root/radiance/src/px/pinterp.c
Revision: 1.16
Committed: Sat Jan 6 22:27:10 1990 UTC (35 years, 9 months ago) by greg
Changes since 1.15: +23 -6 lines
added code to deal with picture exposure
2 static char SCCSid[] = "$SunId$ LBL";
4
5 /*
6 * Interpolate and extrapolate pictures with different view parameters.
7 *
8 * Greg Ward 09Dec89
9 */
10
11 #include "standard.h"
12
13 #include "view.h"
14
15 #include "color.h"
16
17 #define pscan(y) (ourpict+(y)*ourview.hresolu)
18 #define zscan(y) (ourzbuf+(y)*ourview.hresolu)
19
20 #define F_FORE 1 /* fill foreground */
21 #define F_BACK 2 /* fill background */
22
23 #define PACKSIZ 42 /* calculation packet size */
24
25 #define RTCOM "rtrace -h -ovl -fff -x %d %s"
26
27 #define ABS(x) ((x)>0?(x):-(x))
28
29 struct position {int x,y; float z;};
30
31 VIEW ourview = STDVIEW(512); /* desired view */
32
33 double zeps = .02; /* allowed z epsilon */
34
35 COLR *ourpict; /* output picture */
36 float *ourzbuf; /* corresponding z-buffer */
37
38 char *progname;
39
40 int fill = F_FORE|F_BACK; /* selected fill algorithm */
41 extern int backfill(), rcalfill(); /* fill functions */
42 int (*deffill)() = backfill; /* selected fill function */
43 COLR backcolr = BLKCOLR; /* background color */
44 double backz = 0.0; /* background z value */
45 int normdist = 1; /* normalized distance? */
46 double ourexp = -1; /* output picture exposure */
47
48 VIEW theirview = STDVIEW(512); /* input view */
49 int gotview; /* got input view? */
50 double theirs2ours[4][4]; /* transformation matrix */
51 double theirexp; /* input picture exposure */
52
53 int childpid = -1; /* id of fill process */
54 FILE *psend, *precv; /* pipes to/from fill calculation */
55 int queue[PACKSIZ][2]; /* pending pixels */
56 int queuesiz; /* number of pixels pending */
57
58
59 main(argc, argv) /* interpolate pictures */
60 int argc;
61 char *argv[];
62 {
63 #define check(olen,narg) if (argv[i][olen] || narg >= argc-i) goto badopt
64 extern double atof();
65 int gotvfile = 0;
66 char *zfile = NULL;
67 char *err;
68 int i;
69
70 progname = argv[0];
71
72 for (i = 1; i < argc && argv[i][0] == '-'; i++)
73 switch (argv[i][1]) {
74 case 't': /* threshold */
75 check(2,1);
76 zeps = atof(argv[++i]);
77 break;
78 case 'n': /* dist. normalized? */
79 check(2,0);
80 normdist = !normdist;
81 break;
82 case 'f': /* fill type */
83 switch (argv[i][2]) {
84 case '0': /* none */
85 check(3,0);
86 fill = 0;
87 break;
88 case 'f': /* foreground */
89 check(3,0);
90 fill = F_FORE;
91 break;
92 case 'b': /* background */
93 check(3,0);
94 fill = F_BACK;
95 break;
96 case 'a': /* all */
97 check(3,0);
98 fill = F_FORE|F_BACK;
99 break;
100 case 'c': /* color */
101 check(3,3);
102 deffill = backfill;
103 setcolr(backcolr, atof(argv[i+1]),
104 atof(argv[i+2]), atof(argv[i+3]));
105 i += 3;
106 break;
107 case 'z': /* z value */
108 check(3,1);
109 deffill = backfill;
110 backz = atof(argv[++i]);
111 break;
112 case 'r': /* rtrace */
113 check(3,1);
114 deffill = rcalfill;
115 calstart(RTCOM, argv[++i]);
116 break;
117 default:
118 goto badopt;
119 }
120 break;
121 case 'z': /* z file */
122 check(2,1);
123 zfile = argv[++i];
124 break;
125 case 'x': /* x resolution */
126 check(2,1);
127 ourview.hresolu = atoi(argv[++i]);
128 break;
129 case 'y': /* y resolution */
130 check(2,1);
131 ourview.vresolu = atoi(argv[++i]);
132 break;
133 case 'v': /* view */
134 switch (argv[i][2]) {
135 case 't': /* type */
136 check(4,0);
137 ourview.type = argv[i][3];
138 break;
139 case 'p': /* point */
140 check(3,3);
141 ourview.vp[0] = atof(argv[++i]);
142 ourview.vp[1] = atof(argv[++i]);
143 ourview.vp[2] = atof(argv[++i]);
144 break;
145 case 'd': /* direction */
146 check(3,3);
147 ourview.vdir[0] = atof(argv[++i]);
148 ourview.vdir[1] = atof(argv[++i]);
149 ourview.vdir[2] = atof(argv[++i]);
150 break;
151 case 'u': /* up */
152 check(3,3);
153 ourview.vup[0] = atof(argv[++i]);
154 ourview.vup[1] = atof(argv[++i]);
155 ourview.vup[2] = atof(argv[++i]);
156 break;
157 case 'h': /* horizontal */
158 check(3,1);
159 ourview.horiz = atof(argv[++i]);
160 break;
161 case 'v': /* vertical */
162 check(3,1);
163 ourview.vert = atof(argv[++i]);
164 break;
165 case 'f': /* file */
166 check(3,1);
167 gotvfile = viewfile(argv[++i], &ourview);
168 if (gotvfile < 0) {
169 perror(argv[i]);
170 exit(1);
171 } else if (gotvfile == 0) {
172 fprintf(stderr, "%s: bad view file\n",
173 argv[i]);
174 exit(1);
175 }
176 break;
177 default:
178 goto badopt;
179 }
180 break;
181 default:
182 badopt:
183 fprintf(stderr, "%s: command line error at '%s'\n",
184 progname, argv[i]);
185 goto userr;
186 }
187 /* check arguments */
188 if ((argc-i)%2)
189 goto userr;
190 /* set view */
191 if (err = setview(&ourview)) {
192 fprintf(stderr, "%s: %s\n", progname, err);
193 exit(1);
194 }
195 /* allocate frame */
196 ourpict = (COLR *)malloc(ourview.hresolu*ourview.vresolu*sizeof(COLR));
197 ourzbuf = (float *)calloc(ourview.hresolu*ourview.vresolu,sizeof(float));
198 if (ourpict == NULL || ourzbuf == NULL)
199 syserror();
200 /* get input */
201 for ( ; i < argc; i += 2)
202 addpicture(argv[i], argv[i+1]);
203 /* fill in spaces */
204 if (fill&F_BACK)
205 backpicture();
206 else
207 fillpicture();
208 /* close calculation */
209 caldone();
210 /* add to header */
211 printargs(argc, argv, stdout);
212 if (gotvfile) {
213 printf(VIEWSTR);
214 fprintview(&ourview, stdout);
215 printf("\n");
216 }
217 if (ourexp > 0 && ourexp != 1.0)
218 fputexpos(ourexp, stdout);
219 printf("\n");
220 /* write picture */
221 writepicture();
222 /* write z file */
223 if (zfile != NULL)
224 writedistance(zfile);
225
226 exit(0);
227 userr:
228 fprintf(stderr,
229 "Usage: %s [view opts][-t zthresh][-z zout][-fT][-n] pfile zspec ..\n",
230 progname);
231 exit(1);
232 #undef check
233 }
234
235
236 headline(s) /* process header string */
237 char *s;
238 {
239 static char *altname[] = {"rview","rpict","pinterp",VIEWSTR,NULL};
240 register char **an;
241
242 printf("\t%s", s);
243
244 if (isexpos(s)) {
245 theirexp *= exposval(s);
246 return;
247 }
248 for (an = altname; *an != NULL; an++)
249 if (!strncmp(*an, s, strlen(*an))) {
250 if (sscanview(&theirview, s+strlen(*an)) == 0)
251 gotview++;
252 break;
253 }
254 }
255
256
257 addpicture(pfile, zspec) /* add picture to output */
258 char *pfile, *zspec;
259 {
260 extern double atof();
261 FILE *pfp, *zfp;
262 char *err;
263 COLR *scanin;
264 float *zin;
265 struct position *plast;
266 int y;
267 /* open picture file */
268 if ((pfp = fopen(pfile, "r")) == NULL) {
269 perror(pfile);
270 exit(1);
271 }
272 /* get header with exposure and view */
273 theirexp = 1.0;
274 gotview = 0;
275 printf("%s:\n", pfile);
276 getheader(pfp, headline);
277 if (!gotview || fgetresolu(&theirview.hresolu, &theirview.vresolu, pfp)
278 != (YMAJOR|YDECR)) {
279 fprintf(stderr, "%s: picture view error\n", pfile);
280 exit(1);
281 }
282 if (ourexp <= 0)
283 ourexp = theirexp;
284 else if (ABS(theirexp-ourexp) > .01*ourexp)
285 fprintf(stderr, "%s: different exposure (warning)\n", pfile);
286 if (err = setview(&theirview)) {
287 fprintf(stderr, "%s: %s\n", pfile, err);
288 exit(1);
289 }
290 /* compute transformation */
291 pixform(theirs2ours, &theirview, &ourview);
292 /* allocate scanlines */
293 scanin = (COLR *)malloc(theirview.hresolu*sizeof(COLR));
294 zin = (float *)malloc(theirview.hresolu*sizeof(float));
295 plast = (struct position *)calloc(theirview.hresolu,
296 sizeof(struct position));
297 if (scanin == NULL || zin == NULL || plast == NULL)
298 syserror();
299 /* get z specification or file */
300 if ((zfp = fopen(zspec, "r")) == NULL) {
301 double zvalue;
302 register int x;
303 if (!isfloat(zspec) || (zvalue = atof(zspec)) <= 0.0) {
304 perror(zspec);
305 exit(1);
306 }
307 for (x = 0; x < theirview.hresolu; x++)
308 zin[x] = zvalue;
309 }
310 /* load image */
311 for (y = theirview.vresolu-1; y >= 0; y--) {
312 if (freadcolrs(scanin, theirview.hresolu, pfp) < 0) {
313 fprintf(stderr, "%s: read error\n", pfile);
314 exit(1);
315 }
316 if (zfp != NULL
317 && fread(zin,sizeof(float),theirview.hresolu,zfp)
318 < theirview.hresolu) {
319 fprintf(stderr, "%s: read error\n", zspec);
320 exit(1);
321 }
322 addscanline(y, scanin, zin, plast);
323 }
324 /* clean up */
325 free((char *)scanin);
326 free((char *)zin);
327 free((char *)plast);
328 fclose(pfp);
329 if (zfp != NULL)
330 fclose(zfp);
331 }
332
333
334 pixform(xfmat, vw1, vw2) /* compute view1 to view2 matrix */
335 register double xfmat[4][4];
336 register VIEW *vw1, *vw2;
337 {
338 double m4t[4][4];
339
340 setident4(xfmat);
341 xfmat[0][0] = vw1->vhinc[0];
342 xfmat[0][1] = vw1->vhinc[1];
343 xfmat[0][2] = vw1->vhinc[2];
344 xfmat[1][0] = vw1->vvinc[0];
345 xfmat[1][1] = vw1->vvinc[1];
346 xfmat[1][2] = vw1->vvinc[2];
347 xfmat[2][0] = vw1->vdir[0];
348 xfmat[2][1] = vw1->vdir[1];
349 xfmat[2][2] = vw1->vdir[2];
350 xfmat[3][0] = vw1->vp[0];
351 xfmat[3][1] = vw1->vp[1];
352 xfmat[3][2] = vw1->vp[2];
353 setident4(m4t);
354 m4t[0][0] = vw2->vhinc[0]/vw2->vhn2;
355 m4t[1][0] = vw2->vhinc[1]/vw2->vhn2;
356 m4t[2][0] = vw2->vhinc[2]/vw2->vhn2;
357 m4t[3][0] = -DOT(vw2->vp,vw2->vhinc)/vw2->vhn2;
358 m4t[0][1] = vw2->vvinc[0]/vw2->vvn2;
359 m4t[1][1] = vw2->vvinc[1]/vw2->vvn2;
360 m4t[2][1] = vw2->vvinc[2]/vw2->vvn2;
361 m4t[3][1] = -DOT(vw2->vp,vw2->vvinc)/vw2->vvn2;
362 m4t[0][2] = vw2->vdir[0];
363 m4t[1][2] = vw2->vdir[1];
364 m4t[2][2] = vw2->vdir[2];
365 m4t[3][2] = -DOT(vw2->vp,vw2->vdir);
366 multmat4(xfmat, xfmat, m4t);
367 }
368
369
370 addscanline(y, pline, zline, lasty) /* add scanline to output */
371 int y;
372 COLR *pline;
373 float *zline;
374 struct position *lasty; /* input/output */
375 {
376 extern double sqrt();
377 double pos[3];
378 struct position lastx, newpos;
379 register int x;
380
381 for (x = theirview.hresolu-1; x >= 0; x--) {
382 pos[0] = x - .5*(theirview.hresolu-1);
383 pos[1] = y - .5*(theirview.vresolu-1);
384 pos[2] = zline[x];
385 if (theirview.type == VT_PER) {
386 if (normdist) /* adjust for eye-ray distance */
387 pos[2] /= sqrt( 1.
388 + pos[0]*pos[0]*theirview.vhn2
389 + pos[1]*pos[1]*theirview.vvn2 );
390 pos[0] *= pos[2];
391 pos[1] *= pos[2];
392 }
393 multp3(pos, pos, theirs2ours);
394 if (pos[2] <= 0) {
395 lasty[x].z = lastx.z = 0; /* mark invalid */
396 continue;
397 }
398 if (ourview.type == VT_PER) {
399 pos[0] /= pos[2];
400 pos[1] /= pos[2];
401 }
402 pos[0] += .5*ourview.hresolu;
403 pos[1] += .5*ourview.vresolu;
404 newpos.x = pos[0];
405 newpos.y = pos[1];
406 newpos.z = zline[x];
407 /* add pixel to our image */
408 if (pos[0] >= 0 && newpos.x < ourview.hresolu
409 && pos[1] >= 0 && newpos.y < ourview.vresolu) {
410 addpixel(&newpos, &lastx, &lasty[x], pline[x], pos[2]);
411 lasty[x].x = lastx.x = newpos.x;
412 lasty[x].y = lastx.y = newpos.y;
413 lasty[x].z = lastx.z = newpos.z;
414 } else
415 lasty[x].z = lastx.z = 0; /* mark invalid */
416 }
417 }
418
419
420 addpixel(p0, p1, p2, pix, z) /* fill in pixel parallelogram */
421 struct position *p0, *p1, *p2;
422 COLR pix;
423 double z;
424 {
425 double zt = 2.*zeps*p0->z; /* threshold */
426 int s1x, s1y, s2x, s2y; /* step sizes */
427 int l1, l2, c1, c2; /* side lengths and counters */
428 int p1isy; /* p0p1 along y? */
429 int x1, y1; /* p1 position */
430 register int x, y; /* final position */
431
432 /* compute vector p0p1 */
433 if (fill&F_FORE && ABS(p1->z-p0->z) <= zt) {
434 s1x = p1->x - p0->x;
435 s1y = p1->y - p0->y;
436 l1 = ABS(s1x);
437 if (p1isy = (ABS(s1y) > l1))
438 l1 = ABS(s1y);
439 } else {
440 l1 = s1x = s1y = 1;
441 p1isy = -1;
442 }
443 /* compute vector p0p2 */
444 if (fill&F_FORE && ABS(p2->z-p0->z) <= zt) {
445 s2x = p2->x - p0->x;
446 s2y = p2->y - p0->y;
447 if (p1isy == 1)
448 l2 = ABS(s2x);
449 else {
450 l2 = ABS(s2y);
451 if (p1isy != 0 && ABS(s2x) > l2)
452 l2 = ABS(s2x);
453 }
454 } else
455 l2 = s2x = s2y = 1;
456 /* fill the parallelogram */
457 for (c1 = l1; c1-- > 0; ) {
458 x1 = p0->x + c1*s1x/l1;
459 y1 = p0->y + c1*s1y/l1;
460 for (c2 = l2; c2-- > 0; ) {
461 x = x1 + c2*s2x/l2;
462 y = y1 + c2*s2y/l2;
463 if (zscan(y)[x] <= 0 || zscan(y)[x]-z
464 > zeps*zscan(y)[x]) {
465 zscan(y)[x] = z;
466 copycolr(pscan(y)[x], pix);
467 }
468 }
469 }
470 }
471
472
473 backpicture() /* background fill algorithm */
474 {
475 int *yback, xback;
476 int y;
477 COLR pfill;
478 register int x, i;
479 /* get back buffer */
480 yback = (int *)malloc(ourview.hresolu*sizeof(int));
481 if (yback == NULL)
482 syserror();
483 for (x = 0; x < ourview.hresolu; x++)
484 yback[x] = -2;
485 /*
486 * Xback and yback are the pixel locations of suitable
487 * background values in each direction.
488 * A value of -2 means unassigned, and -1 means
489 * that there is no suitable background in this direction.
490 */
491 /* fill image */
492 for (y = 0; y < ourview.vresolu; y++) {
493 xback = -2;
494 for (x = 0; x < ourview.hresolu; x++)
495 if (zscan(y)[x] <= 0) { /* empty pixel */
496 /*
497 * First, find background from above or below.
498 * (farthest assigned pixel)
499 */
500 if (yback[x] == -2) {
501 for (i = y+1; i < ourview.vresolu; i++)
502 if (zscan(i)[x] > 0)
503 break;
504 if (i < ourview.vresolu
505 && (y <= 0 || zscan(y-1)[x] < zscan(i)[x]))
506 yback[x] = i;
507 else
508 yback[x] = y-1;
509 }
510 /*
511 * Next, find background from left or right.
512 */
513 if (xback == -2) {
514 for (i = x+1; i < ourview.hresolu; i++)
515 if (zscan(y)[i] > 0)
516 break;
517 if (i < ourview.hresolu
518 && (x <= 0 || zscan(y)[x-1] < zscan(y)[i]))
519 xback = i;
520 else
521 xback = x-1;
522 }
523 /*
524 * Check to see if we have no background for
525 * this pixel. If not, use background color.
526 */
527 if (xback < 0 && yback[x] < 0) {
528 (*deffill)(x,y);
529 continue;
530 }
531 /*
532 * Compare, and use the background that is
533 * farther, unless one of them is next to us.
534 */
535 if ( yback[x] < 0
536 || (xback >= 0 && ABS(x-xback) <= 1)
537 || ( ABS(y-yback[x]) > 1
538 && zscan(yback[x])[x]
539 < zscan(y)[xback] ) ) {
540 copycolr(pscan(y)[x],pscan(y)[xback]);
541 zscan(y)[x] = zscan(y)[xback];
542 } else {
543 copycolr(pscan(y)[x],pscan(yback[x])[x]);
544 zscan(y)[x] = zscan(yback[x])[x];
545 }
546 } else { /* full pixel */
547 yback[x] = -2;
548 xback = -2;
549 }
550 }
551 free((char *)yback);
552 }
553
554
555 fillpicture() /* paint in empty pixels with default */
556 {
557 register int x, y;
558
559 for (y = 0; y < ourview.vresolu; y++)
560 for (x = 0; x < ourview.hresolu; x++)
561 if (zscan(y)[x] <= 0)
562 (*deffill)(x,y);
563 }
564
565
566 writepicture() /* write out picture */
567 {
568 int y;
569
570 fputresolu(YMAJOR|YDECR, ourview.hresolu, ourview.vresolu, stdout);
571 for (y = ourview.vresolu-1; y >= 0; y--)
572 if (fwritecolrs(pscan(y), ourview.hresolu, stdout) < 0)
573 syserror();
574 }
575
576
577 writedistance(fname) /* write out z file */
578 char *fname;
579 {
580 extern double sqrt();
581 int donorm = normdist && ourview.type == VT_PER;
582 FILE *fp;
583 int y;
584 float *zout;
585
586 if ((fp = fopen(fname, "w")) == NULL) {
587 perror(fname);
588 exit(1);
589 }
590 if (donorm
591 && (zout = (float *)malloc(ourview.hresolu*sizeof(float))) == NULL)
592 syserror();
593 for (y = ourview.vresolu-1; y >= 0; y--) {
594 if (donorm) {
595 double vx, yzn2;
596 register int x;
597 yzn2 = y - .5*(ourview.vresolu-1);
598 yzn2 = 1. + yzn2*yzn2*ourview.vvn2;
599 for (x = 0; x < ourview.hresolu; x++) {
600 vx = x - .5*(ourview.hresolu-1);
601 zout[x] = zscan(y)[x]
602 * sqrt(vx*vx*ourview.vhn2 + yzn2);
603 }
604 } else
605 zout = zscan(y);
606 if (fwrite(zout, sizeof(float), ourview.hresolu, fp)
607 < ourview.hresolu) {
608 perror(fname);
609 exit(1);
610 }
611 }
612 if (donorm)
613 free((char *)zout);
614 fclose(fp);
615 }
616
617
618 isfloat(s) /* see if string is floating number */
619 register char *s;
620 {
621 for ( ; *s; s++)
622 if ((*s < '0' || *s > '9') && *s != '.' && *s != '-'
623 && *s != 'e' && *s != 'E' && *s != '+')
624 return(0);
625 return(1);
626 }
627
628
629 backfill(x, y) /* fill pixel with background */
630 int x, y;
631 {
632 register BYTE *dest = pscan(y)[x];
633
634 copycolr(dest, backcolr);
635 zscan(y)[x] = backz;
636 }
637
638
639 calstart(prog, args) /* start fill calculation */
640 char *prog, *args;
641 {
642 char combuf[512];
643 int p0[2], p1[2];
644
645 if (childpid != -1) {
646 fprintf(stderr, "%s: too many calculations\n", progname);
647 exit(1);
648 }
649 sprintf(combuf, prog, PACKSIZ, args);
650 if (pipe(p0) < 0 || pipe(p1) < 0)
651 syserror();
652 if ((childpid = vfork()) == 0) { /* fork calculation */
653 close(p0[1]);
654 close(p1[0]);
655 if (p0[0] != 0) {
656 dup2(p0[0], 0);
657 close(p0[0]);
658 }
659 if (p1[1] != 1) {
660 dup2(p1[1], 1);
661 close(p1[1]);
662 }
663 execl("/bin/sh", "sh", "-c", combuf, 0);
664 perror("/bin/sh");
665 _exit(127);
666 }
667 if (childpid == -1)
668 syserror();
669 close(p0[0]);
670 close(p1[1]);
671 if ((psend = fdopen(p0[1], "w")) == NULL)
672 syserror();
673 if ((precv = fdopen(p1[0], "r")) == NULL)
674 syserror();
675 queuesiz = 0;
676 }
677
678
679 caldone() /* done with calculation */
680 {
681 int pid;
682
683 if (childpid == -1)
684 return;
685 if (fclose(psend) == EOF)
686 syserror();
687 clearqueue();
688 fclose(precv);
689 while ((pid = wait(0)) != -1 && pid != childpid)
690 ;
691 childpid = -1;
692 }
693
694
695 rcalfill(x, y) /* fill with ray-calculated pixel */
696 int x, y;
697 {
698 FVECT orig, dir;
699 float outbuf[6];
700
701 if (queuesiz >= PACKSIZ) { /* flush queue */
702 if (fflush(psend) == EOF)
703 syserror();
704 clearqueue();
705 }
706 /* send new ray */
707 rayview(orig, dir, &ourview, x+.5, y+.5);
708 outbuf[0] = orig[0]; outbuf[1] = orig[1]; outbuf[2] = orig[2];
709 outbuf[3] = dir[0]; outbuf[4] = dir[1]; outbuf[5] = dir[2];
710 if (fwrite(outbuf, sizeof(float), 6, psend) < 6)
711 syserror();
712 /* remember it */
713 queue[queuesiz][0] = x;
714 queue[queuesiz][1] = y;
715 queuesiz++;
716 }
717
718
719 clearqueue() /* get results from queue */
720 {
721 float inbuf[4];
722 register int i;
723
724 for (i = 0; i < queuesiz; i++) {
725 if (fread(inbuf, sizeof(float), 4, precv) < 4) {
726 fprintf(stderr, "%s: read error in clearqueue\n",
727 progname);
728 exit(1);
729 }
730 if (ourexp > 0 && ourexp != 1.0) {
731 inbuf[0] *= ourexp;
732 inbuf[1] *= ourexp;
733 inbuf[2] *= ourexp;
734 }
735 setcolr(pscan(queue[i][1])[queue[i][0]],
736 inbuf[0], inbuf[1], inbuf[2]);
737 zscan(queue[i][1])[queue[i][0]] = inbuf[3];
738 }
739 queuesiz = 0;
740 }
741
742
743 syserror() /* report error and exit */
744 {
745 perror(progname);
746 exit(1);
747 }
