root/radiance/src/px/pmblur2.c
Wed Jul 2 16:54:44 2025 UTC (3 months, 1 week ago) by greg
CVS Tags: HEAD, rad6R0
perf: Made +/-0.5% threshold for caring about pixel aspect ratio consistent
Tue Jul 1 19:40:35 2025 UTC (3 months, 1 week ago) by greg
fix: Made PIXASPECT= output a little more stringent (+/-0.1% rather than 1%)
Tue Jun 3 21:31:51 2025 UTC (4 months, 1 week ago) by greg
Changes since 2.7: +2 -4 lines
Thu Nov 7 23:20:29 2019 UTC (5 years, 11 months ago) by greg
CVS Tags: rad5R3, rad5R4
Thu Aug 2 18:33:45 2018 UTC (7 years, 2 months ago) by greg
Sat Oct 13 05:18:18 2012 UTC (13 years ago) by greg
Changes since 2.4: +3 -4 lines
Reduced sampling artifacts substantially
Fri Oct 5 18:54:40 2012 UTC (13 years ago) by greg
Changes since 2.3: +5 -3 lines
Added check for frame start equal frame end
Fri Oct 5 15:25:12 2012 UTC (13 years ago) by greg
Changes since 2.2: +21 -9 lines
Added check for same object -- does not seem to make much difference
Fri Oct 5 02:07:10 2012 UTC (13 years ago) by greg
Changes since 2.1: +13 -7 lines
Added optional setting of the number of time slices to pmblur2
Fri Oct 5 00:59:38 2012 UTC (13 years ago) by greg
Diff to selected 2.5
