root/radiance/src/px/ra_ppm.c
Sat Jun 7 05:09:46 2025 UTC (4 months, 1 week ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 2.18: +1 -2 lines
Diff to previous 2.18 , to selected 2.16
Fri Jun 6 19:11:21 2025 UTC (4 months, 1 week ago) by greg
Diff to previous 2.17 , to selected 2.16
refactor: Making use of printargs() more consistent with fixargv0()
Sat Dec 28 18:05:14 2019 UTC (5 years, 9 months ago) by greg
CVS Tags: rad5R3, rad5R4
Changes since 2.16: +1 -3 lines
Diff to previous 2.16
Revision 2.16 - (view) (download) (annotate) - [selected]
Tue Mar 20 18:45:04 2018 UTC (7 years, 6 months ago) by greg
Changes since 2.15: +2 -1 lines
Diff to previous 2.15
Added missing rtio.h include to redefine getc, putc, etc.
Sun Mar 6 01:13:17 2016 UTC (9 years, 7 months ago) by schorsch
Changes since 2.14: +3 -3 lines
Diff to previous 2.14 , to selected 2.16
Mon May 26 17:58:33 2008 UTC (17 years, 4 months ago) by greg
Diff to previous 2.13 , to selected 2.16
Minor fix for reading grayscale images
Fri Jan 6 06:40:53 2006 UTC (19 years, 9 months ago) by greg
CVS Tags: rad3R8, rad3R9
Diff to previous 2.12 , to selected 2.16
Fixed byte ordering for 16-bit/channel PPM files
Sun Mar 28 20:33:14 2004 UTC (21 years, 6 months ago) by schorsch
Changes since 2.11: +115 -72 lines
Diff to previous 2.11 , to selected 2.16
Sun Jul 27 22:12:03 2003 UTC (22 years, 2 months ago) by schorsch
Diff to previous 2.10 , to selected 2.16
Thu Jun 5 19:29:34 2003 UTC (22 years, 4 months ago) by schorsch
Changes since 2.9: +8 -15 lines
Diff to previous 2.9 , to selected 2.16
Sat Feb 22 02:07:28 2003 UTC (22 years, 7 months ago) by greg
Changes since 2.8: +7 -10 lines
Diff to previous 2.8 , to selected 2.16
Wed Feb 10 08:43:41 1999 UTC (26 years, 8 months ago) by gwlarson
Changes since 2.7: +291 -37 lines
Diff to previous 2.7 , to selected 2.16
added -s and -b options for greyscale and high-precision output
Sun Feb 27 10:17:07 1994 UTC (31 years, 7 months ago) by greg
Changes since 2.6: +1 -0 lines
Diff to previous 2.6 , to selected 2.16
Thu Nov 18 09:55:12 1993 UTC (31 years, 11 months ago) by greg
Changes since 2.5: +1 -2 lines
Diff to previous 2.5 , to selected 2.16
minor compiler warning fixes
Mon Jul 12 12:41:15 1993 UTC (32 years, 3 months ago) by greg
Diff to previous 2.4 , to selected 2.16
renamed gamma to avoid math library conflict
Fri Oct 2 16:25:15 1992 UTC (33 years ago) by greg
Diff to previous 2.3 , to selected 2.16
Mon Sep 21 12:14:55 1992 UTC (33 years, 1 month ago) by greg
Changes since 2.2: +20 -3 lines
Diff to previous 2.2 , to selected 2.16
Changes for PC port
Thu Dec 19 14:52:11 1991 UTC (33 years, 10 months ago) by greg
Diff to previous 2.1 , to selected 2.16
Tue Nov 12 16:05:43 1991 UTC (33 years, 11 months ago) by greg
Diff to previous 1.2 , to selected 2.16
Mon Nov 11 14:01:32 1991 UTC (33 years, 11 months ago) by greg
Changes since 1.1: +4 -2 lines
Diff to previous 1.1 , to selected 2.16
Fri Aug 16 12:41:59 1991 UTC (34 years, 2 months ago) by greg
Diff to selected 2.16
