| 1 |
#ifndef lint |
| 2 |
static const char RCSid[] = "$Id: ra_pr.c,v 2.7 2004/03/28 20:33:14 schorsch Exp $"; |
| 3 |
#endif |
| 4 |
| 5 |
* ra_pr.c - program to convert between RADIANCE and pixrect picture format. |
| 6 |
| 7 |
* 11/10/87 |
| 8 |
* 3/1/88 Added Paul Heckbert's color map allocation |
| 9 |
| 10 |
| 11 |
#include <stdio.h> |
| 12 |
#include <math.h> |
| 13 |
#include <time.h> |
| 14 |
| 15 |
#include "rtmisc.h" |
| 16 |
#include "rasterfile.h" |
| 17 |
#include "color.h" |
| 18 |
#include "resolu.h" |
| 19 |
#include "pic.h" |
| 20 |
| 21 |
/* descriptor for a picture file or frame buffer */ |
| 22 |
typedef struct { |
| 23 |
char *name; /* file name */ |
| 24 |
FILE *fp; /* file pointer */ |
| 25 |
int nexty; /* file positioning */ |
| 26 |
int bytes_line; /* 0 == variable length lines */ |
| 27 |
union { |
| 28 |
long b; /* initial scanline */ |
| 29 |
long *y; /* individual scanline */ |
| 30 |
} pos; /* position(s) */ |
| 31 |
} pic; |
| 32 |
| 33 |
| 34 |
double gamcor = 2.2; /* gamma correction */ |
| 35 |
int bradj = 0; /* brightness adjustment */ |
| 36 |
pic *inpic, *outpic; |
| 37 |
char *progname; |
| 38 |
char errmsg[128]; |
| 39 |
COLR *inl; |
| 40 |
int xmax, ymax; |
| 41 |
| 42 |
static void quiterr(char *err); |
| 43 |
static pic * openinput(char *fname, struct rasterfile *h); |
| 44 |
static pic * openoutput(char *fname, struct rasterfile *h); |
| 45 |
static void pr2ra(struct rasterfile *h); |
| 46 |
| 47 |
| 48 |
int |
| 49 |
main(int argc, char *argv[]) |
| 50 |
| 51 |
colormap rasmap; |
| 52 |
struct rasterfile head; |
| 53 |
int dither = 1; |
| 54 |
int reverse = 0; |
| 55 |
int ncolors = 256; |
| 56 |
int greyscale = 0; |
| 57 |
int i; |
| 58 |
| 59 |
progname = argv[0]; |
| 60 |
| 61 |
for (i = 1; i < argc; i++) |
| 62 |
if (argv[i][0] == '-') |
| 63 |
switch (argv[i][1]) { |
| 64 |
case 'd': |
| 65 |
dither = !dither; |
| 66 |
break; |
| 67 |
case 'g': |
| 68 |
gamcor = atof(argv[++i]); |
| 69 |
break; |
| 70 |
case 'b': |
| 71 |
greyscale = !greyscale; |
| 72 |
break; |
| 73 |
case 'e': |
| 74 |
if (argv[i+1][0] != '+' && argv[i+1][0] != '-') |
| 75 |
goto userr; |
| 76 |
bradj = atoi(argv[++i]); |
| 77 |
break; |
| 78 |
case 'r': |
| 79 |
reverse = !reverse; |
| 80 |
break; |
| 81 |
case 'c': |
| 82 |
ncolors = atoi(argv[++i]); |
| 83 |
break; |
| 84 |
default: |
| 85 |
goto userr; |
| 86 |
| 87 |
else |
| 88 |
break; |
| 89 |
| 90 |
if (reverse) { |
| 91 |
if (i < argc-2) |
| 92 |
goto userr; |
| 93 |
if (i <= argc-1 && freopen(argv[i], "r", stdin) == NULL) { |
| 94 |
sprintf(errmsg, "can't open input \"%s\"", argv[i]); |
| 95 |
quiterr(errmsg); |
| 96 |
| 97 |
if (i == argc-2 && freopen(argv[i+1], "w", stdout) == NULL) { |
| 98 |
sprintf(errmsg, "can't open output \"%s\"", argv[i+1]); |
| 99 |
quiterr(errmsg); |
| 100 |
| 101 |
/* get header */ |
| 102 |
if (fread((char *)&head, sizeof(head), 1, stdin) != 1) |
| 103 |
quiterr("missing header"); |
| 104 |
if (head.ras_magic != RAS_MAGIC) |
| 105 |
quiterr("bad raster format"); |
| 106 |
xmax = head.ras_width; |
| 107 |
ymax = head.ras_height; |
| 108 |
if (head.ras_type != RT_STANDARD || |
| 109 |
head.ras_maptype != RMT_EQUAL_RGB || |
| 110 |
head.ras_depth != 8) |
| 111 |
quiterr("incompatible format"); |
| 112 |
/* put header */ |
| 113 |
newheader("RADIANCE", stdout); |
| 114 |
printargs(i, argv, stdout); |
| 115 |
fputformat(COLRFMT, stdout); |
| 116 |
putchar('\n'); |
| 117 |
fprtresolu(xmax, ymax, stdout); |
| 118 |
/* convert file */ |
| 119 |
pr2ra(&head); |
| 120 |
} else { |
| 121 |
if (i < argc-2 || (!greyscale && i > argc-1)) |
| 122 |
goto userr; |
| 123 |
if ((inpic = openinput(argv[i], &head)) == NULL) { |
| 124 |
| 125 |
quiterr(errmsg); |
| 126 |
| 127 |
if ((outpic = openoutput(i==argc-2 ? argv[i+1] : (char *)NULL, |
| 128 |
| 129 |
| 130 |
quiterr(errmsg); |
| 131 |
| 132 |
| 133 |
if (greyscale) |
| 134 |
biq(dither,ncolors,1,rasmap); |
| 135 |
else |
| 136 |
ciq(dither,ncolors,1,rasmap); |
| 137 |
| 138 |
quiterr(NULL); |
| 139 |
userr: |
| 140 |
fprintf(stderr, |
| 141 |
"Usage: %s [-d][-c ncolors][-b][-g gamma][-e +/-stops] input [output]\n", |
| 142 |
progname); |
| 143 |
fprintf(stderr, " Or: %s -r [-g gamma][-e +/-stops] [input [output]]\n", |
| 144 |
progname); |
| 145 |
exit(1); |
| 146 |
| 147 |
| 148 |
| 149 |
static void |
| 150 |
quiterr( /* print message and exit */ |
| 151 |
char *err |
| 152 |
| 153 |
| 154 |
if (err != NULL) { |
| 155 |
fprintf(stderr, "%s: %s\n", progname, err); |
| 156 |
exit(1); |
| 157 |
| 158 |
exit(0); |
| 159 |
| 160 |
| 161 |
| 162 |
void |
| 163 |
eputs(s) |
| 164 |
char *s; |
| 165 |
| 166 |
fputs(s, stderr); |
| 167 |
| 168 |
| 169 |
| 170 |
void |
| 171 |
quit(code) |
| 172 |
int code; |
| 173 |
| 174 |
exit(code); |
| 175 |
| 176 |
| 177 |
| 178 |
static pic * |
| 179 |
openinput( /* open RADIANCE input file */ |
| 180 |
char *fname, |
| 181 |
register struct rasterfile *h |
| 182 |
| 183 |
| 184 |
register pic *p; |
| 185 |
| 186 |
p = (pic *)emalloc(sizeof(pic)); |
| 187 |
p->name = fname; |
| 188 |
if (fname == NULL) |
| 189 |
p->fp = stdin; |
| 190 |
else if ((p->fp = fopen(fname, "r")) == NULL) |
| 191 |
return(NULL); |
| 192 |
/* check header */ |
| 193 |
if (checkheader(p->fp, COLRFMT, NULL) < 0 || |
| 194 |
fgetresolu(&xmax, &ymax, p->fp) < 0) |
| 195 |
quiterr("bad picture format"); |
| 196 |
p->nexty = 0; |
| 197 |
p->bytes_line = 0; /* variable length lines */ |
| 198 |
p->pos.y = (long *)ecalloc(ymax, sizeof(long)); |
| 199 |
p->pos.y[0] = ftell(p->fp); |
| 200 |
/* assign header */ |
| 201 |
h->ras_magic = RAS_MAGIC; |
| 202 |
h->ras_width = xmax + (xmax&1); /* round to 16 bits */ |
| 203 |
h->ras_height = ymax; |
| 204 |
h->ras_depth = 8; |
| 205 |
h->ras_type = RT_STANDARD; |
| 206 |
h->ras_length = h->ras_width*h->ras_height; |
| 207 |
h->ras_maptype = RMT_EQUAL_RGB; |
| 208 |
h->ras_maplength = 256*3; |
| 209 |
/* allocate scanline */ |
| 210 |
inl = (COLR *)emalloc(xmax*sizeof(COLR)); |
| 211 |
| 212 |
return(p); |
| 213 |
| 214 |
| 215 |
| 216 |
static pic * |
| 217 |
openoutput( /* open output rasterfile */ |
| 218 |
char *fname, |
| 219 |
| 220 |
| 221 |
| 222 |
register pic *p; |
| 223 |
| 224 |
| 225 |
p->name = fname; |
| 226 |
| 227 |
p->fp = stdout; |
| 228 |
else if ((p->fp = fopen(fname, "w")) == NULL) |
| 229 |
return(NULL); |
| 230 |
/* write header */ |
| 231 |
fwrite((char *)h, sizeof(*h), 1, p->fp); |
| 232 |
p->nexty = -1; /* needs color map */ |
| 233 |
p->bytes_line = h->ras_width; |
| 234 |
p->pos.b = 0; |
| 235 |
| 236 |
return(p); |
| 237 |
| 238 |
| 239 |
| 240 |
static void |
| 241 |
pr2ra( /* pixrect file to RADIANCE file */ |
| 242 |
| 243 |
| 244 |
| 245 |
BYTE cmap[3][256]; |
| 246 |
COLR ctab[256]; |
| 247 |
COLR *scanline; |
| 248 |
register int i, j, c; |
| 249 |
| 250 |
scanline = (COLR *)emalloc(xmax*sizeof(COLR)); |
| 251 |
/* get color table */ |
| 252 |
for (i = 0; i < 3; i ++) |
| 253 |
if (fread((char *)cmap[i], h->ras_maplength/3, 1, stdin) != 1) |
| 254 |
quiterr("error reading color table"); |
| 255 |
/* convert table */ |
| 256 |
for (i = 0; i < h->ras_maplength/3; i++) |
| 257 |
setcolr(ctab[i], |
| 258 |
pow((cmap[0][i]+.5)/256.,gamcor), |
| 259 |
pow((cmap[1][i]+.5)/256.,gamcor), |
| 260 |
pow((cmap[2][i]+.5)/256.,gamcor)); |
| 261 |
if (bradj) |
| 262 |
shiftcolrs(ctab, 256, bradj); |
| 263 |
| 264 |
for (i = 0; i < ymax; i++) { |
| 265 |
for (j = 0; j < xmax; j++) { |
| 266 |
if ((c = getc(stdin)) == EOF) |
| 267 |
quiterr("error reading rasterfile"); |
| 268 |
copycolr(scanline[j], ctab[c]); |
| 269 |
| 270 |
if (xmax & 1) /* extra byte */ |
| 271 |
getc(stdin); |
| 272 |
if (fwritecolrs(scanline, xmax, stdout) < 0) |
| 273 |
quiterr("error writing RADIANCE file"); |
| 274 |
| 275 |
free((void *)scanline); |
| 276 |
| 277 |
| 278 |
| 279 |
extern void |
| 280 |
picreadline3( /* read in 3-byte scanline */ |
| 281 |
int y, |
| 282 |
register rgbpixel *l3 |
| 283 |
| 284 |
| 285 |
register int i; |
| 286 |
| 287 |
if (inpic->nexty != y) { /* find scanline */ |
| 288 |
if (inpic->bytes_line == 0) { |
| 289 |
if (inpic->pos.y[y] == 0) { |
| 290 |
while (inpic->nexty < y) { |
| 291 |
if (freadcolrs(inl, xmax, inpic->fp) < 0) |
| 292 |
quiterr("read error in picreadline3"); |
| 293 |
inpic->pos.y[++inpic->nexty] = ftell(inpic->fp); |
| 294 |
| 295 |
} else if (fseek(inpic->fp, inpic->pos.y[y], 0) == EOF) |
| 296 |
quiterr("seek error in picreadline3"); |
| 297 |
} else if (fseek(inpic->fp, y*inpic->bytes_line+inpic->pos.b, 0) == EOF) |
| 298 |
| 299 |
} else if (inpic->bytes_line == 0 && inpic->pos.y[inpic->nexty] == 0) |
| 300 |
inpic->pos.y[inpic->nexty] = ftell(inpic->fp); |
| 301 |
if (freadcolrs(inl, xmax, inpic->fp) < 0) /* read scanline */ |
| 302 |
| 303 |
inpic->nexty = y+1; |
| 304 |
/* convert scanline */ |
| 305 |
normcolrs(inl, xmax, bradj); |
| 306 |
for (i = 0; i < xmax; i++) { |
| 307 |
l3[i].r = inl[i][RED]; |
| 308 |
l3[i].g = inl[i][GRN]; |
| 309 |
l3[i].b = inl[i][BLU]; |
| 310 |
| 311 |
| 312 |
| 313 |
| 314 |
extern void |
| 315 |
picwriteline( /* write out scanline */ |
| 316 |
int y, |
| 317 |
register pixel *l |
| 318 |
| 319 |
| 320 |
if (outpic->nexty != y) { /* seek to scanline */ |
| 321 |
if (outpic->bytes_line == 0) { |
| 322 |
if (outpic->pos.y[y] == 0) |
| 323 |
quiterr("cannot seek in picwriteline"); |
| 324 |
else if (fseek(outpic->fp, outpic->pos.y[y], 0) == EOF) |
| 325 |
quiterr("seek error in picwriteline"); |
| 326 |
} else if (fseek(outpic->fp, y*outpic->bytes_line+outpic->pos.b, 0) == EOF) |
| 327 |
| 328 |
| 329 |
/* write scanline */ |
| 330 |
if (fwrite((char *)l, sizeof(pixel), xmax, outpic->fp) != xmax) |
| 331 |
quiterr("write error in picwriteline"); |
| 332 |
if (xmax&1) /* on 16-bit boundary */ |
| 333 |
putc(l[xmax-1], outpic->fp); |
| 334 |
outpic->nexty = y+1; |
| 335 |
if (outpic->bytes_line == 0 && outpic->pos.y[outpic->nexty] == 0) |
| 336 |
outpic->pos.y[outpic->nexty] = ftell(outpic->fp); |
| 337 |
| 338 |
| 339 |
| 340 |
extern void |
| 341 |
picwritecm( /* write out color map */ |
| 342 |
colormap cm |
| 343 |
| 344 |
| 345 |
register int i, j; |
| 346 |
| 347 |
if (outpic->nexty != -1 && |
| 348 |
fseek(outpic->fp, (long)sizeof(struct rasterfile), 0) == EOF) |
| 349 |
quiterr("seek error in picwritecm"); |
| 350 |
for (i = 0; i < 3; i++) |
| 351 |
for (j = 0; j < 256; j++) |
| 352 |
putc(cm[i][j], outpic->fp); |
| 353 |
outpic->nexty = 0; |
| 354 |
if (outpic->bytes_line == 0) |
| 355 |
outpic->pos.y[0] = ftell(outpic->fp); |
| 356 |
else |
| 357 |
outpic->pos.b = ftell(outpic->fp); |
| 358 |
| 359 |
| 360 |
| 361 |
extern void |
| 362 |
picreadcm( /* do gamma correction if requested */ |
| 363 |
colormap map |
| 364 |
| 365 |
| 366 |
register int i, val; |
| 367 |
| 368 |
for (i = 0; i < 256; i++) { |
| 369 |
val = pow((i+0.5)/256.0, 1.0/gamcor) * 256.0; |
| 370 |
map[0][i] = map[1][i] = map[2][i] = val; |
| 371 |
| 372 |
