root/radiance/src/px/pfilt.h
Revision: 2.3
Committed: Fri Dec 8 17:56:26 2023 UTC (22 months, 1 week ago) by greg
Changes since 2.2: +9 -9 lines
feat(pfilt): Added support for hyperspectral image filtering
1 /* RCSid: $Id: pfilt.h,v 2.2 2023/12/07 21:15:54 greg Exp $ */
2 /*
3 * Header file for picture filtering
4 */
5 #ifndef _RAD_PFILT_H_
6 #define _RAD_PFILT_H_
7
8 #include "standard.h"
9 #include "color.h"
10
11 #ifdef __cplusplus
12 extern "C" {
13 #endif
14
15 extern double CHECKRAD; /* radius over which gaussian is summed */
16 extern double rad; /* output pixel radius for filtering */
17 extern double thresh; /* maximum contribution for subpixel */
18 extern int nrows, ncols; /* number of rows and columns for output */
19 extern int xres, yres; /* x and y resolution */
20 extern int avghot; /* true means average in avgbrt spots */
21 extern double hotlvl; /* brightness considered "hot" */
22 extern int npts; /* # of points for stars */
23 extern double spread; /* spread for star points */
24 extern char *progname;
25 extern COLOR exposure; /* exposure for frame */
26
27 extern double x_c, y_r; /* conversion factors */
28
29 extern int xrad; /* x search radius */
30 extern int yrad; /* y search radius */
31 extern int xbrad; /* x box size */
32 extern int ybrad; /* y box size */
33
34 extern int barsize; /* size of input scan bar */
35 extern COLORV **scanin; /* input scan bar */
36 extern COLORV *scanout; /* output scan line */
37 extern COLORV **scoutbar; /* output scan bar (if thresh > 0) */
38 extern float **greybar; /* grey-averaged input values */
39 extern int obarsize; /* size of output scan bar */
40 extern int orad; /* output window radius */
41
42 extern int wrapfilt; /* wrap filter horizontally? */
43
44 typedef double brightfunc_t(SCOLOR c);
45 extern brightfunc_t *ourbright; /* brightness calculation function */
46
47 /* defined in pf2.c */
48 extern void pass1init(void); /* prepare for first pass */
49 extern void pass1default(void); /* for single pass */
50 extern void pass1scan(COLORV *scan, int y); /* process first pass scanline */
51 extern void pass2init(void); /* prepare for final pass */
52 extern void pass2scan(COLORV *scan, int y); /* process final pass scanline */
53
54 /* defined in pf3.c */
55 extern void initmask(void); /* initialize gaussian lookup table */
56 extern void dobox(SCOLOR csum, int xcent, int ycent,
57 int c, int r); /* simple box filter */
58 extern void dogauss(SCOLOR csum, int xcent, int ycent,
59 int c, int r); /* gaussian filter */
60 extern void dothresh(int xcent, int ycent,
61 int ccent, int rcent); /* gaussian threshold filter */
62
63 #ifdef __cplusplus
64 }
65 #endif
66 #endif /* _RAD_PFILT_H_ */
