root/radiance/src/px/pcond3.c
Revision: 3.20
Committed: Wed Sep 11 18:56:12 2024 UTC (12 months, 3 weeks ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 3.19: +3 -2 lines
feat(pcond,pvalue): Added hyperspectral input handling
2 static const char RCSid[] = "$Id: pcond3.c,v 3.19 2021/04/13 02:56:42 greg Exp $";
5 * Routines for computing and applying brightness mapping.
6 */
7
8 #include <string.h>
9
10 #include "pcond.h"
11 #include "random.h"
12
13
14 #define CVRATIO 0.025 /* fraction of samples allowed > env. */
15
16 #define LN_10 2.30258509299404568402
17 #define exp10(x) exp(LN_10*(x))
18
19 double modhist[HISTRES]; /* modified histogram */
20 double mhistot; /* modified histogram total */
21 double cumf[HISTRES+1]; /* cumulative distribution function */
22
23 static double centprob(int x, int y);
24 static void mkcumf(void);
25 static double cf(double b);
26 static double BLw(double Lw);
27 static float *getlumsamp(int n);
28 #if ADJ_VEIL
29 static void mkcrfimage(void);
30 #endif
31
32
33
34 void
35 getfixations( /* load fixation history list */
36 FILE *fp
37 )
38 {
39 #define FIXHUNK 128
40 RESOLU fvres;
41 int pos[2];
42 int px, py, i;
43 /* initialize our resolution struct */
44 if ((fvres.rt=inpres.rt)&YMAJOR) {
45 fvres.xr = fvxr;
46 fvres.yr = fvyr;
47 } else {
48 fvres.xr = fvyr;
49 fvres.yr = fvxr;
50 }
51 /* read each picture position */
52 while (fscanf(fp, "%d %d", &pos[0], &pos[1]) == 2) {
53 /* convert to closest index in foveal image */
54 loc2pix(pos, &fvres,
55 (pos[0]+.5)/inpres.xr, (pos[1]+.5)/inpres.yr);
56 /* include nine neighborhood samples */
57 for (px = pos[0]-1; px <= pos[0]+1; px++) {
58 if (px < 0 || px >= fvxr)
59 continue;
60 for (py = pos[1]-1; py <= pos[1]+1; py++) {
61 if (py < 0 || py >= fvyr)
62 continue;
63 for (i = nfixations; i-- > 0; )
64 if (fixlst[i][0] == px &&
65 fixlst[i][1] == py)
66 break;
67 if (i >= 0)
68 continue; /* already there */
69 if (nfixations % FIXHUNK == 0) {
70 if (nfixations)
71 fixlst = (short (*)[2])
72 realloc((void *)fixlst,
73 (nfixations+FIXHUNK)*
74 2*sizeof(short));
75 else
76 fixlst = (short (*)[2])malloc(
77 FIXHUNK*2*sizeof(short)
78 );
79 if (fixlst == NULL)
80 syserror("malloc");
81 }
82 fixlst[nfixations][0] = px;
83 fixlst[nfixations][1] = py;
84 nfixations++;
85 }
86 }
87 }
88 if (!feof(fp)) {
89 fprintf(stderr, "%s: format error reading fixation data\n",
90 progname);
91 exit(1);
92 }
93 #undef FIXHUNK
94 }
95
96
97 void
98 gethisto( /* load precomputed luminance histogram */
99 FILE *fp
100 )
101 {
102 double histo[MAXPREHIST];
103 double histart, histep;
104 double b, lastb, w;
105 int n;
106 int i;
107 /* load data */
108 for (i = 0; i < MAXPREHIST &&
109 fscanf(fp, "%lf %lf", &b, &histo[i]) == 2; i++) {
110 if (i > 1 && fabs(b - lastb - histep) > .001) {
111 fprintf(stderr,
112 "%s: uneven step size in histogram data\n",
113 progname);
114 exit(1);
115 }
116 if (i == 1)
117 if ((histep = b - (histart = lastb)) <= FTINY) {
118 fprintf(stderr,
119 "%s: illegal step in histogram data\n",
120 progname);
121 exit(1);
122 }
123 lastb = b;
124 }
125 if (i < 2 || !feof(fp)) {
126 fprintf(stderr,
127 "%s: format/length error loading histogram (log10L %f at %d)\n",
128 progname, b, i);
129 exit(1);
130 }
131 n = i;
132 histart *= LN_10;
133 histep *= LN_10;
134 /* find extrema */
135 for (i = 0; i < n && histo[i] <= FTINY; i++)
136 ;
137 bwmin = histart + (i-.001)*histep;
138 for (i = n; i-- && histo[i] <= FTINY; )
139 ;
140 bwmax = histart + (i+1.001)*histep;
141 if (bwmax > Bl(LMAX))
142 bwmax = Bl(LMAX);
143 if (bwmin < Bl(LMIN))
144 bwmin = Bl(LMIN);
145 else /* duplicate bottom bin */
146 bwmin = bwmax - (bwmax-bwmin)*HISTRES/(HISTRES-1);
147 /* convert histogram */
148 bwavg = 0.; histot = 0.;
149 for (i = 0; i < HISTRES; i++)
150 bwhist[i] = 0.;
151 for (i = 0, b = histart; i < n; i++, b += histep) {
152 if (b < bwmin+FTINY) continue;
153 if (b >= bwmax-FTINY) break;
154 w = histo[i];
155 bwavg += w*b;
156 bwhist[bwhi(b)] += w;
157 histot += w;
158 }
159 bwavg /= histot;
160 if (bwmin > Bl(LMIN)+FTINY) { /* add false samples at bottom */
161 bwhist[1] *= 0.5;
162 bwhist[0] += bwhist[1];
163 }
164 }
165
166
167 static double
168 centprob( /* center-weighting probability function */
169 int x,
170 int y
171 )
172 {
173 double xr, yr, p;
174 /* paraboloid, 0 at 90 degrees from center */
175 xr = (x - .5*(fvxr-1))/90.; /* 180 degree fisheye has fv?r == 90 */
176 yr = (y - .5*(fvyr-1))/90.;
177 p = 1. - xr*xr - yr*yr;
178 return(p < 0. ? 0. : p);
179 }
180
181
182 static float *
183 getlumsamp(int n) /* get set of random point sample luminances */
184 {
185 float *ls = (float *)malloc(n*sizeof(float));
186 COLR *cscan = (COLR *)malloc(scanlen(&inpres)*sizeof(COLR));
187 long startpos = ftell(infp);
188 long npleft = (long)inpres.xr*inpres.yr;
189 int x;
190
191 if ((ls == NULL) | (cscan == NULL))
192 syserror("malloc");
193 x = 0; /* read/convert samples */
194 while (n > 0) {
195 COLOR col;
196 int sv = 0;
197 double rval, cumprob = 0;
198
199 if (x <= 0 && fread2colrs(cscan, x=scanlen(&inpres), infp,
200 NCSAMP, WLPART) < 0) {
201 fprintf(stderr, "%s: %s: scanline read error\n",
202 progname, infn);
203 exit(1);
204 }
205 rval = frandom(); /* random distance to next sample */
206 while ((cumprob += (1.-cumprob)*n/(npleft-sv)) < rval)
207 sv++;
208 if (x < ++sv) { /* out of pixels in this scanline */
209 npleft -= x;
210 x = 0;
211 continue;
212 }
213 x -= sv;
214 colr_color(col, cscan[x]);
215 ls[--n] = plum(col);
216 npleft -= sv;
217 }
218 free(cscan); /* clean up and reset file pointer */
219 if (fseek(infp, startpos, SEEK_SET) < 0)
220 syserror("fseek");
221 return(ls);
222 }
223
224
225 void
226 comphist(void) /* create foveal sampling histogram */
227 {
228 double l, b, w, lwmin, lwmax;
229 float *lumsamp;
230 int nlumsamp;
231 int x, y;
232 /* check for precalculated histogram */
233 if (what2do&DO_PREHIST)
234 return;
235 lwmin = 1e10; /* find extrema */
236 lwmax = 0.;
237 for (y = 0; y < fvyr; y++)
238 for (x = 0; x < fvxr; x++) {
239 l = plum(fovscan(y)[x]);
240 if (l < lwmin) lwmin = l;
241 if (l > lwmax) lwmax = l;
242 }
243 /* sample luminance pixels */
244 nlumsamp = fvxr*fvyr*16;
245 if (nlumsamp > inpres.xr*inpres.yr)
246 nlumsamp = inpres.xr*inpres.yr;
247 lumsamp = getlumsamp(nlumsamp);
248 for (x = nlumsamp; x--; ) {
249 l = lumsamp[x];
250 if (l < lwmin) lwmin = l;
251 if (l > lwmax) lwmax = l;
252 }
253 lwmax *= 1.01;
254 if (lwmax > LMAX)
255 lwmax = LMAX;
256 bwmax = Bl(lwmax);
257 if (lwmin < LMIN) {
258 lwmin = LMIN;
259 bwmin = Bl(LMIN);
260 } else { /* duplicate bottom bin */
261 bwmin = bwmax - (bwmax-Bl(lwmin))*HISTRES/(HISTRES-1);
262 lwmin = Lb(bwmin);
263 }
264 /* (re)compute histogram */
265 bwavg = 0.;
266 histot = 0.;
267 memset(bwhist, 0, sizeof(bwhist));
268 /* global average */
269 if (!(what2do&DO_FIXHIST) || fixfrac < 1.-FTINY) {
270 for (y = 0; y < fvyr; y++)
271 for (x = 0; x < fvxr; x++) {
272 l = plum(fovscan(y)[x]);
273 if (l < lwmin+FTINY) continue;
274 if (l >= lwmax-FTINY) continue;
275 b = Bl(l);
276 w = what2do&DO_CWEIGHT ? centprob(x,y) : 1.;
277 bwavg += w*b;
278 bwhist[bwhi(b)] += w;
279 histot += w;
280 }
281 /* weight for point luminances */
282 w = 1. * histot / nlumsamp;
283 for (x = nlumsamp; x--; ) {
284 l = lumsamp[x];
285 if (l < lwmin+FTINY) continue;
286 if (l >= lwmax-FTINY) continue;
287 b = Bl(l);
288 bwavg += w*b;
289 bwhist[bwhi(b)] += w;
290 histot += w;
291 }
292 }
293 /* average fixation points */
294 if (what2do&DO_FIXHIST && nfixations > 0) {
295 if (histot > FTINY)
296 w = fixfrac/(1.-fixfrac)*histot/nfixations;
297 else
298 w = 1.;
299 for (x = 0; x < nfixations; x++) {
300 l = plum(fovscan(fixlst[x][1])[fixlst[x][0]]);
301 if (l < lwmin+FTINY) continue;
302 if (l >= lwmax-FTINY) continue;
303 b = Bl(l);
304 bwavg += w*b;
305 bwhist[bwhi(b)] += w;
306 histot += w;
307 }
308 }
309 bwavg /= histot;
310 if (lwmin > LMIN+FTINY) { /* add false samples at bottom */
311 bwhist[1] *= 0.5;
312 bwhist[0] += bwhist[1];
313 }
314 free(lumsamp);
315 }
316
317
318 static void
319 mkcumf(void) /* make cumulative distribution function */
320 {
321 int i;
322 double sum;
323
324 mhistot = 0.; /* compute modified total */
325 for (i = 0; i < HISTRES; i++)
326 mhistot += modhist[i];
327
328 sum = 0.; /* compute cumulative function */
329 for (i = 0; i < HISTRES; i++) {
330 cumf[i] = sum/mhistot;
331 sum += modhist[i];
332 }
333 cumf[HISTRES] = 1.;
334 }
335
336
337 static double
338 cf( /* return cumulative function at b */
339 double b
340 )
341 {
342 double x;
343 int i;
344
345 i = x = HISTRES*(b - bwmin)/(bwmax - bwmin);
346 x -= (double)i;
347 return(cumf[i]*(1.-x) + cumf[i+1]*x);
348 }
349
350
351 static double
352 BLw( /* map world luminance to display brightness */
353 double Lw
354 )
355 {
356 double b;
357
358 if (Lw <= LMIN || (b = Bl(Lw)) <= bwmin+FTINY)
359 return(Bldmin);
360 if (b >= bwmax-FTINY)
361 return(Bldmax);
362 return(Bldmin + cf(b)*(Bldmax-Bldmin));
363 }
364
365
366 double
367 htcontrs( /* human threshold contrast sensitivity, dL(La) */
368 double La
369 )
370 {
371 double l10La, l10dL;
372 /* formula taken from Ferwerda et al. [SG96] */
373 if (La < 1.148e-4)
374 return(1.38e-3);
375 l10La = log10(La);
376 if (l10La < -1.44) /* rod response regime */
377 l10dL = pow(.405*l10La + 1.6, 2.18) - 2.86;
378 else if (l10La < -.0184)
379 l10dL = l10La - .395;
380 else if (l10La < 1.9) /* cone response regime */
381 l10dL = pow(.249*l10La + .65, 2.7) - .72;
382 else
383 l10dL = l10La - 1.255;
384
385 return(exp10(l10dL));
386 }
387
388
389 double
390 clampf( /* histogram clamping function */
391 double Lw
392 )
393 {
394 double bLw, ratio;
395
396 bLw = BLw(Lw); /* apply current brightness map */
397 ratio = what2do&DO_HSENS ? htcontrs(Lb(bLw))/htcontrs(Lw) : Lb(bLw)/Lw;
398 return(ratio/(Lb1(bLw)*(Bldmax-Bldmin)*Bl1(Lw)));
399 }
400
401 double
402 crfactor( /* contrast reduction factor */
403 double Lw
404 )
405 {
406 int i = HISTRES*(Bl(Lw) - bwmin)/(bwmax - bwmin);
407 double bLw, ratio, Tdb;
408
409 if (i <= 0)
410 return(1.0);
411 if (i >= HISTRES)
412 return(1.0);
413 bLw = BLw(Lw);
414 ratio = what2do&DO_HSENS ? htcontrs(Lb(bLw))/htcontrs(Lw) : Lb(bLw)/Lw;
415 Tdb = mhistot * (bwmax - bwmin) / HISTRES;
416 return(modhist[i]*Lb1(bLw)*(Bldmax-Bldmin)*Bl1(Lw)/(Tdb*ratio));
417 }
418
419
420 #if ADJ_VEIL
421 static void
422 mkcrfimage(void) /* compute contrast reduction factor image */
423 {
424 int i;
425 float *crfptr;
426 COLOR *fovptr;
427
428 if (crfimg == NULL)
429 crfimg = (float *)malloc(fvxr*fvyr*sizeof(float));
430 if (crfimg == NULL)
431 syserror("malloc");
432 crfptr = crfimg;
433 fovptr = fovimg;
434 for (i = fvxr*fvyr; i--; crfptr++, fovptr++)
435 crfptr[0] = crfactor(plum(fovptr[0]));
436 }
437 #endif
438
439
440 int
441 mkbrmap(void) /* make dynamic range map */
442 {
443 double Tdb, b, s;
444 double ceiling, trimmings;
445 int i;
446 /* copy initial histogram */
447 memcpy((void *)modhist, (void *)bwhist, sizeof(modhist));
448 s = (bwmax - bwmin)/HISTRES; /* s is delta b */
449 /* loop until satisfactory */
450 do {
451 mkcumf(); /* sync brightness mapping */
452 if (mhistot <= histot*CVRATIO)
453 return(-1); /* no compression needed! */
454 Tdb = mhistot * s;
455 trimmings = 0.; /* clip to envelope */
456 for (i = 0, b = bwmin + .5*s; i < HISTRES; i++, b += s) {
457 ceiling = Tdb*clampf(Lb(b));
458 if (modhist[i] > ceiling) {
459 trimmings += modhist[i] - ceiling;
460 modhist[i] = ceiling;
461 }
462 }
463 } while (trimmings > mhistot*CVRATIO);
464
465 #if ADJ_VEIL
466 mkcrfimage(); /* contrast reduction image */
467 #endif
468
469 return(0); /* we got it */
470 }
471
472
473 void
474 scotscan( /* apply scotopic color sensitivity loss */
475 COLOR *scan,
476 int xres
477 )
478 {
479 COLOR ctmp;
480 double incolor, b, Lw;
481 int i;
482
483 for (i = 0; i < xres; i++) {
484 Lw = plum(scan[i]);
485 if (Lw >= TopMesopic)
486 incolor = 1.;
487 else if (Lw <= BotMesopic)
488 incolor = 0.;
489 else
490 incolor = (Lw - BotMesopic) /
491 (TopMesopic - BotMesopic);
492 if (incolor < 1.-FTINY) {
493 b = (1.-incolor)*slum(scan[i])*inpexp/SWNORM;
494 if (lumf == rgblum) b /= WHTEFFICACY;
495 setcolor(ctmp, b, b, b);
496 if (incolor <= FTINY)
497 setcolor(scan[i], 0., 0., 0.);
498 else
499 scalecolor(scan[i], incolor);
500 addcolor(scan[i], ctmp);
501 }
502 }
503 }
504
505
506 void
507 mapscan( /* apply tone mapping operator to scanline */
508 COLOR *scan,
509 int xres
510 )
511 {
512 double mult, Lw, b;
513 int x;
514
515 for (x = 0; x < xres; x++) {
516 Lw = plum(scan[x]);
517 if (Lw < LMIN) {
518 setcolor(scan[x], 0., 0., 0.);
519 continue;
520 }
521 b = BLw(Lw); /* apply brightness mapping */
522 mult = (Lb(b) - ldmin)/(ldmax - ldmin)/(Lw*inpexp);
523 if (lumf == rgblum) mult *= WHTEFFICACY;
524 scalecolor(scan[x], mult);
525 }
526 }
527
528
529 void
530 putmapping( /* put out mapping function */
531 FILE *fp
532 )
533 {
534 double b, s;
535 int i;
536 double wlum, sf, dlum;
537
538 sf = scalef*inpexp;
539 if (lumf == cielum) sf *= WHTEFFICACY;
540 s = (bwmax - bwmin)/HISTRES;
541 for (i = 0, b = bwmin + .5*s; i < HISTRES; i++, b += s) {
542 wlum = Lb(b);
543 if (what2do&DO_LINEAR) {
544 dlum = sf*wlum;
545 if (dlum > ldmax) dlum = ldmax;
546 else if (dlum < ldmin) dlum = ldmin;
547 fprintf(fp, "%e %e\n", wlum, dlum);
548 } else
549 fprintf(fp, "%e %e\n", wlum, Lb(BLw(wlum)));
550 }
551 }
