root/radiance/src/px/ra_bmp.c
Revision: 2.12
Committed: Thu Aug 2 18:33:46 2018 UTC (7 years, 3 months ago) by greg
2 static const char RCSid[] = "$Id: ra_bmp.c,v 2.11 2011/05/20 02:06:39 greg Exp $";
5 * program to convert between RADIANCE and Windows BMP file
6 */
7
8 #include <stdio.h>
9 #include <math.h>
10 #include <string.h>
11
12 #include "platform.h"
13 #include "color.h"
14 #include "tonemap.h"
15 #include "resolu.h"
16 #include "bmpfile.h"
17
18 int bradj = 0; /* brightness adjustment */
19
20 double gamcor = 2.2; /* gamma correction value */
21
22 char *progname;
23
24 static void quiterr(const char *err);
25 static void tmap2bmp(char *fnin, char *fnout, char *expec,
26 RGBPRIMP monpri, double gamval);
27 static void rad2bmp(FILE *rfp, BMPWriter *bwr, int inv, RGBPRIMP monpri);
28 static void bmp2rad(BMPReader *brd, FILE *rfp, int inv);
29
30 static RGBPRIMP rgbinp = stdprims; /* RGB input primitives */
31 static RGBPRIMS myinprims; /* custom primitives holder */
32
33 static gethfunc headline;
34
35
36 int
37 main(int argc, char *argv[])
38 {
39 char *inpfile=NULL, *outfile=NULL;
40 char *expec = NULL;
41 int reverse = 0;
42 RGBPRIMP rgbp = stdprims;
43 RGBPRIMS myprims;
44 RESOLU rs;
45 int i;
46
47 progname = argv[0];
48
49 for (i = 1; i < argc; i++)
50 if (argv[i][0] == '-' && argv[i][1])
51 switch (argv[i][1]) {
52 case 'b':
53 rgbp = NULL;
54 break;
55 case 'g':
56 gamcor = atof(argv[++i]);
57 break;
58 case 'e':
59 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
60 expec = argv[++i];
61 else
62 bradj = atoi(argv[++i]);
63 break;
64 case 'p':
65 if (argc-i < 9)
66 goto userr;
67 myprims[RED][CIEX] = atof(argv[++i]);
68 myprims[RED][CIEY] = atof(argv[++i]);
69 myprims[GRN][CIEX] = atof(argv[++i]);
70 myprims[GRN][CIEY] = atof(argv[++i]);
71 myprims[BLU][CIEX] = atof(argv[++i]);
72 myprims[BLU][CIEY] = atof(argv[++i]);
73 myprims[WHT][CIEX] = atof(argv[++i]);
74 myprims[WHT][CIEY] = atof(argv[++i]);
75 if (rgbp == stdprims)
76 rgbp = myprims;
77 break;
78 case 'r':
79 reverse = !reverse;
80 break;
81 default:
82 goto userr;
83 }
84 else
85 break;
86
87 if (i < argc-2)
88 goto userr;
89
90 SET_FILE_BINARY(stdin);
91 SET_FILE_BINARY(stdout);
92 SET_DEFAULT_BINARY();
93
94 if (i <= argc-1 && strcmp(argv[i], "-"))
95 inpfile = argv[i];
96
97 if (i == argc-2 && strcmp(argv[i+1], "-"))
98 outfile = argv[i+1];
99 /* check for tone-mapping */
100 if (expec != NULL) {
101 if (reverse)
102 goto userr;
103 tmap2bmp(inpfile, outfile, expec, rgbp, gamcor);
104 return(0);
105 }
106
107 setcolrgam(gamcor); /* set up conversion */
108
109 if (reverse) {
110 BMPReader *rdr;
111 /* open BMP file or stream */
112 if (inpfile != NULL)
113 rdr = BMPopenInputFile(inpfile);
114 else
115 rdr = BMPopenInputStream(stdin);
116
117 if (rdr == NULL) {
118 fprintf(stderr, "%s: cannot open or recognize BMP\n",
119 inpfile != NULL ? inpfile : "<stdin>");
120 exit(1);
121 }
122 /* open Radiance output */
123 if (outfile != NULL && freopen(outfile, "w", stdout) == NULL) {
124 fprintf(stderr, "%s: cannot open for output\n",
125 outfile);
126 exit(1);
127 }
128 /* put Radiance header */
129 newheader("RADIANCE", stdout);
130 printargs(i, argv, stdout);
131 fputformat(COLRFMT, stdout);
132 putchar('\n');
133 rs.xr = rdr->hdr->width;
134 rs.yr = rdr->hdr->height;
135 rs.rt = YMAJOR;
136 /* write scans downward if we can */
137 if (rdr->hdr->yIsDown || inpfile != NULL)
138 rs.rt |= YDECR;
139 fputsresolu(&rs, stdout);
140 /* convert file */
141 bmp2rad(rdr, stdout, !rdr->hdr->yIsDown && inpfile!=NULL);
142 /* flush output */
143 BMPcloseInput(rdr);
144 if (fflush(stdout) < 0)
145 quiterr("error writing Radiance output");
146 } else {
147 BMPHeader *hdr;
148 BMPWriter *wtr;
149 /* open Radiance input */
150 if (inpfile != NULL && freopen(inpfile, "r", stdin) == NULL) {
151 fprintf(stderr, "%s: cannot open input file\n",
152 inpfile);
153 exit(1);
154 }
155 /* get header info. */
156 if (getheader(stdin, headline, NULL) < 0 ||
157 !fgetsresolu(&rs, stdin))
158 quiterr("bad Radiance picture format");
159 /* initialize BMP header */
160 if (rgbp == NULL) {
161 hdr = BMPmappedHeader(scanlen(&rs),
162 numscans(&rs), 0, 256);
163 /*
164 if (outfile != NULL)
165 hdr->compr = BI_RLE8;
166 */
167 } else
168 hdr = BMPtruecolorHeader(scanlen(&rs),
169 numscans(&rs), 0);
170 if (hdr == NULL)
171 quiterr("cannot initialize BMP header");
172 /* set up output direction */
173 hdr->yIsDown = ((outfile == NULL) | (hdr->compr == BI_RLE8));
174 /* open BMP output */
175 if (outfile != NULL)
176 wtr = BMPopenOutputFile(outfile, hdr);
177 else
178 wtr = BMPopenOutputStream(stdout, hdr);
179 if (wtr == NULL)
180 quiterr("cannot allocate writer structure");
181 /* convert file */
182 rad2bmp(stdin, wtr, !hdr->yIsDown, rgbp);
183 /* flush output */
184 if (fflush((FILE *)wtr->c_data) < 0)
185 quiterr("error writing BMP output");
186 BMPcloseOutput(wtr);
187 }
188 return(0); /* success */
189 userr:
190 fprintf(stderr,
191 "Usage: %s [-b][-g gamma][-e spec][-p xr yr xg yg xb yb xw yw] [input|- [output]]\n",
192 progname);
193 fprintf(stderr,
194 " or: %s -r [-g gamma][-e +/-stops] [input|- [output]]\n",
195 progname);
196 return(1);
197 }
198
199 /* print message and exit */
200 static void
201 quiterr(const char *err)
202 {
203 if (err != NULL) {
204 fprintf(stderr, "%s: %s\n", progname, err);
205 exit(1);
206 }
207 exit(0);
208 }
209
210 /* process header line (don't echo) */
211 static int
212 headline(char *s, void *p)
213 {
214 char fmt[MAXFMTLEN];
215
216 if (formatval(fmt, s)) { /* check if format string */
217 if (!strcmp(fmt,COLRFMT))
218 return(0);
219 if (!strcmp(fmt,CIEFMT)) {
220 rgbinp = TM_XYZPRIM;
221 return(0);
222 }
223 return(-1);
224 }
225 if (isprims(s)) { /* get input primaries */
226 primsval(myinprims, s);
227 rgbinp = myinprims;
228 return(0);
229 }
230 /* should I grok colcorr also? */
231 return(0);
232 }
233
234
235 /* convert Radiance picture to BMP */
236 static void
237 rad2bmp(FILE *rfp, BMPWriter *bwr, int inv, RGBPRIMP monpri)
238 {
239 int usexfm = 0;
240 COLORMAT xfm;
241 COLR *scanin;
242 COLOR cval;
243 int y, yend, ystp;
244 int x;
245 /* allocate scanline */
246 scanin = (COLR *)malloc(bwr->hdr->width*sizeof(COLR));
247 if (scanin == NULL)
248 quiterr("out of memory in rad2bmp");
249 /* set up color conversion */
250 usexfm = (monpri != NULL ? rgbinp != monpri :
251 rgbinp != TM_XYZPRIM && rgbinp != stdprims);
252 if (usexfm) {
253 double expcomp = pow(2.0, (double)bradj);
254 if (rgbinp == TM_XYZPRIM)
255 compxyz2rgbWBmat(xfm, monpri);
256 else
257 comprgb2rgbWBmat(xfm, rgbinp, monpri);
258 for (y = 0; y < 3; y++)
259 for (x = 0; x < 3; x++)
260 xfm[y][x] *= expcomp;
261 }
262 /* convert image */
263 if (inv) {
264 y = bwr->hdr->height - 1;
265 ystp = -1; yend = -1;
266 } else {
267 y = 0;
268 ystp = 1; yend = bwr->hdr->height;
269 }
270 /* convert each scanline */
271 for ( ; y != yend; y += ystp) {
272 if (freadcolrs(scanin, bwr->hdr->width, rfp) < 0)
273 quiterr("error reading Radiance picture");
274 if (usexfm)
275 for (x = bwr->hdr->width; x--; ) {
276 colr_color(cval, scanin[x]);
277 colortrans(cval, xfm, cval);
278 setcolr(scanin[x], colval(cval,RED),
279 colval(cval,GRN),
280 colval(cval,BLU));
281 }
282 else if (bradj)
283 shiftcolrs(scanin, bwr->hdr->width, bradj);
284 if (monpri == NULL && rgbinp != TM_XYZPRIM)
285 for (x = bwr->hdr->width; x--; )
286 scanin[x][GRN] = normbright(scanin[x]);
287 colrs_gambs(scanin, bwr->hdr->width);
288 if (monpri == NULL)
289 for (x = bwr->hdr->width; x--; )
290 bwr->scanline[x] = scanin[x][GRN];
291 else
292 for (x = bwr->hdr->width; x--; ) {
293 bwr->scanline[3*x] = scanin[x][BLU];
294 bwr->scanline[3*x+1] = scanin[x][GRN];
295 bwr->scanline[3*x+2] = scanin[x][RED];
296 }
297 bwr->yscan = y;
298 x = BMPwriteScanline(bwr);
299 if (x != BIR_OK)
300 quiterr(BMPerrorMessage(x));
301 }
302 /* free scanline */
303 free((void *)scanin);
304 }
305
306 /* convert BMP file to Radiance */
307 static void
308 bmp2rad(BMPReader *brd, FILE *rfp, int inv)
309 {
310 COLR *scanout;
311 int y, yend, ystp;
312 int x;
313 /* allocate scanline */
314 scanout = (COLR *)malloc(brd->hdr->width*sizeof(COLR));
315 if (scanout == NULL)
316 quiterr("out of memory in bmp2rad");
317 /* convert image */
318 if (inv) {
319 y = brd->hdr->height - 1;
320 ystp = -1; yend = -1;
321 } else {
322 y = 0;
323 ystp = 1; yend = brd->hdr->height;
324 }
325 /* convert each scanline */
326 for ( ; y != yend; y += ystp) {
327 x = BMPseekScanline(y, brd);
328 if (x != BIR_OK)
329 quiterr(BMPerrorMessage(x));
330 for (x = brd->hdr->width; x--; ) {
331 RGBquad rgbq = BMPdecodePixel(x, brd);
332 scanout[x][RED] = rgbq.r;
333 scanout[x][GRN] = rgbq.g;
334 scanout[x][BLU] = rgbq.b;
335 }
336 gambs_colrs(scanout, brd->hdr->width);
337 if (bradj)
338 shiftcolrs(scanout, brd->hdr->width, bradj);
339 if (fwritecolrs(scanout, brd->hdr->width, rfp) < 0)
340 quiterr("error writing Radiance picture");
341 }
342 /* clean up */
343 free((void *)scanout);
344 }
345
346 /* Tone-map and convert Radiance picture */
347 static void
348 tmap2bmp(char *fnin, char *fnout, char *expec, RGBPRIMP monpri, double gamval)
349 {
350 int tmflags;
351 BMPHeader *hdr;
352 BMPWriter *wtr;
353 FILE *fp;
354 int xr, yr;
355 uby8 *pa;
356 int i;
357 /* check tone-mapping spec */
358 i = strlen(expec);
359 if (i && !strncmp(expec, "auto", i))
360 tmflags = TM_F_CAMERA;
361 else if (i && !strncmp(expec, "human", i))
362 tmflags = TM_F_HUMAN & ~TM_F_UNIMPL;
363 else if (i && !strncmp(expec, "linear", i))
364 tmflags = TM_F_LINEAR;
365 else
366 quiterr("illegal exposure specification (auto|human|linear)");
367 if (monpri == NULL) {
368 tmflags |= TM_F_BW;
369 monpri = stdprims;
370 }
371 /* open Radiance input */
372 if (fnin == NULL)
373 fp = stdin;
374 else if ((fp = fopen(fnin, "r")) == NULL) {
375 fprintf(stderr, "%s: cannot open\n", fnin);
376 exit(1);
377 }
378 /* tone-map picture */
379 if (tmMapPicture(&pa, &xr, &yr, tmflags, monpri, gamval,
380 0., 0., fnin, fp) != TM_E_OK)
381 exit(1);
382 /* initialize BMP header */
383 if (tmflags & TM_F_BW) {
384 hdr = BMPmappedHeader(xr, yr, 0, 256);
385 if (fnout != NULL)
386 hdr->compr = BI_RLE8;
387 } else
388 hdr = BMPtruecolorHeader(xr, yr, 0);
389 if (hdr == NULL)
390 quiterr("cannot initialize BMP header");
391 /* open BMP output */
392 if (fnout != NULL)
393 wtr = BMPopenOutputFile(fnout, hdr);
394 else
395 wtr = BMPopenOutputStream(stdout, hdr);
396 if (wtr == NULL)
397 quiterr("cannot allocate writer structure");
398 /* write to BMP file */
399 while (wtr->yscan < yr) {
400 uby8 *scn = pa + xr*((tmflags & TM_F_BW) ? 1 : 3)*
401 (yr-1 - wtr->yscan);
402 if (tmflags & TM_F_BW)
403 memcpy((void *)wtr->scanline, (void *)scn, xr);
404 else
405 for (i = xr; i--; ) {
406 wtr->scanline[3*i] = scn[3*i+BLU];
407 wtr->scanline[3*i+1] = scn[3*i+GRN];
408 wtr->scanline[3*i+2] = scn[3*i+RED];
409 }
410 if ((i = BMPwriteScanline(wtr)) != BIR_OK)
411 quiterr(BMPerrorMessage(i));
412 }
413 /* flush output */
414 if (fflush((FILE *)wtr->c_data) < 0)
415 quiterr("error writing BMP output");
416 /* clean up */
417 if (fnin != NULL)
418 fclose(fp);
419 free((void *)pa);
420 BMPcloseOutput(wtr);
421 }
