root/radiance/src/px/pvalue.c
Revision: 2.25
Committed: Fri Jan 2 12:47:01 2004 UTC (21 years, 9 months ago) by schorsch
Changes since 2.24: +9 -5 lines
2 static const char RCSid[] = "$Id: pvalue.c,v 2.24 2003/10/22 02:06:35 greg Exp $";
5 * pvalue.c - program to print pixel values.
6 *
7 * 4/23/86
8 */
9
10 #include "platform.h"
11 #include "standard.h"
12 #include "color.h"
13 #include "resolu.h"
14
15 #define min(a,b) ((a)<(b)?(a):(b))
16
17 /* what to put out (also RED, GRN, BLU) */
18 #define ALL 3
19 #define BRIGHT 4
20
21 RESOLU picres; /* resolution of picture */
22
23 int uniq = 0; /* print only unique values? */
24
25 int doexposure = 0; /* exposure change? (>100 to print) */
26
27 int dataonly = 0; /* data only format? */
28
29 int putprim = ALL; /* what to put out */
30
31 int reverse = 0; /* reverse conversion? */
32
33 int format = 'a'; /* input/output format */
34 char *fmtid = "ascii"; /* format identifier for header */
35
36 int header = 1; /* do header? */
37
38 long skipbytes = 0; /* skip bytes in input? */
39
40 int swapbytes = 0; /* swap bytes? */
41
42 int interleave = 1; /* file is interleaved? */
43
44 int resolution = 1; /* put/get resolution string? */
45
46 int original = 0; /* convert to original values? */
47
48 int wrongformat = 0; /* wrong input format? */
49
50 double gamcor = 1.0; /* gamma correction */
51
52 int ord[3] = {RED, GRN, BLU}; /* RGB ordering */
53 int rord[4]; /* reverse ordering */
54
55 COLOR exposure = WHTCOLOR;
56
57 char *progname;
58
59 FILE *fin;
60 FILE *fin2 = NULL, *fin3 = NULL; /* for other color channels */
61
62 int (*getval)(), (*putval)();
63
64 static gethfunc checkhead;
65
66
67 double
68 rgb_bright(clr)
69 COLOR clr;
70 {
71 return(bright(clr));
72 }
73
74 double
75 xyz_bright(clr)
76 COLOR clr;
77 {
78 return(clr[CIEY]);
79 }
80
81 double (*mybright)() = &rgb_bright;
82
83
84 main(argc, argv)
85 int argc;
86 char **argv;
87 {
88 extern long atol();
89 double d, expval = 1.0;
90 int i;
91
92 progname = argv[0];
93
94 for (i = 1; i < argc; i++)
95 if (argv[i][0] == '-' || argv[i][0] == '+')
96 switch (argv[i][1]) {
97 case 'h': /* header */
98 header = argv[i][0] == '+';
99 break;
100 case 'H': /* resolution string */
101 resolution = argv[i][0] == '+';
102 break;
103 case 's': /* skip bytes in header */
104 skipbytes = atol(argv[++i]);
105 break;
106 case 'u': /* unique values */
107 uniq = argv[i][0] == '-';
108 break;
109 case 'o': /* original values */
110 original = argv[i][0] == '-';
111 break;
112 case 'g': /* gamma correction */
113 gamcor = atof(argv[i+1]);
114 if (argv[i][0] == '+')
115 gamcor = 1.0/gamcor;
116 i++;
117 break;
118 case 'e': /* exposure correction */
119 d = atof(argv[i+1]);
120 if (argv[i+1][0] == '-' || argv[i+1][0] == '+')
121 d = pow(2.0, d);
122 if (argv[i][0] == '-')
123 expval *= d;
124 scalecolor(exposure, d);
125 doexposure++;
126 i++;
127 break;
128 case 'R': /* reverse byte sequence */
129 if (argv[i][0] == '-') {
130 ord[0]=BLU; ord[1]=GRN; ord[2]=RED;
131 } else {
132 ord[0]=RED; ord[1]=GRN; ord[2]=BLU;
133 }
134 break;
135 case 'r': /* reverse conversion */
136 reverse = argv[i][0] == '-';
137 break;
138 case 'n': /* non-interleaved RGB */
139 interleave = argv[i][0] == '+';
140 break;
141 case 'b': /* brightness values */
142 putprim = argv[i][0] == '-' ? BRIGHT : ALL;
143 break;
144 case 'p': /* put primary */
145 switch (argv[i][2]) {
146 case 'r': case 'R': putprim = RED; break;
147 case 'g': case 'G': putprim = GRN; break;
148 case 'b': case 'B': putprim = BLU; break;
149 default: goto unkopt;
150 }
151 break;
152 case 'd': /* data only (no indices) */
153 dataonly = argv[i][0] == '-';
154 switch (argv[i][2]) {
155 case '\0':
156 case 'a': /* ascii */
157 format = 'a';
158 fmtid = "ascii";
159 break;
160 case 'i': /* integer */
161 format = 'i';
162 fmtid = "ascii";
163 break;
164 case 'b': /* byte */
165 dataonly = 1;
166 format = 'b';
167 fmtid = "byte";
168 break;
169 case 'W': /* 16-bit swapped */
170 swapbytes = 1;
171 case 'w': /* 16-bit */
172 dataonly = 1;
173 format = 'w';
174 fmtid = "16-bit";
175 break;
176 case 'F': /* swapped floats */
177 swapbytes = 1;
178 case 'f': /* float */
179 dataonly = 1;
180 format = 'f';
181 fmtid = "float";
182 break;
183 case 'D': /* swapped doubles */
184 swapbytes = 1;
185 case 'd': /* double */
186 dataonly = 1;
187 format = 'd';
188 fmtid = "double";
189 break;
190 default:
191 goto unkopt;
192 }
193 break;
194 case 'x': /* x resolution */
195 case 'X': /* x resolution */
196 resolution = 0;
197 if (argv[i][0] == '-')
198 picres.rt |= XDECR;
199 picres.xr = atoi(argv[++i]);
200 break;
201 case 'y': /* y resolution */
202 case 'Y': /* y resolution */
203 resolution = 0;
204 if (argv[i][0] == '-')
205 picres.rt |= YDECR;
206 if (picres.xr == 0)
207 picres.rt |= YMAJOR;
208 picres.yr = atoi(argv[++i]);
209 break;
210 default:
211 unkopt:
212 fprintf(stderr, "%s: unknown option: %s\n",
213 progname, argv[i]);
214 quit(1);
215 break;
216 }
217 else
218 break;
219 /* recognize special formats */
220 if (dataonly && format == 'b') {
221 if (putprim == ALL)
222 fmtid = "24-bit_rgb";
223 else
224 fmtid = "8-bit_grey";
225 }
226 if (dataonly && format == 'w') {
227 if (putprim == ALL)
228 fmtid = "48-bit_rgb";
229 else
230 fmtid = "16-bit_grey";
231 }
232 /* assign reverse ordering */
233 rord[ord[0]] = 0;
234 rord[ord[1]] = 1;
235 rord[ord[2]] = 2;
236 /* get input */
237 if (i == argc) {
238 fin = stdin;
239 } else if (i < argc) {
240 if ((fin = fopen(argv[i], "r")) == NULL) {
241 fprintf(stderr, "%s: can't open file \"%s\"\n",
242 progname, argv[i]);
243 quit(1);
244 }
245 if (reverse && putprim != BRIGHT && i == argc-3) {
246 if ((fin2 = fopen(argv[i+1], "r")) == NULL) {
247 fprintf(stderr, "%s: can't open file \"%s\"\n",
248 progname, argv[i+1]);
249 quit(1);
250 }
251 if ((fin3 = fopen(argv[i+2], "r")) == NULL) {
252 fprintf(stderr, "%s: can't open file \"%s\"\n",
253 progname, argv[i+2]);
254 quit(1);
255 }
256 interleave = -1;
257 } else if (i != argc-1)
258 fin = NULL;
259 if (reverse && putprim != BRIGHT && !interleave) {
260 fin2 = fopen(argv[i], "r");
261 fin3 = fopen(argv[i], "r");
262 }
263 if (skipbytes && (fseek(fin, skipbytes, 0) || (fin2 != NULL &&
264 (fseek(fin2, skipbytes, 0) ||
265 fseek(fin3, skipbytes, 0))))) {
266 fprintf(stderr, "%s: cannot skip %ld bytes on input\n",
267 progname, skipbytes);
268 quit(1);
269 }
270 }
271 if (fin == NULL) {
272 fprintf(stderr, "%s: bad # file arguments\n", progname);
273 quit(1);
274 }
275
276 if (reverse) {
277 #ifdef _WIN32
278 SET_FILE_BINARY(stdout);
279 if (format != 'a' && format != 'i')
280 SET_FILE_BINARY(fin);
281 #endif
282 /* get header */
283 if (header) {
284 if (checkheader(fin, fmtid, stdout) < 0) {
285 fprintf(stderr, "%s: wrong input format\n",
286 progname);
287 quit(1);
288 }
289 if (fin2 != NULL) {
290 getheader(fin2, NULL, NULL);
291 getheader(fin3, NULL, NULL);
292 }
293 } else
294 newheader("RADIANCE", stdout);
295 /* get resolution */
296 if ((resolution && !fgetsresolu(&picres, fin)) ||
297 picres.xr <= 0 || picres.yr <= 0) {
298 fprintf(stderr, "%s: missing resolution\n", progname);
299 quit(1);
300 }
301 if (resolution && fin2 != NULL) {
302 RESOLU pres2;
303 if (!fgetsresolu(&pres2, fin2) ||
304 pres2.rt != picres.rt ||
305 pres2.xr != picres.xr ||
306 pres2.yr != picres.yr ||
307 !fgetsresolu(&pres2, fin3) ||
308 pres2.rt != picres.rt ||
309 pres2.xr != picres.xr ||
310 pres2.yr != picres.yr) {
311 fprintf(stderr, "%s: resolution mismatch\n",
312 progname);
313 quit(1);
314 }
315 }
316 /* add to header */
317 printargs(i, argv, stdout);
318 if (expval < .99 || expval > 1.01)
319 fputexpos(expval, stdout);
320 fputformat(COLRFMT, stdout);
321 putchar('\n');
322 fputsresolu(&picres, stdout); /* always put resolution */
323 valtopix();
324 } else {
325 #ifdef _WIN32
326 SET_FILE_BINARY(fin);
327 if (format != 'a' && format != 'i')
328 SET_FILE_BINARY(stdout);
329 #endif
330 /* get header */
331 getheader(fin, checkhead, NULL);
332 if (wrongformat) {
333 fprintf(stderr,
334 "%s: input not a Radiance RGBE picture\n",
335 progname);
336 quit(1);
337 }
338 if (!fgetsresolu(&picres, fin)) {
339 fprintf(stderr, "%s: missing resolution\n", progname);
340 quit(1);
341 }
342 if (header) {
343 printargs(i, argv, stdout);
344 if (expval < .99 || expval > 1.01)
345 fputexpos(expval, stdout);
346 fputformat(fmtid, stdout);
347 putchar('\n');
348 }
349 if (resolution) /* put resolution */
350 fputsresolu(&picres, stdout);
351 pixtoval();
352 }
353
354 quit(0);
355 }
356
357
358 static int
359 checkhead( /* deal with line from header */
360 char *line,
361 void *p
362 )
363 {
364 char fmt[32];
365 double d;
366 COLOR ctmp;
367
368 if (formatval(fmt, line)) {
369 if (!strcmp(fmt, CIEFMT)) {
370 mybright = &xyz_bright;
371 if (original) {
372 scalecolor(exposure, 1./WHTEFFICACY);
373 doexposure++;
374 }
375 } else if (!strcmp(fmt, COLRFMT))
376 mybright = &rgb_bright;
377 else
378 wrongformat++;
379 } else if (original && isexpos(line)) {
380 d = 1.0/exposval(line);
381 scalecolor(exposure, d);
382 doexposure++;
383 } else if (original && iscolcor(line)) {
384 colcorval(ctmp, line);
385 setcolor(exposure, colval(exposure,RED)/colval(ctmp,RED),
386 colval(exposure,GRN)/colval(ctmp,GRN),
387 colval(exposure,BLU)/colval(ctmp,BLU));
388 doexposure++;
389 } else if (header)
390 fputs(line, stdout);
391 return(0);
392 }
393
394
395 pixtoval() /* convert picture to values */
396 {
397 register COLOR *scanln;
398 int dogamma;
399 COLOR lastc;
400 RREAL hv[2];
401 int startprim, endprim;
402 long startpos;
403 int y;
404 register int x;
405
406 scanln = (COLOR *)malloc(scanlen(&picres)*sizeof(COLOR));
407 if (scanln == NULL) {
408 fprintf(stderr, "%s: out of memory\n", progname);
409 quit(1);
410 }
411 dogamma = gamcor < .95 || gamcor > 1.05;
412 if (putprim == ALL && !interleave) {
413 startprim = RED; endprim = BLU;
414 startpos = ftell(fin);
415 } else {
416 startprim = putprim; endprim = putprim;
417 }
418 for (putprim = startprim; putprim <= endprim; putprim++) {
419 if (putprim != startprim && fseek(fin, startpos, 0)) {
420 fprintf(stderr, "%s: seek error on input file\n",
421 progname);
422 quit(1);
423 }
424 set_io();
425 setcolor(lastc, 0.0, 0.0, 0.0);
426 for (y = 0; y < numscans(&picres); y++) {
427 if (freadscan(scanln, scanlen(&picres), fin) < 0) {
428 fprintf(stderr, "%s: read error\n", progname);
429 quit(1);
430 }
431 for (x = 0; x < scanlen(&picres); x++) {
432 if (uniq) {
433 if ( colval(scanln[x],RED) ==
434 colval(lastc,RED) &&
435 colval(scanln[x],GRN) ==
436 colval(lastc,GRN) &&
437 colval(scanln[x],BLU) ==
438 colval(lastc,BLU) )
439 continue;
440 else
441 copycolor(lastc, scanln[x]);
442 }
443 if (doexposure)
444 multcolor(scanln[x], exposure);
445 if (dogamma)
446 setcolor(scanln[x],
447 pow(colval(scanln[x],RED), 1.0/gamcor),
448 pow(colval(scanln[x],GRN), 1.0/gamcor),
449 pow(colval(scanln[x],BLU), 1.0/gamcor));
450 if (!dataonly) {
451 pix2loc(hv, &picres, x, y);
452 printf("%7d %7d ",
453 (int)(hv[0]*picres.xr),
454 (int)(hv[1]*picres.yr));
455 }
456 if ((*putval)(scanln[x]) < 0) {
457 fprintf(stderr, "%s: write error\n",
458 progname);
459 quit(1);
460 }
461 }
462 }
463 }
464 free((void *)scanln);
465 }
466
467
468 valtopix() /* convert values to a pixel file */
469 {
470 int dogamma;
471 register COLOR *scanln;
472 int y;
473 register int x;
474
475 scanln = (COLOR *)malloc(scanlen(&picres)*sizeof(COLOR));
476 if (scanln == NULL) {
477 fprintf(stderr, "%s: out of memory\n", progname);
478 quit(1);
479 }
480 dogamma = gamcor < .95 || gamcor > 1.05;
481 set_io();
482 for (y = 0; y < numscans(&picres); y++) {
483 for (x = 0; x < scanlen(&picres); x++) {
484 if (!dataonly) {
485 fscanf(fin, "%*d %*d");
486 if (fin2 != NULL) {
487 fscanf(fin2, "%*d %*d");
488 fscanf(fin3, "%*d %*d");
489 }
490 }
491 if ((*getval)(scanln[x]) < 0) {
492 fprintf(stderr, "%s: read error\n", progname);
493 quit(1);
494 }
495 if (dogamma)
496 setcolor(scanln[x],
497 pow(colval(scanln[x],RED), gamcor),
498 pow(colval(scanln[x],GRN), gamcor),
499 pow(colval(scanln[x],BLU), gamcor));
500 if (doexposure)
501 multcolor(scanln[x], exposure);
502 }
503 if (fwritescan(scanln, scanlen(&picres), stdout) < 0) {
504 fprintf(stderr, "%s: write error\n", progname);
505 quit(1);
506 }
507 }
508 free((void *)scanln);
509 }
510
511
512 void
513 quit(code)
514 int code;
515 {
516 exit(code);
517 }
518
519
520 swap16(wp, n) /* swap n 16-bit words */
521 register uint16 *wp;
522 int n;
523 {
524 while (n-- > 0) {
525 *wp = *wp << 8 | ((*wp >> 8) & 0xff);
526 wp++;
527 }
528 }
529
530
531 swap32(wp, n) /* swap n 32-bit words */
532 register uint32 *wp;
533 int n;
534 {
535 while (n-- > 0) {
536 *wp = *wp << 24 | ((*wp >> 24) & 0xff) |
537 (*wp & 0xff00) << 8 | (*wp & 0xff0000) >> 8;
538 wp++;
539 }
540 }
541
542
543 swap64(wp, n) /* swap n 64-bit words */
544 register char *wp;
545 int n;
546 {
547 register int t;
548
549 while (n-- > 0) {
550 t = wp[0]; wp[0] = wp[7]; wp[7] = t;
551 t = wp[1]; wp[1] = wp[6]; wp[6] = t;
552 t = wp[2]; wp[2] = wp[5]; wp[5] = t;
553 t = wp[3]; wp[3] = wp[4]; wp[4] = t;
554 wp += 8;
555 }
556 }
557
558
559 getcascii(col) /* get an ascii color value from stream(s) */
560 COLOR col;
561 {
562 double vd[3];
563
564 if (fin2 == NULL) {
565 if (fscanf(fin, "%lf %lf %lf", &vd[0], &vd[1], &vd[2]) != 3)
566 return(-1);
567 } else {
568 if (fscanf(fin, "%lf", &vd[0]) != 1 ||
569 fscanf(fin2, "%lf", &vd[1]) != 1 ||
570 fscanf(fin3, "%lf", &vd[2]) != 1)
571 return(-1);
572 }
573 setcolor(col, vd[rord[RED]], vd[rord[GRN]], vd[rord[BLU]]);
574 return(0);
575 }
576
577
578 getcdouble(col) /* get a double color value from stream(s) */
579 COLOR col;
580 {
581 double vd[3];
582
583 if (fin2 == NULL) {
584 if (fread((char *)vd, sizeof(double), 3, fin) != 3)
585 return(-1);
586 } else {
587 if (fread((char *)vd, sizeof(double), 1, fin) != 1 ||
588 fread((char *)(vd+1), sizeof(double), 1, fin2) != 1 ||
589 fread((char *)(vd+2), sizeof(double), 1, fin3) != 1)
590 return(-1);
591 }
592 if (swapbytes)
593 swap64((char *)vd, 3);
594 setcolor(col, vd[rord[RED]], vd[rord[GRN]], vd[rord[BLU]]);
595 return(0);
596 }
597
598
599 getcfloat(col) /* get a float color value from stream(s) */
600 COLOR col;
601 {
602 float vf[3];
603
604 if (fin2 == NULL) {
605 if (fread((char *)vf, sizeof(float), 3, fin) != 3)
606 return(-1);
607 } else {
608 if (fread((char *)vf, sizeof(float), 1, fin) != 1 ||
609 fread((char *)(vf+1), sizeof(float), 1, fin2) != 1 ||
610 fread((char *)(vf+2), sizeof(float), 1, fin3) != 1)
611 return(-1);
612 }
613 if (swapbytes)
614 swap32((uint32 *)vf, 3);
615 setcolor(col, vf[rord[RED]], vf[rord[GRN]], vf[rord[BLU]]);
616 return(0);
617 }
618
619
620 getcint(col) /* get an int color value from stream(s) */
621 COLOR col;
622 {
623 int vi[3];
624
625 if (fin2 == NULL) {
626 if (fscanf(fin, "%d %d %d", &vi[0], &vi[1], &vi[2]) != 3)
627 return(-1);
628 } else {
629 if (fscanf(fin, "%d", &vi[0]) != 1 ||
630 fscanf(fin2, "%d", &vi[1]) != 1 ||
631 fscanf(fin3, "%d", &vi[2]) != 1)
632 return(-1);
633 }
634 setcolor(col, (vi[rord[RED]]+.5)/256.,
635 (vi[rord[GRN]]+.5)/256., (vi[rord[BLU]]+.5)/256.);
636 return(0);
637 }
638
639
640 getcbyte(col) /* get a byte color value from stream(s) */
641 COLOR col;
642 {
643 BYTE vb[3];
644
645 if (fin2 == NULL) {
646 if (fread((char *)vb, sizeof(BYTE), 3, fin) != 3)
647 return(-1);
648 } else {
649 if (fread((char *)vb, sizeof(BYTE), 1, fin) != 1 ||
650 fread((char *)(vb+1), sizeof(BYTE), 1, fin2) != 1 ||
651 fread((char *)(vb+2), sizeof(BYTE), 1, fin3) != 1)
652 return(-1);
653 }
654 setcolor(col, (vb[rord[RED]]+.5)/256.,
655 (vb[rord[GRN]]+.5)/256., (vb[rord[BLU]]+.5)/256.);
656 return(0);
657 }
658
659
660 getcword(col) /* get a 16-bit color value from stream(s) */
661 COLOR col;
662 {
663 uint16 vw[3];
664
665 if (fin2 == NULL) {
666 if (fread((char *)vw, sizeof(uint16), 3, fin) != 3)
667 return(-1);
668 } else {
669 if (fread((char *)vw, sizeof(uint16), 1, fin) != 1 ||
670 fread((char *)(vw+1), sizeof(uint16), 1, fin2) != 1 ||
671 fread((char *)(vw+2), sizeof(uint16), 1, fin3) != 1)
672 return(-1);
673 }
674 if (swapbytes)
675 swap16(vw, 3);
676 setcolor(col, (vw[rord[RED]]+.5)/65536.,
677 (vw[rord[GRN]]+.5)/65536., (vw[rord[BLU]]+.5)/65536.);
678 return(0);
679 }
680
681
682 getbascii(col) /* get an ascii brightness value from fin */
683 COLOR col;
684 {
685 double vd;
686
687 if (fscanf(fin, "%lf", &vd) != 1)
688 return(-1);
689 setcolor(col, vd, vd, vd);
690 return(0);
691 }
692
693
694 getbdouble(col) /* get a double brightness value from fin */
695 COLOR col;
696 {
697 double vd;
698
699 if (fread((char *)&vd, sizeof(double), 1, fin) != 1)
700 return(-1);
701 if (swapbytes)
702 swap64((char *)&vd, 1);
703 setcolor(col, vd, vd, vd);
704 return(0);
705 }
706
707
708 getbfloat(col) /* get a float brightness value from fin */
709 COLOR col;
710 {
711 float vf;
712
713 if (fread((char *)&vf, sizeof(float), 1, fin) != 1)
714 return(-1);
715 if (swapbytes)
716 swap32((uint32 *)&vf, 1);
717 setcolor(col, vf, vf, vf);
718 return(0);
719 }
720
721
722 getbint(col) /* get an int brightness value from fin */
723 COLOR col;
724 {
725 int vi;
726 double d;
727
728 if (fscanf(fin, "%d", &vi) != 1)
729 return(-1);
730 d = (vi+.5)/256.;
731 setcolor(col, d, d, d);
732 return(0);
733 }
734
735
736 getbbyte(col) /* get a byte brightness value from fin */
737 COLOR col;
738 {
739 BYTE vb;
740 double d;
741
742 if (fread((char *)&vb, sizeof(BYTE), 1, fin) != 1)
743 return(-1);
744 d = (vb+.5)/256.;
745 setcolor(col, d, d, d);
746 return(0);
747 }
748
749
750 getbword(col) /* get a 16-bit brightness value from fin */
751 COLOR col;
752 {
753 uint16 vw;
754 double d;
755
756 if (fread((char *)&vw, sizeof(uint16), 1, fin) != 1)
757 return(-1);
758 if (swapbytes)
759 swap16(&vw, 1);
760 d = (vw+.5)/65536.;
761 setcolor(col, d, d, d);
762 return(0);
763 }
764
765
766 putcascii(col) /* put an ascii color to stdout */
767 COLOR col;
768 {
769 fprintf(stdout, "%15.3e %15.3e %15.3e\n",
770 colval(col,ord[0]),
771 colval(col,ord[1]),
772 colval(col,ord[2]));
773
774 return(ferror(stdout) ? -1 : 0);
775 }
776
777
778 putcfloat(col) /* put a float color to stdout */
779 COLOR col;
780 {
781 float vf[3];
782
783 vf[0] = colval(col,ord[0]);
784 vf[1] = colval(col,ord[1]);
785 vf[2] = colval(col,ord[2]);
786 if (swapbytes)
787 swap32((uint32 *)vf, 3);
788 fwrite((char *)vf, sizeof(float), 3, stdout);
789
790 return(ferror(stdout) ? -1 : 0);
791 }
792
793
794 putcdouble(col) /* put a double color to stdout */
795 COLOR col;
796 {
797 double vd[3];
798
799 vd[0] = colval(col,ord[0]);
800 vd[1] = colval(col,ord[1]);
801 vd[2] = colval(col,ord[2]);
802 if (swapbytes)
803 swap64((char *)vd, 3);
804 fwrite((char *)vd, sizeof(double), 3, stdout);
805
806 return(ferror(stdout) ? -1 : 0);
807 }
808
809
810 putcint(col) /* put an int color to stdout */
811 COLOR col;
812 {
813 fprintf(stdout, "%d %d %d\n",
814 (int)(colval(col,ord[0])*256.),
815 (int)(colval(col,ord[1])*256.),
816 (int)(colval(col,ord[2])*256.));
817
818 return(ferror(stdout) ? -1 : 0);
819 }
820
821
822 putcbyte(col) /* put a byte color to stdout */
823 COLOR col;
824 {
825 long i;
826 BYTE vb[3];
827
828 i = colval(col,ord[0])*256.;
829 vb[0] = min(i,255);
830 i = colval(col,ord[1])*256.;
831 vb[1] = min(i,255);
832 i = colval(col,ord[2])*256.;
833 vb[2] = min(i,255);
834 fwrite((char *)vb, sizeof(BYTE), 3, stdout);
835
836 return(ferror(stdout) ? -1 : 0);
837 }
838
839
840 putcword(col) /* put a 16-bit color to stdout */
841 COLOR col;
842 {
843 long i;
844 uint16 vw[3];
845
846 i = colval(col,ord[0])*65536.;
847 vw[0] = min(i,65535);
848 i = colval(col,ord[1])*65536.;
849 vw[1] = min(i,65535);
850 i = colval(col,ord[2])*65536.;
851 vw[2] = min(i,65535);
852 if (swapbytes)
853 swap16(vw, 3);
854 fwrite((char *)vw, sizeof(uint16), 3, stdout);
855
856 return(ferror(stdout) ? -1 : 0);
857 }
858
859
860 putbascii(col) /* put an ascii brightness to stdout */
861 COLOR col;
862 {
863 fprintf(stdout, "%15.3e\n", (*mybright)(col));
864
865 return(ferror(stdout) ? -1 : 0);
866 }
867
868
869 putbfloat(col) /* put a float brightness to stdout */
870 COLOR col;
871 {
872 float vf;
873
874 vf = (*mybright)(col);
875 if (swapbytes)
876 swap32((uint32 *)&vf, 1);
877 fwrite((char *)&vf, sizeof(float), 1, stdout);
878
879 return(ferror(stdout) ? -1 : 0);
880 }
881
882
883 putbdouble(col) /* put a double brightness to stdout */
884 COLOR col;
885 {
886 double vd;
887
888 vd = (*mybright)(col);
889 if (swapbytes)
890 swap64((char *)&vd, 1);
891 fwrite((char *)&vd, sizeof(double), 1, stdout);
892
893 return(ferror(stdout) ? -1 : 0);
894 }
895
896
897 putbint(col) /* put an int brightness to stdout */
898 COLOR col;
899 {
900 fprintf(stdout, "%d\n", (int)((*mybright)(col)*256.));
901
902 return(ferror(stdout) ? -1 : 0);
903 }
904
905
906 putbbyte(col) /* put a byte brightness to stdout */
907 COLOR col;
908 {
909 register int i;
910 BYTE vb;
911
912 i = (*mybright)(col)*256.;
913 vb = min(i,255);
914 fwrite((char *)&vb, sizeof(BYTE), 1, stdout);
915
916 return(ferror(stdout) ? -1 : 0);
917 }
918
919
920 putbword(col) /* put a 16-bit brightness to stdout */
921 COLOR col;
922 {
923 long i;
924 uint16 vw;
925
926 i = (*mybright)(col)*65536.;
927 vw = min(i,65535);
928 if (swapbytes)
929 swap16(&vw, 1);
930 fwrite((char *)&vw, sizeof(uint16), 1, stdout);
931
932 return(ferror(stdout) ? -1 : 0);
933 }
934
935
936 putpascii(col) /* put an ascii primary to stdout */
937 COLOR col;
938 {
939 fprintf(stdout, "%15.3e\n", colval(col,putprim));
940
941 return(ferror(stdout) ? -1 : 0);
942 }
943
944
945 putpfloat(col) /* put a float primary to stdout */
946 COLOR col;
947 {
948 float vf;
949
950 vf = colval(col,putprim);
951 if (swapbytes)
952 swap32((uint32 *)&vf, 1);
953 fwrite((char *)&vf, sizeof(float), 1, stdout);
954
955 return(ferror(stdout) ? -1 : 0);
956 }
957
958
959 putpdouble(col) /* put a double primary to stdout */
960 COLOR col;
961 {
962 double vd;
963
964 vd = colval(col,putprim);
965 if (swapbytes)
966 swap64((char *)&vd, 1);
967 fwrite((char *)&vd, sizeof(double), 1, stdout);
968
969 return(ferror(stdout) ? -1 : 0);
970 }
971
972
973 putpint(col) /* put an int primary to stdout */
974 COLOR col;
975 {
976 fprintf(stdout, "%d\n", (int)(colval(col,putprim)*256.));
977
978 return(ferror(stdout) ? -1 : 0);
979 }
980
981
982 putpbyte(col) /* put a byte primary to stdout */
983 COLOR col;
984 {
985 long i;
986 BYTE vb;
987
988 i = colval(col,putprim)*256.;
989 vb = min(i,255);
990 fwrite((char *)&vb, sizeof(BYTE), 1, stdout);
991
992 return(ferror(stdout) ? -1 : 0);
993 }
994
995
996 putpword(col) /* put a 16-bit primary to stdout */
997 COLOR col;
998 {
999 long i;
1000 uint16 vw;
1001
1002 i = colval(col,putprim)*65536.;
1003 vw = min(i,65535);
1004 if (swapbytes)
1005 swap16(&vw, 1);
1006 fwrite((char *)&vw, sizeof(uint16), 1, stdout);
1007
1008 return(ferror(stdout) ? -1 : 0);
1009 }
1010
1011
1012 set_io() /* set put and get functions */
1013 {
1014 switch (format) {
1015 case 'a': /* ascii */
1016 if (putprim == BRIGHT) {
1017 getval = getbascii;
1018 putval = putbascii;
1019 } else if (putprim != ALL) {
1020 getval = getbascii;
1021 putval = putpascii;
1022 } else {
1023 getval = getcascii;
1024 putval = putcascii;
1025 if (reverse && !interleave) {
1026 fprintf(stderr,
1027 "%s: ASCII input files must be interleaved\n",
1028 progname);
1029 quit(1);
1030 }
1031 }
1032 return;
1033 case 'f': /* binary float */
1034 if (putprim == BRIGHT) {
1035 getval = getbfloat;
1036 putval = putbfloat;
1037 } else if (putprim != ALL) {
1038 getval = getbfloat;
1039 putval = putpfloat;
1040 } else {
1041 getval = getcfloat;
1042 putval = putcfloat;
1043 if (reverse && !interleave) {
1044 if (fin2 == NULL)
1045 goto namerr;
1046 if (fseek(fin2,
1047 (long)sizeof(float)*picres.xr*picres.yr, 1))
1048 goto seekerr;
1049 if (fseek(fin3,
1050 (long)sizeof(float)*2*picres.xr*picres.yr, 1))
1051 goto seekerr;
1052 }
1053 }
1054 return;
1055 case 'd': /* binary double */
1056 if (putprim == BRIGHT) {
1057 getval = getbdouble;
1058 putval = putbdouble;
1059 } else if (putprim != ALL) {
1060 getval = getbdouble;
1061 putval = putpdouble;
1062 } else {
1063 getval = getcdouble;
1064 putval = putcdouble;
1065 if (reverse && !interleave) {
1066 if (fin2 == NULL)
1067 goto namerr;
1068 if (fseek(fin2,
1069 (long)sizeof(double)*picres.xr*picres.yr, 1))
1070 goto seekerr;
1071 if (fseek(fin3,
1072 (long)sizeof(double)*2*picres.xr*picres.yr, 1))
1073 goto seekerr;
1074 }
1075 }
1076 return;
1077 case 'i': /* integer */
1078 if (putprim == BRIGHT) {
1079 getval = getbint;
1080 putval = putbint;
1081 } else if (putprim != ALL) {
1082 getval = getbint;
1083 putval = putpint;
1084 } else {
1085 getval = getcint;
1086 putval = putcint;
1087 if (reverse && !interleave) {
1088 fprintf(stderr,
1089 "%s: integer input files must be interleaved\n",
1090 progname);
1091 quit(1);
1092 }
1093 }
1094 return;
1095 case 'b': /* byte */
1096 if (putprim == BRIGHT) {
1097 getval = getbbyte;
1098 putval = putbbyte;
1099 } else if (putprim != ALL) {
1100 getval = getbbyte;
1101 putval = putpbyte;
1102 } else {
1103 getval = getcbyte;
1104 putval = putcbyte;
1105 if (reverse && !interleave) {
1106 if (fin2 == NULL)
1107 goto namerr;
1108 if (fseek(fin2,
1109 (long)sizeof(BYTE)*picres.xr*picres.yr, 1))
1110 goto seekerr;
1111 if (fseek(fin3,
1112 (long)sizeof(BYTE)*2*picres.xr*picres.yr, 1))
1113 goto seekerr;
1114 }
1115 }
1116 return;
1117 case 'w': /* 16-bit */
1118 if (putprim == BRIGHT) {
1119 getval = getbword;
1120 putval = putbword;
1121 } else if (putprim != ALL) {
1122 getval = getbword;
1123 putval = putpword;
1124 } else {
1125 getval = getcword;
1126 putval = putcword;
1127 if (reverse && !interleave) {
1128 if (fin2 == NULL)
1129 goto namerr;
1130 if (fseek(fin2,
1131 (long)sizeof(uint16)*picres.xr*picres.yr, 1))
1132 goto seekerr;
1133 if (fseek(fin3,
1134 (long)sizeof(uint16)*2*picres.xr*picres.yr, 1))
1135 goto seekerr;
1136 }
1137 }
1138 return;
1139 }
1140 badopt:
1141 fprintf(stderr, "%s: botched file type\n", progname);
1142 quit(1);
1143 namerr:
1144 fprintf(stderr, "%s: non-interleaved file(s) must be named\n",
1145 progname);
1146 quit(1);
1147 seekerr:
1148 fprintf(stderr, "%s: cannot seek on interleaved input file\n",
1149 progname);
1150 quit(1);
1151 }
