root/radiance/src/px/ra_bmp.c
Sun Sep 14 17:11:29 2025 UTC (4 weeks, 2 days ago) by greg
Changes since 2.19: +6 -7 lines
Diff to previous 2.19 , to selected 2.13
fix(ra_bmp): Minor fix -- don't save PRIMARIES for grayscale
Sun Sep 14 15:08:26 2025 UTC (4 weeks, 2 days ago) by greg
Changes since 2.18: +9 -7 lines
Diff to previous 2.18 , to selected 2.13
perf(ra_bmp): Minor tweaks on last change
Sun Sep 14 04:39:53 2025 UTC (4 weeks, 3 days ago) by greg
Changes since 2.17: +134 -37 lines
Diff to previous 2.17 , to selected 2.13
feat(ra_bmp): Added metadata handling and i/o
Sat Jun 7 05:09:46 2025 UTC (4 months, 1 week ago) by greg
CVS Tags: rad6R0
Changes since 2.16: +1 -2 lines
Diff to previous 2.16 , to selected 2.13
Fri Jun 6 19:11:21 2025 UTC (4 months, 1 week ago) by greg
Changes since 2.15: +3 -4 lines
Diff to previous 2.15 , to selected 2.13
refactor: Making use of printargs() more consistent with fixargv0()
Tue Sep 10 20:24:42 2024 UTC (13 months ago) by greg
Changes since 2.14: +12 -2 lines
feat(ra_bmp,ra_rgbe,ximage): Added quick conversion of spectral inputs to RGB
Sun Apr 5 19:10:51 2020 UTC (5 years, 6 months ago) by greg
CVS Tags: rad5R3, rad5R4
Changes since 2.13: +5 -4 lines
Diff to previous 2.13
Fixed segmentation error with -b on input with color primaries
Revision 2.13 - (view) (download) (annotate) - [selected]
Fri Jul 19 17:37:56 2019 UTC (6 years, 2 months ago) by greg
Changes since 2.12: +2 -3 lines
Diff to previous 2.12
Thu Aug 2 18:33:46 2018 UTC (7 years, 2 months ago) by greg
Fri May 20 02:06:39 2011 UTC (14 years, 5 months ago) by greg
Mon Oct 4 17:44:22 2004 UTC (21 years ago) by greg
Changes since 2.9: +3 -1 lines
Thu Sep 23 18:00:54 2004 UTC (21 years ago) by greg
Changes since 2.8: +68 -12 lines
Tue Jul 20 03:08:42 2004 UTC (21 years, 3 months ago) by greg
Changes since 2.7: +3 -9 lines
Eliminated unnecessary file chaecking in tmap2bmp()
Fri Apr 30 21:16:58 2004 UTC (21 years, 5 months ago) by greg
Changes since 2.6: +4 -7 lines
Fixed inconsistent behavior with inverted Radiance pictures
Fri Apr 30 17:56:06 2004 UTC (21 years, 5 months ago) by greg
Changes since 2.5: +2 -4 lines
Fixed - option for reading from stdin
Fri Apr 30 17:30:33 2004 UTC (21 years, 5 months ago) by greg
Changes since 2.4: +3 -2 lines
Fixed minor problem with RLE8 output
Fri Apr 30 17:00:29 2004 UTC (21 years, 5 months ago) by greg
Changes since 2.3: +132 -19 lines
Sun Mar 28 20:33:14 2004 UTC (21 years, 6 months ago) by schorsch
Changes since 2.2: +10 -8 lines
Sat Mar 27 05:43:37 2004 UTC (21 years, 6 months ago) by greg
Changes since 2.1: +14 -7 lines
Bug fixes in run-length encoding code
Fri Mar 26 03:11:50 2004 UTC (21 years, 6 months ago) by greg
Diff to selected 2.13
