][BLU] = getc(stdin);
155 }
156 else
157 for (x = 0; x < xmax; x++) {
158 scanout[x][BLU] = getc(stdin);
159 scanout[x][GRN] = getc(stdin);
160 scanout[x][RED] = getc(stdin);
161 }
162 for (x = pad; x--; getc(stdin));
163 if (feof(stdin) || ferror(stdin))
164 quiterr("error reading rasterfile");
165 gambs_colrs(scanout, xmax);
166 if (bradj)
167 shiftcolrs(scanout, xmax, bradj);
168 if (fwritecolrs(scanout, xmax, stdout) < 0)
169 quiterr("error writing Radiance picture");
170 }
171 /* free scanline */
172 free((void *)scanout);
173 }
174
175
176 static void
177 ra2pr( /* convert Radiance scanlines to 24-bit rasterfile */
178 int rf,
179 int pad
180 )
181 {
182 int ord[3];
183 COLR *scanin;
184 register int x;
185 int y;
186 /* allocate scanline */
187 scanin = (COLR *)malloc(xmax*sizeof(COLR));
188 if (scanin == NULL)
189 quiterr("out of memory in ra2pr");
190 if (rf == RT_FORMAT_RGB) {
191 ord[0] = RED; ord[1] = GRN; ord[2] = BLU;
192 } else {
193 ord[0] = BLU; ord[1] = GRN; ord[2] = RED;
194 }
195 /* convert image */
196 for (y = ymax-1; y >= 0; y--) {
197 if (freadcolrs(scanin, xmax, stdin) < 0)
198 quiterr("error reading Radiance picture");
199 if (bradj)
200 shiftcolrs(scanin, xmax, bradj);
201 colrs_gambs(scanin, xmax);
202 if (rf == RT_FORMAT_RGB)
203 for (x = 0; x < xmax; x++) {
204 putc(scanin[x][RED], stdout);
205 putc(scanin[x][GRN], stdout);
206 putc(scanin[x][BLU], stdout);
207 }
208 else
209 for (x = 0; x < xmax; x++) {
210 putc(scanin[x][BLU], stdout);
211 putc(scanin[x][GRN], stdout);
212 putc(scanin[x][RED], stdout);
213 }
214 for (x = 0; x < pad; x++)
215 putc(scanin[xmax-1][ord[x%3]], stdout);
216 if (ferror(stdout))
217 quiterr("error writing rasterfile");
218 }
219 /* free scanline */
220 free((void *)scanin);
221 }
