root/radiance/src/px/psquish.csh
Revision: 3.4
Committed: Wed Feb 16 05:40:11 2005 UTC (20 years, 8 months ago) by greg
Content type: application/x-csh
CVS Tags: rad3R7P2, rad3R7P1, rad3R8, rad3R9
Changes since 3.3: +2 -2 lines
1 #!/bin/csh -f
2 # RCSid: $Id: psquish.csh,v 3.3 2004/01/01 19:44:07 greg Exp $
3 set Lmin=.0001 # minimum visible world luminance
4 set Ldmin=1 # minimum display luminance
5 set Ldmax=100 # maximum display luminance
6 set nsteps=100 # number of steps in perceptual histogram
7 set cvratio=0.05 # fraction of pixels to ignore in envelope clipping
8 set td=/tmp
9 set tf0=$td/tf$$
10 set tf1=$td/hist$$
11 set tf1b=$td/hist$$.diff
12 set tf2=$td/cumt$$
13 set tf3=$td/histeq$$.cal
14 set tf4=$td/cf$$.cal
15 set tf=($tf0 $tf1 $tf1b $tf2 $tf3 $tf4)
16 if ( "$argv[1]" == "-a" ) then
17 set adaptive
18 shift argv
19 endif
20 if ( $#argv != 1 ) then
21 echo "Usage: $0 [-a] input.pic > output.pic"
22 exit 1
23 endif
24 set ifile=$1
25 set ibase=$ifile:t
26 if ( "$ibase" =~ *.pic ) set ibase=$ibase:r
27 set ibase=$ibase:t
28 onintr quit
29 pextrem -o $ifile > $tf0
30 set Lmin=`rcalc -e 'L=179*(.265*$3+.67*$4+.065*$5)' -e 'cond=1.5-recno;$1=if('L-$Lmin,L,$Lmin')' $tf0`
31 set Lmax=`rcalc -e 'L=179*(.265*$3+.67*$4+.065*$5)' -e 'cond=recno-1.5;$1=if('$Ldmax-L,$Ldmax,L')' $tf0`
32 cat > $tf3 << _EOF_
33 min(a,b) : if(a-b, b, a);
34 WE : 179; { Radiance white luminous efficacy }
35 Lmin : $Lmin ; { minimum visible luminance }
36 Lmax : $Lmax ; { maximum picture luminance }
37 Ldmin : $Ldmin ; { minimum output luminance }
38 Ldmax : $Ldmax ; { maximum output luminance }
39 Stepsiz : (Bl(Lmax)-Bl(Lmin))/ $nsteps ; { brightness step size }
40 { Logarithmic brightness function }
41 Bl(L) : log(L);
42 Lb(B) : exp(B);
43 BLw(Lw) : Bl(Ldmin) + (Bl(Ldmax)-Bl(Ldmin))*cf(Bl(Lw));
44 { first derivative functions }
45 Bl1(L) : 1/L;
46 Lb1(B) : exp(B);
47 { histogram equalization function }
48 lin = li(1);
49 Lw = WE/le(1) * lin;
50 Lout = Lb(BLw(Lw));
51 mult = if(Lw-Lmin, (Lout-Ldmin)/(Ldmax-Ldmin)/lin, 0) ;
52 _EOF_
53 if ( $?adaptive ) then
54 cat >> $tf3 << _EOF_
55 { Ferwerda contrast sensitivity function }
56 { log10 of cone threshold luminance }
57 ltp(lLa) : if(-2.6 - lLa, -.72, if(lLa - 1.9, lLa - 1.255,
58 (.249*lLa + .65)^2.7 - .72));
59 { log10 of rod threshold luminance }
60 lts(lLa) : if(-3.94 - lLa, -2.86, if(lLa - -1.44, lLa - .395,
61 (.405*lLa + 1.6)^2.18 - 2.86));
62 { threshold is minimum of rods and cones }
63 ldL2(lLa) : min(ltp(lLa),lts(lLa));
64 dL(La) : 10^ldL2(log10(La));
65 { derivative clamping function }
66 clamp2(L, bLw) : dL(Lb(bLw))/dL(L)/Lb1(bLw)/(Bl(Ldmax)-Bl(Ldmin))/Bl1(L);
67 clamp(L) : clamp2(L, BLw(L));
68 { shift direction for histogram }
69 shiftdir(B) : if(cf(B) - (B - Bl(Lmin))/(Bl(Ldmax) - Bl(Lmin)), 1, -1);
70 { Scotopic/Photopic color adjustment }
71 sL(r,g,b) : .062*r + .608*g + .330*b; { approx. scotopic brightness }
72 BotMesopic : 10^-2.25; { top of scotopic range }
73 TopMesopic : 10^0.75; { bottom of photopic range }
74 incolor = if(Lw-TopMesopic, 1, if(BotMesopic-Lw, 0,
75 (Lw-BotMesopic)/(TopMesopic-BotMesopic)));
76 slf = (1 - incolor)*sL(ri(1),gi(1),bi(1));
77 ro = mult*(incolor*ri(1) + slf);
78 go = mult*(incolor*gi(1) + slf);
79 bo = mult*(incolor*bi(1) + slf);
80 _EOF_
81 else
82 cat >> $tf3 << _EOF_
83 { derivative clamping function }
84 clamp2(L, bLw) : Lb(bLw)/L/Lb1(bLw)/(Bl(Ldmax)-Bl(Ldmin))/Bl1(L);
85 clamp(L) : clamp2(L, BLw(L));
86 { shift direction for histogram }
87 shiftdir(B) : -1;
88 ro = mult*ri(1);
89 go = mult*gi(1);
90 bo = mult*bi(1);
91 _EOF_
92 endif
93 # Compute brightness histogram
94 pfilt -1 -p 1 -x 128 -y 128 $ifile | pvalue -o -b -d -h -H \
95 | rcalc -f $tf3 -e 'Lw=WE*$1;$1=if(Lw-Lmin,Bl(Lw),-1)' \
96 | histo `ev "log($Lmin)" "log($Lmax)"` $nsteps > $tf1
97 # Clamp frequency distribution
98 set totcount=`sed 's/^.*[ ]//' $tf1 | total`
99 set margin=`ev "floor($totcount*$cvratio+.5)"`
100 while ( 1 )
101 # Compute mapping function
102 sed 's/^.*[ ]//' $tf1 | total -1 -r \
103 | rcalc -e '$1=$1/'$totcount | rlam $tf1 - \
104 | tabfunc -i 0 cf > $tf4
105 # Compute difference with visible envelope
106 rcalc -f $tf4 -f $tf3 -e "T:$totcount*Stepsiz" \
107 -e 'clfq=floor(T*clamp(Lb($1))+.5)' \
108 -e '$1=$2-clfq;$2=shiftdir($1)' $tf1 > $tf1b
109 if (`sed 's/[ ].*$//' $tf1b | total` >= 0) then
110 # Nothing visible? -- just normalize
111 pfilt -1 -e `pextrem $ifile | rcalc -e 'cond=recno-1.5;$1=1/(.265*$3+.67*$4+.065*$5)'` $ifile
112 goto quit
113 endif
114 # Check to see if we're close enough
115 if (`rcalc -e '$1=if($1,$1,0)' $tf1b | total` <= $margin) break
116 # Squash frequency distribution
117 set diffs=(`sed 's/[ ].*$//' $tf1b`)
118 set shftd=(`sed 's/^.*[ ]//' $tf1b`)
119 while ( 1 )
120 set maxi=0
121 set maxd=0
122 set i=$nsteps
123 while ( $i > 0 )
124 if ( $diffs[$i] > $maxd ) then
125 set maxd=$diffs[$i]
126 set maxi=$i
127 endif
128 @ i--
129 end
130 if ( $maxd == 0 ) break
131 set i=0
132 tryagain:
133 set r=$shftd[$maxi]
134 while ( $i == 0 )
135 @ t= $maxi + $r
136 if ( $t < 1 || $t > $nsteps ) then
137 @ shftd[$maxi]= -($shftd[$maxi])
138 goto tryagain
139 endif
140 if ( $diffs[$t] < 0 ) set i=$t
141 @ r+= $shftd[$maxi]
142 end
143 if ( $diffs[$i] <= -$diffs[$maxi] ) then
144 @ diffs[$i]+= $diffs[$maxi]
145 set diffs[$maxi]=0
146 else
147 @ diffs[$maxi]+= $diffs[$i]
148 set diffs[$i]=0
149 endif
150 end
151 # Mung histogram
152 echo $diffs | tr ' ' '\012' | rlam $tf1 - \
153 | rcalc -f $tf4 -f $tf3 -e "T:$totcount*Stepsiz" \
154 -e 'clfq=floor(T*clamp(Lb($1))+.5)' \
155 -e '$1=$1;$2=$3+clfq' > $tf1b
156 mv -f $tf1b $tf1
157 end
158 # Plot the mapping function if we are in debug mode
159 if ( $?DEBUG ) then
160 cat > ${ibase}_histo.plt << _EOF_
161 include=curve.plt
162 title="Brightness Frequency Distribution"
163 subtitle= $ibase
164 ymin=0
165 xlabel="Perceptual Brightness B(Lw)"
166 ylabel="Frequency Count"
167 Alabel="Histogram"
168 Alintype=0
169 Blabel="Envelope"
170 Bsymsize=0
171 Adata=
172 _EOF_
173 (cat $tf1; echo \;; echo Bdata=) >> ${ibase}_histo.plt
174 rcalc -f $tf4 -f $tf3 -e "T:$totcount*Stepsiz" \
175 -e '$1=$1;$2=T*clamp(Lb($1))' $tf1 \
176 >> ${ibase}_histo.plt
177 cat > ${ibase}_brmap.plt << _EOF_
178 include=line.plt
179 title="Brightness Mapping Function"
180 subtitle= $ibase
181 xlabel="World Luminance (log cd/m^2)"
182 ylabel="Display Luminance (cd/m^2)"
183 ymax= $Ldmax
184 Adata=
185 _EOF_
186 cnt 100 | rcalc -f $tf4 -f $tf3 -e '$1=lx;$2=Lb(BLw(10^lx))' \
187 -e 'lx=$1/99*(log10(Lmax)-log10(Lmin))+log10(Lmin)' \
188 >> ${ibase}_brmap.plt
189 if ( $?DISPLAY ) then
190 bgraph ${ibase}_histo.plt ${ibase}_brmap.plt | x11meta &
191 endif
192 endif
193 # Map our picture
194 getinfo < $ifile | egrep '^((VIEW|PIXASPECT|PRIMARIES)=|[^ ]*(rpict|rview|pinterp) )'
195 pcomb -f $tf4 -f $tf3 $ifile
196 quit:
197 rm -f $tf
