| 1 | schorsch | 2.1 | /* RCSid: $Id$ */ |
| 2 |  |  | /* |
| 3 |  |  | * Header file for picture filtering |
| 4 |  |  | */ |
| 5 |  |  | #ifndef _RAD_PFILT_H_ |
| 6 |  |  | #define _RAD_PFILT_H_ |
| 7 |  |  |  |
| 8 |  |  | #ifdef __cplusplus |
| 9 |  |  | extern "C" { |
| 10 |  |  | #endif |
| 11 |  |  |  |
| 12 |  |  |  |
| 13 |  |  | extern double  CHECKRAD;        /* radius over which gaussian is summed */ |
| 14 |  |  | extern double  rad;             /* output pixel radius for filtering */ |
| 15 |  |  | extern double  thresh;          /* maximum contribution for subpixel */ |
| 16 |  |  | extern int  nrows, ncols;       /* number of rows and columns for output */ |
| 17 |  |  | extern int  xres, yres;         /* x and y resolution */ |
| 18 |  |  | extern int  avghot;             /* true means average in avgbrt spots */ |
| 19 |  |  | extern double  hotlvl;          /* brightness considered "hot" */ |
| 20 |  |  | extern int  npts;               /* # of points for stars */ |
| 21 |  |  | extern double  spread;          /* spread for star points */ |
| 22 |  |  | extern char  *progname; |
| 23 |  |  | extern COLOR  exposure;         /* exposure for frame */ |
| 24 |  |  |  |
| 25 |  |  | extern double  x_c, y_r;        /* conversion factors */ |
| 26 |  |  |  |
| 27 |  |  | extern int  xrad;               /* x search radius */ |
| 28 |  |  | extern int  yrad;               /* y search radius */ |
| 29 |  |  | extern int  xbrad;              /* x box size */ |
| 30 |  |  | extern int  ybrad;              /* y box size */ |
| 31 |  |  |  |
| 32 |  |  | extern int  barsize;            /* size of input scan bar */ |
| 33 |  |  | extern COLOR  **scanin;         /* input scan bar */ |
| 34 |  |  | extern COLOR  *scanout;         /* output scan line */ |
| 35 |  |  | extern COLOR  **scoutbar;       /* output scan bar (if thresh > 0) */ |
| 36 |  |  | extern float  **greybar;        /* grey-averaged input values */ |
| 37 |  |  | extern int  obarsize;           /* size of output scan bar */ |
| 38 |  |  | extern int  orad;               /* output window radius */ |
| 39 |  |  |  |
| 40 |  |  | extern int  wrapfilt;           /* wrap filter horizontally? */ |
| 41 |  |  |  |
| 42 |  |  | typedef double brightfunc_t(COLOR c); |
| 43 |  |  | extern brightfunc_t *ourbright; /* brightness calculation function */ |
| 44 |  |  |  |
| 45 |  |  | /* defined in pf2.c */ |
| 46 |  |  | extern void pass1init(void);            /* prepare for first pass */ |
| 47 |  |  | extern void pass1default(void);         /* for single pass */ |
| 48 |  |  | extern void pass1scan(COLOR *scan, int  y);     /* process first pass scanline */ |
| 49 |  |  | extern void pass2init(void);            /* prepare for final pass */ |
| 50 |  |  | extern void pass2scan(COLOR *scan, int  y);     /* process final pass scanline */ |
| 51 |  |  |  |
| 52 |  |  | /* defined in pf3.c */ |
| 53 |  |  | extern void initmask(void);                     /* initialize gaussian lookup table */ |
| 54 |  |  | extern void dobox(COLOR  csum, int  xcent, int  ycent, |
| 55 |  |  | int  c, int  r);                /* simple box filter */ |
| 56 |  |  | extern void dogauss(COLOR  csum, int  xcent, int  ycent, |
| 57 |  |  | int  c, int  r);        /* gaussian filter */ |
| 58 |  |  | extern void dothresh(int  xcent, int  ycent, |
| 59 |  |  | int  ccent, int  rcent);        /* gaussian threshold filter */ |
| 60 |  |  |  |
| 61 |  |  | #ifdef __cplusplus |
| 62 |  |  | } |
| 63 |  |  | #endif |
| 64 |  |  | #endif /* _RAD_PFILT_H_ */ |
| 65 |  |  |  |
