root/radiance/src/px/pinterp.c
Revision: 2.3
Committed: Mon Mar 23 16:50:26 1992 UTC (33 years, 6 months ago) by greg
Changes since 2.2: +78 -74 lines
modified to use process.c routines and badarg.c -- not checked!
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Interpolate and extrapolate pictures with different view parameters.
9 *
10 * Greg Ward 09Dec89
11 */
12
13 #include "standard.h"
14
15 #include <fcntl.h>
16
17 #include <ctype.h>
18
19 #include "view.h"
20
21 #include "color.h"
22
23 #include "resolu.h"
24
25 #ifndef BSD
26 #define vfork fork
27 #endif
28
29 #define pscan(y) (ourpict+(y)*hresolu)
30 #define zscan(y) (ourzbuf+(y)*hresolu)
31
32 #define F_FORE 1 /* fill foreground */
33 #define F_BACK 2 /* fill background */
34
35 #define PACKSIZ 256 /* max. calculation packet size */
36
37 #define RTCOM "rtrace -h- -ovl -fff"
38
39 #define ABS(x) ((x)>0?(x):-(x))
40
41 struct position {int x,y; float z;};
42
43 VIEW ourview = STDVIEW; /* desired view */
44 int hresolu = 512; /* horizontal resolution */
45 int vresolu = 512; /* vertical resolution */
46 double pixaspect = 1.0; /* pixel aspect ratio */
47
48 double zeps = .02; /* allowed z epsilon */
49
50 COLR *ourpict; /* output picture */
51 float *ourzbuf; /* corresponding z-buffer */
52
53 char *progname;
54
55 int fillo = F_FORE|F_BACK; /* selected fill options */
56 int fillsamp = 0; /* sample separation (0 == inf) */
57 extern int backfill(), rcalfill(); /* fill functions */
58 int (*fillfunc)() = backfill; /* selected fill function */
59 COLR backcolr = BLKCOLR; /* background color */
60 double backz = 0.0; /* background z value */
61 int normdist = 1; /* normalized distance? */
62 double ourexp = -1; /* output picture exposure */
63
64 VIEW theirview = STDVIEW; /* input view */
65 int gotview; /* got input view? */
66 int wrongformat = 0; /* input in another format? */
67 RESOLU tresolu; /* input resolution */
68 double theirexp; /* input picture exposure */
69 double theirs2ours[4][4]; /* transformation matrix */
70 int hasmatrix = 0; /* has transformation matrix */
71
72 int PDesc[3] = {-1,-1,-1}; /* rtrace process descriptor */
73 #define childpid (PDesc[2])
74 unsigned short queue[PACKSIZ][2]; /* pending pixels */
75 int packsiz; /* actual packet size */
76 int queuesiz; /* number of pixels pending */
77
78
79 main(argc, argv) /* interpolate pictures */
80 int argc;
81 char *argv[];
82 {
83 #define check(ol,al) if (argv[i][ol] || \
84 badarg(argc-i-1,argv+i+1,al)) \
85 goto badopt
86 int gotvfile = 0;
87 char *zfile = NULL;
88 char *err;
89 int i, rval;
90
91 progname = argv[0];
92
93 for (i = 1; i < argc && argv[i][0] == '-'; i++) {
94 rval = getviewopt(&ourview, argc-i, argv+i);
95 if (rval >= 0) {
96 i += rval;
97 continue;
98 }
99 switch (argv[i][1]) {
100 case 't': /* threshold */
101 check(2,"f");
102 zeps = atof(argv[++i]);
103 break;
104 case 'n': /* dist. normalized? */
105 check(2,NULL);
106 normdist = !normdist;
107 break;
108 case 'f': /* fill type */
109 switch (argv[i][2]) {
110 case '0': /* none */
111 check(3,NULL);
112 fillo = 0;
113 break;
114 case 'f': /* foreground */
115 check(3,NULL);
116 fillo = F_FORE;
117 break;
118 case 'b': /* background */
119 check(3,NULL);
120 fillo = F_BACK;
121 break;
122 case 'a': /* all */
123 check(3,NULL);
124 fillo = F_FORE|F_BACK;
125 break;
126 case 's': /* sample */
127 check(3,"i");
128 fillsamp = atoi(argv[++i]);
129 break;
130 case 'c': /* color */
131 check(3,"fff");
132 fillfunc = backfill;
133 setcolr(backcolr, atof(argv[i+1]),
134 atof(argv[i+2]), atof(argv[i+3]));
135 i += 3;
136 break;
137 case 'z': /* z value */
138 check(3,"f");
139 fillfunc = backfill;
140 backz = atof(argv[++i]);
141 break;
142 case 'r': /* rtrace */
143 check(3,"s");
144 fillfunc = rcalfill;
145 calstart(RTCOM, argv[++i]);
146 break;
147 default:
148 goto badopt;
149 }
150 break;
151 case 'z': /* z file */
152 check(2,"s");
153 zfile = argv[++i];
154 break;
155 case 'x': /* x resolution */
156 check(2,"i");
157 hresolu = atoi(argv[++i]);
158 break;
159 case 'y': /* y resolution */
160 check(2,"i");
161 vresolu = atoi(argv[++i]);
162 break;
163 case 'p': /* pixel aspect */
164 check(2,"f");
165 pixaspect = atof(argv[++i]);
166 break;
167 case 'v': /* view file */
168 if (argv[i][2] != 'f')
169 goto badopt;
170 check(3,"s");
171 gotvfile = viewfile(argv[++i], &ourview, 0, 0);
172 if (gotvfile < 0) {
173 perror(argv[i]);
174 exit(1);
175 } else if (gotvfile == 0) {
176 fprintf(stderr, "%s: bad view file\n",
177 argv[i]);
178 exit(1);
179 }
180 break;
181 default:
182 badopt:
183 fprintf(stderr, "%s: command line error at '%s'\n",
184 progname, argv[i]);
185 goto userr;
186 }
187 }
188 /* check arguments */
189 if ((argc-i)%2)
190 goto userr;
191 if (fillsamp == 1)
192 fillo &= ~F_BACK;
193 /* set view */
194 if (err = setview(&ourview)) {
195 fprintf(stderr, "%s: %s\n", progname, err);
196 exit(1);
197 }
198 normaspect(viewaspect(&ourview), &pixaspect, &hresolu, &vresolu);
199 /* allocate frame */
200 ourpict = (COLR *)malloc(hresolu*vresolu*sizeof(COLR));
201 ourzbuf = (float *)calloc(hresolu*vresolu,sizeof(float));
202 if (ourpict == NULL || ourzbuf == NULL)
203 syserror();
204 /* get input */
205 for ( ; i < argc; i += 2)
206 addpicture(argv[i], argv[i+1]);
207 /* fill in spaces */
208 if (fillo&F_BACK)
209 backpicture(fillfunc, fillsamp);
210 else
211 fillpicture(fillfunc);
212 /* close calculation */
213 caldone();
214 /* add to header */
215 printargs(argc, argv, stdout);
216 if (gotvfile) {
217 fputs(VIEWSTR, stdout);
218 fprintview(&ourview, stdout);
219 putc('\n', stdout);
220 }
221 if (pixaspect < .99 || pixaspect > 1.01)
222 fputaspect(pixaspect, stdout);
223 if (ourexp > 0 && (ourexp < .995 || ourexp > 1.005))
224 fputexpos(ourexp, stdout);
225 fputformat(COLRFMT, stdout);
226 putc('\n', stdout);
227 /* write picture */
228 writepicture();
229 /* write z file */
230 if (zfile != NULL)
231 writedistance(zfile);
232
233 exit(0);
234 userr:
235 fprintf(stderr,
236 "Usage: %s [view opts][-t eps][-z zout][-fT][-n] pfile zspec ..\n",
237 progname);
238 exit(1);
239 #undef check
240 }
241
242
243 headline(s) /* process header string */
244 char *s;
245 {
246 static char *altname[] = {VIEWSTR,"rpict","rview","pinterp",NULL};
247 register char **an;
248 char fmt[32];
249
250 if (isformat(s)) {
251 formatval(fmt, s);
252 wrongformat = strcmp(fmt, COLRFMT);
253 return;
254 }
255 putc('\t', stdout);
256 fputs(s, stdout);
257
258 if (isexpos(s)) {
259 theirexp *= exposval(s);
260 return;
261 }
262 for (an = altname; *an != NULL; an++)
263 if (!strncmp(*an, s, strlen(*an))) {
264 if (sscanview(&theirview, s+strlen(*an)) > 0)
265 gotview++;
266 break;
267 }
268 }
269
270
271 addpicture(pfile, zspec) /* add picture to output */
272 char *pfile, *zspec;
273 {
274 FILE *pfp;
275 int zfd;
276 char *err;
277 COLR *scanin;
278 float *zin;
279 struct position *plast;
280 int y;
281 /* open picture file */
282 if ((pfp = fopen(pfile, "r")) == NULL) {
283 perror(pfile);
284 exit(1);
285 }
286 /* get header with exposure and view */
287 theirexp = 1.0;
288 gotview = 0;
289 printf("%s:\n", pfile);
290 getheader(pfp, headline, NULL);
291 if (wrongformat || !gotview || !fgetsresolu(&tresolu, pfp)) {
292 fprintf(stderr, "%s: picture format error\n", pfile);
293 exit(1);
294 }
295 if (ourexp <= 0)
296 ourexp = theirexp;
297 else if (ABS(theirexp-ourexp) > .01*ourexp)
298 fprintf(stderr, "%s: different exposure (warning)\n", pfile);
299 if (err = setview(&theirview)) {
300 fprintf(stderr, "%s: %s\n", pfile, err);
301 exit(1);
302 }
303 /* compute transformation */
304 hasmatrix = pixform(theirs2ours, &theirview, &ourview);
305 /* allocate scanlines */
306 scanin = (COLR *)malloc(scanlen(&tresolu)*sizeof(COLR));
307 zin = (float *)malloc(scanlen(&tresolu)*sizeof(float));
308 plast = (struct position *)calloc(scanlen(&tresolu),
309 sizeof(struct position));
310 if (scanin == NULL || zin == NULL || plast == NULL)
311 syserror();
312 /* get z specification or file */
313 if ((zfd = open(zspec, O_RDONLY)) == -1) {
314 double zvalue;
315 register int x;
316 if (!isfloat(zspec) || (zvalue = atof(zspec)) <= 0.0) {
317 perror(zspec);
318 exit(1);
319 }
320 for (x = scanlen(&tresolu); x-- > 0; )
321 zin[x] = zvalue;
322 }
323 /* load image */
324 for (y = 0; y < numscans(&tresolu); y++) {
325 if (freadcolrs(scanin, scanlen(&tresolu), pfp) < 0) {
326 fprintf(stderr, "%s: read error\n", pfile);
327 exit(1);
328 }
329 if (zfd != -1 && read(zfd,(char *)zin,
330 scanlen(&tresolu)*sizeof(float))
331 < scanlen(&tresolu)*sizeof(float)) {
332 fprintf(stderr, "%s: read error\n", zspec);
333 exit(1);
334 }
335 addscanline(y, scanin, zin, plast);
336 }
337 /* clean up */
338 free((char *)scanin);
339 free((char *)zin);
340 free((char *)plast);
341 fclose(pfp);
342 if (zfd != -1)
343 close(zfd);
344 }
345
346
347 pixform(xfmat, vw1, vw2) /* compute view1 to view2 matrix */
348 register double xfmat[4][4];
349 register VIEW *vw1, *vw2;
350 {
351 double m4t[4][4];
352
353 if (vw1->type != VT_PER && vw1->type != VT_PAR)
354 return(0);
355 if (vw2->type != VT_PER && vw2->type != VT_PAR)
356 return(0);
357 setident4(xfmat);
358 xfmat[0][0] = vw1->hvec[0];
359 xfmat[0][1] = vw1->hvec[1];
360 xfmat[0][2] = vw1->hvec[2];
361 xfmat[1][0] = vw1->vvec[0];
362 xfmat[1][1] = vw1->vvec[1];
363 xfmat[1][2] = vw1->vvec[2];
364 xfmat[2][0] = vw1->vdir[0];
365 xfmat[2][1] = vw1->vdir[1];
366 xfmat[2][2] = vw1->vdir[2];
367 xfmat[3][0] = vw1->vp[0];
368 xfmat[3][1] = vw1->vp[1];
369 xfmat[3][2] = vw1->vp[2];
370 setident4(m4t);
371 m4t[0][0] = vw2->hvec[0]/vw2->hn2;
372 m4t[1][0] = vw2->hvec[1]/vw2->hn2;
373 m4t[2][0] = vw2->hvec[2]/vw2->hn2;
374 m4t[3][0] = -DOT(vw2->vp,vw2->hvec)/vw2->hn2;
375 m4t[0][1] = vw2->vvec[0]/vw2->vn2;
376 m4t[1][1] = vw2->vvec[1]/vw2->vn2;
377 m4t[2][1] = vw2->vvec[2]/vw2->vn2;
378 m4t[3][1] = -DOT(vw2->vp,vw2->vvec)/vw2->vn2;
379 m4t[0][2] = vw2->vdir[0];
380 m4t[1][2] = vw2->vdir[1];
381 m4t[2][2] = vw2->vdir[2];
382 m4t[3][2] = -DOT(vw2->vp,vw2->vdir);
383 multmat4(xfmat, xfmat, m4t);
384 return(1);
385 }
386
387
388 addscanline(y, pline, zline, lasty) /* add scanline to output */
389 int y;
390 COLR *pline;
391 float *zline;
392 struct position *lasty; /* input/output */
393 {
394 extern double sqrt();
395 FVECT pos;
396 struct position lastx, newpos;
397 register int x;
398
399 lastx.z = 0;
400 for (x = scanlen(&tresolu); x-- > 0; ) {
401 pix2loc(pos, &tresolu, x, y);
402 pos[2] = zline[x];
403 if (movepixel(pos) < 0) {
404 lasty[x].z = lastx.z = 0; /* mark invalid */
405 continue;
406 }
407 newpos.x = pos[0] * hresolu;
408 newpos.y = pos[1] * vresolu;
409 newpos.z = zline[x];
410 /* add pixel to our image */
411 if (pos[0] >= 0 && newpos.x < hresolu
412 && pos[1] >= 0 && newpos.y < vresolu) {
413 addpixel(&newpos, &lastx, &lasty[x], pline[x], pos[2]);
414 lasty[x].x = lastx.x = newpos.x;
415 lasty[x].y = lastx.y = newpos.y;
416 lasty[x].z = lastx.z = newpos.z;
417 } else
418 lasty[x].z = lastx.z = 0; /* mark invalid */
419 }
420 }
421
422
423 addpixel(p0, p1, p2, pix, z) /* fill in pixel parallelogram */
424 struct position *p0, *p1, *p2;
425 COLR pix;
426 double z;
427 {
428 double zt = 2.*zeps*p0->z; /* threshold */
429 int s1x, s1y, s2x, s2y; /* step sizes */
430 int l1, l2, c1, c2; /* side lengths and counters */
431 int p1isy; /* p0p1 along y? */
432 int x1, y1; /* p1 position */
433 register int x, y; /* final position */
434
435 /* compute vector p0p1 */
436 if (fillo&F_FORE && ABS(p1->z-p0->z) <= zt) {
437 s1x = p1->x - p0->x;
438 s1y = p1->y - p0->y;
439 l1 = ABS(s1x);
440 if (p1isy = (ABS(s1y) > l1))
441 l1 = ABS(s1y);
442 } else {
443 l1 = s1x = s1y = 1;
444 p1isy = -1;
445 }
446 /* compute vector p0p2 */
447 if (fillo&F_FORE && ABS(p2->z-p0->z) <= zt) {
448 s2x = p2->x - p0->x;
449 s2y = p2->y - p0->y;
450 if (p1isy == 1)
451 l2 = ABS(s2x);
452 else {
453 l2 = ABS(s2y);
454 if (p1isy != 0 && ABS(s2x) > l2)
455 l2 = ABS(s2x);
456 }
457 } else
458 l2 = s2x = s2y = 1;
459 /* fill the parallelogram */
460 for (c1 = l1; c1-- > 0; ) {
461 x1 = p0->x + c1*s1x/l1;
462 y1 = p0->y + c1*s1y/l1;
463 for (c2 = l2; c2-- > 0; ) {
464 x = x1 + c2*s2x/l2;
465 if (x < 0 || x >= hresolu)
466 continue;
467 y = y1 + c2*s2y/l2;
468 if (y < 0 || y >= vresolu)
469 continue;
470 if (zscan(y)[x] <= 0 || zscan(y)[x]-z
471 > zeps*zscan(y)[x]) {
472 zscan(y)[x] = z;
473 copycolr(pscan(y)[x], pix);
474 }
475 }
476 }
477 }
478
479
480 movepixel(pos) /* reposition image point */
481 FVECT pos;
482 {
483 FVECT pt, direc;
484
485 if (pos[2] <= 0) /* empty pixel */
486 return(-1);
487 if (hasmatrix) {
488 pos[0] += theirview.hoff - .5;
489 pos[1] += theirview.voff - .5;
490 if (theirview.type == VT_PER) {
491 if (normdist) /* adjust for eye-ray distance */
492 pos[2] /= sqrt( 1.
493 + pos[0]*pos[0]*theirview.hn2
494 + pos[1]*pos[1]*theirview.vn2 );
495 pos[0] *= pos[2];
496 pos[1] *= pos[2];
497 }
498 multp3(pos, pos, theirs2ours);
499 if (pos[2] <= 0)
500 return(-1);
501 if (ourview.type == VT_PER) {
502 pos[0] /= pos[2];
503 pos[1] /= pos[2];
504 }
505 pos[0] += .5 - ourview.hoff;
506 pos[1] += .5 - ourview.voff;
507 return(0);
508 }
509 if (viewray(pt, direc, &theirview, pos[0], pos[1]) < 0)
510 return(-1);
511 pt[0] += direc[0]*pos[2];
512 pt[1] += direc[1]*pos[2];
513 pt[2] += direc[2]*pos[2];
514 viewloc(pos, &ourview, pt);
515 if (pos[2] <= 0)
516 return(-1);
517 return(0);
518 }
519
520
521 backpicture(fill, samp) /* background fill algorithm */
522 int (*fill)();
523 int samp;
524 {
525 int *yback, xback;
526 int y;
527 register int x, i;
528 /* get back buffer */
529 yback = (int *)malloc(hresolu*sizeof(int));
530 if (yback == NULL)
531 syserror();
532 for (x = 0; x < hresolu; x++)
533 yback[x] = -2;
534 /*
535 * Xback and yback are the pixel locations of suitable
536 * background values in each direction.
537 * A value of -2 means unassigned, and -1 means
538 * that there is no suitable background in this direction.
539 */
540 /* fill image */
541 for (y = 0; y < vresolu; y++) {
542 xback = -2;
543 for (x = 0; x < hresolu; x++)
544 if (zscan(y)[x] <= 0) { /* empty pixel */
545 /*
546 * First, find background from above or below.
547 * (farthest assigned pixel)
548 */
549 if (yback[x] == -2) {
550 for (i = y+1; i < vresolu; i++)
551 if (zscan(i)[x] > 0)
552 break;
553 if (i < vresolu
554 && (y <= 0 || zscan(y-1)[x] < zscan(i)[x]))
555 yback[x] = i;
556 else
557 yback[x] = y-1;
558 }
559 /*
560 * Next, find background from left or right.
561 */
562 if (xback == -2) {
563 for (i = x+1; i < hresolu; i++)
564 if (zscan(y)[i] > 0)
565 break;
566 if (i < hresolu
567 && (x <= 0 || zscan(y)[x-1] < zscan(y)[i]))
568 xback = i;
569 else
570 xback = x-1;
571 }
572 /*
573 * If we have no background for this pixel,
574 * use the given fill function.
575 */
576 if (xback < 0 && yback[x] < 0)
577 goto fillit;
578 /*
579 * Compare, and use the background that is
580 * farther, unless one of them is next to us.
581 * If the background is too distant, call
582 * the fill function.
583 */
584 if ( yback[x] < 0
585 || (xback >= 0 && ABS(x-xback) <= 1)
586 || ( ABS(y-yback[x]) > 1
587 && zscan(yback[x])[x]
588 < zscan(y)[xback] ) ) {
589 if (samp > 0 && ABS(x-xback) >= samp)
590 goto fillit;
591 copycolr(pscan(y)[x],pscan(y)[xback]);
592 zscan(y)[x] = zscan(y)[xback];
593 } else {
594 if (samp > 0 && ABS(y-yback[x]) > samp)
595 goto fillit;
596 copycolr(pscan(y)[x],pscan(yback[x])[x]);
597 zscan(y)[x] = zscan(yback[x])[x];
598 }
599 continue;
600 fillit:
601 (*fill)(x,y);
602 if (fill == rcalfill) { /* use it */
603 clearqueue();
604 xback = x;
605 yback[x] = y;
606 }
607 } else { /* full pixel */
608 yback[x] = -2;
609 xback = -2;
610 }
611 }
612 free((char *)yback);
613 }
614
615
616 fillpicture(fill) /* paint in empty pixels using fill */
617 int (*fill)();
618 {
619 register int x, y;
620
621 for (y = 0; y < vresolu; y++)
622 for (x = 0; x < hresolu; x++)
623 if (zscan(y)[x] <= 0)
624 (*fill)(x,y);
625 }
626
627
628 writepicture() /* write out picture */
629 {
630 int y;
631
632 fprtresolu(hresolu, vresolu, stdout);
633 for (y = vresolu-1; y >= 0; y--)
634 if (fwritecolrs(pscan(y), hresolu, stdout) < 0)
635 syserror();
636 }
637
638
639 writedistance(fname) /* write out z file */
640 char *fname;
641 {
642 extern double sqrt();
643 int donorm = normdist && ourview.type == VT_PER;
644 int fd;
645 int y;
646 float *zout;
647
648 if ((fd = open(fname, O_WRONLY|O_CREAT|O_TRUNC, 0666)) == -1) {
649 perror(fname);
650 exit(1);
651 }
652 if (donorm
653 && (zout = (float *)malloc(hresolu*sizeof(float))) == NULL)
654 syserror();
655 for (y = vresolu-1; y >= 0; y--) {
656 if (donorm) {
657 double vx, yzn2;
658 register int x;
659 yzn2 = (y+.5)/vresolu + ourview.voff - .5;
660 yzn2 = 1. + yzn2*yzn2*ourview.vn2;
661 for (x = 0; x < hresolu; x++) {
662 vx = (x+.5)/hresolu + ourview.hoff - .5;
663 zout[x] = zscan(y)[x]
664 * sqrt(vx*vx*ourview.hn2 + yzn2);
665 }
666 } else
667 zout = zscan(y);
668 if (write(fd, (char *)zout, hresolu*sizeof(float))
669 < hresolu*sizeof(float)) {
670 perror(fname);
671 exit(1);
672 }
673 }
674 if (donorm)
675 free((char *)zout);
676 close(fd);
677 }
678
679
680 isfloat(s) /* see if string is floating number */
681 register char *s;
682 {
683 for ( ; *s; s++)
684 if ((*s < '0' || *s > '9') && *s != '.' && *s != '-'
685 && *s != 'e' && *s != 'E' && *s != '+')
686 return(0);
687 return(1);
688 }
689
690
691 backfill(x, y) /* fill pixel with background */
692 int x, y;
693 {
694 register BYTE *dest = pscan(y)[x];
695
696 copycolr(dest, backcolr);
697 zscan(y)[x] = backz;
698 }
699
700
701 calstart(prog, args) /* start fill calculation */
702 char *prog, *args;
703 {
704 char combuf[512];
705 char *argv[64];
706 int rval;
707 register char **wp, *cp;
708
709 if (childpid != -1) {
710 fprintf(stderr, "%s: too many calculations\n", progname);
711 exit(1);
712 }
713 strcpy(combuf, prog);
714 strcat(combuf, args);
715 cp = combuf;
716 wp = argv;
717 for ( ; ; ) {
718 while (isspace(*cp)) cp++;
719 if (!*cp) break;
720 *wp++ = cp;
721 while (!isspace(*cp))
722 if (!*cp++) goto done;
723 *cp++ = '\0';
724 }
725 done:
726 *wp = NULL;
727 /* start process */
728 if ((rval = open_process(PDesc, argv)) < 0)
729 syserror();
730 if (rval == 0) {
731 fprintf(stderr, "%s: command not found\n", argv[0]);
732 exit(1);
733 }
734 packsiz = rval/(6*sizeof(float)) - 1;
735 if (packsiz > PACKSIZ)
736 packsiz = PACKSIZ;
737 queuesiz = 0;
738 }
739
740
741 caldone() /* done with calculation */
742 {
743 if (childpid == -1)
744 return;
745 clearqueue();
746 close_process(PDesc);
747 childpid = -1;
748 }
749
750
751 rcalfill(x, y) /* fill with ray-calculated pixel */
752 int x, y;
753 {
754 if (queuesiz >= packsiz) /* flush queue if needed */
755 clearqueue();
756 /* add position to queue */
757 queue[queuesiz][0] = x;
758 queue[queuesiz][1] = y;
759 queuesiz++;
760 }
761
762
763 clearqueue() /* process queue */
764 {
765 FVECT orig, dir;
766 float fbuf[6*(PACKSIZ+1)];
767 register float *fbp;
768 register int i;
769
770 fbp = fbuf;
771 for (i = 0; i < queuesiz; i++) {
772 viewray(orig, dir, &ourview,
773 (queue[i][0]+.5)/hresolu,
774 (queue[i][1]+.5)/vresolu);
775 *fbp++ = orig[0]; *fbp++ = orig[1]; *fbp++ = orig[2];
776 *fbp++ = dir[0]; *fbp++ = dir[1]; *fbp++ = dir[2];
777 }
778 /* mark end and get results */
779 bzero((char *)fbp, 6*sizeof(float));
780 if (process(PDesc, fbuf, fbuf, 4*sizeof(float)*queuesiz,
781 6*sizeof(float)*(queuesiz+1)) !=
782 4*sizeof(float)*queuesiz) {
783 fprintf(stderr, "%s: error reading from rtrace process\n",
784 progname);
785 exit(1);
786 }
787 fbp = fbuf;
788 for (i = 0; i < queuesiz; i++) {
789 if (ourexp > 0 && ourexp != 1.0) {
790 fbp[0] *= ourexp;
791 fbp[1] *= ourexp;
792 fbp[2] *= ourexp;
793 }
794 setcolr(pscan(queue[i][1])[queue[i][0]],
795 fbp[0], fbp[1], fbp[2]);
796 zscan(queue[i][1])[queue[i][0]] = fbp[3];
797 fbp += 4;
798 }
799 queuesiz = 0;
800 }
801
802
803 syserror() /* report error and exit */
804 {
805 perror(progname);
806 exit(1);
807 }
