root/radiance/src/px/pfilt.c
Revision: 1.8
Committed: Fri Jan 5 17:52:52 1990 UTC (35 years, 9 months ago) by greg
changed EXPOSURE information interface
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * pfilt.c - program to post-process picture file.
9 *
10 * 9/26/85
11 */
12
13 #include <stdio.h>
14
15 #include <signal.h>
16
17 #include "color.h"
18
19
20 extern char *malloc();
21
22 #define CHECKRAD 1.5 /* radius to check for filtering */
23
24 COLOR exposure = WHTCOLOR; /* exposure for the frame */
25
26 double rad = 0.0; /* output pixel radius for filtering */
27
28 int nrows = 0; /* number of rows for output */
29 int ncols = 0; /* number of columns for output */
30
31 double x_c = 1.0; /* ratio of output x size to input */
32 double y_r = 1.0; /* ratio of output y size to input */
33
34 int singlepass = 0; /* true means skip first pass */
35
36 int avghot = 0; /* true means average in bright spots */
37
38 double hotlvl = 1000.0; /* level considered "hot" */
39
40 int npts = 0; /* (half) number of points for stars */
41
42 double spread = 1e-4; /* spread for star points */
43
44 #define TEMPLATE "/usr/tmp/pfXXXXXX"
45
46 char *tfname = NULL;
47
48 int xres, yres; /* resolution of input */
49
50 int xrad; /* x window size */
51 int yrad; /* y window size */
52
53 int barsize; /* size of input scan bar */
54 COLOR **scanin; /* input scan bar */
55 COLOR *scanout; /* output scan line */
56
57 char *progname;
58
59
60 main(argc, argv)
61 int argc;
62 char **argv;
63 {
64 extern char *mktemp();
65 extern double atof(), pow();
66 extern long ftell();
67 extern int quit();
68 FILE *fin;
69 long fpos;
70 double d;
71 int i;
72
73 if (signal(SIGINT, quit) == SIG_IGN)
74 signal(SIGINT, SIG_IGN);
75 if (signal(SIGHUP, quit) == SIG_IGN)
76 signal(SIGINT, SIG_IGN);
77 signal(SIGTERM, quit);
78 signal(SIGPIPE, quit);
79 #ifdef SIGXCPU
80 signal(SIGXCPU, quit);
81 signal(SIGXFSZ, quit);
82 #endif
83
84 progname = argv[0];
85
86 for (i = 1; i < argc; i++)
87 if (argv[i][0] == '-')
88 switch (argv[i][1]) {
89 case 'x':
90 i++;
91 if (argv[i][0] == '/') {
92 x_c = 1.0/atof(argv[i]+1);
93 ncols = 0;
94 } else
95 ncols = atoi(argv[i]);
96 break;
97 case 'y':
98 i++;
99 if (argv[i][0] == '/') {
100 y_r = 1.0/atof(argv[i]+1);
101 nrows = 0;
102 } else
103 nrows = atoi(argv[i]);
104 break;
105 case 'e':
106 if (argv[i+1][0] == '+' || argv[i+1][0] == '-')
107 d = pow(2.0, atof(argv[i+1]));
108 else
109 d = atof(argv[i+1]);
110 switch (argv[i][2]) {
111 case '\0':
112 scalecolor(exposure, d);
113 break;
114 case 'r':
115 colval(exposure,RED) *= d;
116 break;
117 case 'g':
118 colval(exposure,GRN) *= d;
119 break;
120 case 'b':
121 colval(exposure,BLU) *= d;
122 break;
123 default:
124 goto badopt;
125 }
126 i++;
127 break;
128 case '1':
129 singlepass = 1;
130 break;
131 case '2':
132 singlepass = 0;
133 break;
134 case 'p':
135 npts = atoi(argv[++i]) / 2;
136 break;
137 case 's':
138 spread = atof(argv[++i]);
139 break;
140 case 'a':
141 avghot = !avghot;
142 break;
143 case 'h':
144 hotlvl = atof(argv[++i]);
145 break;
146 case 'r':
147 rad = atof(argv[++i]);
148 break;
149 case 'b':
150 rad = 0.0;
151 break;
152 default:;
153 badopt:
154 fprintf(stderr, "%s: unknown option: %s\n",
155 progname, argv[i]);
156 quit(1);
157 break;
158 }
159 else
160 break;
161
162 if (i == argc) {
163 if (singlepass)
164 fin = stdin;
165 else {
166 tfname = mktemp(TEMPLATE);
167 if ((fin = fopen(tfname, "w+")) == NULL) {
168 fprintf(stderr, "%s: can't create ", progname);
169 fprintf(stderr, "temp file \"%s\"\n", tfname);
170 quit(1);
171 }
172 copyfile(stdin, fin);
173 if (fseek(fin, 0L, 0) == -1) {
174 fprintf(stderr, "%s: seek fail\n", progname);
175 quit(1);
176 }
177 }
178 } else if (i == argc-1) {
179 if ((fin = fopen(argv[i], "r")) == NULL) {
180 fprintf(stderr, "%s: can't open file \"%s\"\n",
181 progname, argv[i]);
182 quit(1);
183 }
184 } else {
185 fprintf(stderr, "%s: bad # file arguments\n", progname);
186 quit(1);
187 }
188 /* copy header */
189 copyheader(fin, stdout);
190 /* add new header info. */
191 printargs(i, argv, stdout);
192 /* get picture size */
193 if (fgetresolu(&xres, &yres, fin) != (YMAJOR|YDECR)) {
194 fprintf(stderr, "%s: bad picture size\n", progname);
195 quit(1);
196 }
197 if (ncols > 0)
198 x_c = (double)ncols/xres;
199 else
200 ncols = x_c*xres + .5;
201 if (nrows > 0)
202 y_r = (double)nrows/yres;
203 else
204 nrows = y_r*yres + .5;
205
206 if (singlepass) {
207 /* skip exposure, etc. */
208 pass1default();
209 pass2(fin);
210 quit(0);
211 }
212
213 fpos = ftell(fin); /* save input file position */
214
215 pass1(fin);
216
217 if (fseek(fin, fpos, 0) == -1) {
218 fprintf(stderr, "%s: seek fail\n", progname);
219 quit(1);
220 }
221 pass2(fin);
222
223 quit(0);
224 }
225
226
227 copyfile(in, out) /* copy a file */
228 register FILE *in, *out;
229 {
230 register int c;
231
232 while ((c = getc(in)) != EOF)
233 putc(c, out);
234
235 if (ferror(out)) {
236 fprintf(stderr, "%s: write error in copyfile\n", progname);
237 quit(1);
238 }
239 }
240
241
242 pass1(in) /* first pass of picture file */
243 FILE *in;
244 {
245 int i;
246 COLOR *scan;
247
248 pass1init();
249
250 scan = (COLOR *)malloc(xres*sizeof(COLOR));
251 if (scan == NULL) {
252 fprintf(stderr, "%s: out of memory\n", progname);
253 quit(1);
254 }
255 for (i = 0; i < yres; i++) {
256 if (freadscan(scan, xres, in) < 0) {
257 nrows = nrows * i / yres; /* adjust frame */
258 if (nrows <= 0) {
259 fprintf(stderr, "%s: empty frame\n", progname);
260 quit(1);
261 }
262 fprintf(stderr, "%s: warning - partial frame (%d%%)\n",
263 progname, 100*i/yres);
264 yres = i;
265 break;
266 }
267 pass1scan(scan, i);
268 }
269 free((char *)scan);
270 }
271
272
273 pass2(in) /* last pass on file, write to stdout */
274 FILE *in;
275 {
276 int yread;
277 int ycent, xcent;
278 int r, c;
279
280 pass2init();
281 scan2init();
282 yread = 0;
283 for (r = 0; r < nrows; r++) {
284 ycent = (long)r*yres/nrows;
285 while (yread <= ycent+yrad) {
286 if (yread < yres) {
287 if (freadscan(scanin[yread%barsize],
288 xres, in) < 0) {
289 fprintf(stderr,
290 "%s: bad read (y=%d)\n",
291 progname, yres-1-yread);
292 quit(1);
293 }
294 pass2scan(scanin[yread%barsize], yread);
295 }
296 yread++;
297 }
298 for (c = 0; c < ncols; c++) {
299 xcent = (long)c*xres/ncols;
300 if (rad <= 0.0)
301 dobox(scanout[c], xcent, ycent, c, r);
302 else
303 dogauss(scanout[c], xcent, ycent, c, r);
304 }
305 if (fwritescan(scanout, ncols, stdout) < 0) {
306 fprintf(stderr, "%s: write error in pass2\n", progname);
307 quit(1);
308 }
309 }
310 }
311
312
313 scan2init() /* prepare scanline arrays */
314 {
315 double e;
316 register int i;
317
318 if (rad <= 0.0) {
319 xrad = xres/ncols/2 + 1;
320 yrad = yres/nrows/2 + 1;
321 } else {
322 if (nrows >= yres && ncols >= xres)
323 rad *= (y_r + x_c)/2.0;
324
325 xrad = CHECKRAD*rad/x_c + 1;
326 yrad = CHECKRAD*rad/y_r + 1;
327
328 initmask(); /* initialize filter table */
329 }
330 barsize = 2 * yrad;
331 scanin = (COLOR **)malloc(barsize*sizeof(COLOR *));
332 for (i = 0; i < barsize; i++) {
333 scanin[i] = (COLOR *)malloc(xres*sizeof(COLOR));
334 if (scanin[i] == NULL) {
335 fprintf(stderr, "%s: out of memory\n", progname);
336 quit(1);
337 }
338 }
339 scanout = (COLOR *)malloc(ncols*sizeof(COLOR));
340 if (scanout == NULL) {
341 fprintf(stderr, "%s: out of memory\n", progname);
342 quit(1);
343 }
344 e = bright(exposure);
345 if (e < 1-1e-7 || e > 1+1e-7) /* record exposure */
346 fputexpos(e, stdout);
347 printf("\n");
348 fputresolu(YMAJOR|YDECR, ncols, nrows, stdout); /* resolution */
349 }
350
351
352 quit(code) /* remove temporary file and exit */
353 int code;
354 {
355 if (tfname != NULL)
356 unlink(tfname);
357 exit(code);
358 }
