root/radiance/src/px/protate.c
Thu Aug 2 18:33:46 2018 UTC (7 years, 2 months ago) by greg
Wed Feb 8 04:18:13 2012 UTC (13 years, 8 months ago) by greg
Changes since 2.10: +5 -1 lines
Fixed bug for Windows (forgot binary mode)
Fri Apr 30 20:29:24 2004 UTC (21 years, 5 months ago) by greg
Changes since 2.9: +19 -5 lines
Sun Mar 28 20:33:14 2004 UTC (21 years, 6 months ago) by schorsch
Changes since 2.8: +21 -11 lines
Thu May 15 05:13:35 2003 UTC (22 years, 5 months ago) by greg
Sat Feb 22 02:07:27 2003 UTC (22 years, 7 months ago) by greg
Changes since 2.6: +5 -6 lines
Tue Oct 27 16:32:33 1998 UTC (26 years, 11 months ago) by gwlarson
Changes since 2.5: +4 -6 lines
replaced bcopy() with copycolr()
Tue Oct 27 12:34:39 1998 UTC (26 years, 11 months ago) by gwlarson
Changes since 2.4: +81 -11 lines
added -r option to rotate CCW and fixed bug in pixel order reporting
Mon Oct 16 11:40:22 1995 UTC (30 years ago) by greg
added compatibility with alternate RADIANCE picture formats
Wed Feb 1 09:52:34 1995 UTC (30 years, 8 months ago) by greg
added -c option to header info
Mon Apr 25 09:32:36 1994 UTC (31 years, 5 months ago) by greg
Changes since 2.1: +4 -0 lines
changed to 4 Meg buffer if BIGMEM defined
Tue Nov 12 16:04:09 1991 UTC (33 years, 11 months ago) by greg
Diff to previous 1.9 , to selected 2.9
Mon Nov 11 14:01:44 1991 UTC (33 years, 11 months ago) by greg
Changes since 1.8: +18 -26 lines
Diff to previous 1.8 , to selected 2.9
Thu Apr 18 14:42:06 1991 UTC (34 years, 6 months ago) by greg
Changes since 1.7: +13 -1 lines
Diff to previous 1.7 , to selected 2.9
Tue Dec 4 11:25:46 1990 UTC (34 years, 10 months ago) by greg
Diff to previous 1.6 , to selected 2.9
added standard.h to take care of bcopy() incompatibilities
Tue Jul 3 08:45:48 1990 UTC (35 years, 3 months ago) by greg
Changes since 1.5: +14 -2 lines
Diff to previous 1.5 , to selected 2.9
added corrections to picture aspect ratio
Tue Jun 26 09:09:35 1990 UTC (35 years, 3 months ago) by greg
Changes since 1.4: +5 -5 lines
Diff to previous 1.4 , to selected 2.9
inline will be reserved word
Thu Jan 25 08:28:35 1990 UTC (35 years, 8 months ago) by greg
Changes since 1.3: +1 -2 lines
Diff to previous 1.3 , to selected 2.9
Thu Jan 18 23:58:15 1990 UTC (35 years, 9 months ago) by greg
Changes since 1.2: +2 -1 lines
Diff to previous 1.2 , to selected 2.9
Tue Sep 12 13:04:27 1989 UTC (36 years, 1 month ago) by greg
Changes since 1.1: +2 -3 lines
Diff to previous 1.1 , to selected 2.9
Thu Feb 2 10:49:27 1989 UTC (36 years, 8 months ago) by greg
Diff to selected 2.9
