root/radiance/src/px/pdelta.csh
Revision: 3.1
Committed: Sat Feb 22 02:07:27 2003 UTC (22 years, 7 months ago) by greg
Content type: application/x-csh
CVS Tags: rad3R7P2, rad3R7P1, rad3R5, rad3R6, rad3R6P1, rad3R8, rad3R9
1 #!/bin/csh -f
2 # RCSid: $Id$
3 #
4 # Compute 1976 CIE Lab deltaE* between two Radiance pictures
5 #
6 if ($#argv != 2) then
7 echo "Usage: $0 picture1 picture2 > output.pic"
8 exit 1
9 endif
10 set cielab='sq(x):x*x;Ls(Yi):if(Yi/Yw-.01,116*(Yi/Yw)^(1/3)-16,903.3*Yi/Yw);as(Xi,Yi,Zi):500*((Xi/Xw)^(1/3)-(Yi/Yw)^(1/3));bs(Xi,Yi,Zi):200*((Yi/Yw)^(1/3)-(Zi/Zw)^(1/3));dE(X1,Y1,Z1,X2,Y2,Z2):sqrt(sq(Ls(Y1)-Ls(Y2))+sq(as(X1,Y1,Z1)-as(X2,Y2,Z2))+sq(bs(X1,Y1,Z1)-bs(X2,Y2,Z2)));'
11 # The following is for Radiance RGB -> XYZ
12 set rgb2xyz='X(R,G,B):92.03*R+57.98*G+28.99*B;Y(R,G,B):47.45*R+119.9*G+11.6*B;Z(R,G,B):4.31*R+21.99*G+152.7*B'
13 # The following is for sRGB -> XYZ
14 # set rgb2xyz='X(R,G,B):73.82*R+64.01*G+32.31*B;Y(R,G,B):38.06*R+128*G+12.92*B;Z(R,G,B):3.46*R+21.34*G+170.15*B'
15 set f1="$1"
16 set inp1='x1=ri(1);y1=gi(1);z1=bi(1)'
17 set f2="$2"
18 set inp2='x2=ri(2);y2=gi(2);z2=bi(2)'
19 if ( "`getinfo < $f1:q | grep '^FORMAT=32-bit_rle_xyze'`" == "" ) then
20 set inp1='x1=X(ri(1),gi(1),bi(1));y1=Y(ri(1),gi(1),bi(1));z1=Z(ri(1),gi(1),bi(1))'
21 endif
22 if ( "`getinfo < $f2:q | grep '^FORMAT=32-bit_rle_xyze'`" == "" ) then
23 set inp2='x2=X(ri(2),gi(2),bi(2));y2=Y(ri(2),gi(2),bi(2));z2=Z(ri(2),gi(2),bi(2))'
24 endif
25 pfilt -1 -x 128 -y 128 -p 1 $f1:q | pvalue -o -h -H -d > /tmp/tf$$.dat
26 set wht=(`total -u /tmp/tf$$.dat`)
27 set avg=`rcalc -e '$1=$2' /tmp/tf$$.dat | total -m`
28 rm /tmp/tf$$.dat
29 pcomb -e $cielab:q -e $rgb2xyz:q \
30 -e "Yw:179*3*$avg; Xw:$wht[1]*Yw/$wht[2]; Zw:$wht[3]*Yw/$wht[2]" \
31 -e $inp1:q -e $inp2:q -e 'lo=dE(x1,y1,z1,x2,y2,z2)' \
32 -o $f1:q -o $f2:q
