root/radiance/src/px/pinterp.c
Revision: 2.6
Committed: Tue May 26 15:23:09 1992 UTC (33 years, 4 months ago) by greg
fixed -pa option
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Interpolate and extrapolate pictures with different view parameters.
9 *
10 * Greg Ward 09Dec89
11 */
12
13 #include "standard.h"
14
15 #include <fcntl.h>
16
17 #include <ctype.h>
18
19 #include "view.h"
20
21 #include "color.h"
22
23 #include "resolu.h"
24
25 #ifndef BSD
26 #define vfork fork
27 #endif
28
29 #define pscan(y) (ourpict+(y)*hresolu)
30 #define zscan(y) (ourzbuf+(y)*hresolu)
31
32 #define F_FORE 1 /* fill foreground */
33 #define F_BACK 2 /* fill background */
34
35 #define PACKSIZ 256 /* max. calculation packet size */
36
37 #define RTCOM "rtrace -h- -ovl -fff "
38
39 #define ABS(x) ((x)>0?(x):-(x))
40
41 struct position {int x,y; float z;};
42
43 VIEW ourview = STDVIEW; /* desired view */
44 int hresolu = 512; /* horizontal resolution */
45 int vresolu = 512; /* vertical resolution */
46 double pixaspect = 1.0; /* pixel aspect ratio */
47
48 double zeps = .02; /* allowed z epsilon */
49
50 COLR *ourpict; /* output picture */
51 float *ourzbuf; /* corresponding z-buffer */
52
53 char *progname;
54
55 int fillo = F_FORE|F_BACK; /* selected fill options */
56 int fillsamp = 0; /* sample separation (0 == inf) */
57 extern int backfill(), rcalfill(); /* fill functions */
58 int (*fillfunc)() = backfill; /* selected fill function */
59 COLR backcolr = BLKCOLR; /* background color */
60 double backz = 0.0; /* background z value */
61 int normdist = 1; /* normalized distance? */
62 double ourexp = -1; /* output picture exposure */
63
64 VIEW theirview = STDVIEW; /* input view */
65 int gotview; /* got input view? */
66 int wrongformat = 0; /* input in another format? */
67 RESOLU tresolu; /* input resolution */
68 double theirexp; /* input picture exposure */
69 double theirs2ours[4][4]; /* transformation matrix */
70 int hasmatrix = 0; /* has transformation matrix */
71
72 int PDesc[3] = {-1,-1,-1}; /* rtrace process descriptor */
73 #define childpid (PDesc[2])
74 unsigned short queue[PACKSIZ][2]; /* pending pixels */
75 int packsiz; /* actual packet size */
76 int queuesiz; /* number of pixels pending */
77
78
79 main(argc, argv) /* interpolate pictures */
80 int argc;
81 char *argv[];
82 {
83 #define check(ol,al) if (argv[i][ol] || \
84 badarg(argc-i-1,argv+i+1,al)) \
85 goto badopt
86 int gotvfile = 0;
87 char *zfile = NULL;
88 char *err;
89 int i, rval;
90
91 progname = argv[0];
92
93 for (i = 1; i < argc && argv[i][0] == '-'; i++) {
94 rval = getviewopt(&ourview, argc-i, argv+i);
95 if (rval >= 0) {
96 i += rval;
97 continue;
98 }
99 switch (argv[i][1]) {
100 case 't': /* threshold */
101 check(2,"f");
102 zeps = atof(argv[++i]);
103 break;
104 case 'n': /* dist. normalized? */
105 check(2,NULL);
106 normdist = !normdist;
107 break;
108 case 'f': /* fill type */
109 switch (argv[i][2]) {
110 case '0': /* none */
111 check(3,NULL);
112 fillo = 0;
113 break;
114 case 'f': /* foreground */
115 check(3,NULL);
116 fillo = F_FORE;
117 break;
118 case 'b': /* background */
119 check(3,NULL);
120 fillo = F_BACK;
121 break;
122 case 'a': /* all */
123 check(3,NULL);
124 fillo = F_FORE|F_BACK;
125 break;
126 case 's': /* sample */
127 check(3,"i");
128 fillsamp = atoi(argv[++i]);
129 break;
130 case 'c': /* color */
131 check(3,"fff");
132 fillfunc = backfill;
133 setcolr(backcolr, atof(argv[i+1]),
134 atof(argv[i+2]), atof(argv[i+3]));
135 i += 3;
136 break;
137 case 'z': /* z value */
138 check(3,"f");
139 fillfunc = backfill;
140 backz = atof(argv[++i]);
141 break;
142 case 'r': /* rtrace */
143 check(3,"s");
144 fillfunc = rcalfill;
145 calstart(RTCOM, argv[++i]);
146 break;
147 default:
148 goto badopt;
149 }
150 break;
151 case 'z': /* z file */
152 check(2,"s");
153 zfile = argv[++i];
154 break;
155 case 'x': /* x resolution */
156 check(2,"i");
157 hresolu = atoi(argv[++i]);
158 break;
159 case 'y': /* y resolution */
160 check(2,"i");
161 vresolu = atoi(argv[++i]);
162 break;
163 case 'p': /* pixel aspect */
164 if (argv[i][2] != 'a')
165 goto badopt;
166 check(3,"f");
167 pixaspect = atof(argv[++i]);
168 break;
169 case 'v': /* view file */
170 if (argv[i][2] != 'f')
171 goto badopt;
172 check(3,"s");
173 gotvfile = viewfile(argv[++i], &ourview, 0, 0);
174 if (gotvfile < 0) {
175 perror(argv[i]);
176 exit(1);
177 } else if (gotvfile == 0) {
178 fprintf(stderr, "%s: bad view file\n",
179 argv[i]);
180 exit(1);
181 }
182 break;
183 default:
184 badopt:
185 fprintf(stderr, "%s: command line error at '%s'\n",
186 progname, argv[i]);
187 goto userr;
188 }
189 }
190 /* check arguments */
191 if ((argc-i)%2)
192 goto userr;
193 if (fillsamp == 1)
194 fillo &= ~F_BACK;
195 /* set view */
196 if (err = setview(&ourview)) {
197 fprintf(stderr, "%s: %s\n", progname, err);
198 exit(1);
199 }
200 normaspect(viewaspect(&ourview), &pixaspect, &hresolu, &vresolu);
201 /* allocate frame */
202 ourpict = (COLR *)malloc(hresolu*vresolu*sizeof(COLR));
203 ourzbuf = (float *)calloc(hresolu*vresolu,sizeof(float));
204 if (ourpict == NULL || ourzbuf == NULL)
205 syserror();
206 /* get input */
207 for ( ; i < argc; i += 2)
208 addpicture(argv[i], argv[i+1]);
209 /* fill in spaces */
210 if (fillo&F_BACK)
211 backpicture(fillfunc, fillsamp);
212 else
213 fillpicture(fillfunc);
214 /* close calculation */
215 caldone();
216 /* add to header */
217 printargs(argc, argv, stdout);
218 if (gotvfile) {
219 fputs(VIEWSTR, stdout);
220 fprintview(&ourview, stdout);
221 putc('\n', stdout);
222 }
223 if (pixaspect < .99 || pixaspect > 1.01)
224 fputaspect(pixaspect, stdout);
225 if (ourexp > 0 && (ourexp < .995 || ourexp > 1.005))
226 fputexpos(ourexp, stdout);
227 fputformat(COLRFMT, stdout);
228 putc('\n', stdout);
229 /* write picture */
230 writepicture();
231 /* write z file */
232 if (zfile != NULL)
233 writedistance(zfile);
234
235 exit(0);
236 userr:
237 fprintf(stderr,
238 "Usage: %s [view opts][-t eps][-z zout][-fT][-n] pfile zspec ..\n",
239 progname);
240 exit(1);
241 #undef check
242 }
243
244
245 headline(s) /* process header string */
246 char *s;
247 {
248 char fmt[32];
249
250 if (isformat(s)) {
251 formatval(fmt, s);
252 wrongformat = strcmp(fmt, COLRFMT);
253 return;
254 }
255 putc('\t', stdout);
256 fputs(s, stdout);
257
258 if (isexpos(s)) {
259 theirexp *= exposval(s);
260 return;
261 }
262 if (isview(s) && sscanview(&theirview, s) > 0)
263 gotview++;
264 }
265
266
267 addpicture(pfile, zspec) /* add picture to output */
268 char *pfile, *zspec;
269 {
270 FILE *pfp;
271 int zfd;
272 char *err;
273 COLR *scanin;
274 float *zin;
275 struct position *plast;
276 int y;
277 /* open picture file */
278 if ((pfp = fopen(pfile, "r")) == NULL) {
279 perror(pfile);
280 exit(1);
281 }
282 /* get header with exposure and view */
283 theirexp = 1.0;
284 gotview = 0;
285 printf("%s:\n", pfile);
286 getheader(pfp, headline, NULL);
287 if (wrongformat || !gotview || !fgetsresolu(&tresolu, pfp)) {
288 fprintf(stderr, "%s: picture format error\n", pfile);
289 exit(1);
290 }
291 if (ourexp <= 0)
292 ourexp = theirexp;
293 else if (ABS(theirexp-ourexp) > .01*ourexp)
294 fprintf(stderr, "%s: different exposure (warning)\n", pfile);
295 if (err = setview(&theirview)) {
296 fprintf(stderr, "%s: %s\n", pfile, err);
297 exit(1);
298 }
299 /* compute transformation */
300 hasmatrix = pixform(theirs2ours, &theirview, &ourview);
301 /* allocate scanlines */
302 scanin = (COLR *)malloc(scanlen(&tresolu)*sizeof(COLR));
303 zin = (float *)malloc(scanlen(&tresolu)*sizeof(float));
304 plast = (struct position *)calloc(scanlen(&tresolu),
305 sizeof(struct position));
306 if (scanin == NULL || zin == NULL || plast == NULL)
307 syserror();
308 /* get z specification or file */
309 if ((zfd = open(zspec, O_RDONLY)) == -1) {
310 double zvalue;
311 register int x;
312 if (!isfloat(zspec) || (zvalue = atof(zspec)) <= 0.0) {
313 perror(zspec);
314 exit(1);
315 }
316 for (x = scanlen(&tresolu); x-- > 0; )
317 zin[x] = zvalue;
318 }
319 /* load image */
320 for (y = 0; y < numscans(&tresolu); y++) {
321 if (freadcolrs(scanin, scanlen(&tresolu), pfp) < 0) {
322 fprintf(stderr, "%s: read error\n", pfile);
323 exit(1);
324 }
325 if (zfd != -1 && read(zfd,(char *)zin,
326 scanlen(&tresolu)*sizeof(float))
327 < scanlen(&tresolu)*sizeof(float)) {
328 fprintf(stderr, "%s: read error\n", zspec);
329 exit(1);
330 }
331 addscanline(y, scanin, zin, plast);
332 }
333 /* clean up */
334 free((char *)scanin);
335 free((char *)zin);
336 free((char *)plast);
337 fclose(pfp);
338 if (zfd != -1)
339 close(zfd);
340 }
341
342
343 pixform(xfmat, vw1, vw2) /* compute view1 to view2 matrix */
344 register double xfmat[4][4];
345 register VIEW *vw1, *vw2;
346 {
347 double m4t[4][4];
348
349 if (vw1->type != VT_PER && vw1->type != VT_PAR)
350 return(0);
351 if (vw2->type != VT_PER && vw2->type != VT_PAR)
352 return(0);
353 setident4(xfmat);
354 xfmat[0][0] = vw1->hvec[0];
355 xfmat[0][1] = vw1->hvec[1];
356 xfmat[0][2] = vw1->hvec[2];
357 xfmat[1][0] = vw1->vvec[0];
358 xfmat[1][1] = vw1->vvec[1];
359 xfmat[1][2] = vw1->vvec[2];
360 xfmat[2][0] = vw1->vdir[0];
361 xfmat[2][1] = vw1->vdir[1];
362 xfmat[2][2] = vw1->vdir[2];
363 xfmat[3][0] = vw1->vp[0];
364 xfmat[3][1] = vw1->vp[1];
365 xfmat[3][2] = vw1->vp[2];
366 setident4(m4t);
367 m4t[0][0] = vw2->hvec[0]/vw2->hn2;
368 m4t[1][0] = vw2->hvec[1]/vw2->hn2;
369 m4t[2][0] = vw2->hvec[2]/vw2->hn2;
370 m4t[3][0] = -DOT(vw2->vp,vw2->hvec)/vw2->hn2;
371 m4t[0][1] = vw2->vvec[0]/vw2->vn2;
372 m4t[1][1] = vw2->vvec[1]/vw2->vn2;
373 m4t[2][1] = vw2->vvec[2]/vw2->vn2;
374 m4t[3][1] = -DOT(vw2->vp,vw2->vvec)/vw2->vn2;
375 m4t[0][2] = vw2->vdir[0];
376 m4t[1][2] = vw2->vdir[1];
377 m4t[2][2] = vw2->vdir[2];
378 m4t[3][2] = -DOT(vw2->vp,vw2->vdir);
379 multmat4(xfmat, xfmat, m4t);
380 return(1);
381 }
382
383
384 addscanline(y, pline, zline, lasty) /* add scanline to output */
385 int y;
386 COLR *pline;
387 float *zline;
388 struct position *lasty; /* input/output */
389 {
390 extern double sqrt();
391 FVECT pos;
392 struct position lastx, newpos;
393 register int x;
394
395 lastx.z = 0;
396 for (x = scanlen(&tresolu); x-- > 0; ) {
397 pix2loc(pos, &tresolu, x, y);
398 pos[2] = zline[x];
399 if (movepixel(pos) < 0) {
400 lasty[x].z = lastx.z = 0; /* mark invalid */
401 continue;
402 }
403 newpos.x = pos[0] * hresolu;
404 newpos.y = pos[1] * vresolu;
405 newpos.z = zline[x];
406 /* add pixel to our image */
407 if (pos[0] >= 0 && newpos.x < hresolu
408 && pos[1] >= 0 && newpos.y < vresolu) {
409 addpixel(&newpos, &lastx, &lasty[x], pline[x], pos[2]);
410 lasty[x].x = lastx.x = newpos.x;
411 lasty[x].y = lastx.y = newpos.y;
412 lasty[x].z = lastx.z = newpos.z;
413 } else
414 lasty[x].z = lastx.z = 0; /* mark invalid */
415 }
416 }
417
418
419 addpixel(p0, p1, p2, pix, z) /* fill in pixel parallelogram */
420 struct position *p0, *p1, *p2;
421 COLR pix;
422 double z;
423 {
424 double zt = 2.*zeps*p0->z; /* threshold */
425 int s1x, s1y, s2x, s2y; /* step sizes */
426 int l1, l2, c1, c2; /* side lengths and counters */
427 int p1isy; /* p0p1 along y? */
428 int x1, y1; /* p1 position */
429 register int x, y; /* final position */
430
431 /* compute vector p0p1 */
432 if (fillo&F_FORE && ABS(p1->z-p0->z) <= zt) {
433 s1x = p1->x - p0->x;
434 s1y = p1->y - p0->y;
435 l1 = ABS(s1x);
436 if (p1isy = (ABS(s1y) > l1))
437 l1 = ABS(s1y);
438 } else {
439 l1 = s1x = s1y = 1;
440 p1isy = -1;
441 }
442 /* compute vector p0p2 */
443 if (fillo&F_FORE && ABS(p2->z-p0->z) <= zt) {
444 s2x = p2->x - p0->x;
445 s2y = p2->y - p0->y;
446 if (p1isy == 1)
447 l2 = ABS(s2x);
448 else {
449 l2 = ABS(s2y);
450 if (p1isy != 0 && ABS(s2x) > l2)
451 l2 = ABS(s2x);
452 }
453 } else
454 l2 = s2x = s2y = 1;
455 /* fill the parallelogram */
456 for (c1 = l1; c1-- > 0; ) {
457 x1 = p0->x + c1*s1x/l1;
458 y1 = p0->y + c1*s1y/l1;
459 for (c2 = l2; c2-- > 0; ) {
460 x = x1 + c2*s2x/l2;
461 if (x < 0 || x >= hresolu)
462 continue;
463 y = y1 + c2*s2y/l2;
464 if (y < 0 || y >= vresolu)
465 continue;
466 if (zscan(y)[x] <= 0 || zscan(y)[x]-z
467 > zeps*zscan(y)[x]) {
468 zscan(y)[x] = z;
469 copycolr(pscan(y)[x], pix);
470 }
471 }
472 }
473 }
474
475
476 movepixel(pos) /* reposition image point */
477 FVECT pos;
478 {
479 FVECT pt, direc;
480
481 if (pos[2] <= 0) /* empty pixel */
482 return(-1);
483 if (hasmatrix) {
484 pos[0] += theirview.hoff - .5;
485 pos[1] += theirview.voff - .5;
486 if (theirview.type == VT_PER) {
487 if (normdist) /* adjust for eye-ray distance */
488 pos[2] /= sqrt( 1.
489 + pos[0]*pos[0]*theirview.hn2
490 + pos[1]*pos[1]*theirview.vn2 );
491 pos[0] *= pos[2];
492 pos[1] *= pos[2];
493 }
494 multp3(pos, pos, theirs2ours);
495 if (pos[2] <= 0)
496 return(-1);
497 if (ourview.type == VT_PER) {
498 pos[0] /= pos[2];
499 pos[1] /= pos[2];
500 }
501 pos[0] += .5 - ourview.hoff;
502 pos[1] += .5 - ourview.voff;
503 return(0);
504 }
505 if (viewray(pt, direc, &theirview, pos[0], pos[1]) < 0)
506 return(-1);
507 pt[0] += direc[0]*pos[2];
508 pt[1] += direc[1]*pos[2];
509 pt[2] += direc[2]*pos[2];
510 viewloc(pos, &ourview, pt);
511 if (pos[2] <= 0)
512 return(-1);
513 return(0);
514 }
515
516
517 backpicture(fill, samp) /* background fill algorithm */
518 int (*fill)();
519 int samp;
520 {
521 int *yback, xback;
522 int y;
523 register int x, i;
524 /* get back buffer */
525 yback = (int *)malloc(hresolu*sizeof(int));
526 if (yback == NULL)
527 syserror();
528 for (x = 0; x < hresolu; x++)
529 yback[x] = -2;
530 /*
531 * Xback and yback are the pixel locations of suitable
532 * background values in each direction.
533 * A value of -2 means unassigned, and -1 means
534 * that there is no suitable background in this direction.
535 */
536 /* fill image */
537 for (y = 0; y < vresolu; y++) {
538 xback = -2;
539 for (x = 0; x < hresolu; x++)
540 if (zscan(y)[x] <= 0) { /* empty pixel */
541 /*
542 * First, find background from above or below.
543 * (farthest assigned pixel)
544 */
545 if (yback[x] == -2) {
546 for (i = y+1; i < vresolu; i++)
547 if (zscan(i)[x] > 0)
548 break;
549 if (i < vresolu
550 && (y <= 0 || zscan(y-1)[x] < zscan(i)[x]))
551 yback[x] = i;
552 else
553 yback[x] = y-1;
554 }
555 /*
556 * Next, find background from left or right.
557 */
558 if (xback == -2) {
559 for (i = x+1; i < hresolu; i++)
560 if (zscan(y)[i] > 0)
561 break;
562 if (i < hresolu
563 && (x <= 0 || zscan(y)[x-1] < zscan(y)[i]))
564 xback = i;
565 else
566 xback = x-1;
567 }
568 /*
569 * If we have no background for this pixel,
570 * use the given fill function.
571 */
572 if (xback < 0 && yback[x] < 0)
573 goto fillit;
574 /*
575 * Compare, and use the background that is
576 * farther, unless one of them is next to us.
577 * If the background is too distant, call
578 * the fill function.
579 */
580 if ( yback[x] < 0
581 || (xback >= 0 && ABS(x-xback) <= 1)
582 || ( ABS(y-yback[x]) > 1
583 && zscan(yback[x])[x]
584 < zscan(y)[xback] ) ) {
585 if (samp > 0 && ABS(x-xback) >= samp)
586 goto fillit;
587 copycolr(pscan(y)[x],pscan(y)[xback]);
588 zscan(y)[x] = zscan(y)[xback];
589 } else {
590 if (samp > 0 && ABS(y-yback[x]) > samp)
591 goto fillit;
592 copycolr(pscan(y)[x],pscan(yback[x])[x]);
593 zscan(y)[x] = zscan(yback[x])[x];
594 }
595 continue;
596 fillit:
597 (*fill)(x,y);
598 if (fill == rcalfill) { /* use it */
599 clearqueue();
600 xback = x;
601 yback[x] = y;
602 }
603 } else { /* full pixel */
604 yback[x] = -2;
605 xback = -2;
606 }
607 }
608 free((char *)yback);
609 }
610
611
612 fillpicture(fill) /* paint in empty pixels using fill */
613 int (*fill)();
614 {
615 register int x, y;
616
617 for (y = 0; y < vresolu; y++)
618 for (x = 0; x < hresolu; x++)
619 if (zscan(y)[x] <= 0)
620 (*fill)(x,y);
621 }
622
623
624 writepicture() /* write out picture */
625 {
626 int y;
627
628 fprtresolu(hresolu, vresolu, stdout);
629 for (y = vresolu-1; y >= 0; y--)
630 if (fwritecolrs(pscan(y), hresolu, stdout) < 0)
631 syserror();
632 }
633
634
635 writedistance(fname) /* write out z file */
636 char *fname;
637 {
638 extern double sqrt();
639 int donorm = normdist && ourview.type == VT_PER;
640 int fd;
641 int y;
642 float *zout;
643
644 if ((fd = open(fname, O_WRONLY|O_CREAT|O_TRUNC, 0666)) == -1) {
645 perror(fname);
646 exit(1);
647 }
648 if (donorm
649 && (zout = (float *)malloc(hresolu*sizeof(float))) == NULL)
650 syserror();
651 for (y = vresolu-1; y >= 0; y--) {
652 if (donorm) {
653 double vx, yzn2;
654 register int x;
655 yzn2 = (y+.5)/vresolu + ourview.voff - .5;
656 yzn2 = 1. + yzn2*yzn2*ourview.vn2;
657 for (x = 0; x < hresolu; x++) {
658 vx = (x+.5)/hresolu + ourview.hoff - .5;
659 zout[x] = zscan(y)[x]
660 * sqrt(vx*vx*ourview.hn2 + yzn2);
661 }
662 } else
663 zout = zscan(y);
664 if (write(fd, (char *)zout, hresolu*sizeof(float))
665 < hresolu*sizeof(float)) {
666 perror(fname);
667 exit(1);
668 }
669 }
670 if (donorm)
671 free((char *)zout);
672 close(fd);
673 }
674
675
676 isfloat(s) /* see if string is floating number */
677 register char *s;
678 {
679 for ( ; *s; s++)
680 if ((*s < '0' || *s > '9') && *s != '.' && *s != '-'
681 && *s != 'e' && *s != 'E' && *s != '+')
682 return(0);
683 return(1);
684 }
685
686
687 backfill(x, y) /* fill pixel with background */
688 int x, y;
689 {
690 register BYTE *dest = pscan(y)[x];
691
692 copycolr(dest, backcolr);
693 zscan(y)[x] = backz;
694 }
695
696
697 calstart(prog, args) /* start fill calculation */
698 char *prog, *args;
699 {
700 char combuf[512];
701 char *argv[64];
702 int rval;
703 register char **wp, *cp;
704
705 if (childpid != -1) {
706 fprintf(stderr, "%s: too many calculations\n", progname);
707 exit(1);
708 }
709 strcpy(combuf, prog);
710 strcat(combuf, args);
711 cp = combuf;
712 wp = argv;
713 for ( ; ; ) {
714 while (isspace(*cp)) cp++;
715 if (!*cp) break;
716 *wp++ = cp;
717 while (!isspace(*cp))
718 if (!*cp++) goto done;
719 *cp++ = '\0';
720 }
721 done:
722 *wp = NULL;
723 /* start process */
724 if ((rval = open_process(PDesc, argv)) < 0)
725 syserror();
726 if (rval == 0) {
727 fprintf(stderr, "%s: command not found\n", argv[0]);
728 exit(1);
729 }
730 packsiz = rval/(6*sizeof(float)) - 1;
731 if (packsiz > PACKSIZ)
732 packsiz = PACKSIZ;
733 queuesiz = 0;
734 }
735
736
737 caldone() /* done with calculation */
738 {
739 if (childpid == -1)
740 return;
741 clearqueue();
742 close_process(PDesc);
743 childpid = -1;
744 }
745
746
747 rcalfill(x, y) /* fill with ray-calculated pixel */
748 int x, y;
749 {
750 if (queuesiz >= packsiz) /* flush queue if needed */
751 clearqueue();
752 /* add position to queue */
753 queue[queuesiz][0] = x;
754 queue[queuesiz][1] = y;
755 queuesiz++;
756 }
757
758
759 clearqueue() /* process queue */
760 {
761 FVECT orig, dir;
762 float fbuf[6*(PACKSIZ+1)];
763 register float *fbp;
764 register int i;
765
766 fbp = fbuf;
767 for (i = 0; i < queuesiz; i++) {
768 viewray(orig, dir, &ourview,
769 (queue[i][0]+.5)/hresolu,
770 (queue[i][1]+.5)/vresolu);
771 *fbp++ = orig[0]; *fbp++ = orig[1]; *fbp++ = orig[2];
772 *fbp++ = dir[0]; *fbp++ = dir[1]; *fbp++ = dir[2];
773 }
774 /* mark end and get results */
775 bzero((char *)fbp, 6*sizeof(float));
776 if (process(PDesc, fbuf, fbuf, 4*sizeof(float)*queuesiz,
777 6*sizeof(float)*(queuesiz+1)) !=
778 4*sizeof(float)*queuesiz) {
779 fprintf(stderr, "%s: error reading from rtrace process\n",
780 progname);
781 exit(1);
782 }
783 fbp = fbuf;
784 for (i = 0; i < queuesiz; i++) {
785 if (ourexp > 0 && ourexp != 1.0) {
786 fbp[0] *= ourexp;
787 fbp[1] *= ourexp;
788 fbp[2] *= ourexp;
789 }
790 setcolr(pscan(queue[i][1])[queue[i][0]],
791 fbp[0], fbp[1], fbp[2]);
792 zscan(queue[i][1])[queue[i][0]] = fbp[3];
793 fbp += 4;
794 }
795 queuesiz = 0;
796 }
797
798
799 syserror() /* report error and exit */
800 {
801 perror(progname);
802 exit(1);
803 }
