root/radiance/src/px/ra_gif.c
Revision: 2.10
Committed: Sun Jul 27 22:12:03 2003 UTC (22 years, 2 months ago) by schorsch
2 static const char RCSid[] = "$Id: ra_gif.c,v 2.9 2003/07/21 22:30:19 schorsch Exp $";
5 * Convert from Radiance picture file to Compuserve GIF.
6 * Currently, we don't know how to get back.
7 */
8
9 #include <stdio.h>
10 #include <time.h>
11 #include <math.h>
12
13 #include "platform.h"
14 #include "color.h"
15 #include "resolu.h"
16
17 #define MAXCOLORS 256
18
19 int rmap[MAXCOLORS];
20 int gmap[MAXCOLORS];
21 int bmap[MAXCOLORS];
22
23 int currow;
24
25 extern long ftell();
26
27 long picstart;
28
29 BYTE clrtab[256][3];
30
31 extern int samplefac;
32
33 extern int getgifpix();
34
35 COLR *scanln;
36 BYTE *pixscan;
37
38 int xmax, ymax; /* picture size */
39
40 double gamv = 2.2; /* gamma correction */
41
42 int greyscale = 0; /* convert to B&W? */
43
44 int dither = 1; /* dither colors? */
45
46 int bradj = 0; /* brightness adjustment */
47
48 int ncolors = 0; /* number of colors requested */
49
50 char *progname;
51
52
53 main(argc, argv)
54 int argc;
55 char *argv[];
56 {
57 int bitsperpix;
58 int i;
59 SET_DEFAULT_BINARY();
60 SET_FILE_BINARY(stdin);
61 SET_FILE_BINARY(stdout);
62 progname = argv[0];
63 samplefac = 0;
64
65 for (i = 1; i < argc; i++)
66 if (argv[i][0] == '-')
67 switch (argv[i][1]) {
68 case 'g':
69 gamv = atof(argv[++i]);
70 break;
71 case 'b':
72 greyscale = 1;
73 break;
74 case 'd':
75 dither = !dither;
76 break;
77 case 'c':
78 ncolors = atoi(argv[++i]);
79 break;
80 case 'e':
81 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
82 goto userr;
83 bradj = atoi(argv[++i]);
84 break;
85 case 'n':
86 samplefac = atoi(argv[++i]);
87 break;
88 default:
89 goto userr;
90 }
91 else
92 break;
93
94 if (i < argc-2)
95 goto userr;
96 if (i <= argc-1 && freopen(argv[i], "r", stdin) == NULL) {
97 fprintf(stderr, "%s: cannot open input \"%s\"\n",
98 progname, argv[i]);
99 exit(1);
100 }
101 if (i == argc-2 && freopen(argv[i+1], "w", stdout) == NULL) {
102 fprintf(stderr, "%s: cannot open output \"%s\"\n",
103 progname, argv[i+1]);
104 exit(1);
105 }
106 if (checkheader(stdin, COLRFMT, NULL) < 0 ||
107 fgetresolu(&xmax, &ymax, stdin) < 0) {
108 fprintf(stderr, "%s: bad picture format\n", progname);
109 exit(1);
110 }
111 picstart = ftell(stdin);
112 currow = -1;
113 scanln = (COLR *)malloc(xmax*sizeof(COLR));
114 if (scanln == NULL) {
115 fprintf(stderr, "%s: out of memory\n", progname);
116 exit(1);
117 }
118 /* set up gamma correction */
119 setcolrgam(gamv);
120 /* figure out the bits per pixel */
121 if ((ncolors < 2) | (ncolors > MAXCOLORS))
122 ncolors = MAXCOLORS;
123 for (bitsperpix = 1; ncolors > 1<<bitsperpix; bitsperpix++)
124 ;
125 /* compute color map */
126 if (greyscale)
127 mkgrymap(ncolors);
128 else
129 mkclrmap(ncolors);
130 /* convert image */
131 GIFEncode(stdout, xmax, ymax, 0, 0, bitsperpix,
132 rmap, gmap, bmap, getgifpix);
133 exit(0);
134 userr:
135 fprintf(stderr,
136 "Usage: %s [-b][-d][-n samp][-c ncolors][-g gamv][-e +/-stops] input [output]\n",
137 progname);
138 exit(1);
139 }
140
141
142 getrow(y) /* get the specified row from our image */
143 int y;
144 {
145 if (y == currow)
146 return;
147 if (y < currow) {
148 fseek(stdin, picstart, 0);
149 currow = -1;
150 }
151 do
152 if (freadcolrs(scanln, xmax, stdin) < 0) {
153 fprintf(stderr, "%s: error reading picture (y==%d)\n",
154 progname, ymax-1-y);
155 exit(1);
156 }
157 while (++currow < y);
158 if (bradj)
159 shiftcolrs(scanln, xmax, bradj);
160 colrs_gambs(scanln, xmax);
161 if (pixscan != NULL) {
162 if (samplefac)
163 neu_dith_colrs(pixscan, scanln, xmax);
164 else
165 dith_colrs(pixscan, scanln, xmax);
166 }
167 }
168
169
170 mkclrmap(nc) /* make our color map */
171 int nc;
172 {
173 register int i;
174
175 if ((samplefac ? neu_init(xmax*ymax) : new_histo(xmax*ymax)) == -1)
176 goto memerr;
177 for (i = 0; i < ymax; i++) {
178 getrow(i);
179 if (samplefac)
180 neu_colrs(scanln, xmax);
181 else
182 cnt_colrs(scanln, xmax);
183 }
184 if (samplefac)
185 neu_clrtab(nc);
186 else
187 new_clrtab(nc);
188 for (i = 0; i < nc; i++) {
189 rmap[i] = clrtab[i][RED];
190 gmap[i] = clrtab[i][GRN];
191 bmap[i] = clrtab[i][BLU];
192 }
193 if (dither && (pixscan = (BYTE *)malloc(xmax)) == NULL)
194 goto memerr;
195 return;
196 memerr:
197 fprintf(stderr, "%s: out of memory\n", progname);
198 exit(1);
199 }
200
201
202 mkgrymap(nc)
203 int nc;
204 {
205 register int i;
206
207 for (i = 0; i < nc; i++) {
208 rmap[i] =
209 gmap[i] =
210 bmap[i] = ((unsigned)i<<8)/nc;
211 }
212 }
213
214
215 int
216 getgifpix(x, y) /* get a single pixel from our picture */
217 int x, y;
218 {
219 int pix;
220
221 getrow(y);
222 if (greyscale)
223 return((normbright(scanln[x])*ncolors)>>8);
224 if (pixscan != NULL)
225 return(pixscan[x]);
226 return(samplefac ? neu_map_pixel(scanln[x]) : map_pixel(scanln[x]));
227 }
228
229
230 /*
231 * SCARY GIF code follows . . . . sorry.
232 *
233 * Based on GIFENCOD by David Rowley <[email protected]>.A
234 * Lempel-Zim compression based on "compress".
235 *
236 */
237
238 /*****************************************************************************
239 *
240 * GIFENCODE.C - GIF Image compression interface
241 *
242 * GIFEncode( FName, GHeight, GWidth, GInterlace, Background,
243 * BitsPerPixel, Red, Green, Blue, GetPixel )
244 *
245 *****************************************************************************/
246 typedef int (* ifunptr)();
247
248 #define TRUE 1
249 #define FALSE 0
250
251 int Width, Height;
252 int curx, cury;
253 long CountDown;
254 int Pass;
255 int Interlace;
256 unsigned long cur_accum = 0;
257 int cur_bits = 0;
258
259 /*
260 * Bump the 'curx' and 'cury' to point to the next pixel
261 */
262 BumpPixel()
263 {
264 curx++;
265 if( curx == Width ) {
266 curx = 0;
267 if( !Interlace ) {
268 cury++;
269 } else {
270 switch( Pass ) {
271 case 0:
272 cury += 8;
273 if( cury >= Height ) {
274 Pass++;
275 cury = 4;
276 }
277 break;
278 case 1:
279 cury += 8;
280 if( cury >= Height ) {
281 Pass++;
282 cury = 2;
283 }
284 break;
285 case 2:
286 cury += 4;
287 if( cury >= Height ) {
288 Pass++;
289 cury = 1;
290 }
291 break;
292 case 3:
293 cury += 2;
294 break;
295 }
296 }
297 }
298 }
299
300 /*
301 * Return the next pixel from the image
302 */
303 GIFNextPixel( getpixel )
304 ifunptr getpixel;
305 {
306 int r;
307
308 if( CountDown == 0 )
309 return EOF;
310 CountDown--;
311 r = (*getpixel)( curx, cury );
312 BumpPixel();
313 return r;
314 }
315
316 /*
317 * public GIFEncode
318 */
319 GIFEncode( fp, GWidth, GHeight, GInterlace, Background,
320 BitsPerPixel, Red, Green, Blue, GetPixel )
321 FILE *fp;
322 int GWidth, GHeight;
323 int GInterlace;
324 int Background;
325 int BitsPerPixel;
326 int Red[], Green[], Blue[];
327 ifunptr GetPixel;
328 {
329 int B;
330 int RWidth, RHeight;
331 int LeftOfs, TopOfs;
332 int Resolution;
333 int ColorMapSize;
334 int InitCodeSize;
335 int i;
336
337 long cur_accum = 0;
338 cur_bits = 0;
339
340 Interlace = GInterlace;
341 ColorMapSize = 1 << BitsPerPixel;
342 RWidth = Width = GWidth;
343 RHeight = Height = GHeight;
344 LeftOfs = TopOfs = 0;
345 Resolution = BitsPerPixel;
346
347 CountDown = (long)Width * (long)Height;
348 Pass = 0;
349 if( BitsPerPixel <= 1 )
350 InitCodeSize = 2;
351 else
352 InitCodeSize = BitsPerPixel;
353 curx = cury = 0;
354 fwrite( "GIF87a", 1, 6, fp );
355 Putword( RWidth, fp );
356 Putword( RHeight, fp );
357 B = 0x80; /* Yes, there is a color map */
358 B |= (Resolution - 1) << 5;
359 B |= (BitsPerPixel - 1);
360 fputc( B, fp );
361 fputc( Background, fp );
362 fputc( 0, fp );
363 for( i=0; i<ColorMapSize; i++ ) {
364 fputc( Red[i], fp );
365 fputc( Green[i], fp );
366 fputc( Blue[i], fp );
367 }
368 fputc( ',', fp );
369 Putword( LeftOfs, fp );
370 Putword( TopOfs, fp );
371 Putword( Width, fp );
372 Putword( Height, fp );
373 if( Interlace )
374 fputc( 0x40, fp );
375 else
376 fputc( 0x00, fp );
377 fputc( InitCodeSize, fp );
378 compress( InitCodeSize+1, fp, GetPixel );
379 fputc( 0, fp );
380 fputc( ';', fp );
381 fclose( fp );
382 }
383
384 /*
385 * Write out a word to the GIF file
386 */
387 Putword( w, fp )
388 int w;
389 FILE *fp;
390 {
391 fputc( w & 0xff, fp );
392 fputc( (w/256) & 0xff, fp );
393 }
394
395
396 /***************************************************************************
397 *
398 * GIFCOMPR.C - GIF Image compression routines
399 *
400 * Lempel-Ziv compression based on 'compress'. GIF modifications by
401 * David Rowley ([email protected])
402 *
403 ***************************************************************************/
404
405 #define CBITS 12
406 #define HSIZE 5003 /* 80% occupancy */
407
408 /*
409 * a code_int must be able to hold 2**CBITS values of type int, and also -1
410 */
411 typedef int code_int;
412 typedef long int count_int;
413 typedef unsigned char char_type;
414
415 /*
416 *
417 * GIF Image compression - modified 'compress'
418 *
419 * Based on: compress.c - File compression ala IEEE Computer, June 1984.
420 *
421 * By Authors: Spencer W. Thomas (decvax!harpo!utah-cs!utah-gr!thomas)
422 * Jim McKie (decvax!mcvax!jim)
423 * Steve Davies (decvax!vax135!petsd!peora!srd)
424 * Ken Turkowski (decvax!decwrl!turtlevax!ken)
425 * James A. Woods (decvax!ihnp4!ames!jaw)
426 * Joe Orost (decvax!vax135!petsd!joe)
427 *
428 */
429 #include <ctype.h>
430
431 #define ARGVAL() (*++(*argv) || (--argc && *++argv))
432
433 int n_bits; /* number of bits/code */
434 int maxbits = CBITS; /* user settable max # bits/code */
435 code_int maxcode; /* maximum code, given n_bits */
436 code_int maxmaxcode = (code_int)1 << CBITS; /* should NEVER generate this code */
437 # define MAXCODE(n_bits) (((code_int) 1 << (n_bits)) - 1)
438
439 count_int htab [HSIZE];
440 unsigned short codetab [HSIZE];
441 #define HashTabOf(i) htab[i]
442 #define CodeTabOf(i) codetab[i]
443
444 code_int hsize = HSIZE; /* for dynamic table sizing */
445
446 /*
447 * To save much memory, we overlay the table used by compress() with those
448 * used by decompress(). The tab_prefix table is the same size and type
449 * as the codetab. The tab_suffix table needs 2**CBITS characters. We
450 * get this from the beginning of htab. The output stack uses the rest
451 * of htab, and contains characters. There is plenty of room for any
452 * possible stack (stack used to be 8000 characters).
453 */
454 #define tab_prefixof(i) CodeTabOf(i)
455 #define tab_suffixof(i) ((char_type *)(htab))[i]
456 #define de_stack ((char_type *)&tab_suffixof((code_int)1<<CBITS))
457
458 code_int free_ent = 0; /* first unused entry */
459
460 /*
461 * block compression parameters -- after all codes are used up,
462 * and compression rate changes, start over.
463 */
464 int clear_flg = 0;
465 int offset;
466 long int in_count = 1; /* length of input */
467 long int out_count = 0; /* # of codes output (for debugging) */
468
469 /*
470 * compress stdin to stdout
471 *
472 * Algorithm: use open addressing double hashing (no chaining) on the
473 * prefix code / next character combination. We do a variant of Knuth's
474 * algorithm D (vol. 3, sec. 6.4) along with G. Knott's relatively-prime
475 * secondary probe. Here, the modular division first probe is gives way
476 * to a faster exclusive-or manipulation. Also do block compression with
477 * an adaptive reset, whereby the code table is cleared when the compression
478 * ratio decreases, but after the table fills. The variable-length output
479 * codes are re-sized at this point, and a special CLEAR code is generated
480 * for the decompressor. Late addition: construct the table according to
481 * file size for noticeable speed improvement on small files. Please direct
482 * questions about this implementation to ames!jaw.
483 */
484
485 int g_init_bits;
486 FILE *g_outfile;
487 int ClearCode;
488 int EOFCode;
489
490 compress( init_bits, outfile, ReadValue )
491 int init_bits;
492 FILE *outfile;
493 ifunptr ReadValue;
494 {
495 register long fcode;
496 register code_int i = 0;
497 register int c;
498 register code_int ent;
499 register code_int disp;
500 register code_int hsize_reg;
501 register int hshift;
502
503 /*
504 * Set up the globals: g_init_bits - initial number of bits
505 * g_outfile - pointer to output file
506 */
507 g_init_bits = init_bits;
508 g_outfile = outfile;
509 /*
510 * Set up the necessary values
511 */
512 offset = 0;
513 out_count = 0;
514 clear_flg = 0;
515 in_count = 1;
516 maxcode = MAXCODE(n_bits = g_init_bits);
517 ClearCode = (1 << (init_bits - 1));
518 EOFCode = ClearCode + 1;
519 free_ent = ClearCode + 2;
520 char_init();
521 ent = GIFNextPixel( ReadValue );
522 hshift = 0;
523 for ( fcode = (long) hsize; fcode < 65536L; fcode *= 2L )
524 hshift++;
525 hshift = 8 - hshift; /* set hash code range bound */
526 hsize_reg = hsize;
527 cl_hash( (count_int) hsize_reg); /* clear hash table */
528 output( (code_int)ClearCode );
529 while ( (c = GIFNextPixel( ReadValue )) != EOF ) {
530 in_count++;
531 fcode = (long) (((long) c << maxbits) + ent);
532 /* i = (((code_int)c << hshift) ~ ent); /* xor hashing */
533 i = (((code_int)c << hshift) ^ ent); /* xor hashing */
534 if ( HashTabOf (i) == fcode ) {
535 ent = CodeTabOf (i);
536 continue;
537 } else if ( (long)HashTabOf (i) < 0 ) /* empty slot */
538 goto nomatch;
539 disp = hsize_reg - i; /* secondary hash (after G. Knott) */
540 if ( i == 0 )
541 disp = 1;
542 probe:
543 if ( (i -= disp) < 0 )
544 i += hsize_reg;
545 if ( HashTabOf (i) == fcode ) {
546 ent = CodeTabOf (i);
547 continue;
548 }
549 if ( (long)HashTabOf (i) > 0 )
550 goto probe;
551 nomatch:
552 output ( (code_int) ent );
553 out_count++;
554 ent = c;
555 if ( free_ent < maxmaxcode ) {
556 CodeTabOf (i) = free_ent++; /* code -> hashtable */
557 HashTabOf (i) = fcode;
558 } else
559 cl_block();
560 }
561 /*
562 * Put out the final code.
563 */
564 output( (code_int)ent );
565 out_count++;
566 output( (code_int) EOFCode );
567 return;
568 }
569
570 /*****************************************************************
571 * TAG( output )
572 *
573 * Output the given code.
574 * Inputs:
575 * code: A n_bits-bit integer. If == -1, then EOF. This assumes
576 * that n_bits =< (long)wordsize - 1.
577 * Outputs:
578 * Outputs code to the file.
579 * Assumptions:
580 * Chars are 8 bits long.
581 * Algorithm:
582 * Maintain a CBITS character long buffer (so that 8 codes will
583 * fit in it exactly). Use the VAX insv instruction to insert each
584 * code in turn. When the buffer fills up empty it and start over.
585 */
586
587 unsigned long masks[] = { 0x0000, 0x0001, 0x0003, 0x0007, 0x000F,
588 0x001F, 0x003F, 0x007F, 0x00FF,
589 0x01FF, 0x03FF, 0x07FF, 0x0FFF,
590 0x1FFF, 0x3FFF, 0x7FFF, 0xFFFF };
591
592 output( code )
593 code_int code;
594 {
595 cur_accum &= masks[ cur_bits ];
596 if( cur_bits > 0 )
597 cur_accum |= ((long)code << cur_bits);
598 else
599 cur_accum = code;
600 cur_bits += n_bits;
601 while( cur_bits >= 8 ) {
602 char_out( (unsigned int)(cur_accum & 0xff) );
603 cur_accum >>= 8;
604 cur_bits -= 8;
605 }
606
607 /*
608 * If the next entry is going to be too big for the code size,
609 * then increase it, if possible.
610 */
611 if ( free_ent > maxcode || clear_flg ) {
612 if( clear_flg ) {
613 maxcode = MAXCODE (n_bits = g_init_bits);
614 clear_flg = 0;
615 } else {
616 n_bits++;
617 if ( n_bits == maxbits )
618 maxcode = maxmaxcode;
619 else
620 maxcode = MAXCODE(n_bits);
621 }
622 }
623 if( code == EOFCode ) {
624 /*
625 * At EOF, write the rest of the buffer.
626 */
627 while( cur_bits > 0 ) {
628 char_out( (unsigned int)(cur_accum & 0xff) );
629 cur_accum >>= 8;
630 cur_bits -= 8;
631 }
632 flush_char();
633 fflush( g_outfile );
634 if( ferror( g_outfile ) )
635 writeerr();
636 }
637 }
638
639 /*
640 * Clear out the hash table
641 */
642 cl_block () /* table clear for block compress */
643 {
644 cl_hash ( (count_int) hsize );
645 free_ent = ClearCode + 2;
646 clear_flg = 1;
647 output( (code_int)ClearCode );
648 }
649
650 cl_hash(hsize) /* reset code table */
651 register count_int hsize;
652 {
653 register count_int *htab_p = htab+hsize;
654 register long i;
655 register long m1 = -1;
656
657 i = hsize - 16;
658 do { /* might use Sys V memset(3) here */
659 *(htab_p-16) = m1;
660 *(htab_p-15) = m1;
661 *(htab_p-14) = m1;
662 *(htab_p-13) = m1;
663 *(htab_p-12) = m1;
664 *(htab_p-11) = m1;
665 *(htab_p-10) = m1;
666 *(htab_p-9) = m1;
667 *(htab_p-8) = m1;
668 *(htab_p-7) = m1;
669 *(htab_p-6) = m1;
670 *(htab_p-5) = m1;
671 *(htab_p-4) = m1;
672 *(htab_p-3) = m1;
673 *(htab_p-2) = m1;
674 *(htab_p-1) = m1;
675 htab_p -= 16;
676 } while ((i -= 16) >= 0);
677 for ( i += 16; i > 0; i-- )
678 *--htab_p = m1;
679 }
680
681 writeerr()
682 {
683 printf( "error writing output file\n" );
684 exit(1);
685 }
686
687 /******************************************************************************
688 *
689 * GIF Specific routines
690 *
691 ******************************************************************************/
692
693 /*
694 * Number of characters so far in this 'packet'
695 */
696 int a_count;
697
698 /*
699 * Set up the 'byte output' routine
700 */
701 char_init()
702 {
703 a_count = 0;
704 }
705
706 /*
707 * Define the storage for the packet accumulator
708 */
709 char accum[256];
710
711 /*
712 * Add a character to the end of the current packet, and if it is 254
713 * characters, flush the packet to disk.
714 */
715 char_out( c )
716 int c;
717 {
718 accum[ a_count++ ] = c;
719 if( a_count >= 254 )
720 flush_char();
721 }
722
723 /*
724 * Flush the packet to disk, and reset the accumulator
725 */
726 flush_char()
727 {
728 if( a_count > 0 ) {
729 fputc( a_count, g_outfile );
730 fwrite( accum, 1, a_count, g_outfile );
731 a_count = 0;
732 }
733 }
734
735 static float curgamma;
736 static short gamtab[256];
737
738 gammawarp(sbuf,gam,n)
739 short *sbuf;
740 float gam;
741 int n;
742 {
743 int i;
744 float f;
745
746 if(gam!=curgamma) {
747 for(i=0; i<256; i++)
748 gamtab[i] = 255*pow(i/255.0,gam)+0.5;
749 curgamma = gam;
750 }
751 while(n--) {
752 *sbuf = gamtab[*sbuf];
753 sbuf++;
754 }
755 }
