root/radiance/src/px/pfilt.h
Revision: 2.4
Committed: Sat Jun 7 05:09:46 2025 UTC (5 months ago) by greg
CVS Tags: rad6R0, HEAD
# User Rev Content
1 greg 2.4 /* RCSid: $Id: pfilt.h,v 2.3 2023/12/08 17:56:26 greg Exp $ */
2 schorsch 2.1 /*
3     * Header file for picture filtering
4     */
5     #ifndef _RAD_PFILT_H_
6     #define _RAD_PFILT_H_
7
8 greg 2.2 #include "standard.h"
9 greg 2.4 #include "paths.h"
10 greg 2.2 #include "color.h"
11
12 schorsch 2.1 #ifdef __cplusplus
13     extern "C" {
14     #endif
15
16     extern double CHECKRAD; /* radius over which gaussian is summed */
17     extern double rad; /* output pixel radius for filtering */
18     extern double thresh; /* maximum contribution for subpixel */
19     extern int nrows, ncols; /* number of rows and columns for output */
20     extern int xres, yres; /* x and y resolution */
21     extern int avghot; /* true means average in avgbrt spots */
22     extern double hotlvl; /* brightness considered "hot" */
23     extern int npts; /* # of points for stars */
24     extern double spread; /* spread for star points */
25     extern char *progname;
26     extern COLOR exposure; /* exposure for frame */
27
28     extern double x_c, y_r; /* conversion factors */
29
30     extern int xrad; /* x search radius */
31     extern int yrad; /* y search radius */
32     extern int xbrad; /* x box size */
33     extern int ybrad; /* y box size */
34
35     extern int barsize; /* size of input scan bar */
36 greg 2.3 extern COLORV **scanin; /* input scan bar */
37     extern COLORV *scanout; /* output scan line */
38     extern COLORV **scoutbar; /* output scan bar (if thresh > 0) */
39 schorsch 2.1 extern float **greybar; /* grey-averaged input values */
40     extern int obarsize; /* size of output scan bar */
41     extern int orad; /* output window radius */
42
43     extern int wrapfilt; /* wrap filter horizontally? */
44
45 greg 2.3 typedef double brightfunc_t(SCOLOR c);
46 schorsch 2.1 extern brightfunc_t *ourbright; /* brightness calculation function */
47
48     /* defined in pf2.c */
49     extern void pass1init(void); /* prepare for first pass */
50     extern void pass1default(void); /* for single pass */
51 greg 2.3 extern void pass1scan(COLORV *scan, int y); /* process first pass scanline */
52 schorsch 2.1 extern void pass2init(void); /* prepare for final pass */
53 greg 2.3 extern void pass2scan(COLORV *scan, int y); /* process final pass scanline */
54 schorsch 2.1
55     /* defined in pf3.c */
56     extern void initmask(void); /* initialize gaussian lookup table */
57 greg 2.3 extern void dobox(SCOLOR csum, int xcent, int ycent,
58 schorsch 2.1 int c, int r); /* simple box filter */
59 greg 2.3 extern void dogauss(SCOLOR csum, int xcent, int ycent,
60 schorsch 2.1 int c, int r); /* gaussian filter */
61     extern void dothresh(int xcent, int ycent,
62     int ccent, int rcent); /* gaussian threshold filter */
63
64     #ifdef __cplusplus
65     }
66     #endif
67     #endif /* _RAD_PFILT_H_ */
