root/radiance/src/px/ra_gif.c
Revision: 2.8
Committed: Thu Jun 5 19:29:34 2003 UTC (22 years, 4 months ago) by schorsch
Changes since 2.7: +6 -15 lines
2 static const char RCSid[] = "$Id: ra_gif.c,v 2.7 2003/02/22 02:07:27 greg Exp $";
5 * Convert from Radiance picture file to Compuserve GIF.
6 * Currently, we don't know how to get back.
7 */
8
9 #include <stdio.h>
10 #include <time.h>
11 #include <math.h>
12
13 #include "platform.h"
14 #include "color.h"
15 #include "resolu.h"
16
17 #define MAXCOLORS 256
18
19 int rmap[MAXCOLORS];
20 int gmap[MAXCOLORS];
21 int bmap[MAXCOLORS];
22
23 int currow;
24
25 extern long ftell();
26
27 long picstart;
28
29 BYTE clrtab[256][3];
30
31 extern int samplefac;
32
33 extern int getgifpix();
34
35 COLR *scanln;
36 BYTE *pixscan;
37
38 int xmax, ymax; /* picture size */
39
40 double gamv = 2.2; /* gamma correction */
41
42 int greyscale = 0; /* convert to B&W? */
43
44 int dither = 1; /* dither colors? */
45
46 int bradj = 0; /* brightness adjustment */
47
48 int ncolors = 0; /* number of colors requested */
49
50 char *progname;
51
52
53 main(argc, argv)
54 int argc;
55 char *argv[];
56 {
57 int bitsperpix;
58 int i;
59 SET_DEFAULT_BINARY();
60 SET_FILE_BINARY(stdin);
61 SET_FILE_BINARY(stdout);
62 progname = argv[0];
63 samplefac = 0;
64
65 for (i = 1; i < argc; i++)
66 if (argv[i][0] == '-')
67 switch (argv[i][1]) {
68 case 'g':
69 gamv = atof(argv[++i]);
70 break;
71 case 'b':
72 greyscale = 1;
73 break;
74 case 'd':
75 dither = !dither;
76 break;
77 case 'c':
78 ncolors = atoi(argv[++i]);
79 break;
80 case 'e':
81 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
82 goto userr;
83 bradj = atoi(argv[++i]);
84 break;
85 case 'n':
86 samplefac = atoi(argv[++i]);
87 break;
88 default:
89 goto userr;
90 }
91 else
92 break;
93
94 if (i < argc-2)
95 goto userr;
96 if (i <= argc-1 && freopen(argv[i], "r", stdin) == NULL) {
97 fprintf(stderr, "%s: cannot open input \"%s\"\n",
98 progname, argv[i]);
99 exit(1);
100 }
101 if (i == argc-2 && freopen(argv[i+1], "w", stdout) == NULL) {
102 fprintf(stderr, "%s: cannot open output \"%s\"\n",
103 progname, argv[i+1]);
104 exit(1);
105 }
106 if (checkheader(stdin, COLRFMT, NULL) < 0 ||
107 fgetresolu(&xmax, &ymax, stdin) < 0) {
108 fprintf(stderr, "%s: bad picture format\n", progname);
109 exit(1);
110 }
111 picstart = ftell(stdin);
112 currow = -1;
113 scanln = (COLR *)malloc(xmax*sizeof(COLR));
114 if (scanln == NULL) {
115 fprintf(stderr, "%s: out of memory\n", progname);
116 exit(1);
117 }
118 /* set up gamma correction */
119 setcolrgam(gamv);
120 /* figure out the bits per pixel */
121 if (ncolors < 2 | ncolors > MAXCOLORS)
122 ncolors = MAXCOLORS;
123 for (bitsperpix = 1; ncolors > 1<<bitsperpix; bitsperpix++)
124 ;
125 /* compute color map */
126 if (greyscale)
127 mkgrymap(ncolors);
128 else
129 mkclrmap(ncolors);
130 /* convert image */
131 GIFEncode(stdout, xmax, ymax, 0, 0, bitsperpix,
132 rmap, gmap, bmap, getgifpix);
133 exit(0);
134 userr:
135 fprintf(stderr,
136 "Usage: %s [-b][-d][-n samp][-c ncolors][-g gamv][-e +/-stops] input [output]\n",
137 progname);
138 exit(1);
139 }
140
141
142 getrow(y) /* get the specified row from our image */
143 int y;
144 {
145 if (y == currow)
146 return;
147 if (y < currow) {
148 fseek(stdin, picstart, 0);
149 currow = -1;
150 }
151 do
152 if (freadcolrs(scanln, xmax, stdin) < 0) {
153 fprintf(stderr, "%s: error reading picture (y==%d)\n",
154 progname, ymax-1-y);
155 exit(1);
156 }
157 while (++currow < y);
158 if (bradj)
159 shiftcolrs(scanln, xmax, bradj);
160 colrs_gambs(scanln, xmax);
161 if (pixscan != NULL)
162 if (samplefac)
163 neu_dith_colrs(pixscan, scanln, xmax);
164 else
165 dith_colrs(pixscan, scanln, xmax);
166 }
167
168
169 mkclrmap(nc) /* make our color map */
170 int nc;
171 {
172 register int i;
173
174 if ((samplefac ? neu_init(xmax*ymax) : new_histo(xmax*ymax)) == -1)
175 goto memerr;
176 for (i = 0; i < ymax; i++) {
177 getrow(i);
178 if (samplefac)
179 neu_colrs(scanln, xmax);
180 else
181 cnt_colrs(scanln, xmax);
182 }
183 if (samplefac)
184 neu_clrtab(nc);
185 else
186 new_clrtab(nc);
187 for (i = 0; i < nc; i++) {
188 rmap[i] = clrtab[i][RED];
189 gmap[i] = clrtab[i][GRN];
190 bmap[i] = clrtab[i][BLU];
191 }
192 if (dither && (pixscan = (BYTE *)malloc(xmax)) == NULL)
193 goto memerr;
194 return;
195 memerr:
196 fprintf(stderr, "%s: out of memory\n", progname);
197 exit(1);
198 }
199
200
201 mkgrymap(nc)
202 int nc;
203 {
204 register int i;
205
206 for (i = 0; i < nc; i++) {
207 rmap[i] =
208 gmap[i] =
209 bmap[i] = ((unsigned)i<<8)/nc;
210 }
211 }
212
213
214 int
215 getgifpix(x, y) /* get a single pixel from our picture */
216 int x, y;
217 {
218 int pix;
219
220 getrow(y);
221 if (greyscale)
222 return((normbright(scanln[x])*ncolors)>>8);
223 if (pixscan != NULL)
224 return(pixscan[x]);
225 return(samplefac ? neu_map_pixel(scanln[x]) : map_pixel(scanln[x]));
226 }
227
228
229 /*
230 * SCARY GIF code follows . . . . sorry.
231 *
232 * Based on GIFENCOD by David Rowley <[email protected]>.A
233 * Lempel-Zim compression based on "compress".
234 *
235 */
236
237 /*****************************************************************************
238 *
239 * GIFENCODE.C - GIF Image compression interface
240 *
241 * GIFEncode( FName, GHeight, GWidth, GInterlace, Background,
242 * BitsPerPixel, Red, Green, Blue, GetPixel )
243 *
244 *****************************************************************************/
245 typedef int (* ifunptr)();
246
247 #define TRUE 1
248 #define FALSE 0
249
250 int Width, Height;
251 int curx, cury;
252 long CountDown;
253 int Pass;
254 int Interlace;
255 unsigned long cur_accum = 0;
256 int cur_bits = 0;
257
258 /*
259 * Bump the 'curx' and 'cury' to point to the next pixel
260 */
261 BumpPixel()
262 {
263 curx++;
264 if( curx == Width ) {
265 curx = 0;
266 if( !Interlace ) {
267 cury++;
268 } else {
269 switch( Pass ) {
270 case 0:
271 cury += 8;
272 if( cury >= Height ) {
273 Pass++;
274 cury = 4;
275 }
276 break;
277 case 1:
278 cury += 8;
279 if( cury >= Height ) {
280 Pass++;
281 cury = 2;
282 }
283 break;
284 case 2:
285 cury += 4;
286 if( cury >= Height ) {
287 Pass++;
288 cury = 1;
289 }
290 break;
291 case 3:
292 cury += 2;
293 break;
294 }
295 }
296 }
297 }
298
299 /*
300 * Return the next pixel from the image
301 */
302 GIFNextPixel( getpixel )
303 ifunptr getpixel;
304 {
305 int r;
306
307 if( CountDown == 0 )
308 return EOF;
309 CountDown--;
310 r = (*getpixel)( curx, cury );
311 BumpPixel();
312 return r;
313 }
314
315 /*
316 * public GIFEncode
317 */
318 GIFEncode( fp, GWidth, GHeight, GInterlace, Background,
319 BitsPerPixel, Red, Green, Blue, GetPixel )
320 FILE *fp;
321 int GWidth, GHeight;
322 int GInterlace;
323 int Background;
324 int BitsPerPixel;
325 int Red[], Green[], Blue[];
326 ifunptr GetPixel;
327 {
328 int B;
329 int RWidth, RHeight;
330 int LeftOfs, TopOfs;
331 int Resolution;
332 int ColorMapSize;
333 int InitCodeSize;
334 int i;
335
336 long cur_accum = 0;
337 cur_bits = 0;
338
339 Interlace = GInterlace;
340 ColorMapSize = 1 << BitsPerPixel;
341 RWidth = Width = GWidth;
342 RHeight = Height = GHeight;
343 LeftOfs = TopOfs = 0;
344 Resolution = BitsPerPixel;
345
346 CountDown = (long)Width * (long)Height;
347 Pass = 0;
348 if( BitsPerPixel <= 1 )
349 InitCodeSize = 2;
350 else
351 InitCodeSize = BitsPerPixel;
352 curx = cury = 0;
353 fwrite( "GIF87a", 1, 6, fp );
354 Putword( RWidth, fp );
355 Putword( RHeight, fp );
356 B = 0x80; /* Yes, there is a color map */
357 B |= (Resolution - 1) << 5;
358 B |= (BitsPerPixel - 1);
359 fputc( B, fp );
360 fputc( Background, fp );
361 fputc( 0, fp );
362 for( i=0; i<ColorMapSize; i++ ) {
363 fputc( Red[i], fp );
364 fputc( Green[i], fp );
365 fputc( Blue[i], fp );
366 }
367 fputc( ',', fp );
368 Putword( LeftOfs, fp );
369 Putword( TopOfs, fp );
370 Putword( Width, fp );
371 Putword( Height, fp );
372 if( Interlace )
373 fputc( 0x40, fp );
374 else
375 fputc( 0x00, fp );
376 fputc( InitCodeSize, fp );
377 compress( InitCodeSize+1, fp, GetPixel );
378 fputc( 0, fp );
379 fputc( ';', fp );
380 fclose( fp );
381 }
382
383 /*
384 * Write out a word to the GIF file
385 */
386 Putword( w, fp )
387 int w;
388 FILE *fp;
389 {
390 fputc( w & 0xff, fp );
391 fputc( (w/256) & 0xff, fp );
392 }
393
394
395 /***************************************************************************
396 *
397 * GIFCOMPR.C - GIF Image compression routines
398 *
399 * Lempel-Ziv compression based on 'compress'. GIF modifications by
400 * David Rowley ([email protected])
401 *
402 ***************************************************************************/
403
404 #define CBITS 12
405 #define HSIZE 5003 /* 80% occupancy */
406
407 /*
408 * a code_int must be able to hold 2**CBITS values of type int, and also -1
409 */
410 typedef int code_int;
411 typedef long int count_int;
412 typedef unsigned char char_type;
413
414 /*
415 *
416 * GIF Image compression - modified 'compress'
417 *
418 * Based on: compress.c - File compression ala IEEE Computer, June 1984.
419 *
420 * By Authors: Spencer W. Thomas (decvax!harpo!utah-cs!utah-gr!thomas)
421 * Jim McKie (decvax!mcvax!jim)
422 * Steve Davies (decvax!vax135!petsd!peora!srd)
423 * Ken Turkowski (decvax!decwrl!turtlevax!ken)
424 * James A. Woods (decvax!ihnp4!ames!jaw)
425 * Joe Orost (decvax!vax135!petsd!joe)
426 *
427 */
428 #include <ctype.h>
429
430 #define ARGVAL() (*++(*argv) || (--argc && *++argv))
431
432 int n_bits; /* number of bits/code */
433 int maxbits = CBITS; /* user settable max # bits/code */
434 code_int maxcode; /* maximum code, given n_bits */
435 code_int maxmaxcode = (code_int)1 << CBITS; /* should NEVER generate this code */
436 # define MAXCODE(n_bits) (((code_int) 1 << (n_bits)) - 1)
437
438 count_int htab [HSIZE];
439 unsigned short codetab [HSIZE];
440 #define HashTabOf(i) htab[i]
441 #define CodeTabOf(i) codetab[i]
442
443 code_int hsize = HSIZE; /* for dynamic table sizing */
444
445 /*
446 * To save much memory, we overlay the table used by compress() with those
447 * used by decompress(). The tab_prefix table is the same size and type
448 * as the codetab. The tab_suffix table needs 2**CBITS characters. We
449 * get this from the beginning of htab. The output stack uses the rest
450 * of htab, and contains characters. There is plenty of room for any
451 * possible stack (stack used to be 8000 characters).
452 */
453 #define tab_prefixof(i) CodeTabOf(i)
454 #define tab_suffixof(i) ((char_type *)(htab))[i]
455 #define de_stack ((char_type *)&tab_suffixof((code_int)1<<CBITS))
456
457 code_int free_ent = 0; /* first unused entry */
458
459 /*
460 * block compression parameters -- after all codes are used up,
461 * and compression rate changes, start over.
462 */
463 int clear_flg = 0;
464 int offset;
465 long int in_count = 1; /* length of input */
466 long int out_count = 0; /* # of codes output (for debugging) */
467
468 /*
469 * compress stdin to stdout
470 *
471 * Algorithm: use open addressing double hashing (no chaining) on the
472 * prefix code / next character combination. We do a variant of Knuth's
473 * algorithm D (vol. 3, sec. 6.4) along with G. Knott's relatively-prime
474 * secondary probe. Here, the modular division first probe is gives way
475 * to a faster exclusive-or manipulation. Also do block compression with
476 * an adaptive reset, whereby the code table is cleared when the compression
477 * ratio decreases, but after the table fills. The variable-length output
478 * codes are re-sized at this point, and a special CLEAR code is generated
479 * for the decompressor. Late addition: construct the table according to
480 * file size for noticeable speed improvement on small files. Please direct
481 * questions about this implementation to ames!jaw.
482 */
483
484 int g_init_bits;
485 FILE *g_outfile;
486 int ClearCode;
487 int EOFCode;
488
489 compress( init_bits, outfile, ReadValue )
490 int init_bits;
491 FILE *outfile;
492 ifunptr ReadValue;
493 {
494 register long fcode;
495 register code_int i = 0;
496 register int c;
497 register code_int ent;
498 register code_int disp;
499 register code_int hsize_reg;
500 register int hshift;
501
502 /*
503 * Set up the globals: g_init_bits - initial number of bits
504 * g_outfile - pointer to output file
505 */
506 g_init_bits = init_bits;
507 g_outfile = outfile;
508 /*
509 * Set up the necessary values
510 */
511 offset = 0;
512 out_count = 0;
513 clear_flg = 0;
514 in_count = 1;
515 maxcode = MAXCODE(n_bits = g_init_bits);
516 ClearCode = (1 << (init_bits - 1));
517 EOFCode = ClearCode + 1;
518 free_ent = ClearCode + 2;
519 char_init();
520 ent = GIFNextPixel( ReadValue );
521 hshift = 0;
522 for ( fcode = (long) hsize; fcode < 65536L; fcode *= 2L )
523 hshift++;
524 hshift = 8 - hshift; /* set hash code range bound */
525 hsize_reg = hsize;
526 cl_hash( (count_int) hsize_reg); /* clear hash table */
527 output( (code_int)ClearCode );
528 while ( (c = GIFNextPixel( ReadValue )) != EOF ) {
529 in_count++;
530 fcode = (long) (((long) c << maxbits) + ent);
531 /* i = (((code_int)c << hshift) ~ ent); /* xor hashing */
532 i = (((code_int)c << hshift) ^ ent); /* xor hashing */
533 if ( HashTabOf (i) == fcode ) {
534 ent = CodeTabOf (i);
535 continue;
536 } else if ( (long)HashTabOf (i) < 0 ) /* empty slot */
537 goto nomatch;
538 disp = hsize_reg - i; /* secondary hash (after G. Knott) */
539 if ( i == 0 )
540 disp = 1;
541 probe:
542 if ( (i -= disp) < 0 )
543 i += hsize_reg;
544 if ( HashTabOf (i) == fcode ) {
545 ent = CodeTabOf (i);
546 continue;
547 }
548 if ( (long)HashTabOf (i) > 0 )
549 goto probe;
550 nomatch:
551 output ( (code_int) ent );
552 out_count++;
553 ent = c;
554 if ( free_ent < maxmaxcode ) {
555 CodeTabOf (i) = free_ent++; /* code -> hashtable */
556 HashTabOf (i) = fcode;
557 } else
558 cl_block();
559 }
560 /*
561 * Put out the final code.
562 */
563 output( (code_int)ent );
564 out_count++;
565 output( (code_int) EOFCode );
566 return;
567 }
568
569 /*****************************************************************
570 * TAG( output )
571 *
572 * Output the given code.
573 * Inputs:
574 * code: A n_bits-bit integer. If == -1, then EOF. This assumes
575 * that n_bits =< (long)wordsize - 1.
576 * Outputs:
577 * Outputs code to the file.
578 * Assumptions:
579 * Chars are 8 bits long.
580 * Algorithm:
581 * Maintain a CBITS character long buffer (so that 8 codes will
582 * fit in it exactly). Use the VAX insv instruction to insert each
583 * code in turn. When the buffer fills up empty it and start over.
584 */
585
586 unsigned long masks[] = { 0x0000, 0x0001, 0x0003, 0x0007, 0x000F,
587 0x001F, 0x003F, 0x007F, 0x00FF,
588 0x01FF, 0x03FF, 0x07FF, 0x0FFF,
589 0x1FFF, 0x3FFF, 0x7FFF, 0xFFFF };
590
591 output( code )
592 code_int code;
593 {
594 cur_accum &= masks[ cur_bits ];
595 if( cur_bits > 0 )
596 cur_accum |= ((long)code << cur_bits);
597 else
598 cur_accum = code;
599 cur_bits += n_bits;
600 while( cur_bits >= 8 ) {
601 char_out( (unsigned int)(cur_accum & 0xff) );
602 cur_accum >>= 8;
603 cur_bits -= 8;
604 }
605
606 /*
607 * If the next entry is going to be too big for the code size,
608 * then increase it, if possible.
609 */
610 if ( free_ent > maxcode || clear_flg ) {
611 if( clear_flg ) {
612 maxcode = MAXCODE (n_bits = g_init_bits);
613 clear_flg = 0;
614 } else {
615 n_bits++;
616 if ( n_bits == maxbits )
617 maxcode = maxmaxcode;
618 else
619 maxcode = MAXCODE(n_bits);
620 }
621 }
622 if( code == EOFCode ) {
623 /*
624 * At EOF, write the rest of the buffer.
625 */
626 while( cur_bits > 0 ) {
627 char_out( (unsigned int)(cur_accum & 0xff) );
628 cur_accum >>= 8;
629 cur_bits -= 8;
630 }
631 flush_char();
632 fflush( g_outfile );
633 if( ferror( g_outfile ) )
634 writeerr();
635 }
636 }
637
638 /*
639 * Clear out the hash table
640 */
641 cl_block () /* table clear for block compress */
642 {
643 cl_hash ( (count_int) hsize );
644 free_ent = ClearCode + 2;
645 clear_flg = 1;
646 output( (code_int)ClearCode );
647 }
648
649 cl_hash(hsize) /* reset code table */
650 register count_int hsize;
651 {
652 register count_int *htab_p = htab+hsize;
653 register long i;
654 register long m1 = -1;
655
656 i = hsize - 16;
657 do { /* might use Sys V memset(3) here */
658 *(htab_p-16) = m1;
659 *(htab_p-15) = m1;
660 *(htab_p-14) = m1;
661 *(htab_p-13) = m1;
662 *(htab_p-12) = m1;
663 *(htab_p-11) = m1;
664 *(htab_p-10) = m1;
665 *(htab_p-9) = m1;
666 *(htab_p-8) = m1;
667 *(htab_p-7) = m1;
668 *(htab_p-6) = m1;
669 *(htab_p-5) = m1;
670 *(htab_p-4) = m1;
671 *(htab_p-3) = m1;
672 *(htab_p-2) = m1;
673 *(htab_p-1) = m1;
674 htab_p -= 16;
675 } while ((i -= 16) >= 0);
676 for ( i += 16; i > 0; i-- )
677 *--htab_p = m1;
678 }
679
680 writeerr()
681 {
682 printf( "error writing output file\n" );
683 exit(1);
684 }
685
686 /******************************************************************************
687 *
688 * GIF Specific routines
689 *
690 ******************************************************************************/
691
692 /*
693 * Number of characters so far in this 'packet'
694 */
695 int a_count;
696
697 /*
698 * Set up the 'byte output' routine
699 */
700 char_init()
701 {
702 a_count = 0;
703 }
704
705 /*
706 * Define the storage for the packet accumulator
707 */
708 char accum[256];
709
710 /*
711 * Add a character to the end of the current packet, and if it is 254
712 * characters, flush the packet to disk.
713 */
714 char_out( c )
715 int c;
716 {
717 accum[ a_count++ ] = c;
718 if( a_count >= 254 )
719 flush_char();
720 }
721
722 /*
723 * Flush the packet to disk, and reset the accumulator
724 */
725 flush_char()
726 {
727 if( a_count > 0 ) {
728 fputc( a_count, g_outfile );
729 fwrite( accum, 1, a_count, g_outfile );
730 a_count = 0;
731 }
732 }
733
734 static float curgamma;
735 static short gamtab[256];
736
737 gammawarp(sbuf,gam,n)
738 short *sbuf;
739 float gam;
740 int n;
741 {
742 int i;
743 float f;
744
745 if(gam!=curgamma) {
746 for(i=0; i<256; i++)
747 gamtab[i] = 255*pow(i/255.0,gam)+0.5;
748 curgamma = gam;
749 }
750 while(n--) {
751 *sbuf = gamtab[*sbuf];
752 sbuf++;
753 }
754 }
