root/radiance/src/px/pfilt.c
Revision: 2.10
Committed: Fri Jun 25 17:07:03 1993 UTC (32 years, 3 months ago) by greg
Changes since 2.9: +14 -13 lines
minor optimization
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * pfilt.c - program to post-process picture file.
9 *
10 * 9/26/85
11 * 6/23/93 Added additional buffers for value spreading
12 */
13
14 #include "standard.h"
15
16 #include <signal.h>
17
18 #include "color.h"
19
20 #include "resolu.h"
21
22 #include "paths.h"
23
24 extern float *matchlamp();
25
26 #define FEQ(a,b) ((a) >= .98*(b) && (a) <= 1.02*(b))
27
28 double CHECKRAD = 1.5; /* radius to check for filtering */
29
30 #define THRESHRAD 5.0 /* maximum sample spread in output */
31
32 COLOR exposure = WHTCOLOR; /* exposure for the frame */
33
34 double rad = 0.0; /* output pixel radius for filtering */
35
36 double thresh = 0.0; /* maximum contribution for subpixel */
37
38 int nrows = 0; /* number of rows for output */
39 int ncols = 0; /* number of columns for output */
40
41 double x_c = 1.0; /* ratio of output x size to input */
42 double y_r = 1.0; /* ratio of output y size to input */
43
44 int singlepass = 0; /* true means skip first pass */
45
46 int avghot = 0; /* true means average in bright spots */
47
48 double hotlvl = 100.0; /* level considered "hot" */
49
50 int npts = 0; /* (half) number of points for stars */
51
52 double spread = 1e-4; /* spread for star points */
53
54 char *tfname = NULL;
55
56 char *lampdat = "lamp.tab"; /* lamp data file */
57
58 int order; /* scanline ordering of input */
59 int xres, yres; /* resolution of input */
60 double inpaspect = 1.0; /* pixel aspect ratio of input */
61 int correctaspect = 0; /* aspect ratio correction? */
62
63 int wrongformat = 0;
64
65 int xrad; /* x search radius */
66 int yrad; /* y search radius */
67 int xbrad; /* x box size */
68 int ybrad; /* y box size */
69
70 int barsize; /* size of input scan bar */
71 COLOR **scanin; /* input scan bar */
72 COLOR *scanout; /* output scan line */
73 COLOR **scoutbar; /* output scan bar (if thresh > 0) */
74 float **greybar; /* grey-averaged input values */
75 int obarsize = 0; /* size of output scan bar */
76 int orad = 0; /* output window radius */
77
78 char *progname;
79
80
81 main(argc, argv)
82 int argc;
83 char **argv;
84 {
85 extern long ftell();
86 extern int quit(), headline();
87 FILE *fin;
88 float *lampcolor;
89 char *lamptype = NULL;
90 long fpos;
91 double outaspect = 0.0;
92 double d;
93 int i, j;
94 #ifdef MSDOS
95 extern int _fmode;
96 _fmode = O_BINARY;
97 setmode(fileno(stdin), O_BINARY);
98 setmode(fileno(stdout), O_BINARY);
99 #endif
100 if (signal(SIGINT, quit) == SIG_IGN)
101 signal(SIGINT, SIG_IGN);
102 if (signal(SIGHUP, quit) == SIG_IGN)
103 signal(SIGINT, SIG_IGN);
104 signal(SIGTERM, quit);
105 signal(SIGPIPE, quit);
106 #ifdef SIGXCPU
107 signal(SIGXCPU, quit);
108 signal(SIGXFSZ, quit);
109 #endif
110
111 progname = argv[0] = fixargv0(argv[0]);
112
113 for (i = 1; i < argc; i++)
114 if (argv[i][0] == '-')
115 switch (argv[i][1]) {
116 case 'x':
117 i++;
118 if (argv[i][0] == '/') {
119 x_c = 1.0/atof(argv[i]+1);
120 ncols = 0;
121 } else
122 ncols = atoi(argv[i]);
123 break;
124 case 'y':
125 i++;
126 if (argv[i][0] == '/') {
127 y_r = 1.0/atof(argv[i]+1);
128 nrows = 0;
129 } else
130 nrows = atoi(argv[i]);
131 break;
132 case 'c':
133 correctaspect = !correctaspect;
134 break;
135 case 'p':
136 i++;
137 outaspect = atof(argv[i]);
138 break;
139 case 'e':
140 if (argv[i+1][0] == '+' || argv[i+1][0] == '-')
141 d = pow(2.0, atof(argv[i+1]));
142 else
143 d = atof(argv[i+1]);
144 if (d < 1e-20 || d > 1e20) {
145 fprintf(stderr,
146 "%s: exposure out of range\n",
147 argv[0]);
148 exit(1);
149 }
150 switch (argv[i][2]) {
151 case '\0':
152 scalecolor(exposure, d);
153 break;
154 case 'r':
155 colval(exposure,RED) *= d;
156 break;
157 case 'g':
158 colval(exposure,GRN) *= d;
159 break;
160 case 'b':
161 colval(exposure,BLU) *= d;
162 break;
163 default:
164 goto badopt;
165 }
166 i++;
167 break;
168 case 'f':
169 lampdat = argv[++i];
170 break;
171 case 't':
172 lamptype = argv[++i];
173 break;
174 case '1':
175 singlepass = 1;
176 break;
177 case '2':
178 singlepass = 0;
179 break;
180 case 'n':
181 npts = atoi(argv[++i]) / 2;
182 break;
183 case 's':
184 spread = atof(argv[++i]);
185 break;
186 case 'a':
187 avghot = !avghot;
188 break;
189 case 'h':
190 hotlvl = atof(argv[++i]);
191 break;
192 case 'r':
193 rad = atof(argv[++i]);
194 break;
195 case 'm':
196 thresh = atof(argv[++i]);
197 if (rad <= FTINY)
198 rad = 1.0;
199 break;
200 case 'b':
201 rad = thresh = 0.0;
202 break;
203 default:;
204 badopt:
205 fprintf(stderr, "%s: unknown option: %s\n",
206 progname, argv[i]);
207 quit(1);
208 break;
209 }
210 else
211 break;
212 /* get lamp data (if necessary) */
213 if (lamptype != NULL) {
214 if (loadlamps(lampdat) < 0)
215 quit(1);
216 if ((lampcolor = matchlamp(lamptype)) == NULL) {
217 fprintf(stderr, "%s: unknown lamp type\n", lamptype);
218 quit(1);
219 }
220 for (i = 0; i < 3; i++)
221 if (lampcolor[i] > 1e-4)
222 colval(exposure,i) /= lampcolor[i];
223 freelamps();
224 }
225 /* open input file */
226 if (i == argc) {
227 if (singlepass)
228 fin = stdin;
229 else {
230 tfname = mktemp(TEMPLATE);
231 if ((fin = fopen(tfname, "w+")) == NULL) {
232 fprintf(stderr, "%s: can't create ", progname);
233 fprintf(stderr, "temp file \"%s\"\n", tfname);
234 quit(1);
235 }
236 copyfile(stdin, fin);
237 if (fseek(fin, 0L, 0) == -1) {
238 fprintf(stderr, "%s: seek fail\n", progname);
239 quit(1);
240 }
241 }
242 } else if (i == argc-1) {
243 if ((fin = fopen(argv[i], "r")) == NULL) {
244 fprintf(stderr, "%s: can't open file \"%s\"\n",
245 progname, argv[i]);
246 quit(1);
247 }
248 } else {
249 fprintf(stderr, "%s: bad # file arguments\n", progname);
250 quit(1);
251 }
252 /* get header */
253 getheader(fin, headline, NULL);
254 if (wrongformat) {
255 fprintf(stderr, "%s: input must be a Radiance picture\n",
256 progname);
257 quit(1);
258 }
259 /* add new header info. */
260 printargs(i, argv, stdout);
261 /* get picture size */
262 if ((order = fgetresolu(&xres, &yres, fin)) < 0) {
263 fprintf(stderr, "%s: bad picture size\n", progname);
264 quit(1);
265 }
266 if (!(order & YMAJOR))
267 inpaspect = 1.0/inpaspect;
268 /* compute output resolution */
269 if (ncols <= 0)
270 ncols = x_c*xres + .5;
271 if (nrows <= 0)
272 nrows = y_r*yres + .5;
273 if (outaspect > .01) {
274 d = inpaspect * yres/xres / outaspect;
275 if (d * ncols > nrows)
276 ncols = nrows / d;
277 else
278 nrows = ncols * d;
279 }
280 x_c = (double)ncols/xres;
281 y_r = (double)nrows/yres;
282
283 if (singlepass) { /* skip exposure, etc. */
284 pass1default();
285 pass2(fin);
286 quit(0);
287 }
288
289 fpos = ftell(fin); /* save input file position */
290
291 pass1(fin);
292
293 if (fseek(fin, fpos, 0) == -1) {
294 fprintf(stderr, "%s: seek fail\n", progname);
295 quit(1);
296 }
297 pass2(fin);
298
299 quit(0);
300 }
301
302
303 headline(s) /* process line from header */
304 char *s;
305 {
306 char fmt[32];
307
308 fputs(s, stdout); /* copy to output */
309 if (isaspect(s)) /* get aspect ratio */
310 inpaspect *= aspectval(s);
311 else if (isexpos(s))
312 hotlvl *= exposval(s);
313 else if (isformat(s)) {
314 formatval(fmt, s);
315 wrongformat = strcmp(fmt, COLRFMT);
316 }
317 }
318
319
320 copyfile(in, out) /* copy a file */
321 register FILE *in, *out;
322 {
323 register int c;
324
325 while ((c = getc(in)) != EOF)
326 putc(c, out);
327
328 if (ferror(out)) {
329 fprintf(stderr, "%s: write error in copyfile\n", progname);
330 quit(1);
331 }
332 }
333
334
335 pass1(in) /* first pass of picture file */
336 FILE *in;
337 {
338 int i;
339 COLOR *scan;
340
341 pass1init();
342
343 scan = (COLOR *)malloc(xres*sizeof(COLOR));
344 if (scan == NULL) {
345 fprintf(stderr, "%s: out of memory\n", progname);
346 quit(1);
347 }
348 for (i = 0; i < yres; i++) {
349 if (freadscan(scan, xres, in) < 0) {
350 nrows = (long)nrows * i / yres; /* adjust frame */
351 if (nrows <= 0) {
352 fprintf(stderr, "%s: empty frame\n", progname);
353 quit(1);
354 }
355 fprintf(stderr, "%s: warning - partial frame (%d%%)\n",
356 progname, (int)(100L*i/yres));
357 yres = i;
358 y_r = (double)nrows/yres;
359 break;
360 }
361 pass1scan(scan, i);
362 }
363 free((char *)scan);
364 }
365
366
367 pass2(in) /* last pass on file, write to stdout */
368 FILE *in;
369 {
370 int yread;
371 int ycent, xcent;
372 int r, c;
373
374 pass2init();
375 scan2init();
376 yread = 0;
377 for (r = 0; r < nrows; r++) {
378 ycent = (long)r*yres/nrows;
379 while (yread <= ycent+yrad) {
380 if (yread < yres) {
381 if (freadscan(scanin[yread%barsize],
382 xres, in) < 0) {
383 fprintf(stderr,
384 "%s: bad read (y=%d)\n",
385 progname, yres-1-yread);
386 quit(1);
387 }
388 pass2scan(scanin[yread%barsize], yread);
389 }
390 yread++;
391 }
392 if (obarsize > 0)
393 scan2sync(r);
394 for (c = 0; c < ncols; c++) {
395 xcent = (long)c*xres/ncols;
396 if (thresh > FTINY)
397 dothresh(xcent, ycent, c, r);
398 else if (rad > FTINY)
399 dogauss(scanout[c], xcent, ycent, c, r);
400 else
401 dobox(scanout[c], xcent, ycent, c, r);
402 }
403 if (scanout != NULL && fwritescan(scanout, ncols, stdout) < 0) {
404 fprintf(stderr, "%s: write error in pass2\n", progname);
405 quit(1);
406 }
407 }
408 /* skip leftover input */
409 while (yread < yres) {
410 if (freadscan(scanin[0], xres, in) < 0)
411 break;
412 yread++;
413 }
414 scan2flush(); /* flush output */
415 }
416
417
418 scan2init() /* prepare scanline arrays */
419 {
420 COLOR ctmp;
421 double d;
422 register int i;
423
424 xbrad = xres/ncols/2 + 1;
425 ybrad = yres/nrows/2 + 1;
426 if (rad > FTINY) {
427 if (nrows >= yres && ncols >= xres)
428 rad *= (y_r + x_c)/2.0;
429
430 if (thresh > FTINY) {
431 xrad = CHECKRAD*THRESHRAD*rad/x_c + xbrad;
432 yrad = CHECKRAD*THRESHRAD*rad/y_r + ybrad;
433 orad = CHECKRAD*THRESHRAD*rad + 1;
434 obarsize = 2*orad + 1;
435 } else {
436 xrad = CHECKRAD*rad/x_c + 1;
437 yrad = CHECKRAD*rad/y_r + 1;
438 }
439 initmask(); /* initialize filter table */
440 } else {
441 xrad = xbrad;
442 yrad = ybrad;
443 }
444 barsize = 2*yrad + 1;
445 scanin = (COLOR **)malloc(barsize*sizeof(COLOR *));
446 if (scanin == NULL)
447 goto memerr;
448 for (i = 0; i < barsize; i++) {
449 scanin[i] = (COLOR *)malloc(xres*sizeof(COLOR));
450 if (scanin[i] == NULL)
451 goto memerr;
452 }
453 if (obarsize > 0) {
454 scoutbar = (COLOR **)malloc(obarsize*sizeof(COLOR *));
455 greybar = (float **)malloc(obarsize*sizeof(float *));
456 if (scoutbar == NULL | greybar == NULL)
457 goto memerr;
458 for (i = 0; i < obarsize; i++) {
459 scoutbar[i] = (COLOR *)malloc(ncols*sizeof(COLOR));
460 greybar[i] = (float *)malloc(ncols*sizeof(float));
461 if (scoutbar[i] == NULL | greybar[i] == NULL)
462 goto memerr;
463 }
464 } else {
465 scanout = (COLOR *)malloc(ncols*sizeof(COLOR));
466 if (scanout == NULL)
467 goto memerr;
468 }
469 /* record pixel aspect ratio */
470 if (!correctaspect) {
471 d = order & YMAJOR ? x_c/y_r : y_r/x_c ;
472 if (!FEQ(d,1.0))
473 fputaspect(d, stdout);
474 }
475 /* record exposure */
476 d = bright(exposure);
477 if (!FEQ(d,1.0))
478 fputexpos(d, stdout);
479 /* record color correction */
480 copycolor(ctmp, exposure);
481 scalecolor(ctmp, 1.0/d);
482 if (!FEQ(colval(ctmp,RED),colval(ctmp,GRN)) ||
483 !FEQ(colval(ctmp,GRN),colval(ctmp,BLU)))
484 fputcolcor(ctmp, stdout);
485 printf("\n");
486 /* write out resolution */
487 fputresolu(order, ncols, nrows, stdout);
488 return;
489 memerr:
490 fprintf(stderr, "%s: out of memory\n", progname);
491 quit(1);
492 }
493
494
495 scan2sync(r) /* synchronize grey averages and output scan */
496 int r;
497 {
498 static int nextrow = 0;
499 COLOR ctmp;
500 int ybot;
501 register int c;
502 /* average input scanlines */
503 while (nextrow < r+orad && nextrow < nrows) {
504 ybot = (long)nextrow*yres/nrows;
505 for (c = 0; c < ncols; c++) {
506 dobox(ctmp, (int)((long)c*xres/ncols),ybot, c,nextrow);
507 greybar[nextrow%obarsize][c] = bright(ctmp);
508 }
509 /* and zero output scanline */
510 bzero((char *)scoutbar[nextrow%obarsize], ncols*sizeof(COLOR));
511 nextrow++;
512 }
513 /* point to top scanline for output */
514 if (r-orad >= 0)
515 scanout = scoutbar[(r-orad)%obarsize];
516 else
517 scanout = NULL;
518 }
519
520
521 scan2flush() /* flush output buffer */
522 {
523 register int r;
524
525 for (r = nrows-orad; r < nrows; r++)
526 if (fwritescan(scoutbar[r%obarsize], ncols, stdout) < 0)
527 break;
528 if (fflush(stdout) < 0) {
529 fprintf(stderr, "%s: write error at end of pass2\n", progname);
530 exit(1);
531 }
532 }
533
534
535 quit(code) /* remove temporary file and exit */
536 int code;
537 {
538 if (tfname != NULL)
539 unlink(tfname);
540 exit(code);
541 }
