root/radiance/src/px/pfilt.c
Wed Jul 2 16:54:44 2025 UTC (3 months, 1 week ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 2.41: +2 -2 lines
Diff to previous 2.41
perf: Made +/-0.5% threshold for caring about pixel aspect ratio consistent
Revision 2.41 - (view) (download) (annotate) - [selected]
Sat Jun 7 05:09:46 2025 UTC (4 months, 1 week ago) by greg
Changes since 2.40: +1 -2 lines
Diff to previous 2.40
Tue Jun 3 21:31:51 2025 UTC (4 months, 1 week ago) by greg
Changes since 2.39: +4 -7 lines
Diff to previous 2.39 , to selected 2.41
Fri Dec 15 01:57:45 2023 UTC (21 months, 4 weeks ago) by greg
Changes since 2.38: +78 -76 lines
Diff to previous 2.38 , to selected 2.41
refactor(pfilt): minor code fixes and reorg
Thu Dec 14 19:03:19 2023 UTC (21 months, 4 weeks ago) by greg
Changes since 2.37: +3 -3 lines
Diff to previous 2.37 , to selected 2.41
fix(pfilt): Not sure if binary mode is working under Windows
Sat Dec 9 02:33:14 2023 UTC (22 months ago) by greg
Diff to previous 2.36 , to selected 2.41
fix(pfilt): Need to set primary channels for pbright() to work properly
Fri Dec 8 17:56:26 2023 UTC (22 months ago) by greg
Changes since 2.35: +45 -28 lines
Diff to previous 2.35 , to selected 2.41
feat(pfilt): Added support for hyperspectral image filtering
Thu Dec 7 21:15:54 2023 UTC (22 months ago) by greg
Changes since 2.34: +3 -8 lines
Diff to previous 2.34 , to selected 2.41
refactor: Cleaned up and simplified #include's
Sat Dec 28 18:05:14 2019 UTC (5 years, 9 months ago) by greg
CVS Tags: rad5R3, rad5R4
Changes since 2.33: +1 -2 lines
Diff to previous 2.33 , to selected 2.41
Thu Aug 2 18:33:44 2018 UTC (7 years, 2 months ago) by greg
Diff to previous 2.32 , to selected 2.41
Thu Jul 26 23:50:40 2018 UTC (7 years, 2 months ago) by greg
Changes since 2.31: +7 -7 lines
Diff to previous 2.31 , to selected 2.41
Fixed issue with pfilt -m option and non-integer size divisors
Fri Sep 3 21:18:15 2010 UTC (15 years, 1 month ago) by greg
Changes since 2.30: +1 -3 lines
Diff to previous 2.30 , to selected 2.41
Removed '//' comments that don't fit with standard C
Mon Mar 29 00:34:23 2004 UTC (21 years, 6 months ago) by schorsch
Changes since 2.29: +6 -5 lines
Diff to previous 2.29 , to selected 2.41
Continued ANSIfication. Added headerfiles pfilt.h and clrtab.h.
Sun Mar 28 20:33:14 2004 UTC (21 years, 6 months ago) by schorsch
Changes since 2.28: +46 -21 lines
Diff to previous 2.28 , to selected 2.41
Fri Jan 2 12:47:01 2004 UTC (21 years, 9 months ago) by schorsch
Changes since 2.27: +8 -5 lines
Diff to previous 2.27 , to selected 2.41
Wed Oct 22 02:06:35 2003 UTC (21 years, 11 months ago) by greg
Diff to previous 2.26 , to selected 2.41
Sun Jul 27 22:12:03 2003 UTC (22 years, 2 months ago) by schorsch
Diff to previous 2.25 , to selected 2.41
Mon Jun 30 14:59:12 2003 UTC (22 years, 3 months ago) by schorsch
Changes since 2.24: +5 -2 lines
Diff to previous 2.24 , to selected 2.41
Sun Jun 8 12:03:10 2003 UTC (22 years, 4 months ago) by schorsch
Changes since 2.23: +6 -1 lines
Diff to previous 2.23 , to selected 2.41
Thu Jun 5 19:29:34 2003 UTC (22 years, 4 months ago) by schorsch
Changes since 2.22: +5 -11 lines
Diff to previous 2.22 , to selected 2.41
Tue Feb 25 00:26:05 2003 UTC (22 years, 7 months ago) by greg
Diff to previous 2.21 , to selected 2.41
Fixed pre-release upsampling bug in new filtering kernel
Sat Feb 22 02:07:27 2003 UTC (22 years, 7 months ago) by greg
Changes since 2.20: +5 -10 lines
Diff to previous 2.20 , to selected 2.41
Tue Oct 27 09:08:26 1998 UTC (26 years, 11 months ago) by gwlarson
Changes since 2.19: +2 -0 lines
Diff to previous 2.19 , to selected 2.41
Wed Oct 2 16:56:16 1996 UTC (29 years ago) by greg
Changes since 2.18: +4 -4 lines
Diff to previous 2.18 , to selected 2.41
made output pixel positioning more precise
Wed May 22 10:42:08 1996 UTC (29 years, 4 months ago) by greg
Changes since 2.17: +6 -3 lines
Diff to previous 2.17 , to selected 2.41
added exit status change for truncated input files
Mon Apr 1 17:24:44 1996 UTC (29 years, 6 months ago) by greg
Changes since 2.16: +11 -1 lines
Diff to previous 2.16 , to selected 2.41
Wed Feb 14 20:19:52 1996 UTC (29 years, 8 months ago) by greg
Diff to previous 2.15 , to selected 2.41
fixed bug in indexing and size of buffers for -m option
Mon Oct 16 12:04:36 1995 UTC (30 years ago) by greg
Changes since 2.14: +30 -6 lines
Diff to previous 2.14 , to selected 2.41
added compatibility with Radiance XYZE picture format
Wed May 31 08:50:27 1995 UTC (30 years, 4 months ago) by greg
Diff to previous 2.13 , to selected 2.41
improved error message for truncated input
Mon Feb 7 16:27:50 1994 UTC (31 years, 8 months ago) by greg
Diff to previous 2.12 , to selected 2.41
fixed bug in lamp data routine
Thu Nov 18 09:56:17 1993 UTC (31 years, 11 months ago) by greg
Diff to previous 2.11 , to selected 2.41
minor compiler warning fixes
Tue Sep 21 10:55:54 1993 UTC (32 years, 1 month ago) by greg
Diff to previous 2.10 , to selected 2.41
minor bug fixes
Fri Jun 25 17:07:03 1993 UTC (32 years, 3 months ago) by greg
Changes since 2.9: +14 -13 lines
Diff to previous 2.9 , to selected 2.41
minor optimization
Fri Jun 25 15:01:17 1993 UTC (32 years, 3 months ago) by greg
Changes since 2.8: +103 -20 lines
Diff to previous 2.8 , to selected 2.41
added -m option for sample smoothing
Fri Jun 18 16:20:16 1993 UTC (32 years, 4 months ago) by greg
Diff to previous 2.7 , to selected 2.41
changed default setting of hotlvl and made it absolute
Thu Nov 12 09:05:17 1992 UTC (32 years, 11 months ago) by greg
Diff to previous 2.6 , to selected 2.41
bug fix for 16-bit integers (DOS)
Tue Nov 3 16:52:20 1992 UTC (32 years, 11 months ago) by greg
Changes since 2.5: +2 -9 lines
Diff to previous 2.5 , to selected 2.41
Fri Oct 2 16:24:06 1992 UTC (33 years ago) by greg
Diff to previous 2.4 , to selected 2.41
Mon Sep 21 12:14:17 1992 UTC (33 years ago) by greg
Changes since 2.3: +24 -15 lines
Diff to previous 2.3 , to selected 2.41
Changes for PC port
Tue Sep 8 15:33:08 1992 UTC (33 years, 1 month ago) by greg
Changes since 2.2: +2 -3 lines
Diff to previous 2.2 , to selected 2.41
Thu Dec 19 14:51:52 1991 UTC (33 years, 10 months ago) by greg
Diff to previous 2.1 , to selected 2.41
Tue Nov 12 16:04:27 1991 UTC (33 years, 11 months ago) by greg
Diff to previous 1.19 , to selected 2.41
Mon Nov 11 14:01:15 1991 UTC (33 years, 11 months ago) by greg
Changes since 1.18: +8 -3 lines
Diff to previous 1.18 , to selected 2.41
Mon Oct 28 08:10:18 1991 UTC (33 years, 11 months ago) by greg
Changes since 1.17: +5 -5 lines
Diff to previous 1.17 , to selected 2.41
added insurance for lampcolor[i] == 0.0
Wed Jun 5 12:15:30 1991 UTC (34 years, 4 months ago) by greg
Diff to previous 1.16 , to selected 2.41
improved gaussian filtering
Thu Apr 18 14:35:21 1991 UTC (34 years, 6 months ago) by greg
Changes since 1.15: +14 -1 lines
Diff to previous 1.15 , to selected 2.41
Fri Dec 14 16:33:16 1990 UTC (34 years, 10 months ago) by greg
Changes since 1.14: +21 -4 lines
Diff to previous 1.14 , to selected 2.41
added use of COLORCORR header i/o
Sat Dec 8 13:23:47 1990 UTC (34 years, 10 months ago) by greg
Changes since 1.13: +14 -14 lines
Diff to previous 1.13 , to selected 2.41
moved loading of lamp data before opening of input file
Sat Dec 8 10:14:33 1990 UTC (34 years, 10 months ago) by greg
Changes since 1.12: +24 -0 lines
Diff to previous 1.12 , to selected 2.41
Wed Nov 28 11:13:23 1990 UTC (34 years, 10 months ago) by greg
Changes since 1.11: +9 -3 lines
Diff to previous 1.11 , to selected 2.41
added option to override output of aspect ratio change
Tue Oct 16 13:52:44 1990 UTC (35 years ago) by greg
Changes since 1.10: +1 -0 lines
Diff to previous 1.10 , to selected 2.41
recomputed y_r after picture adjustment (bug fix)
Thu Sep 13 09:46:00 1990 UTC (35 years, 1 month ago) by greg
Diff to previous 1.9 , to selected 2.41
fixed pass2() so it reads all its input regardless
Tue Jan 9 17:58:35 1990 UTC (35 years, 9 months ago) by greg
Changes since 1.8: +40 -17 lines
Diff to previous 1.8 , to selected 2.41
added code to maintain pixel aspect ratio
Fri Jan 5 17:52:52 1990 UTC (35 years, 9 months ago) by greg
Diff to previous 1.7 , to selected 2.41
changed EXPOSURE information interface
Wed Sep 13 17:16:37 1989 UTC (36 years, 1 month ago) by greg
Diff to previous 1.6 , to selected 2.41
Sat Apr 29 09:22:54 1989 UTC (36 years, 5 months ago) by greg
Changes since 1.5: +3 -0 lines
Diff to previous 1.5 , to selected 2.41
Added -2 option for two-pass
Thu Apr 13 07:52:50 1989 UTC (36 years, 6 months ago) by greg
Changes since 1.4: +6 -4 lines
Diff to previous 1.4 , to selected 2.41
resolution ratio supercedes previous specification
Tue Apr 11 21:50:05 1989 UTC (36 years, 6 months ago) by greg
Changes since 1.3: +8 -13 lines
Diff to previous 1.3 , to selected 2.41
consolidated resolution ratio variables
Tue Apr 11 21:39:00 1989 UTC (36 years, 6 months ago) by greg
Changes since 1.2: +8 -6 lines
Diff to previous 1.2 , to selected 2.41
changed syntax for resolution ratios
Tue Apr 11 17:22:05 1989 UTC (36 years, 6 months ago) by greg
Changes since 1.1: +19 -6 lines
Diff to previous 1.1 , to selected 2.41
added scaling options for x and y resolution
Thu Feb 2 10:49:26 1989 UTC (36 years, 8 months ago) by greg
Diff to selected 2.41
